11 Replies Latest reply on Apr 24, 2012 7:33 AM by WitchXHunter
    [AS2] Character movement
    xmasgame
      Okey my character got this script: (its lots more but yeah.. this is the trouble code).
      Frame 1 = character stand still
      Frame 2 = character (MC) - movement
      Frame 3 = character (MC) - Jump movement
      It works fine, when I press UP, he jumpes and play frame 3.
      When i press left and right it plays frame 2.
      When I press .. nothing, frame 1 is played.
      That correct!
      BUT when i press .. left + up, or right + up, it will play frame 1.
      Any idea how i can make it play Frame 3 (jump) even if I press two buttons at the same time? Would be awesome if someone knew it.
      onClipEvent (enterFrame) {
      if (Key.isDown(Key.RIGHT)) {
      _root.player.gotoAndStop(2);
      if (Key.isDown(Key.LEFT)) {
      if (Key.isDown(Key.UP)) {
      _root.player.gotoAndStop(3);
      if (!Key.isDown(Key.LEFT) and (!Key.isDown(Key.RIGHT) and (!Key.isDown(Key.UP)))) {
      this.gotoAndStop(1);
        • 1. Re: [AS2] Character movement
          WitchXHunter
                     do something
                              } else if (Key.isDown(Key.RIGHT)) {
                      do something
                    } else {
                              } else if (Key.isDown(Key.LEFT)) {
                              } else {
          This should solve that. but I can't guarantee if it will cause any problem for your game.
          • 2. Re: [AS2] Character movement
            xmasgame Level 1
            That gave alot of errors hmm, to tired to check it out tonight. But what do you mean with "do something" ?
            • 3. Re: [AS2] Character movement
              prodigalmaster Level 2
              Just use the and opperator: &&
              so something like:
              if (Key.isDown(Key.LEFT) && Key.isDown(Key.UP) ) {
              if (Key.isDown(Key.RIGHT) && Key.isDown(Key.UP) ) {
              • 4. Re: [AS2] Character movement
                WitchXHunter Level 1
                the do something is not surpose to be in the code, it means the place for you to add your actions inside. like setting a different movement speed where it's nested without having to assign the jumping again.  prodigal master's code will work as well. depending on what way you want to script it.
                • 5. Re: [AS2] Character movement
                  xmasgame Level 1
                  Prodigalmaster, it did sound abit to easy with that code and it was, it did not work .. hmm
                  The issue is that whatever I do, when i press MORE buttons, the character FREEZE on frame 3 and wont play the MC
                  So in overall the code is right, it is going to frame 3 .. BUT it wont play the MC.
                  If i only press UP btw, it will play the MC
                  • 6. Re: [AS2] Character movement
                    Maybe that is because it is repeatedly goto and stopping on frame (3) due to the key's being down. Maybe use a boolean variable e.g. isJumping = false; and when the jump animationbegins make it isJumping = true; and finally when the animation ends make isJumping = false; and therefore in the code use && in the if statement with isJumping == false
                    • 7. Re: [AS2] Character movement
                      xmasgame Level 1
                      Not that good with booleans I  have to admit.. anyhow I did put "play" in the first frame of the MC in frame 3, that did not work out either.
                      • 8. Re: [AS2] Character movement
                        A boolean is just the name for a variable with two states. In flash this is true and false.
                        Just try what I said.
                        You know how to make a variable right?
                        var isJumping:Boolean = false;
                        (on the main timeline).
                        So, there are 3 frames in the player movieclip, and animation movieclips inside those frames of the player?
                        Did you try WitchXHunters' code without the 'do something' bit?
                        1 person found this helpful
                        • 9. Re: [AS2] Character movement
                          xmasgame Level 1
                          It made lots of errors but when I removed some scripts and removed do something it Worked thx for the head up.
                          Love you guys ^^
                          • 10. Re: [AS2] Character movement
                            xmasgame Level 1
                            Epic Script, thx again. My bad at the start, I had some code I had to remove to make that work and such.. When I read your script again today, it made it clear why it gave errors
                            • 11. Re: [AS2] Character movement
                              you're welcome .^^
