5 Replies Latest reply on Apr 23, 2012 3:11 AM by upthemillers
    CS4 Bridge to ACR
    upthemillers
      Just installed CS4 onto my Mac laptop (it all works fine on my Mac Desktop) When trying to open images from Bridge to camera raw the icon and the option in the drop down are both "dead" They open with a double click , so its just a niggle I could live without. Any clues?
        • 1. Re: CS4 Bridge to ACR
          Omke Oudeman Rockstar
          That means there is something wrong with your install and you probably have no connection with Photoshop via a start up script. First check the menu Tools and see if Photoshop is in the list at the bottom. If not check Bridge Prefs to see if the start up script for Photoshop CS4 is there and you can add a checkmark to it.
          Either way, the easiest go seems to restart Bridge holding down option key and choose reset preferences. This should bring the start up script for PS back in business.
          In Bridge Prefs general you can check to set double click to open in ACR using Bridge. The drop down menu and the icon should be active also.
          Be also sure you have only one version of ACR installed in the correct place. Open Photoshop and under the menu Photoshop check About plug in / Camera Raw. It should say ACR 5.xx (don't have CS4 anymore installed and not sure what the latest ACR for CS4 should be).
          1 person found this helpful
          • 2. Re: CS4 Bridge to ACR
            upthemillers Newcomer
            Went through all the suggestions and no luck which is odd, as they make perfect sense. Should re loading the disc help? I am not sure how many time I can use the key ( used it twice now) Really appreciate the help so far.
            • 3. Re: CS4 Bridge to ACR
              Curt Y Ninja
              You can have an activated copies on 2 different machines, but can only have one copy in use.
              If you are reinstalling on the same machine you are probably OK.  You need to deactivate copy first if moving to another computer or if you reformat HD.  Re-activate when move complete.
              • 4. Re: CS4 Bridge to ACR
                Not if you don't deactivate, uninstall with removing preferences and use the Clean Tool:
                http://www.adobe.com/support/contact/cscleanertool.html
                to get rid of all presets and prefs for PS and Bridge. Reinstall does not always means resetting the preferences.
                As Curt stated deactivate might not be necessary on the same machine but in this case you should do it by the book in the official way.
                Can you report the exact versions you are using for Mac OS X and Adobe CS4 (PS, Bridge and ACR)
                • 5. Re: CS4 Bridge to ACR
                  Thanks Guys all sorted due to your help. Still an od thing to happen.
