Hi all,
I installed ADE on win 7 64bit. I installed 1.7 and then 1.8.2, trying to fix a problem.
The problem is that when I connect my NOOK by the usb plug, ADE crashes. End of the story.
I used two different pc's and two different NOOK readers, and ADE always crashes.
When crashing, ADE does not say anything, of course, so I cannot do anything.
Ideas?
Note: I tried to run ADE explcitly as administrator. No way. Crash.
Thanks all for helping.
Bye
Let's review a couple of things that might have something to do with the
problems.
Have you registered the Nook with B&N, using your ADE ID?
Have you done an update to the Nook from the B&N website?
Have you registered your copy of ADE with Adobe, using your Adobe ID?
Have you connected the Nook first, before you open ADE, and made sure that
Win 7 recognizes the device?
I am having the exact same problem. I initially tried installing and running ADE on an HP Inspiron laptop with Windows 7. After 2 weeks of frustration and 5 hours of Geek Squad remote access, I was told that there was something fundamentally wrong with my laptop... take it back and exchange it for one that works. I did as suggested and got another HP. Same problem. Talked to Geek Squad again and they said must be an HP problem... try a different brand. Have now tried on a Lenovo running Windows 7 and, shock and surprise... same exact problem.I tried changing the firewall settings that someone else on one of the forums recommended, but I still can't get it to work. I uninstalled/reinstalled ADE, I deleted the adobe file on my Nook, I've tried everything. HELP!!!!
