23 Replies Latest reply on May 18, 2012 7:48 AM by Jonathan Fortis
    radio button javascript alert
    Jonathan Fortis Newcomer
      i am using the code below for form validations
      var x=document.forms["form2"]["weeks"].value;
      if (x==null || x=="")
        alert("Duration needs to be checked");
        return false;
      but weeks is actually radio buttons
      <input type="radio" value="364" name="weeks" />
      <input type="radio" value="301" name="weeks" />
      how do i convert the above code to work with a radio button
      thanks
      in advance
        • 1. Re: radio button javascript alert
          sudarshan.t Ninja
          <HTML>
          <HEAD>
          <SCRIPT LANGUAGE="JavaScript">
          function checkRadio (frmName, rbGroupName) {
          var radios = document[frmName].elements[rbGroupName];
          for (var i=0; i <radios.length; i++) {
          if (radios[i].checked) {
          return true;
          return false;
          function valFrm() {
          if (!checkRadio("frm1","weeks"))
          alert("You didnt select any weeks");
          else
          alert("You selected a week");
          </SCRIPT>
          </HEAD>
          <BODY>
          <FORM NAME="frm1" ACTION="javascript:valFrm();">
          <INPUT TYPE="radio" NAME="weeks" value="364"/>364
          <INPUT TYPE="radio" NAME="weeks" value="301"/> 301
          <INPUT TYPE="radio" NAME="weeks" value="400"/>400
          <INPUT TYPE="submit">
          </FORM>
          </BODY>
          </HTML>
          Try this script.
          • 2. Re: radio button javascript alert
            ok i tried putting the following into my form
            i have a alert before that says if the start date hasnt been filled in and one after that tells if the end date hasnt been filled in
            the you code goes in between them
            var x=document.forms["form2"]["StartDate"].value;
              alert("Start Date needs to be filled in");
              return false;
            return true;
            return false;
            function valFrm() {
            if (!checkRadio("form2","weeks"))
            alert("Duration needs to be selected");
            else
            var x=document.forms["form2"]["EndDate"].value;
              alert("End Date needs to be filled in");
              return false;
            the form is called form2 and the inputs are
            • 3. Re: radio button javascript alert
              i have just noticed you have the action in your form as ACTION="javascript:valFrm();
              i already have an action in my form called onsubmit="return validateForm()"
              • 4. Re: radio button javascript alert
                i have got it sort of working i removed the function valFrm() {
                from your code as i a;lready have that in place for the rest of the alerts however now it prompts if the weeks havent been selected but also the one below "End Date needs to be filled in" so it it going from one prompt to another, i tried adding a
                  return false;
                at the end of alert("Duration needs to be selected"); to read
                  return false;
                but then that doesnt work
                here is the code
                function validateForm()
                  return false;
                return true;
                return false;
                  return false;
                i have also run into another problem, i have multiple radio boxes, i also have
                <input type="radio" name="Title" value="Mr" />
                <input type="radio" name="Title" value="Mrs" />
                <input type="radio"name="Title" value="Miss" />
                input type="radio" name="Title" value="Ms" />
                can theses use the same
                return true;
                return false;
                then carry on with
                if (!checkRadio("form2","Title"))
                alert("Title needs to be selected");
                thanks in advance
                • 5. Re: radio button javascript alert
                  sudarshan.t Ninja
                  You seem to be wanting lot of validation in your code.
                  Check out jQuery Validator plugin - http://bassistance.de/jquery-plugins/jquery-plugin-validation/
                  It's a great lightweight plugin you could use for validating your form inputs.
                  • 6. Re: radio button javascript alert
                    i have had a quick look at it and it looks rather complex. Is there any turtorials on how to use it or any guidance of how to get started
                    • 7. Re: radio button javascript alert
                      sudarshan.t Ninja
                      They have Demos on their site that should give you complete insights.
                      You could also download the source file kit here: http://jquery.bassistance.de/validate/jquery-validation-1.9.0.zip
                      This kit includes demos, CSS, JS and all related files. They should help you get started.
