6 Replies Latest reply on Apr 18, 2012 1:36 PM by Niall O'Donovan
    add instance and hidden fields
    NikDK Newcomer
      I have a section in my form where you can add multiple subforms by clicking a button. i also have a field within the subform that only appears when one of 4 radio buttons is checked. if the radio button is checked then the user adds multiple subforms by clicking the button, the hidden fields appear as they are suppose to. If the user then changes their selection and chooses another radio button, it should remove the fields on each instance. the problem is that if it is only removing fields from the first and last instance, but nothing in between.
      Under the change event of the radio buttons I have used the following (for radio buttons 1, 3 and 4)
      when these buttons are clicked i want Text1 & Text2 to hide on all instances.
      var intNewIndex = form1.subfrm1.instanceManager.count-1;
      form1.resolveNode("subfrm1[" + intNewIndex + "]").Text1.presence = "hidden";
      form1.resolveNode("subfrm1[" + intNewIndex + "]").Text2.presence = "hidden";
      and for radio button 2 i have the following under the change event:
      for Radio button 2 i want Text1 and Text2 to appear on all instances.
      form1.resolveNode("subfrm1[" + intNewIndex + "]").Text1.presence = "visible";
      form1.resolveNode("subfrm1[" + intNewIndex + "]").Text2.presence = "visible";
      Thanks in advance for your help,
      Nik
