1 2 Previous Next 40 Replies Latest reply on Apr 3, 2013 10:48 AM by jaredg18
    Video investigation with Flash Player 11.2.202.228
    chris.campbell Adobe Employee
      Are you seeing a green screen or bars when watching video with the latest Flash Player update, version 11.2.202.228?
      Do you see other display bugs, such as incorrect colors or severe artifacting?
      We're actively investigating these problem and would like to consolidate information into this thread.  Here's what we need from you:
      First, please update your drivers to the latest released version.  Do not use beta drivers.  There are known issues with Nvidia beta drivers (285.27 and 285.38) that can cause bugs with Flash Player.  Please verify that you have the released versions from your GPU manufacturer.  If you have to choose between an older driver provided by your computer manufacturer (Dell, Acer, etc.) or a new driver by the GPU manufacturer (Nvidia, ATI, Intel, etc), choose the newer driver.  You can find these drivers here:
      If updating your driver does not solve the problem, here's what we'd like to know.  Please answer all four questions:
      1. What problem are you encountering?
      2. Try disabling Flash's hardware acceleration.  Does this fix the bug?
      3. What URL did you use to view video?  Please be specific (ie. we need something more than just "any youtube video")
      4. Please post your DxDiag report.  See these steps for details for creating the DxDiag.txt file.  Open this file and copy/paste the contents to your reply.
      Chris
        • 1. Re: Video investigation with Flash Player 11.2.202.228
          ginganinga1
          1. Messed up colour with green line at the top just like your example screenshot when playing some embedded videos
          2. Disabling Flash Hardware acceleration fixes the issue
          3. http://www.qvcuk.com/video/todaysproducts.html?cm_re=LN-_-OnQVCTV-_-VOTP
          4. See below:
          System Information
          Time of this report: 4/12/2012, 00:46:32
                 Machine name: xxxxx
             Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.111118-2330)
                     Language: English (Regional Setting: English)
          System Manufacturer: Medion
                 System Model: X6815
                         BIOS: BIOS Date: 07/18/11 14:06:58 Ver: 04.06.03
                    Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
                       Memory: 8192MB RAM
          Available OS Memory: 8104MB RAM
                    Page File: 3009MB used, 13194MB available
                  Windows Dir: C:\Windows
              DirectX Version: DirectX 11
          DX Setup Parameters: Not found
             User DPI Setting: 120 DPI (125 percent)
          System DPI Setting: 120 DPI (125 percent)
              DWM DPI Scaling: Disabled
               DxDiag Version: 6.01.7601.17514 64bit Unicode
          DxDiag Notes
                Display Tab 1: No problems found.
                  Sound Tab 1: No problems found.
                  Sound Tab 2: No problems found.
                    Input Tab: No problems found.
          DirectX Debug Levels
          Direct3D:    0/4 (retail)
          DirectDraw:  0/4 (retail)
          DirectInput: 0/5 (retail)
          DirectMusic: 0/5 (retail)
          DirectPlay:  0/9 (retail)
          DirectSound: 0/5 (retail)
          DirectShow:  0/6 (retail)
          Display Devices
                    Card name: Intel(R) HD Graphics 3000
                 Manufacturer: Intel Corporation
                    Chip type: Intel(R) HD Graphics Family
                     DAC type: Internal
                   Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_20801B0A&REV_09
               Display Memory: 1696 MB
             Dedicated Memory: 64 MB
                Shared Memory: 1632 MB
                 Current Mode: 1920 x 1080 (32 bit) (60Hz)
                 Monitor Name: Generic PnP Monitor
                Monitor Model: unknown
                   Monitor Id: SEC314C
                  Native Mode: 1920 x 1080(p) (59.999Hz)
                  Output Type: Internal
                  Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
          Driver File Version: 8.15.0010.2656 (English)
               Driver Version: 8.15.10.2656
                  DDI Version: 10.1
                 Driver Model: WDDM 1.1
            Driver Attributes: Final Retail
             Driver Date/Size: 2/17/2012 10:28:48, 8087040 bytes
                  WHQL Logo'd: Yes
              WHQL Date Stamp:
            Device Identifier: {D7B78E66-4256-11CF-DA72-8A00A9C2C535}
                    Vendor ID: 0x8086
                    Device ID: 0x0116
                    SubSys ID: 0x20801B0A
                  Revision ID: 0x0009
          Driver Strong Name: oem29.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2656:pci\ven_8086&dev_0116
               Rank Of Driver: 00E62001
                  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
             Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                 D3D9 Overlay: Supported
                      DXVA-HD: Supported
                 DDraw Status: Enabled
                   D3D Status: Enabled
                   AGP Status: Enabled
          Sound Devices
                      Description: Speakers (Realtek High Definition Audio)
          Default Sound Playback: Yes
          Default Voice Playback: Yes
                      Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_1B0A20B8&REV_1001
                  Manufacturer ID: 1
                       Product ID: 100
                             Type: WDM
                      Driver Name: RTKVHD64.sys
                   Driver Version: 6.00.0001.6353 (English)
                      WHQL Logo'd: Yes
                    Date and Size: 4/19/2011 17:19:42, 2839912 bytes
                      Other Files:
                  Driver Provider: Realtek Semiconductor Corp.
                   HW Accel Level: Basic
                        Cap Flags: 0xF1F
              Min/Max Sample Rate: 100, 200000
          Static/Strm HW Mix Bufs: 1, 0
          Static/Strm HW 3D Bufs: 0, 0
                        HW Memory: 0
                 Voice Management: No
          EAX(tm) 2.0 Listen/Src: No, No
             I3DL2(tm) Listen/Src: No, No
          Sensaura(tm) ZoomFX(tm): No
                      Description: Realtek Digital Output (Realtek High Definition Audio)
          Default Sound Playback: No
          Default Voice Playback: No
                  Manufacturer ID: 1
                       Product ID: 100
                             Type: WDM
                      WHQL Logo'd: Yes
                      Other Files:
                        Cap Flags: 0xF1F
                        HW Memory: 0
          Sound Capture Devices
                      Description: Microphone (Realtek High Definition Audio)
            Default Sound Capture: Yes
            Default Voice Capture: Yes
                        Cap Flags: 0x1
                     Format Flags: 0xFFFFF
          DirectInput Devices
                Device Name: Mouse
                   Attached: 1
              Controller ID: n/a
          Vendor/Product ID: n/a
                  FF Driver: n/a
                Device Name: Keyboard
                   Attached: 1
              Controller ID: n/a
                  FF Driver: n/a
          Poll w/ Interrupt: No
          USB Devices
          + USB Root Hub
          | Vendor/Product ID: 0x8086, 0x1C26
          | Matching Device ID: usb\root_hub20
          | Service: usbhub
          | Driver: usbhub.sys, 3/25/2011 04:29:26, 343040 bytes
          | Driver: usbd.sys, 3/25/2011 04:28:59, 7936 bytes
          +-+ Generic USB Hub
          | | Vendor/Product ID: 0x8087, 0x0024
          | | Matching Device ID: usb\class_09
          | | Service: usbhub
          Gameport Devices
          PS/2 Devices
          + Standard PS/2 Keyboard
          | Matching Device ID: *pnp0303
          | Service: i8042prt
          | Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
          | Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
          + Terminal Server Keyboard Driver
          | Matching Device ID: root\rdp_kbd
          | Upper Filters: kbdclass
          | Service: TermDD
          + Synaptics PS/2 Port TouchPad
          | Matching Device ID: *syn1d0f
          | Upper Filters: SynTP
          | Service: i8042prt
          + Terminal Server Mouse Driver
          | Matching Device ID: root\rdp_mou
          | Upper Filters: mouclass
          | Service: TermDD
          | Driver: termdd.sys, 11/21/2010 04:23:47, 63360 bytes
          | Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
          | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
          Disk & DVD/CD-ROM Drives
                Drive: C:
          Free Space: 485.5 GB
          Total Space: 901.5 GB
          File System: NTFS
                Model: SAMSUNG HN-M101MBB
                Drive: D:
          Free Space: 29.5 GB
          Total Space: 51.2 GB
          File System: NTFS
                Drive: E:
                Model: HL-DT-ST BDDVDRW CT40N
               Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 147456 bytes
          System Devices
               Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
          Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_20A91B0A&REV_05\3&11583659&2&FB
             Driver: n/a
               Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0104
          Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_20A91B0A&REV_09\3&11583659&2&00
             Driver: n/a
               Name: High Definition Audio Controller
          Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_20B81B0A&REV_05\3&11583659&2&D8
             Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 122368 bytes
               Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
          Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_20A91B0A&REV_09\3&11583659&2&08
             Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 184704 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A
