1. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Pattie F Apr 10, 2012 10:20 PM (in response to Meta Heavies)I created 3 text boxes on 3 layers and using the move tool with shift to select them all. I clicked the text tool and changed the font size in the character panel. The text in all 3 boxes changed from 48 to 58 and seemed to display properly.
Is this basically what you did?
Pattie
2. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Meta Heavies Apr 10, 2012 11:15 PM (in response to Pattie F)Essentially, yes.
I've not been able to replicate the issue - I discovered it in the course of working on a project.
3. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Pattie F Apr 11, 2012 12:36 AM (in response to Meta Heavies)If you happened to perform a transform on the text with several layers selected, then there is a known bug there.
See this for reference: http://forums.adobe.com/message/4306413#4306413
Any chance you did that?
I can't seem to find an issue with what you described, however. If it happens again, please let me know and list your workflow.
Thanks-
Pattie
4. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Meta Heavies Apr 11, 2012 12:45 AM (in response to Pattie F)Very possible -
thanks for the update Pattie
Gordon
5. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
IsaacFowler Apr 16, 2012 8:41 AM (in response to Meta Heavies)I'm also experiencing these issues on Window 7, so it's not specific to the Mac version of the application.
6. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Pattie F Apr 16, 2012 2:24 PM (in response to IsaacFowler)Isaac-
Can you reproduce your text issue? If so, please list the steps necessary to reproduce it and I will try them here.
Pattie
7. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
IsaacFowler Apr 18, 2012 8:07 AM (in response to Pattie F)I can reproduce it by creating a few text items, selecting them all then re-sizing them with free transform, and then they have the before-mentioned issue.
The issue being that if a I mutliple text items with a font-size of say 18pt and select them all it will say my font-size is 15.6 pt (roughly, I don't have it open now) but if I select the text items individually it will say 18pt. What's really weird is that if I select all of them and change the font-size to 18pt it will then say 18pt, but it actually resizes them to 15.6pt which is aparent when you select a text item individually... and also if you create a separate text item at 15.6pt and compare you'll realize they're the same size. But group selecting them just displays the wrong font size?
It's very weird behavior.
8. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
IsaacFowler Apr 18, 2012 8:08 AM (in response to Pattie F)Let me know if that's still unclear and I'll attempt to do a screen-capture of the issue.
9. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Pattie F Apr 18, 2012 9:14 AM (in response to IsaacFowler)as I mentioned above, there is a bug if you select several layers and then transform the text. See this link for a good explanation of the issue:
I have already logged a bug on this.
Pattie
10. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
IsaacFowler Apr 18, 2012 10:29 AM (in response to Pattie F)Yes I did read your message, I just was confirming that it also occurs on windows as the OP said it was a Mac.
11. Re: Bug - Selecting multiple text boxes shows incorrect point size (Mac 10.6.8)
Pattie F Apr 18, 2012 5:40 PM (in response to IsaacFowler)Yes, it appears to be in both.
Pattie
