1 Reply Latest reply on Apr 18, 2012 5:39 AM by Cuwen
    fscommand, position opened window?
    Cuwen Newcomer
      Hey everyone.  So, I just learned about the fscommand and can't believe I didn't know about it before!  It is amazing and does almost exactly what I need it to do.
      However, I can't get the new window/exe file that opens to be centered.  Is there a way to do this so that when the .exe file is open, it is centered and on top?  I found one solution from years back here:
      http://board.flashkit.com/board/showthread.php?t=656462
      But wow.  That is so complex and I can't even get it to work right.
      So, I was hoping that if I showed you my code, you all might be able to help me with this.  I hope that some kind of code came out before AS3 was launched that can fix this.  Thank you all in advance, and here's my code!
      RelayBtn_btn.onRelease=function(){
      fscommand("exec", "BathingLineAD.exe");
        • 1. Re: fscommand, position opened window?
          Cuwen Newcomer
          I've had over 20 views, but still no help or answer?  I know the code isn't bad b/c it's simple and I've tested it.  It works.  I just need to know if there's a way I can get the file that opens (BathingLineAD.exe) to be centered on the desktop, on top of the main file that's open.  Help would be very greatly appreciated.