          Device ID: PCI\VEN_8086&DEV_1C1A&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E5
               Name: Intel(R) Centrino(R) Wireless-N 1030
          Device ID: PCI\VEN_8086&DEV_008A&SUBSYS_53058086&REV_34\4&23A43D1D&0&00E1
             Driver: n/a
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
          Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E3
               Name: Realtek PCIe GBE Family Controller
          Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_20A81B0A&REV_06\4&132F4C9F&0&00E5
             Driver: n/a
               Name: Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49
          Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_20A91B0A&REV_05\3&11583659&2&F8
             Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
          Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E1
               Name: NVIDIA GeForce GT 555M
          Device ID: PCI\VEN_10DE&DEV_0DCE&SUBSYS_20A61B0A&REV_A1\4&2974873A&0&0008
             Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 213096 bytes
             Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 6/12/2011 11:43:00, 307604 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 233064 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 6/12/2011 11:43:00, 4096 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 224360 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 259072 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 6/12/2011 11:43:00, 4096 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 248320 bytes
             Driver: C:\Program Files\NVIDIA Corporation\license.txt, 6/12/2011 11:43:00, 15511 bytes
             Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 13241448 bytes
             Driver: C:\Windows\system32\DRIVERS\nvpciflt.sys, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 27240 bytes
             Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 6/12/2011 11:43:00, 67176 bytes
             Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2646632 bytes
             Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 18583144 bytes
             Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 7130216 bytes
             Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.7548 (English), 6/12/2011 11:43:00, 2213480 bytes
             Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2944104 bytes
             Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 15238248 bytes
             Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 362600 bytes
             Driver: C:\Windows\system32\nvinfo.pb, 6/12/2011 11:43:00, 7240 bytes
             Driver: C:\Windows\system32\nvinitx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 239720 bytes
             Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 22296168 bytes
             Driver: C:\Windows\system32\nvoptimusmft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 366696 bytes
             Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 834152 bytes
             Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 8863336 bytes
             Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 6/12/2011 11:43:00, 57960 bytes
             Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2337896 bytes
             Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 13011560 bytes
             Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 5303912 bytes
             Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.7548 (English), 6/12/2011 11:43:00, 2082408 bytes
             Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2804840 bytes
             Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 12003432 bytes
             Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 300136 bytes
             Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 200808 bytes
             Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 16464488 bytes
             Driver: C:\Windows\SysWow64\nvoptimusmft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 326248 bytes
             Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 695400 bytes
             Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 6554216 bytes
             Driver: C:\Windows\system32\nvdispco6420150.dll, 2.00.0015.0000 (English), 6/12/2011 11:43:00, 1496168 bytes
             Driver: C:\Windows\system32\nvgenco6420100.dll, 2.00.0010.0000 (English), 6/12/2011 11:43:00, 1427560 bytes
               Name: Intel(R) 6 Series/C200 Series Management Engine Interface - 1C3A
          Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_20A91B0A&REV_04\3&11583659&2&B0
             Driver: n/a
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
          Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E0
               Name: Renesas Electronics USB 3.0 Host Controller
          Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_20931B0A&REV_04\4&37254DAA&0&00E3
             Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 2.01.0016.0000 (English), 4/13/2011 17:30:54, 207872 bytes
             Driver: C:\Windows\system32\nusb3co1.dll, 2.01.0014.0000 (English), 4/1/2011 17:50:40, 81920 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
          Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_20A91B0A&REV_05\3&11583659&2&D0
             Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 52736 bytes
             Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:14, 325120 bytes
             Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:26, 343040 bytes
               Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
          Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_20A91B0A&REV_05\3&11583659&2&FA
             Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 10.01.0000.1008 (English), 11/6/2010 07:45:48, 438808 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
          Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_20A91B0A&REV_05\3&11583659&2&E8
               Name: Intel(R) HD Graphics 3000
          Device ID: PCI\VEN_8086&DEV_0116&SUBSYS_20801B0A&REV_09\3&11583659&2&10
             Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 8.15.0010.2656 (English), 2/17/2012 10:28:56, 14692896 bytes
             Driver: C:\Windows\system32\igdumd64.dll, 8.15.0010.2656 (English), 2/17/2012 10:28:48, 8087040 bytes
             Driver: C:\Windows\system32\igd10umd64.dll, 8.15.0010.2656 (English), 2/17/2012 10:21:54, 9605632 bytes
             Driver: C:\Windows\system32\igfxcmrt64.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 193024 bytes
             Driver: C:\Windows\system32\igfxcmjit64.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 2967040 bytes
             Driver: C:\Windows\system32\IccLibDll_x64.dll, 3/26/2011 14:29:42, 94208 bytes
             Driver: C:\Windows\system32\igkrng600.bin, 2/17/2012 10:27:56, 963912 bytes
             Driver: C:\Windows\system32\igcompkrng600.bin, 3/26/2011 15:18:08, 145804 bytes
             Driver: C:\Windows\system32\igfcg600m.bin, 2/17/2012 10:27:56, 261208 bytes
             Driver: C:\Windows\SysWow64\igkrng600.bin, 2/17/2012 10:27:56, 963912 bytes
             Driver: C:\Windows\SysWow64\igcompkrng600.bin, 3/26/2011 15:18:08, 145804 bytes
             Driver: C:\Windows\SysWow64\igfcg600m.bin, 2/17/2012 10:27:56, 261208 bytes
             Driver: C:\Windows\system32\igdde64.dll, 2/17/2012 10:27:54, 79360 bytes
             Driver: C:\Windows\SysWow64\igdde32.dll, 2/17/2012 10:24:50, 58880 bytes
             Driver: C:\Windows\system32\iglhxs64.vp, 2/17/2012 10:42:22, 18508 bytes
             Driver: C:\Windows\system32\iglhxo64.vp, 2/17/2012 09:21:50, 59425 bytes
             Driver: C:\Windows\system32\iglhxc64.vp, 2/17/2012 09:21:50, 59230 bytes
             Driver: C:\Windows\system32\iglhxg64.vp, 2/17/2012 09:21:50, 59398 bytes
             Driver: C:\Windows\system32\iglhxo64_dev.vp, 2/17/2012 09:21:50, 58109 bytes
             Driver: C:\Windows\system32\iglhxc64_dev.vp, 2/17/2012 09:21:50, 59104 bytes
             Driver: C:\Windows\system32\iglhxg64_dev.vp, 2/17/2012 09:21:50, 58796 bytes
             Driver: C:\Windows\system32\iglhxa64.vp, 3/26/2011 14:29:42, 1074 bytes
             Driver: C:\Windows\system32\iglhxa64.cpa, 3/26/2011 14:29:42, 1981696 bytes
             Driver: C:\Windows\system32\iglhcp64.dll, 3.00.0001.0014 (English), 2/17/2012 09:21:50, 213504 bytes
             Driver: C:\Windows\system32\iglhsip64.dll, 3.00.0000.0012 (English), 2/17/2012 09:21:50, 524800 bytes
             Driver: C:\Windows\SysWow64\igdumd32.dll, 8.15.0010.2656 (English), 2/17/2012 10:24:54, 6121472 bytes
             Driver: C:\Windows\SysWow64\igfxdv32.dll, 8.15.0010.2656 (English), 2/17/2012 09:23:18, 321024 bytes
             Driver: C:\Windows\SysWow64\igd10umd32.dll, 8.15.0010.2656 (English), 2/17/2012 10:13:04, 7794688 bytes
             Driver: C:\Windows\SysWow64\iglhcp32.dll, 3.00.0001.0014 (English), 2/17/2012 09:21:50, 177152 bytes
             Driver: C:\Windows\SysWow64\iglhsip32.dll, 3.00.0000.0012 (English), 2/17/2012 09:21:50, 519680 bytes
             Driver: C:\Windows\SysWow64\IntelCpHeciSvc.exe, 1.00.0001.0014 (English), 2/17/2012 10:37:02, 276248 bytes
             Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 237056 bytes
             Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 2321408 bytes
             Driver: C:\Windows\system32\difx64.exe, 1.04.0001.0000 (English), 2/17/2012 10:37:02, 184600 bytes
             Driver: C:\Windows\system32\hccutils.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:18, 110592 bytes
             Driver: C:\Windows\system32\igfxsrvc.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:38, 63488 bytes
             Driver: C:\Windows\system32\igfxsrvc.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 511768 bytes
             Driver: C:\Windows\system32\igfxpph.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:54, 386560 bytes
             Driver: C:\Windows\system32\igfxcpl.cpl, 8.15.0010.2656 (English), 2/17/2012 09:26:14, 126976 bytes
             Driver: C:\Windows\system32\igfxdev.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:10, 430080 bytes
             Driver: C:\Windows\system32\igfxdo.dll, 8.15.0010.2656 (English), 2/17/2012 09:24:40, 142336 bytes
             Driver: C:\Windows\system32\igfxtray.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 170264 bytes
             Driver: C:\Windows\system32\hkcmd.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 398616 bytes
             Driver: C:\Windows\system32\igfxress.dll, 8.15.0010.2656 (English), 2/17/2012 09:24:40, 9007616 bytes
             Driver: C:\Windows\system32\igfxpers.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 440600 bytes
             Driver: C:\Windows\system32\igfxTMM.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:50, 410624 bytes
             Driver: C:\Windows\system32\gfxSrvc.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:10, 172032 bytes
             Driver: C:\Windows\system32\GfxUI.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 5886232 bytes
             Driver: C:\Windows\system32\GfxUI.exe.config, 2/17/2012 09:22:08, 264 bytes
             Driver: C:\Windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 2/17/2012 09:25:10, 9216 bytes
             Driver: C:\Windows\system32\igfxext.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 250136 bytes
             Driver: C:\Windows\system32\igfxexps.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:46, 28672 bytes
             Driver: C:\Windows\SysWow64\igfxexps32.dll, 8.15.0010.2656 (English), 2/17/2012 09:23:48, 25088 bytes
             Driver: C:\Windows\system32\igfxrara.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:14, 435712 bytes
             Driver: C:\Windows\system32\igfxrchs.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 428544 bytes
             Driver: C:\Windows\system32\igfxrcht.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 429056 bytes
             Driver: C:\Windows\system32\igfxrdan.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 437248 bytes
             Driver: C:\Windows\system32\igfxrdeu.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438784 bytes
             Driver: C:\Windows\system32\igfxrenu.lrc, 8.15.0010.2656 (English), 2/17/2012 09:24:42, 286208 bytes
             Driver: C:\Windows\system32\igfxresn.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 439808 bytes
             Driver: C:\Windows\system32\igfxrfin.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438272 bytes
             Driver: C:\Windows\system32\igfxrfra.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 439808 bytes
             Driver: C:\Windows\system32\igfxrheb.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 435712 bytes
             Driver: C:\Windows\system32\igfxrhrv.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:22, 438784 bytes
             Driver: C:\Windows\system32\igfxrita.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438784 bytes
             Driver: C:\Windows\system32\igfxrjpn.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 432128 bytes
             Driver: C:\Windows\system32\igfxrkor.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 430592 bytes
             Driver: C:\Windows\system32\igfxrnld.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438784 bytes
             Driver: C:\Windows\system32\igfxrnor.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 437760 bytes
             Driver: C:\Windows\system32\igfxrplk.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438784 bytes
             Driver: C:\Windows\system32\igfxrptb.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrptg.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 438784 bytes
             Driver: C:\Windows\system32\igfxrrom.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:22, 439296 bytes
             Driver: C:\Windows\system32\igfxrrus.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 439296 bytes
             Driver: C:\Windows\system32\igfxrsky.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 438272 bytes
             Driver: C:\Windows\system32\igfxrslv.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrsve.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrtha.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437248 bytes
             Driver: C:\Windows\system32\igfxrcsy.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438272 bytes
             Driver: C:\Windows\system32\igfxrell.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 440320 bytes
             Driver: C:\Windows\system32\igfxrhun.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438272 bytes
             Driver: C:\Windows\system32\igfxrtrk.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\Gfxres.ar-SA.resources, 2/17/2012 09:26:22, 164334 bytes
             Driver: C:\Windows\system32\Gfxres.cs-CZ.resources, 2/17/2012 09:26:22, 140885 bytes
             Driver: C:\Windows\system32\Gfxres.da-DK.resources, 2/17/2012 09:26:24, 135868 bytes
             Driver: C:\Windows\system32\Gfxres.de-DE.resources, 2/17/2012 09:26:24, 145579 bytes
             Driver: C:\Windows\system32\Gfxres.el-GR.resources, 2/17/2012 09:26:24, 207830 bytes
             Driver: C:\Windows\system32\Gfxres.es-ES.resources, 2/17/2012 09:26:24, 145687 bytes
             Driver: C:\Windows\system32\Gfxres.en-US.resources, 2/17/2012 09:26:14, 131317 bytes
             Driver: C:\Windows\system32\Gfxres.fi-FI.resources, 2/17/2012 09:26:26, 140549 bytes
             Driver: C:\Windows\system32\Gfxres.fr-FR.resources, 2/17/2012 09:26:26, 143805 bytes
             Driver: C:\Windows\system32\Gfxres.he-IL.resources, 2/17/2012 09:26:26, 157226 bytes
             Driver: C:\Windows\system32\Gfxres.hr-HR.resources, 2/17/2012 09:26:36, 139487 bytes
             Driver: C:\Windows\system32\Gfxres.hu-HU.resources, 2/17/2012 09:26:26, 142189 bytes
             Driver: C:\Windows\system32\Gfxres.it-IT.resources, 2/17/2012 09:26:28, 148033 bytes
             Driver: C:\Windows\system32\Gfxres.ja-JP.resources, 2/17/2012 09:26:28, 161613 bytes
             Driver: C:\Windows\system32\Gfxres.ko-KR.resources, 2/17/2012 09:26:28, 146675 bytes
             Driver: C:\Windows\system32\Gfxres.nb-NO.resources, 2/17/2012 09:26:28, 136369 bytes
             Driver: C:\Windows\system32\Gfxres.nl-NL.resources, 2/17/2012 09:26:30, 142335 bytes
             Driver: C:\Windows\system32\Gfxres.pl-PL.resources, 2/17/2012 09:26:30, 140923 bytes
             Driver: C:\Windows\system32\Gfxres.pt-BR.resources, 2/17/2012 09:26:30, 142664 bytes
             Driver: C:\Windows\system32\Gfxres.pt-PT.resources, 2/17/2012 09:26:30, 141644 bytes
             Driver: C:\Windows\system32\Gfxres.ro-RO.resources, 2/17/2012 09:26:36, 144338 bytes
             Driver: C:\Windows\system32\Gfxres.ru-RU.resources, 2/17/2012 09:26:32, 191775 bytes
             Driver: C:\Windows\system32\Gfxres.sk-SK.resources, 2/17/2012 09:26:32, 140122 bytes
             Driver: C:\Windows\system32\Gfxres.sl-SI.resources, 2/17/2012 09:26:32, 136451 bytes
             Driver: C:\Windows\system32\Gfxres.sv-SE.resources, 2/17/2012 09:26:34, 141435 bytes
             Driver: C:\Windows\system32\Gfxres.th-TH.resources, 2/17/2012 09:26:34, 221099 bytes
             Driver: C:\Windows\system32\Gfxres.tr-TR.resources, 2/17/2012 09:26:34, 143155 bytes
             Driver: C:\Windows\system32\Gfxres.zh-CN.resources, 2/17/2012 09:26:34, 123467 bytes
             Driver: C:\Windows\system32\Gfxres.zh-TW.resources, 2/17/2012 09:26:36, 124962 bytes
             Driver: C:\Windows\system32\ig4icd64.dll, 2/17/2012 09:40:00, 18124800 bytes
             Driver: C:\Windows\SysWow64\ig4icd32.dll, 2/17/2012 09:29:28, 13209600 bytes
             Driver: C:\Windows\system32\igfxCoIn_v2656.dll, 1.02.0030.0000 (English), 2/17/2012 10:35:32, 90112 bytes
          DirectShow Filters
          DirectShow Filters:
          WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
          WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
          WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
          MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
          Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
          WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
          WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
          Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
          Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
          DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
          Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
          WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
          Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
          AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
          VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
          SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
          AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
          StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
          MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
          CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
          MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
          SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
          MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
          Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
          SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
          Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
          MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
          PlayReady DMO Wrapper,0x00600002,1,1,PRDMOW~1.DLL,1.03.2297.0000
          DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
          Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
          MS PR Source Filter,0x00200000,0,2,PRSource.dll,1.03.2297.0000
          Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
          ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
          Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
          MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Line 21 Decoder,0x00600000,1,1,,
          Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
          Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
          VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
          WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
          VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
          File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
          iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
          iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
          VDP Renderer,0x00200000,1,0,vdpsnka.dll,1.00.0000.0049
          DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
          Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
          Overlay Mixer2,0x00200000,1,1,,
          RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
          Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
          WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
          MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
          DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
          SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
          Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
          MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
          Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
          StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
          Overlay Mixer,0x00200000,0,0,,
          AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
          NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
          AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
          Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
          Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
          StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
          AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
          Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
          File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
          File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
          Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
          AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
          AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
          SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
          Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
          Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
          BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
          MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
          WDM Streaming Tee/Splitter Devices:
          Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          Video Compressors:
          WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
          WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
          MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
          DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
          MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
          Audio Compressors:
          WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
          WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
          IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
          Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
          GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
          CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
          CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
          MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
          Audio Capture Sources:
          Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
          PBDA CP Filters:
          PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
          PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
          PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
          Midi Renderers:
          Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
          Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
          WDM Streaming Capture Devices:
          ,0x00000000,0,0,,
          Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          ,0x00000000,0,0,,
          Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          USB2.0 UVC 1.3M Webcam,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
          WDM Streaming Rendering Devices:
          Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          BDA Network Providers:
          Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
          Video Capture Sources:
          VDP Source,0x00200000,0,1,vdpsrca.dll,1.00.0000.0049
          Multi-Instance Capable VBI Codecs:
          BDA Transport Information Renderers:
          BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
          MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
          BDA CP/CA Filters:
          Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
          Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          WDM Streaming Communication Transforms:
          Audio Renderers:
          Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
          Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
          Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
          DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
          DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
          Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
          EVR Power Information
          Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
            Quality Flags: 2576
              Enabled:
              Force throttling
              Allow half deinterlace
              Allow scaling
              Decode Power Usage: 100
            Balanced Flags: 1424
              Enabled:
              Force throttling
              Allow batching
              Force half deinterlace
              Force scaling
              Decode Power Usage: 50
            PowerFlags: 1424
              Enabled:
              Force throttling
              Allow batching
              Force scaling
              Decode Power Usage: 0
          • 2. Re: Video investigation with Flash Player 11.2.202.228
            dacct Level 1
            1. Firefox exhibit green bands; IE stops working
            2. disbabling HW Acceleration fixes the issue OR forcing Firefox and IE to use the Integrated Graphics
            3. http://vimeo.com/37254322
            4. see bellow
            note: driver update directly from NVIDIA is not an option at the moment since I run high-end 3D applications requiring computer manufaturer qualified drivers.
            System Information
            Time of this report: 4/9/2012, 15:53:46
                   Machine name: DF-M4600
               Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.111118-2330)
            System Manufacturer: Dell Inc.
                   System Model: Precision M4600
                           BIOS: Default System BIOS
                      Processor: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
                         Memory: 8192MB RAM
            Available OS Memory: 8072MB RAM
                      Page File: 3065MB used, 13078MB available
               User DPI Setting: 96 DPI (100 percent)
                 DxDiag Version: 6.01.7601.17514 32bit Unicode
            DxDiag Notes
            Display Devices
                      Card name: Intel(R) HD Graphics Family
                       DAC type: Internal
                     Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_04A31028&REV_09
                     Monitor Id: SEC5448
                    Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
            Driver File Version: 8.15.0010.2418 (English)
                 Driver Version: 8.15.10.2418
                    DDI Version: 10.1
               Driver Date/Size: 6/11/2011 03:16:04, 8292352 bytes
                    WHQL Logo'd: Yes
                WHQL Date Stamp:
              Device Identifier: {D7B78E66-4266-11CF-EA7A-A924A9C2C535}
                      Vendor ID: 0x8086
                      Device ID: 0x0126
                      SubSys ID: 0x04A31028
                    Revision ID: 0x0009
            Driver Strong Name: oem48.inf:Intel.Mfg.NTamd64.6.1:iSNBM0:8.15.10.2418:pci\ven_8086&dev_0126&subsys_04a31028
                 Rank Of Driver: 00E60001
                        DXVA-HD: Supported
                     D3D Status: Enabled
                     AGP Status: Enabled
            Sound Devices
                        Description: Speakers / Headphones (IDT High Definition Audio CODEC)
                        Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_76E7&SUBSYS_102804A3&REV_1001
                    Manufacturer ID: 1
                         Product ID: 100
                               Type: WDM
                        Driver Name: stwrt64.sys
                     Driver Version: 6.10.6320.0000 (English)
                        WHQL Logo'd: Yes
                      Date and Size: 1/7/2011 11:32:52, 520192 bytes
                        Other Files:
                    Driver Provider: IDT
                          Cap Flags: 0xF1F
                          HW Memory: 0
                        Description: Communications Headphones (IDT High Definition Audio CODEC)
                    Manufacturer ID: 1
                         Product ID: 100
                               Type: WDM
                        WHQL Logo'd: Yes
                        Other Files:
                          Cap Flags: 0xF1F
                          HW Memory: 0
                        Description: Microphone Array (IDT High Definition Audio CODEC)
              Default Voice Capture: No
                          Cap Flags: 0x1
                        Description: Dock Mic (IDT High Definition Audio CODEC)
              Default Sound Capture: No
                          Cap Flags: 0x1
                        Description: Rec. Playback (IDT High Definition Audio CODEC)
                          Cap Flags: 0x1
                        Description: Microphone / Line In (IDT High Definition Audio CODEC)
                          Cap Flags: 0x1
            DirectInput Devices
                  Device Name: Mouse
                     Attached: 1
                Controller ID: n/a
                    FF Driver: n/a
                     Attached: 1
                Controller ID: n/a
                    FF Driver: n/a
                  Device Name: USB Receiver
                     Attached: 1
                Controller ID: 0x0
            Vendor/Product ID: 0x046D, 0xC52B
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                  Device Name: Cordless Receiver
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
            USB Devices
            + USB Root Hub
            | Vendor/Product ID: 0x8086, 0x1C2D
            | Service: usbhub
            +-+ Generic USB Hub
            | | Service: usbhub
            Gameport Devices
            PS/2 Devices
            | Service: i8042prt
            + HID Keyboard Device
            | Matching Device ID: hid_device_system_keyboard
            | Service: kbdhid
            | Service: TermDD
            + Dell Touchpad
            | Matching Device ID: acpi\dll04a3
            | Upper Filters: ApfiltrService
            | Service: i8042prt
            + HID-compliant mouse
            | Matching Device ID: hid_device_system_mouse
            | Service: mouhid
            + Logitech HID-compliant Unifying mouse
            | Matching Device ID: hid\vid_046d&class_0004
            | Upper Filters: LMouFilt
            | Lower Filters: LHidFilt
            | Service: mouhid
            | Service: TermDD
                  Drive: C:
            Free Space: 18.7 GB
            Total Space: 351.7 GB
            File System: NTFS
                  Model: ST9750420AS
                  Drive: D:
            Free Space: 1.9 GB
            File System: NTFS
                  Model: ST9750420AS
                  Drive: E:
                  Model: HL-DT-ST DVD+-RW GS30N
                 Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
            System Devices
            Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_04A31028&REV_04\3&11583659&0&E8
               Driver: n/a
                 Name: Intel(R) 82579LM Gigabit Network Connection
            Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_04A31028&REV_04\3&11583659&0&C8
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_04A31028&REV_04\3&11583659&0&FB
               Driver: n/a
                 Name: Intel(R) HD Graphics Family
            Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_04A31028&REV_09\3&11583659&0&10
               Driver: n/a
            Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_04A31028&REV_04\4&869802D&0&00E3
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_04A31028&REV_04\3&11583659&0&D8
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_04A31028&REV_09\3&11583659&0&00
               Driver: n/a
                 Name: Intel(R) Centrino(R) Ultimate-N 6300 AGN
            Device ID: PCI\VEN_8086&DEV_422B&SUBSYS_11218086&REV_35\4&366A6158&0&00E1
               Driver: n/a
                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E
            Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_04A31028&REV_B4\3&11583659&0&E7
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_04A31028&REV_09\3&11583659&0&08
               Driver: n/a
                 Name: Intel(R) Mobile Express Chipset SATA RAID Controller
            Device ID: PCI\VEN_8086&DEV_282A&SUBSYS_04A31028&REV_04\3&11583659&0&FA
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_04A31028&REV_B4\3&11583659&0&E3
               Driver: n/a
                 Name: O2Micro Integrated MS/MSPRO/xD Controller
            Device ID: PCI\VEN_1217&DEV_8330&SUBSYS_04A31028&REV_05\4&3A23FE2&0&02E7
               Driver: n/a
                 Name: Intel(R) QM67 Express Chipset Family LPC Interface Controller - 1C4F
            Device ID: PCI\VEN_8086&DEV_1C4F&SUBSYS_04A31028&REV_04\3&11583659&0&F8
               Driver: n/a
                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 3 - 1C14
            Device ID: PCI\VEN_8086&DEV_1C14&SUBSYS_04A31028&REV_B4\3&11583659&0&E2
               Driver: n/a
                 Name: O2Micro Integrated MMC/SD controller
            Device ID: PCI\VEN_1217&DEV_8320&SUBSYS_04A31028&REV_05\4&3A23FE2&0&01E7
               Driver: n/a
                 Name: Intel(R) Management Engine Interface
            Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_04A31028&REV_04\3&11583659&0&B0
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_04A31028&REV_B4\3&11583659&0&E1
               Driver: n/a
                 Name: 1394 OHCI Compliant Host Controller
            Device ID: PCI\VEN_1217&DEV_11F7&SUBSYS_04A31028&REV_05\4&3A23FE2&0&00E7
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_04A31028&REV_04\3&11583659&0&D0
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_04A31028&REV_B4\3&11583659&0&E0
               Driver: n/a
                 Name: NVIDIA Quadro 2000M
            Device ID: PCI\VEN_10DE&DEV_0DDA&SUBSYS_14A31028&REV_A1\4&2BFF4559&0&0008
               Driver: n/a
            DirectShow Filters
            DirectShow Filters:
            Blackmagic Design Decoder (DMO),0x00200000,1,1,dmobmd.dll,9.01.0000.0000
            Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,0.80.15035.0000
            CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,0.80.15035.0000
            CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,0.80.15035.0000
            FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,0.80.15035.0000
            FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,0.80.15035.0000
            Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,0.80.15035.0000
            Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,0.80.15035.0000
            Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,0.80.15035.0000
            OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,0.80.15035.0000
            Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,0.80.15035.0000
            Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,0.80.15035.0000
            Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,0.80.15035.0000
            Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,0.80.15035.0000
            Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,0.80.15035.0000
            Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,0.80.15035.0000
            CyberLink Audio Effect (PDVD9),0x00200000,1,1,ClAudFx.ax,6.00.0000.8417
            Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,0.80.15035.0000
            ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,12.02.0001.0071
            ROXIO Image/Colour Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
            WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            Roxio MPEG2 Encoder,0x00000000,0,0,,
            VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0071
            ROXIO WAV Dest 3.0,0x00200000,0,0,,
            ROXIO MPEG Writer,0x00000000,0,0,,
            ROXIO Scene Detector 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,12.02.0001.0071
            ROXIO Video Resampler 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink Digest Filter (PDVD9),0x00200000,2,2,DigestFilter.dll,1.00.0000.3314
            CyberLink TimeStretch Filter (PDVD9),0x00200000,1,1,clauts.ax,2.00.0000.3404
            ROXIO Audio Source 3.0,0x00200000,0,1,roxaudio.ax,10.00.0000.0000
            roxio DCFilters Subpicture Mixer,0x00000000,0,0,,
            VCGImageSource,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0071
            Roxio MPEG1 Audio Encoder,0x00000000,0,0,,
            CyberLink Tzan Filter (PDVD9),0x00200000,1,1,CLTzan.ax,3.05.0000.3606
            Creative Video Processing Filter,0x00200000,1,1,VidProcU.ax,1.00.0009.0000
            ROXIO VideoCombine 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio Smart AVC Video Decode,0x00800000,1,2,,
            ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            Roxio RealD to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VideoTransition 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            CyberLink HD/BD Mixer (PDVD9),0x00200000,1,2,CLHBMixer.ax,2.00.0000.2422
            roxio DCFilters Audio Sync Filter 2,0x00000000,0,0,,
            CyberLink Video/SP Decoder (PDVD9),0x00602000,2,3,CLVsd.ax,8.04.0000.2308
            ROXIO CPU Regulator,0x00200000,1,1,CPURegulator.ax,10.00.0000.0000
            CyberLink AudioCD Filter (PDVD9),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
            Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,12.02.0001.0071
            ROXIO LPCMSyncFilter,0x00000000,0,0,,
            ROXIO VCFStationLogo 1.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VideoInfo Transcoder 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.2317
            roxio DCFilters MPEG Transcoder,0x00000000,0,0,,
            ROXIO DV Scene Detector Tee 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink Audio Decoder (PDVD9),0x00201000,1,1,Claud.ax,8.04.0000.3630
            Cyberlink SubTitle Importor (PDVD9),0x00200000,2,1,CLSubTitle.ax,2.00.0000.0416
            ROXIO Field Splitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters DVD Reader,0x00000000,0,0,,
            Roxio Audio Stream Writer Filter,0x00000000,0,0,,
            CyberLink Line21 Decoder (PDVD9),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
            Roxio Repacketizer Filter,0x00000000,0,0,,
            PSI Parser,0x00200000,0,0,RoxVideo.ax,12.02.0001.0071
            Roxio Audio Stream Reader Filter,0x00000000,0,0,,
            ROXIO Field Combiner 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO QuickGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO Video Effect 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio Anaglyph to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFLatency 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Video Rotater,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.4013
            roxio DCFilters Mpeg I/II Decoder,0x00000000,0,0,,
            Roxio Mp3 Encoder (SC),0x00000000,0,0,,
            Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
            ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0071
            Creative MJPEG Decoder 2,0x00200000,1,1,CtMJPGDec2.ax,1.00.0008.0000
            Cyberlink SubTitle Importor 2.0 (PDVD9),0x00200000,1,0,CLSubTitle.ax,2.00.0000.0416
            CyberLink FLV Splitter (PDVD9),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.1030
            ROXIO AudioConvert 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,12.02.0001.0071
            ROXIO InputSelector 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,12.02.0001.0071
            Roxio Smart AVC Encode,0x00200000,2,1,,
            File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
            ROXIO Audio VCFLooper 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
            CyberLink Audio Spectrum Analyzer (PDVD9),0x00200000,1,1,CLAudSpa.ax,1.00.0000.7113
            Roxio Audio Source Filter,0x00000000,0,0,,
            Sonic MPEG-2 Video Decoder,0x00200000,2,2,c12oem_dec_mp2v_ds.ax,8.05.0000.19970
            Roxio MPEG1 Encoder,0x00000000,0,0,,
            ROXIO Pan Zoom 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO Pin Tee,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO Audio VCFChunker 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio MPEG2 Video Decoder,0x00000000,0,0,,
            CyberLink DVD Navigator (PDVD9),0x00200000,0,3,CLNavX.ax,8.01.0000.2931
            ROXIO Video VCFLooper 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Decklink MJPEG Decompressor,0x00800000,1,1,DeckLink.dll,9.01.0000.0000
            CyberLink MPEG-4 Splitter (PDVD9),0x00200000,1,2,clm4splt.ax,1.01.0000.2906
            CyberLink RealMedia Splitter (PDVD9),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1103
            ROXIO InputSelectorNew 3.0,0x00200000,1,0,,
            ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,12.02.0001.0071
            Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
            ROXIO Video Integrate,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio Smart Decoder,0x00000000,0,0,,
            Media Analyser,0x00200000,1,2,mediaanalyser.ax,12.02.0001.0071
            ROXIO VCFAudioMixer 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Smart Encoder,0x00000000,0,0,,
            Sonic Cinemaster® Audio Decoder 4.3 (No Dolby),0x005ffffe,1,1,CinemasterAudioND.DLL,4.03.0000.0240
            AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
            CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.7190.3125
            ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO ListImage Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO SceneRecorder 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFWaveform 1.0,0x00200000,1,0,roxaudio.ax,10.00.0000.0000
            LVMWriter,0x00200000,1,0,LVMWriter.ax,12.02.0001.0071
            Roxio MPEG Analyzer,0x00000000,0,0,,
            CyberLink RealAudio Decoder (PDVD9),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
            ROXIO ColorSpace Converter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio File Writer Wrapper,0x00200000,1,0,RoxFileWriterWrapper.ax,1.00.0000.0001
            ROXIO VCFAlphaSplitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters Smart Resizer,0x00000000,0,0,,
            ROXIO AudioGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            CyberLink Video Decoder (PDVD9),0x00200000,1,2,CLCvd.ax,1.00.7190.3125
            VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0071
            Sonic Audio Resampler,0x00200000,1,1,c12oem_trans_audio_samplerate_ds.ax,8.05.0000.19970
            ROXIO BDAV Smart Render 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio StereoSource Cropper,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Decklink Still Sequence Source,0x00200000,0,1,DeckLink.dll,9.01.0000.0000
            Half Size to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters DVD Splitter,0x00000000,0,0,,
            ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Sonic Cinemaster® VideoDecoder 4.3 (EMC12),0x005ffffe,2,2,CinemasterVideo.DLL,4.03.0001.0279
            roxio DCFilters DVD Muxer,0x00000000,0,0,,
            CyberLink RealVideo Decoder (PDVD9),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
            Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
            Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,4.03.0000.0134
            ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,12.02.0001.0071
            ROXIO InputSelectorNew 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters Dragon Lair,0x00000000,0,0,,
            Decklink Still Sequence Sink,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Sonic MPEG Multiplexer,0x00200000,1,1,c12oem_mux_mp2_ds.ax,8.05.0000.19970
            ROXIO VCFVideoCutList 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO SubPicture Encoder,0x00000000,0,0,,
            Roxio MPEG2 Muxer,0x00000000,0,0,,
            ROXIO Deinterlace 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio MPEG Stream Analyzer,0x00000000,0,0,,
            Roxio Transport Stream Source,0x00000000,0,0,,
            ROXIO VCFpeakmeter 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio MPEG1 Muxer,0x00000000,0,0,,
            Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,12.02.0001.0071
            ROXIO VCFHDVSceneDetect 1.0,0x00200000,2,1,RoxVideo.ax,12.02.0001.0071
            Roxio MPEG2 Demuxer,0x00000000,0,0,,
            Decklink Upsample,0x00200000,1,1,DeckLink.dll,9.01.0000.0000
            ROXIO QT Source,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,RoxVideo.ax,12.02.0001.0071
            CyberLink Matroska Splitter (PDVD9),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.2811
            Video Compressors:
            Decklink MJPEG Compressor,0x00200000,1,1,DeckLink.dll,9.01.0000.0000
            Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic HD 8 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 8 bit MJPEG Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 10 bit 4:4:4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic SD 8 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 10 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Audio Compressors:
            Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
            Microphone Array (IDT High Defi,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Decklink Audio Capture,0x00200000,0,1,DeckLink.dll,9.01.0000.0000
            Dock Mic (IDT High Definition A,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Microphone / Line In (IDT High ,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Rec. Playback (IDT High Definit,0x00200000,0,0,qcap.dll,6.06.7601.17514
            PBDA CP Filters:
            Midi Renderers:
            ,0x00000000,0,0,,
            MicIn2,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            MuxedIn,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            ,0x00000000,0,0,,
            Integrated Webcam,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            HpOut,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            ,0x00000000,0,0,,
            ,0x00000000,0,0,,
            Speaker/HP,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            Decklink Video Capture,0x00200000,0,3,DeckLink.dll,9.01.0000.0000
            BDA CP/CA Filters:
            External Renderers:
            Decklink Video Render,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Audio Renderers:
            Speakers / Headphones (IDT High,0x00200000,1,0,quartz.dll,6.06.7601.17713
            CyberLink Audio Renderer (PDVD9),0x00200000,1,0,cladr.ax,7.00.0000.3603
            Decklink Audio Render,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Communications Headphones (IDT ,0x00200000,1,0,quartz.dll,6.06.7601.17713
            DirectSound: Communications Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,6.06.7601.17713
            DirectSound: Speakers / Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,6.06.7601.17713
              Quality Flags: 2576
                Enabled:
                Force throttling
                Allow scaling
                Enabled:
                Force throttling
                Allow batching
                Force scaling
              PowerFlags: 1424
                Enabled:
                Force throttling
                Allow batching
                Force scaling
            • 3. Re: Video investigation with Flash Player 11.2.202.228
              Adam Skovron
              • Confirmed video drivers are the latest
              • Problem: Green bar and color out of sync as per image
              • Disabling Flash's hardware acceleration fixes the problem
              • URL to view video: http://youtu.be/wkEDOFhA7Pw  [anything that is using the video player]
              • DxDiag report as follows:
              System Information
              Time of this report: 4/12/2012, 13:51:46
                     Machine name: T420S-4170CTO
                 Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
              System Manufacturer: LENOVO
                     System Model: 4170CTO
                        Processor: Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz (4 CPUs), ~2.7GHz
                           Memory: 8192MB RAM
              Available OS Memory: 8074MB RAM
                        Page File: 5396MB used, 10750MB available
                 User DPI Setting: Using System DPI
              System DPI Setting: 96 DPI (100 percent)
              DxDiag Notes
                    Display Tab 2: No problems found.
                      Sound Tab 3: No problems found.
                      Sound Tab 4: No problems found.
              Display Devices
                         DAC type: Internal
                       Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_21D317AA&REV_09
                     Current Mode: 1600 x 900 (32 bit) (60Hz)
                     Monitor Name: ThinkPad Display 1600x900
                       Monitor Id: LEN40A1
                      Native Mode: 1600 x 900(p) (60.000Hz)
              Driver File Version: 8.15.0010.2538 (English)
                   Driver Version: 8.15.10.2538
                      DDI Version: 10.1
                 Driver Date/Size: 9/26/2011 03:44:56, 8313856 bytes
                      WHQL Logo'd: Yes
                  WHQL Date Stamp:
                Device Identifier: {D7B78E66-4266-11CF-B369-DF01B7C2C535}
                        Vendor ID: 0x8086
                        Device ID: 0x0126
                        SubSys ID: 0x21D317AA
                      Revision ID: 0x0009
              Driver Strong Name: oem97.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2538:pci\ven_8086&dev_0126&subsys_21d317aa
                          DXVA-HD: Supported
                       D3D Status: Enabled
                       AGP Status: Enabled
                        Card name: NVIDIA NVS 4200M
                     Manufacturer: NVIDIA
                        Chip type: NVS 4200M
                         DAC type: Integrated RAMDAC
                       Device Key: Enum\PCI\VEN_10DE&DEV_1056&SUBSYS_21D317AA&REV_A1
                   Display Memory: 4065 MB
                 Dedicated Memory: 993 MB
                    Shared Memory: 3071 MB
                     Current Mode: 2560 x 1440 (32 bit) (59Hz)
                     Monitor Name: Dell U2711(DP)
                    Monitor Model: DELL U2711
                       Monitor Id: DELA057
                      Native Mode: 2560 x 1440(p) (59.951Hz)
                      Output Type: Displayport External
                      Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
              Driver File Version: 8.17.0012.7593 (English)
                   Driver Version: 8.17.12.7593
                      DDI Version: 11
                 Driver Date/Size: 8/13/2011 00:18:00, 15241832 bytes
                      WHQL Logo'd: Yes
                  WHQL Date Stamp:
                Device Identifier: {D7B71E3E-5316-11CF-B369-DF011FC2C535}
                        Vendor ID: 0x10DE
                        Device ID: 0x1056
                      Revision ID: 0x00A1
              Driver Strong Name: oem33.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section097:8.17.12.7593:pci\ven_10de&dev_1056&s ubsys_21d317aa
                      Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
                 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                          DXVA-HD: Supported
                       D3D Status: Enabled
                       AGP Status: Enabled
              Sound Devices
                          Description: Speakers (MM-1)
                          Hardware ID: USB\VID_19B5&PID_0004&REV_0111&MI_00
                      Manufacturer ID: 65535
                           Product ID: 65535
                                 Type: WDM
                          Driver Name: USBAUDIO.sys
                       Driver Version: 6.01.7601.17514 (English)
                    Driver Attributes: Final Retail
                          WHQL Logo'd: Yes
                        Date and Size: 11/20/2010 23:23:47, 109696 bytes
                          Other Files:
                      Driver Provider: Microsoft
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Speakers (4- Jabra PRO 9470)
                          Hardware ID: USB\VID_0B0E&PID_1041&REV_0305&MI_00
                           Product ID: 65535
                                 Type: WDM
                          WHQL Logo'd: Yes
                          Other Files:
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Speakers (Conexant 20672 SmartAudio HD)
                          Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_506E&SUBSYS_17AA21D2&REV_1000
                      Manufacturer ID: 1
                           Product ID: 100
                                 Type: WDM
                          Driver Name: CHDRT64.sys
                       Driver Version: 8.32.0023.0002 (English)
                          WHQL Logo'd: n/a
                        Date and Size: 10/3/2011 19:46:40, 1577088 bytes
                          Other Files:
                      Driver Provider: Conexant
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: DELL U2711-2 (NVIDIA High Definition Audio)
                          Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_001C&SUBSYS_17AA21D3&REV_1001
                      Manufacturer ID: 1
                           Product ID: 100
                                 Type: WDM
                          Driver Name: nvhda64v.sys
                       Driver Version: 1.02.0023.0003 (English)
                          WHQL Logo'd: Yes
                        Date and Size: 5/10/2011 15:11:28, 174184 bytes
                          Other Files:
                      Driver Provider: NVIDIA Corporation
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Microphone (4- Jabra PRO 9470)
                            Cap Flags: 0x1
                          Description: Internal Microphone (Conexant 20672 SmartAudio HD)
                            Cap Flags: 0x1
                          Description: Microphone (HD Pro Webcam C910)
                            Cap Flags: 0x1
              DirectInput Devices
                    Device Name: Mouse
                       Attached: 1
                  Controller ID: n/a
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: n/a
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                    Device Name: Jabra PRO 9470
                       Attached: 1
                  Controller ID: 0x0
              Vendor/Product ID: 0x0B0E, 0x1041
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                    Device Name: MM-1
                       Attached: 1
                  Controller ID: 0x0
              Vendor/Product ID: 0x19B5, 0x0004
                      FF Driver: n/a
              USB Devices
              + USB Root Hub
              | Service: usbhub
              +-+ Generic USB Hub
              | | Service: usbhub
              Gameport Devices
              PS/2 Devices
              | Service: i8042prt
              | Service: kbdhid
              | Service: TermDD
              + ThinkPad UltraNav Pointing Device
              | Matching Device ID: *len0015
              | Service: i8042prt
              | Service: mouhid
              | Service: TermDD
                    Drive: C:
              Free Space: 41.3 GB
              Total Space: 269.0 GB
              File System: NTFS
                    Model: INTEL SSDSA2CW300G3
                    Drive: Q:
              Free Space: 6.5 GB
              Total Space: 16.0 GB
              File System: NTFS
                    Drive: E:
                    Model: ROXIO DVD-ROM EMULATOR SCSI CdRom Device
              System Devices
              Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_21D217AA&REV_09\3&42FFD25&0&08
                 Driver: n/a
                   Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
              Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E4
                 Driver: n/a
                   Name: Intel(R) Centrino(R) Advanced-N 6250 AGN
              Device ID: PCI\VEN_8086&DEV_0089&SUBSYS_13118086&REV_5E\4&104CF0A&0&00E1
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E3
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C4F&SUBSYS_21D217AA&REV_04\3&42FFD25&0&F8
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E1
