Each time I attempt to install the following error pops up:
Note:Flash Player does not support 64-bit versions of Windows XP and Vista.
Before today I've never had issues with installing flash updates. Can anyone help?
Vista x64 is unsupported and untested, however the installer shouldn't block you as far as I know. Can you tell me what the file name is that you are trying to install?
Unless you're using a 64 bit browser, you should be able to install the 32 bit version of Flash Player which you can find here.
Thanks for the swift response but I think that I figured it out and I have
installed successfully the latest ver of Flash. Thanks again!