                      • 8. Re: radio button javascript alert
                        i have looked at the plugin and it looks great for new projects but my form is complete except for the alerts, ideally i want alert pop ups rather than the alerts to be built into the page, i will definatly use this in future projects.
                        • 9. Re: radio button javascript alert
                          i am very nearly where i need to be with your previous code. just need multiple radio alerts thats it, i have the rest
                          thanks
                          • 10. Re: radio button javascript alert
                            sudarshan.t Ninja
                            For validating 2 radio buttons, try this:
                            <html>
                            <head>
                            <script type="text/javascript">
                            function validateRadio(obj,correct){
                                var result = 0
                                for(var i=0; i<obj.length; i++){
                                    if(obj[i].checked==true && obj[i].value==correct) result = 1
                                if(!result && obj.value == correct) result = 1
                                return result }
                            </script>
                            </head>
                            <body>
                            <form onSubmit="
                            var err = ''
                            if(!validateRadio(this.a,3)){ err+='\nFirst radio is wrong' }
                            if(!validateRadio(this.b,2)){ err+='\nSecond radio is wrong' }
                            if(err.length){ alert('Problem:'+err); return false; }
                            else{ alert('Good Job -- Submitting'); return true; }
                            action="#">
                              Choose "3"
                              <input name="a" value="1" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
                              1
                              <input name="a" value="2" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
                              2
                              <input name="a" value="3" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
                              3
                              <input name="a" value="4" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
                              4
                              <p>Choose "2"
                                <input name="b" value="1" type="radio">
                                1
                                <input name="b" value="2" type="radio">
                                2
                                <input name="b" value="3" type="radio">
                                3
                                <input name="b" value="4" type="radio">
                                4 </p>
                              <p>
                                <input value="Submit" type="submit">
                              </p>
                            </form>
                            </body></html>
                            • 11. Re: radio button javascript alert
                              ok i am having a look at this one but isnt there an easy way of just saying this radio group needs to be selected, and use them as indivudual commands
                              can these use the same as mentioned earlier, this above code is again doing too much
                              return true;
                              return false;
                              then carry on with
                              thanks again
                              • 12. Re: radio button javascript alert
                                sudarshan.t Ninja
                                Try this for 2 validations:
                                <HTML>
                                <HEAD>
                                   return true;
                                return false;
                                function valFrm() {
                                if (!checkRadio("frm1","start"))
                                  alert("You didnt select any start week");
                                else
                                  alert("You selected a start week");
                                  if (!checkRadio("frm1","end"))
                                  alert("You didnt select any end week");
                                  else
                                  alert("You selected a end week");
                                </SCRIPT>
                                </HEAD>
                                <BODY>
                                START
                                <INPUT TYPE="radio" NAME="start" value="364"/>364
                                <INPUT TYPE="radio" NAME="start" value="301"/> 301
                                <INPUT TYPE="radio" NAME="start" value="400"/>400
                                <br>
                                END
                                <INPUT TYPE="radio" NAME="end" value="400"/>100
                                <INPUT TYPE="radio" NAME="end" value="400"/>200
                                <INPUT TYPE="radio" NAME="end" value="400"/>300
                                <BR>
                                </FORM>
                                </BODY>
                                </HTML>
                                • 13. Re: radio button javascript alert
                                  sudarshan.t Ninja
                                  For Title, append this script in your function:
                                  function valFrm() {
                                  else
                                    else
                                    if (!checkRadio("frm1","title"))
                                    else
                                    alert("You selected a title");
                                  • 14. Re: radio button javascript alert
                                    sudarshan.t Ninja
                                    Also, if you don't want alert messages for boxes that are already validated 'true', you could simply use 'else if' instead of 'if' in the function
                                    • 15. Re: radio button javascript alert
                                      ok i think we are getting there. i will have a playa round with this. the thing is i dont really want them leading from one to another, i want them completly seperate si i think i need to get rid of the else statement,
                                      in the form i have
                                      radio
                                      text input
                                      text input
                                      text input
                                      then radio, and i need them going in order of input.
