21 Replies Latest reply on May 11, 2013 5:48 AM by Avinashtan
    osgi workflowprocess gives classnotfound exception when osgi bundle is activated
    bvibor Level 1
      I did create an osgi service that extends workflowprocess interrface using eclipse. I install the bundle that contains this service and then deploy and activate the bundle in day cq. However, on activation I receive an error stating that my class is not found. Please note that both this service and the referenced service(twitterservice that I created) gets registered and the bundle is activated, however, its unable to find the class SendMessageProcessAction on the activation of the bundle. Hope someone could assist.
      POST /system/console/bundles/246 HTTP/1.1] com.day.twitter.workflow [com.day.twitter.service.impl.SendMessageProcessAction] Error during instantiation of the implementation object (java.lang.ClassNotFoundException: com.day.twitter.service.impl.SendMessageProcessAction not found by com.day.twitter.workflow [246]) java.lang.ClassNotFoundException: com.day.twitter.service.impl.SendMessageProcessAction not found by com.day.twitter.workflow [246]
          at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:787 )
          at org.apache.felix.framework.ModuleImpl.access$400(ModuleImpl.java:71)
      package com.day.twitter.service.impl;
      import javax.jcr.RepositoryException;
      import javax.jcr.Session;
      import org.apache.felix.scr.annotations.Component;
      import org.apache.felix.scr.annotations.Properties;
      import org.apache.felix.scr.annotations.Property;
      import org.apache.felix.scr.annotations.Reference;
      import org.apache.felix.scr.annotations.Service;
      import org.osgi.framework.Constants;
      import org.slf4j.Logger;
      import org.slf4j.LoggerFactory;
      import com.day.cq.workflow.WorkflowException;
      import com.day.cq.workflow.WorkflowSession;
      import com.day.cq.workflow.exec.WorkItem;
      import com.day.cq.workflow.exec.WorkflowData;
      import com.day.cq.workflow.exec.WorkflowProcess;
      import com.day.cq.workflow.metadata.MetaDataMap;
      import com.day.twitter.service.SendMessageProcess;
      import com.day.twitter.service.TwitterService;
          @Property(name = Constants.SERVICE_DESCRIPTION, value = " An example of Social Publish Implementation"),
          @Property(name = Constants.SERVICE_VENDOR, value = "RIM POC"),
          @Property(name = "process.label", value = "RIM POC Social Publish")
      public class SendMessageProcessAction implements WorkflowProcess{
          private TwitterService twitterService;
          public TwitterService getTwitterService() {
              return twitterService;
          public void setTwitterService(TwitterService twitterService) {
              this.twitterService = twitterService;
           * @scr.reference
          private static final String TYPE_JCR_PATH = "JCR_PATH";
          private final Logger logger = LoggerFactory.getLogger(this.getClass()
          private final Logger logger1 = LoggerFactory.getLogger(SendMessageProcessAction.class);
          public void execute(WorkItem workItem, WorkflowSession workflowSession,MetaDataMap args)
          throws WorkflowException {
              final Session session = workflowSession.getSession();
              final WorkflowData data = workItem.getWorkflowData();
              logger.info("TEST VIBHOR!!");
              logger1.info("TEST VIBHOR BHATIA!!");
              String path = null;
              String type = data.getPayloadType();
              if (type.equals(TYPE_JCR_PATH) && data.getPayload() != null) {
                  String payloadData = (String) data.getPayload();
                  try {
                      if (session.itemExists(payloadData)) {
                          path = payloadData;
                  } catch (RepositoryException e) {
                      // TODO Auto-generated catch block
                      logger.error("Exception - Check repository for Payload data path");
              String msg = "CQ5 workflow event";
                  // is there a message?
              String argument = args.get("PROCESS_ARGS", "default value");
              boolean equal = argument.equals("argument1");
                  String recipient = argument.toString();
                   sendDirectMessageOnTwitter(recipient, msg, path);
              } else {
                          .error("for sending a DM on Twitter (make sure Twitter allows you to DM that account): dm,(recipient id)");
                 //  return "Check config - error";
          private void sendDirectMessageOnTwitter(String recipient, String msg, String path) {
              getTwitterService().sendDirectMessage(recipient, msg + ", path: " + path);
