8 Replies Latest reply on May 5, 2012 11:52 AM by Xircal
    Cannot disable Hardware Acceleration
    Decclan Newcomer
      After searching for a few days now i have fount somewhere that could possibly help me. I am encountering the error of not being able to disable my hardware accel as i am getting a pink screen while i view streams and things using the same sort of flash player like BBC Iplayer. I have done all of the go into %appdata% things. Done most things but i still have no luck, it just re-enables itself after i uncheck the box and go off the screen. I also cannot click the 3rd party software button either. Please help guys it'd be much appreiciated.
        • 1. Re: Cannot disable Hardware Acceleration
          pwillener Legend
          Did you delete the Flash Player folders in there?
          • 2. Re: Cannot disable Hardware Acceleration
            pwillener Legend
            P.S. if disabling Hardware Acceleration fixes some problems for you, then you may need to update your display adapter drivers; see http://forums.adobe.com/thread/945765
            • 3. Re: Cannot disable Hardware Acceleration
              Decclan Newcomer
              yes, multiple times and i can't even change any settings so the post you put below i don't even know if it works yet, but i cannot view streams etc.
              • 4. Re: Cannot disable Hardware Acceleration
                TTDiver Newcomer
                I'm having a similar problem.  Flash player in Firefox causes causes screen to turn pink and distort.  System completely locks up - ctrl/alt/del does not work - holding the power button until shutdown is the only option.  I have the latest flash and the latest graphics drivers.  I have disabled graphic accellerators within the flash player, but it has not helped.  The crashes only occur in flash player apps and happen at sporadic times.  I've been looking into this for a week and I'm totally disgusted.  Any other thoughts?
                Windows XP 32 bit sp 3
                EVGA GTX 560 driver 296.10
                Directx Support 11
                Firefox 12.0
                Adobe Flash Player 11.2.202.235
                • 5. Re: Cannot disable Hardware Acceleration
                  Xircal Pioneer
                  Directx Support 11
                  Firefox 12.0
                  DirectX 11.0 is not supported on Windows XP even if the video card does. That operating system doesn't support DirectX 10.0 either. The last version it will support is DirectX 9.0c. You do however have the latest drivers installed.
                  You might try rolling back to the previous drivers since it seems to be a common problem with the 560 GTX. That worked for someone who posted on the Nvidia forums: http://forums.nvidia.com/index.php?showtopic=227457
                  • 6. Re: Cannot disable Hardware Acceleration
                    TTDiver Newcomer
                    According to the dxdiag I am only running DirectX 9.0c.  I'm not sure where
                    I saw the 11.0 before.
                    Any other thoughts?
                    • 7. Re: Cannot disable Hardware Acceleration
                      Xircal Pioneer
                      Any other thoughts?
                      In your dreams maybe See: http://en.wikipedia.org/wiki/Microsoft_Direct3D#Direct3D_10
                      • 8. Re: Cannot disable Hardware Acceleration
                        Xircal Pioneer
                        Decclan, what's your operating system and is it 32-bit or 64-bit?
                        Also, which browser are you using and is that 32-bit or 64-bit?
