i would like to know which settings are correct if i want to disable all updates
this is what i have in mms.cfg
Autoupdatedisable=1
silentautoupdateenable=0
is there way to validate\test either it is disable or not.
using windows 7 64 bit enterprise
msi version of flash player 11.2
thanks in advance.
You should use the Flash Player applet in the Contol Panel to enable/disable automatic updates.
But generally:
Unfortunately the Flash Player Admin Guide has it listed incorrectly.
The settings you mentioned are correct.
We have updated this information in the Admin guide.
Sorry, I am now thoroughly confused; the Admin Guide (page 17) states the following:
Background update is disabled by default. To enable it, edit the mms.cfg file, as shown below:
AutoUpdateDisable=1
SilentAutoUpdateEnable=0
Are you saying that AutoUpdateDisable=1
means enable autoupdate?
