11 Replies Latest reply: Apr 21, 2012 6:02 AM by Jacob Bugge RSS
    Splitting a circle up evenly
    Josh525
      Hello,
      I am brand new to Illustrator.
      I want to create a circle, split into 5 even segments with small gaps in between each segment.
      What would be the easiest way of doing this?
      Also, how can I split the circle up freehand and then enter measurement values numerically to get each segment an even width across.
      Many thank for your help in advance..
        • 1. Re: Splitting a circle up evenly
          Mike Gondek2 ACP/MVP
          Draw circle
          Pull 2 guides for center
          Draw a rectangle using the thicknes for your gap
          Center rectangle on guides (recomend using smart guides on)
          Rotate Tool
          Option click on guides center, and enter 72° = 360/5)
          CMD D to make 4 more copies
          Select All
          Pathfinder >>Minus front
          Not sure what your second question is? Try the knife tool to split up your circel freehand, click and hold the eraser to to find the knife tool.
          • 2. Re: Splitting a circle up evenly
            Jacob Bugge ACP/MVPs
            Josh,
            Or you may, with no drawing/transforming at all:
            1) Create a Polar Grid (Polar Grid Tool bundled with the Line Tool) with 5 Radial Dividers and no Concentric ones, size as the circle,
            2) Select the Radial Divider Group and set the Stroke Weight to the desired gap width,
            3) Object>Path>Outline Stroke,
            4) Also select the circular path and Pathfinder>Minus Front (Subtract from shape area in older versions, maybe holding Alt/Option),
            5) (Re)set the Fill colour (using the option at the bottom of the Toolbox).
            • 3. Re: Splitting a circle up evenly
              Steve Fairbairn Community Member
              Or use a pie chart with 5 equal slices. Then Jacob's method
              • 4. Re: Splitting a circle up evenly
                [scott] Community Member
                I'd use Steve's method....
                Simply ungroup and remove the 1% slices if needed.
                100%/5 = 20% per slice - 1% for spacing = 19% per slice with alternating 1% gaps.
                • 5. Re: Splitting a circle up evenly
                  Wade_Zimmerman Community Member
                  You can also try using this method in the video
                  http://www.wadezimmerman.com/videos/FiveSectionCircle.mov
                  BTW on the pc to draw a shape such as an ellipse from the center you hold down the control key.
                  • 6. Re: Splitting a circle up evenly
                    Josh525 Community Member
                    Hey guys. Thanks for your responses. I actually wanted to make the slices vertically through the circle to make vertical segments (rather than a pie chart effect). I guess the process for doing so remains the same.
                    I just wanted to check - after creating my segmented circle, I want to make each segment 3D as this design is for a Logo.
                    Which of the methods presented, would lend itself best to 3D designing? Or wouldn't it matter?
                    ie, If I created the segments using rectangles, would I then be able to edit/fill those segments individually?
                    Would one never just "draw in" the gaps from a circle template using the pen/line tool etc??
                    Many thanks again,
                    josh
                    • 7. Re: Splitting a circle up evenly
                      Josh,
                      Ah.
                      You may quite easily:
                      1) Place a vertical line with the Line Tool, at 1/5 W from the left, Stroke weight equalling the desired gap,
                      2) Object>Path>Outline Stroke,
                      3) Object>Transform>Move a copy 3 times by 1/5 W,
                      4) Select everything and Pathfinder>Minus Front.
                      This will leave you with 5 simple paths, for easy application of 3D.
                      • 8. Re: Splitting a circle up evenly
                        You can draw a rectangle at the top and bottom or left and right of the circle and then make a 4 step blend
                        Then expand the blend and eliminate the rectangles at the extremities
                        Then use the pathfinder to minus front
                        • 9. Re: Splitting a circle up evenly
                          Josh,
                          If you do what Wade said, remember to rotate by 90 degrees.
                          • 10. Re: Splitting a circle up evenly
                            Or just make the blend left to right as I already wrote in the first line of my response.
                            • 11. Re: Splitting a circle up evenly
                              Josh,
                              I just rediscovered this thread, after having overlooked it, and realized my overlooking of the crucial left to right option mentioned post #8, as pointed out in post #10; the right wording in post #9 would have been:
                              If you do what Wade showed, remember to rotate by 90 degrees.
                              It is easier to look at a drawing, but sometimes full reading (and understanding) is better.
                              It has occurred to me that a literal interpretation of the OP and post #6 may be that the circle should be cut, but nothing should be carved out of it.
                              This would lead to a quite different solution, which may be done in a number of ways, the one shown below being silly but fun to make:
                              1) Create the circle,
                              2) Create a vertical line at one fifth from the left side (line Tool is fine), longer than the circle is high,
                              3) Move a copy of the line thrice by one fifth,
                              4) Join adjacent endpoints to create a single meander path of the four lines,
                              5) With only the path selected, Object>Path>Divide Objects below,
                              6) Move the slices apart (may be done four/two/one at a time with Object>Transform>Move).
                              Here shown for a circle without and with stroke:
