7 Replies Latest reply on Apr 20, 2012 5:41 PM by dj_paige
    I have files and folders in several locations - documents-adobe; my pictures; myelements5.
    warblerbird
      About a month or two ago, I moved and somehow the photo files and folders I used to access directly from the PSE5 icon now can only be accessed from My Documents / Adobe or My Pictures.  How can I get all my files in one place and continue to download with the newest download appearing first when I click All Photos?  I have 22 T photos and want to spend some time organizing them effectively and also deleting any duplicates.  I'm not even sure if I'm deleting photos completely or just at one address.  I've tried to find local assistance, contacted Adobe to pay for support  and was unsuccessful in both instances.  I'm a senior and didn't grow up with computers but have been fine teaching myself PSE 5.  I sure would appreciate opening a dialog with a pro that can give me some guidance.  Thanks in advance.  Cozee
        • 1. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
          dj_paige Level 10
          How does your moving affect the fact that you can't access your photos from PSE5? Do you mean that the photos in PSE5 have question marks next to them?
          To tell you the truth, I think you are missing a key point here. The benefit of the PSE Organizer is not that it allows you to organize via folders. If you want to organize via folders, you already have Windows to do that (and Windows does a better job with a better interface). The benefit of the PSE Organizer is that it grives you different tools than folders, tools which in my opinion are far superior to folders. These PSE tools are tags and optionally captions and notes. If you assign tags, captions and notes diligently to your photos, and use those tags, captions and notes to describe the image content, you then have a different way of finding your photos ... by image content, not by folder location ... and in fact you don't need to know what folders the photos are in because PSE knows. PSE does the hard work of remembering where things are, so you don't have to.  So in my opinion, this whole idea of straightening out the folder locations of your photos is way off base ... you now have better tools.
          • 2. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
            warblerbird Level 1
            Thanks for the response.  First question - moving to a new home is when the problem initially arose.  I don't know if a setting was inadvertently changed or what but where I had direct access to 22,000 photos from my start-up PSE5 Icon, I now have 11,000.  I believe these photos reverted to an old address or I changed a setting such as "restore factory settings" (please remember that I don't always know the correct terms).  I had many of my photos tagged and also many collections / slide shows / etc.  Now when I open those, there are mostly "?" icons.  I've done find missing files but since there are so many, it will stick on one for an hour or more and still not locate it.  There are too many for me to find through the Browse option.
            I agree with you advise about using the PSE advanced organization tools, but I don't know how to reconnect my collection into one place - PSE5 - before doing a "make-over" of the catalogs, now that I have the time.  As I mentioned, even when I delete photos, how do I know if I am deleting from all these various locations where they are housed?
            I probably don't have the background understanding to solve this through Forums but hope you or someone would be willing to walk me through it.  Again, I've tried to get assistance and support from a paid source and had no luck.
            Thanks for you time.
            Cozee Lynn Smith
            14833 Shaw Road
            Tampa, FL  33625
            727-686-7372 (cell)
            cozee@tampabay.rr.com
            • 3. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
              dj_paige Level 10
              Okay, lets see if when can figure out how to re-connect the photos and make the ? go away.
              The problem is that PSE thinks the photos are in Folder A, and actually the photos are in Folder B (or the photos got renamed, in which case you have a real mess). The easiest way to fix this is to move the photos (using Windows) back to Folder A.
              So, go to a photo with a question mark in PSE, right-click on the photo and select Properties. Write down the folder that PSE thinks the photos should be in, I will call this Folder A. Then, find the photo in Windows, they will be in a different folder, which I will call Folder B. Using Windows, move the photo from Folder B to Folder A. This should make the ? go away in the PSE Organizer.
              If that works, then you need to figure out if you can move all photos in Folder B to Folder A. Typically you would be able to do this if somehow an entire folder got moved in Windows. If it appears that is what happened, that the entire folder moved, then using Windows, move all photos from Folder B to Folder A.
              Let's try that much and see how it goes.
              • 4. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
                warblerbird Level 1
                How do I find the photo in Windows?  I have located the photo but don't know how to do the next step.
                Cozee Lynn Smith
                14833 Shaw Road
                Tampa, FL  33625
                727-686-7372 (cell)
                • 5. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
                  dj_paige Level 10
                  Windows can search for your photos, if you know the name, for example if PSE tells you the photo's name is DSC_0657.jpg, then you would have Windows do that search. Exactly how depends on which version of Windows.
                  • 6. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
                    warblerbird Level 1
                    I have Windows XP
                    Cozee Lynn Smith
                    14833 Shaw Road
                    Tampa, FL  33625
                    727-686-7372 (cell)
                    • 7. Re: I have files and folders in several locations - documents-adobe; my pictures; myelements5.
                      dj_paige Level 10
                      Well, going by memory (since I don't have XP) if you right-click on My Computer, one of the options is Search. Select that. Type in the name of the photo, and click on Search
