Windows Vista 64 Home Premium
Internet Explorer 9.0.8112.16421 (32 bit)
Firefox 11
Flash Player 11.2.202.233
Until the last update, I was able to run Flash files without any problem in both IE and FF. The latest update has forced me to have Flash player installed for IE -or- FF, but not both. If I clean install on IE, when i try to install in FF, it gives me a BSOD. The opposite also happens. Clean install in FF, try to install for IE, get a BSOD.
Any clue on how to get Flash player installed for both again?
Please refer to ESET's knowledgebase article here:
You may need to update your AntiVirus software.
Stephen
What is the BSOD error code (and module, if indicated) during the install?
What is your display adapter, device driver version & date?
Are you using the offline installers from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_... ?
If I'm reading the right info..
the top line of the BSoD is
DRIVER_IRQL_NOT_LESS_OR_EQUAL
The error code down below is
STOP: 0x000000D1
eamonm.sys
my laptop hasan Nvidia 8700M GT
Driver version 8.12.11.8621
Driver date 6/16/2009
I did double check for an updated driver, what I have appears to be the latest supported available for the video chipset.
I currently have Firefox working at the moment. IE is where Flash isn't working at the moment. If it would help, I can get IE working and the repair can be on Firefox.
Stephen
That did it. Thanks Stephen.
Updated my ESet to latest engine (not to be confused with dat files) and tried the install again...everything is working as it has and should.