                                      with the method you have shown me this will validate all the radio togeather wont it??
                                      • 16. Re: radio button javascript alert
                                        sudarshan.t Ninja
                                        Replace all if from 2nd if onwards with else if
                                        It should work
                                        • 17. Re: radio button javascript alert
                                          ok i will go through this and see how i get on, i will keep you posted, thanks for your help
                                          • 18. Re: radio button javascript alert
                                            i have the code below working and trued adding the else if but it wouldnt allow it. I have put the else in BOLD where i added it.
                                              return false;
                                            return true;
                                            return false;
                                            else if (x==null || x=="")
                                              return false;
                                            • 19. Re: radio button javascript alert
                                              its all working now except the script is show the prompt for the actual feild and the one after
                                              • 20. Re: radio button javascript alert
                                                sudarshan.t Ninja
                                                Post your latest code
                                                • 21. Re: radio button javascript alert
                                                  I have included the whole alert code but its just the top part that i am talking about
                                                    return false;
                                                  return true;
                                                  return false;
                                                    return false;
                                                  var x=document.forms["form2"]["userid"].value;
                                                    alert("user id needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["password"].value;
                                                    alert("user password needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["sex"].value;
                                                    alert("sex needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["Nationality"].value;
                                                    alert("Nationality needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["Marital_Status"].value;
                                                    alert("Marital Status needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["PhoneDay"].value;
                                                    alert("Daytime phone number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["PhoneEvening"].value;
                                                    alert("Evening phone number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["PhoneMobile"].value;
                                                    alert("Mobile phone number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["email"].value;
                                                    alert("email address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["Smoker"].value;
                                                    alert("smoking status needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["NextKin"].value;
                                                    alert("Next of Kin needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["CurrentAddress"].value;
                                                    alert("Current Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["LivingStatus"].value;
                                                    alert("Living Status needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["PrevAddress"].value;
                                                    alert("Previous Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["Student"].value;
                                                    alert("Student needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankName"].value;
                                                    alert("Bank Name needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankAccNum"].value;
                                                    alert("Bank Account Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankSortCode"].value;
                                                    alert("Bank Sort Code needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankDuration"].value;
                                                    alert("Bank Duration needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankDCard"].value;
                                                    alert("Debit / Credit card needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["BankElectoral"].value;
                                                    alert("Electoral Roll needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["LLHost"].value;
                                                    alert("Previuos Host Tenant needs to be checked");
                                                    return false;
                                                  var x=document.forms["form2"]["LLName"].value;
                                                    alert("Landlords Name needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["LLTele"].value;
                                                    alert("Landlords Telephone Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["LLEmail"].value;
                                                    alert("Landlords Email Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["LLAddress"].value;
                                                    alert("Landlords Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuName"].value;
                                                    alert("Guarantors Name needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuTitle"].value;
                                                    alert("Guarantors Title needs to be complete");
                                                    return false;
                                                  var x=document.forms["form2"]["GuSex"].value;
                                                    return false;
                                                  var x=document.forms["form2"]["GuMarital"].value;
                                                    alert("Guarantors MArital Status needs to be complete");
                                                    return false;
                                                  var x=document.forms["form2"]["GuPhoneDay"].value;
                                                    alert("Guarantors Daytime Telephone Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuPhoneEven"].value;
