6 Replies Latest reply on Apr 22, 2012 7:44 AM by John T Smith
    How Do I Change The Resolution?
    Solution/ Aspect Ratio
      Hello Community, hello Support Team,
      I am new to Premiere Elements. I use PE 10.
      I use the german version of PE. So please excuse me, when my terms do not match correctly.
      I was looking for a possiblity to change the project's resolution. I have found the "Project's Preferences" ("Projekt Eigenschaften").
      There you find the resolution in pixels. But I can not change it. It is greyed out.
      I have had the correct resolution until I have tried out one of the given titles. Then PE automatically changed the resolution. It now has a widescreen-format. I can not change it back. Even if I start a new project, there is set a widescreen. But PE shows a resolution of 720 x 576, which is definitely not widescreen.
      It's quite odd for me. But I think, there is a simple one-click-solution.
      In case you suggest a bug, here are my specs:
      Windows Vista, Home Premium, Service Pack 02
      Quadcore 8 GB, 8 GHertz
      Graphic Card: NVidia GeForce 9600 GT, 500 MB
      and lots of space on my harddisk
      I am looking forward to your answers ;-)
      Kind regards
      Arnim
        • 1. Re: How Do I Change The Resolution?
          the_wine_snob Level 9
          Welcome to the forum.
          You cannot alter the resolution, or FPS, etc., of an existing Project.
          You can only make those changes, when you choose New Project, from one of the available Presets.
          Note: PrE has a rather long list of possible Presets, that should match the Source Footage 100%, but does NOT have a Custom Preset, where you can change attributes to accommodate non-standard Footage.
          Good luck,
          Hunt
          1 person found this helpful
          • 2. Re: How Do I Change The Resolution?
            As for the Titles, if you have chosen, say a DV (PAL for Germany) Standard 4:3, the Title Templates should match that Project's Preset and Frame Size. There should be no changes, what so ever.
            If I read correctly, you are saying that you have a PAL Standard 4:3 Project for matching Source Footage, but when you add a Title (New Title), the Project is changing to Widescreen 16:9. Is that correct? That should not be possible, as PrE will match the Title to the Project, and not the other way around. Which Title Template did you choose?
            Good luck,
            Hunt
            • 3. Re: How Do I Change The Resolution?
              Solution/ Aspect Ratio Level 1
              Hello Bill,
              thank you for your answer. To be honest: I hoped for a different one. But to recognize the limitations of PE is also helpfull.
              Well, as I do not use camcorder-footage, I do not consider the standard resolutions to be very helpfull. I have the images rendered by a CGI (3D-) programm. So I can define the resolution of the (input-)images on my own.
              As you mentioned in your second answer, the change of resolution contradicts the "Forced-Happiness-Strategy" of Adobe, which forbids the user to change the resolution within the project. But this is what happened. Premiere changed it without giving me the possibility to change it back.
              Strange...
              But your answer helps me, not to look for a solution where there is none. Thanks again.
              Kind regards
              Arnim
              • 4. Re: How Do I Change The Resolution?
                If you are planning on using PrE (PrPro allows for Custom Frame Sizes, FPS, etc.), I would "reverse-engineer" things a bit. I would look to the "standard" Video Formats/Frame Sizes, and THEN Export to the chosen one, and one, that PrE supports. That will make life much easier.
                Good luck,
                Hunt
                • 5. Re: How Do I Change The Resolution?
                  Thanks again.
                  The hint to the PRO version is a good one. But as I plan to buy the creative suit in the near future I do not want to spend more money than necessary. I prefer a low-cost solution for the time beeing.
                  Maybe I reverse-engineer, as you said, the resolution. But I consider the change and unrestricted definition of resolution as a standard and not as a professional function. And a programm which has cost me 60 € should be able to do so. Maybe I make use of the proposal of my reseller who offered me to take the programm back, if it does not fit my needs.
                  This restriction is no good policy of Adobe.
                  But we are probably not the ones who can change this ;-)
                  Kind regards
                  Arnim
                  • 6. Re: How Do I Change The Resolution?
                    That is why this forum/program is called Premiere Elements... the professional forum/program is Premiere Pro, where you may create a custom project to match your video... but, do not buy PPro and expect it to instantly work with the CODEC produced by your CGI software, since computer generated video is still sometimes hard to edit, even with PPro
