6 Replies Latest reply on Jun 9, 2012 9:24 AM by Alan_AEDScripts
    Opening a web browser from an After Effects script
    Christian Lett Level 3
      This may be a stupid question, but is there any way to open a web browser with a URL from an AE script, other than explicity lanuching the browser app via a sys.callSystem() command?
      I'm asking because obviously scripts need to run on both Windows and MacOS, and the user's default/preferred browser isn't necessarily going to be IE or Safari. That and I'd need to find the file path of the browser anyway somehow.
      It's to display external help.
      Christian
        • 1. Re: Opening a web browser from an After Effects script
          OK so I've figured out a method that works.
          Within your script dynamically create a local, temporary HTML file that does a simple URL redirect, such as:
          <html>
              <head>
                  <script language="javascript">
                      location.replace("http://www.quarterlightpictures.com");
                  </script>
              </head>
              <body>
              </body>
          </html>
          called something like "openwebpage.html"
          Then use new File("openwebpage.html").execute(); to open the HTML file in the default browser. The Javascript in the HTML head tag forwards to the desired web page.
          • 2. Re: Opening a web browser from an After Effects script
            David Torno Level 4
            system.callSystem() can launch a URL without specifying the specific app. This code user's default browser. The last line is the main deal, the other stuff keeps it universal for PC and MAC.
            //CHECKS FOR USER OS
            function osCheck(){
                      var op = $.os;
                      var match = op.indexOf("Windows");
                      if(match != (-1)){
                                var userOS = "PC";// User is on PC
                      }else{
                                var userOS = "MAC";// User is on MAC
                      return userOS;
            // RUNS OS CHECK FUNCTION
            var userOSVer = osCheck();
            //DEFINES PC OR MAC TERMINAL SYNTAX
            if(userOSVer == "MAC"){
                      var urlLaunchCode = "Open";//Mac based
            }else{
                      var urlLaunchCode = "Start";//PC based
            //ONCLICK FUNCTION FOR YOUR URL BUTTON CONTROL
            //urlLaunchCode = Open or Start / " " = keeps a space character separator / "http://myurl.com" = Defines the actual URL path
            myURLButton.onClick = function(){system.callSystem(urlLaunchCode + " " + "http://forums.adobe.com/thread/993523?tstart=0")};
            • 3. Re: Opening a web browser from an After Effects script
              David, you've been very helpful on here, thank you! A much more elegant solution than mine too!
              Christian
              • 4. Re: Opening a web browser from an After Effects script
                //-- Michel --
                Here is an example of what I use to display a web page (to run directly from After Effects) :
                var win = new Window ("dialog");
                var winBrowserCmd = "C:/Program Files/Internet Explorer/iexplore.exe";
                var macBrowserCmdStart = "osascript -e 'open location \"";
                var macBrowserCmdEnd = "\"'";
                var BtnURL = win.add("button", undefined, "Check for update");
                BtnURL.onClick = LinkToURL;
                win.add ("button", undefined, "Close", {name: "ok"});
                function LinkToURL()
                            var URL = "http://www.google.fr/"; // your web page
                            if ($.os.indexOf("Windows") != -1)
                                system.callSystem(winBrowserCmd + " " + URL);
                            else
                                system.callSystem(macBrowserCmdStart + URL + macBrowserCmdEnd);
                win.show ();
                • 5. Re: Opening a web browser from an After Effects script
                  Alan_AEDScripts Level 2
                  I had been using the below, not fully tested on mac however....
                  function checkOSandLaunch(theAddress){ // pass in www. no need for http etc.
                            $.writeln(system.osName);
                                      if (    $.os.indexOf("Windows") != -1 ) {//SYSTEM IS ONE OF THE WINDOWS, XP OR 7 ETC - have the word Windows in it.
                                                system.callSystem("cmd.exe /c\"start http://"+theAddress+"\"" );
                                                else{//MUST BE MAC
                                                 system.callSystem("open http://"+theAddress+ "\"");
                  }//Close function.
                  • 6. Re: Opening a web browser from an After Effects script
                    I posted incorrect information in the last post, just to correct, this is what is working.
                    function checkOSandLaunch(theAddress) { // pass in www.
                              var site=theAddress;
                                                  system.callSystem("cmd.exe /c\"start http://"+site+"\"" );
                                                  else{//MUST BE MAC
                                                  system.callSystem("open http://"+site);
                    }//Close function.