                                                    alert("Guarantors Evening Telephone Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuPhoneMob"].value;
                                                    alert("Guarantors Mobile Telephone Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuPhoneEmail"].value;
                                                    alert("Guarantors Email Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuCurrentAdd"].value;
                                                    alert("Guarantors Current Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuPrevAdd"].value;
                                                    alert("Guarantors Previous Address needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankName"].value;
                                                    alert("Guarantors Bank Name needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankAccNu"].value;
                                                    alert("Guarantors Bank Account Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankSort"].value;
                                                    alert("Guarantors Bank Sort Code needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankDurat"].value;
                                                    alert("Guarantors Bank Duration needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankDebit"].value;
                                                    alert("Guarantors Debit / Credit card needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuBankElect"].value;
                                                    alert("Guarantors Electoral Roll  needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmpProffes"].value;
                                                    alert("Guarantors Profession needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmpAnnWa"].value;
                                                    alert("Guarantors Annual Wages needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmpPayroll"].value;
                                                    alert("Guarantors Payroll Number needs to be filled in");
                                                    return false;
                                                  var x=document.forms["form2"]["GuSelfEmp"].value;
                                                    alert("Guarantors Self Employment Options needs to be complete");
                                                    return false;
                                                  var x=document.forms["form2"]["GuHaveAcc"].value;
                                                    alert("Guarantors Have an Accountant Options needs to be complete");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccName"].value;
                                                    alert("Guarantors Accountant Name needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccContName"].value;
                                                    alert("Guarantors Accountant Contact Name needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccAdd"].value;
                                                    alert("Guarantors Accountants Address needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccDayTel"].value;
                                                    alert("Guarantors Accountants Daytime Telephone number needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccMobTel"].value;
                                                    alert("Guarantors Accountants Mobile Telephone number needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccEmail"].value;
                                                    alert("Guarantors Accountants Email Address needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuAccAdditional"].value;
                                                    alert("Guarantors Accountants Additional informatio needs to be filled out (if none please type 'none'");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmployerNam"].value;
                                                    alert("Guarantors Employers Name needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmployerAdd"].value;
                                                    alert("Guarantors Employers Address needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmployerContactName"].value;
                                                    alert("Guarantors Employers Contact Name needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmployerTele"].value;
                                                    alert("Guarantors Employers Telephone Number needs to be filled out");
                                                    return false;
                                                  var x=document.forms["form2"]["GuEmployerEmail"].value;
                                                    alert("Guarantors Employers Email Address needs to be filled out");
                                                    return false;
                                                  if (!document.form2.terms.checked)
                                                  { alert("By ticking this box you agree that you have clearly read this document according to our terms and conditions.");
                                                  return false; }
                                                  return true;
                                                  </script>
                                                  • 22. Re: radio button javascript alert
                                                    i still havent got this working
                                                      return false;
                                                    return true;
                                                    return false;
                                                    else if
                                                      return false;
                                                    i have added the else if but dreamweaver is showing an error here..if i remove the else if statment two alerts are show one after the other. i need to show just the first one
                                                    first this is shown
                                                    then i "ok " this one then
                                                    i need something in between these to stop the second alert
                                                    • 23. Re: radio button javascript alert
                                                      Hi there, i have used the jquery link and i works great until i go to submit the form
                                                      it has got an alert at the beginning
                                                      $.validator.setDefaults({
        submitHandler: function() { alert("submitted!");
                                                      i want to delete the submitted alert and just direct to the new page, how is this done?
                                                      the full script is here
                                                              <script src="lib/jquery.metadata.js" type="text/javascript"></script>
                                                              <script src="jquery.validate.js" type="text/javascript"></script>
                                                      $().ready(function() {
        // validate signup form on keyup and submit
        $("#form2").validate({
        rules: {
        StartDate: "required",
        EndDate: "required",
        Nationality: "required",
        PhoneDay: "required",
        PhoneEvening: "required",
        PhoneMobile: "required",
        NextKin: "required",
        CurrentAddress: "required",
        PrevAddress: "required",
        BankName: "required",
        BankAccNum: "required",
        BankSortCode: "required",
        BankDuration: "required",
        LLName: "required",
        LLTele: "required",
        LLEmail: "required",
        LLAddress: "required",
        GuName: "required",
        GuPhoneDay: "required",
        GuPhoneEven: "required",
        GuPhoneMob: "required",
        GuPhoneEmail: "required",
        GuCurrentAdd: "required",
        GuPrevAdd: "required",
        GuBankName: "required",
        GuBankAccNu: "required",
        GuBankSort: "required",
        GuBankDurat: "required",
        GuEmpProffes: "required",
        GuEmpAnnWa: "required",
        GuEmpPayroll: "required",
        GuAccName: "required",
        GuAccContName: "required",
        GuAccAdd: "required",
        GuAccDayTel: "required",
        GuAccMobTel: "required",
        GuAccEmail: "required",
        GuEmployerNam: "required",
        GuEmployerAdd: "required",
        GuEmployerContactName: "required",
        GuEmployerTele: "required",
        GuEmployerEmail: "required",
        userid: {
        required: true,
        minlength: 2
        password: {
        required: true,
        minlength: 5
        email: {
        required: true,
        email: true
        terms: "required"
        messages: {
        StartDate: "Please select a start date",
        EndDate: "Please select an end date",
        Nationality: "Please enter your nationality",
        PhoneDay: "Please enter a daytime phone number",
        PhoneEvening: "Please enter a evening phone number",
        PhoneMobile: "Please enter a mobile number",
        NextKin: "Please enter your next of kin",
        CurrentAddress: "Please enter a current address",
        PrevAddress: "Please enter a previous address",
        BankName: "Please enter your bank name",
        BankAccNum: "Please enter your account number",
        BankSortCode: "Please enter your sort code",
        BankDuration: "Please enter your bank duration",
        LLName: "Please enter landlords name",
        LLTele: "Please enter landlords telephone number",
        LLEmail: "Please enter landlords email address",
        LLAddress: "Please enter landlords address",
        GuName: "Please enter guarantor name",
        GuPhoneDay: "Please enter guarantor phone number",
        GuPhoneEven: "Please enter guarantor evening number",
        GuPhoneMob: "Please enter guarantor mobile number",
        GuPhoneEmail: "Please enter guarantor email address",
        GuCurrentAdd: "Please enter guarantor current address",
        GuPrevAdd: "Please enter previous address",
        GuBankName: "Please enter guarantor bank name",
        GuBankAccNu: "Please enter guarantor account number",
        GuBankSort: "Please enter guarantor sort code",
        GuBankDurat: "Please enter guarantor bank duration",
        GuEmpProffes: "Please enter guarantor proffesion",
        GuEmpAnnWa: "Please enter guarantor annual wage",
        GuEmpPayroll: "Please enter guarantor payroll number",
        GuAccName: "Please enter guarantor accountant name",
        GuAccContName: "Please enter guarantors accountant contact",
        GuAccAdd: "Please enter guarantors accountants address",
        GuAccDayTel: "Please enter guarantors accountants daytime numbers",
        GuAccMobTel: "Please enter guarantors accountants mobile",
        GuAccEmail: "Please enter guarantors accountants email",
        GuAccAdditional: "Please enter guarantors accounts additional info",
        GuEmployerNam: "Please enter guarantors employers name",
        GuEmployerAdd: "Please enter guarantors employers address",
        GuEmployerContactName: "Please enter guarantors employers contact",
        GuEmployerTele: "Please enter enter guarantors employers number",
        GuEmployerEmail: "Please enter guarantors employers email",
        userid: {
        required: "Please enter a user ID",
        minlength: "Your username must consist of at least 2 characters"
        password: {
        required: "Please provide a password",
        minlength: "Your password must be at least 5 characters long"
        confirm_password: {
        minlength: "Your password must be at least 5 characters long",
        equalTo: "Please enter the same password as above"
        email: "Please enter a valid email address",
        terms: "Please accept our policy"
                                                      $.metadata.setType("attr", "validate");
                                                      $(document).ready(function() {
        $("#form2").validate();
        $("#selecttest").validate();
                                                      </script>
                                                      with the form header here
                                                      <form class="cmxform"action="<?php echo $editFormAction; ?>" method="post" name="form2" id="form2">
                                                          <input type="hidden" name="MM_insert" value="form2" />
                                                      form content in here and works
                                                      <input type="submit" value="submit" />
                                                      </form>