                 Driver: n/a
                   Name: Intel(R) Active Management Technology - SOL (COM7)
              Device ID: PCI\VEN_8086&DEV_1C3D&SUBSYS_21D217AA&REV_04\3&42FFD25&0&B3
                 Driver: n/a
                   Name: NVIDIA NVS 4200M
              Device ID: PCI\VEN_10DE&DEV_1056&SUBSYS_21D317AA&REV_A1\4&16E83063&0&0008
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E0
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_21D217AA&REV_04\3&42FFD25&0&B0
                 Driver: n/a
              Device ID: PCI\VEN_10DE&DEV_0E08&SUBSYS_21D317AA&REV_A1\4&16E83063&0&0108
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_21D217AA&REV_04\3&42FFD25&0&FA
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_21D217AA&REV_04\3&42FFD25&0&D0
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_21CE17AA&REV_04\3&42FFD25&0&C8
                 Driver: n/a
              Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_21D217AA&REV_04\4&1540E4B9&0&00E4
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_21D217AA&REV_04\3&42FFD25&0&E8
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_21D317AA&REV_09\3&42FFD25&0&10
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_21D217AA&REV_04\3&42FFD25&0&FB
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_21D217AA&REV_09\3&42FFD25&0&00
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_21D217AA&REV_04\3&42FFD25&0&D8
                 Driver: n/a
              DirectShow Filters
              DirectShow Filters:
              G2M Session Decoder,0x00600000,1,1,G2M.dll,5.01.0000.0880
              MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,4.00.7577.0000
              WD Secure Source Filter,0x00200000,0,1,WDSecureSourceFilter.dll,2.01.0041.0000
              Ulead DV Writer,0x00000000,0,0,,
              InterVideo Video Decoder,0x00700000,2,5,IVIVIDEO.ax,10.00.0005.0828
              Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,12.02.0001.0082
              WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
              WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              Ulead Ogg Parser,0x00600000,1,1,ulOggParserFilter.ax,1.00.0000.0002
              Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,12.02.0001.0082
              MainConcept (Sonic) DV Video Decoder,0x00600000,1,1,sonicmcdsdv.ax,2.01.0000.0004
              MainConcept (Sonic) DV Video Encoder,0x00200000,1,1,sonicmcdsdv.ax,2.01.0000.0004
              ROXIO VCFVideoCutList 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO Image/Colour Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
              Roxio Smart AVC Encode,0x00200000,2,1,RoxioSmartAVCenc.ax,7.05.0000.0000
              Sonic MPEG-4 Video Decoder,0x00200000,1,1,sonic765m4vd.ax,7.05.0000.46181
              MainConcept AMR Decoder,0x00800000,1,1,mc_dec_amr_ds.ax,8.05.0000.14265
              Ulead Push Source Filter,0x00000000,0,0,,
              Ulead Sub-Picture Push Source Filter,0x00000000,0,0,,
              Ulead DVSD Push Source Filter,0x00000000,0,0,,
              MainConcept AAC Decoder,0x00800000,1,1,mc_dec_aac_ds.ax,8.05.0000.14265
              ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,12.02.0001.0082
              ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,12.02.0001.0082
              DV V/A Source Filter,0x00000000,0,0,,
              Sonic AMR Decoder,0x00200000,1,1,sonic765amrd.ax,7.03.0000.46181
              Sonic Cinemaster® Audio Decoder 4.3,0x005ffffe,1,1,CinemasterAudio.DLL,4.03.0000.0238
              VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0088
              DS Video Buffer Filter,0x00200000,1,1,DSBuffer_Video.ax,2.01.0041.0000
              Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,5.00.0000.0134
              MainConcept Color Space Converter,0x00600000,1,1,mc_trans_video_colorspace_ds.ax,8.05.0000.14265
              MainConcept MP4 Demultiplexer,0x00800101,1,2,mc_demux_mp4_ds.ax,8.05.0000.14265
              ROXIO InputSelectorNew 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
              MainConcept Layer II Audio Decoder,0x00600000,1,1,mc_dec_mpa_ds.ax,8.05.0000.14265
              LVMWriter,0x00200000,1,0,LVMWriter.ax,12.02.0001.0082
              MainConcept AAC Encoder,0x00100000,1,1,mc_enc_aac_ds.ax,8.00.0000.43595
              Ulead Video Deinterlace Filter,0x00000000,0,0,,
              ROXIO QuickGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO SceneRecorder 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO Video Resampler 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              DV V/A ACM Source Filter,0x00000000,0,0,,
              Sonic AVC/H.264 Video Decoder,0x00800000,1,2,sonic765avcvd.ax,7.05.0000.46181
              ROXIO VCFHDVSceneDetect 1.0,0x00200000,2,1,RoxVideo.ax,12.02.0001.0082
              ROXIO Video VCFLooper 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              DV Video Source Filter,0x00000000,0,0,,
              AVS Video Out,0x00200000,0,1,AVSVideoOutFilter3.ax,1.00.0000.0248
              Sonic MPEG Demultiplexer,0x00200000,1,2,sonic765mpgdmx.ax,7.03.0000.46181
              ROXIO ColorSpace Converter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              MainConcept (Consumer) AVC/H.264 Video Decoder,0x00400000,1,2,,
              VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0088
              ROXIO DV Scene Detector Tee 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Roxio AMR File Writer,0x00000000,0,0,,
              XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
              ROXIO AudioGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO FLV Splitter,0x00200000,1,1,RoxFlvSplitter.ax,1.00.0000.0001
              Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,12.02.0001.0082
              Ulead DV Scene Detect,0x00000000,0,0,,
              ROXIO Deinterlace 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,RoxVideo.ax,12.02.0001.0082
              ROXIO Pin Tee,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,12.02.0001.0082
              SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0008.0000
              SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0008.0000
              ROXIO VideoInfo Transcoder 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,12.02.0001.0082
              Media Analyser,0x00200000,1,2,mediaanalyser.ax,12.02.0001.0082
              File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
              ROXIO Field Combiner 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Video decoder 2,0x00000000,0,0,,
              MainConcept Audio Converter,0x00200000,1,1,mc_trans_audio_converter_ds.ax,8.05.0000.14265
              MainConcept Audio Resampler,0x00200000,1,1,mc_trans_audio_samplerate_ds.ax,8.05.0000.14265
              ROXIO Video Effect 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              InterVideo Audio Decoder,0x00400000,1,1,iviaudio.ax,10.00.0005.0828
              Sonic AAC Decoder,0x00200000,1,1,sonic765daac.ax,7.06.0000.46181
              Dib Output,0x00000000,0,0,,
              Dib Receive,0x00000000,0,0,,
              Sonic MP4 Demultiplexer,0x00200000,1,2,sonic765mp4demux.ax,7.07.0000.46181
              VCGImageSource,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0088
              ROXIO VideoTransition 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              PSI Parser,0x00200000,0,0,RoxVideo.ax,12.02.0001.0082
              Intel® Mux Renderer,0x00200000,2,0,IntelMux.dll,2.01.0041.0000
              Menu Source Bitmap Filter,0x00200000,0,1,MenuDShowSource11.ax,12.02.0001.0099
              MainConcept AVC/H.264 Video Decoder,0x00800001,1,2,mc_dec_avc_ds.ax,8.05.0000.14265
              Ulead OggVorbis Encoder,0x00400000,1,1,ulOggVorbisEncoderFilter.ax,1.00.0000.0001
              Ulead MPEG Transcoder,0x00000000,0,0,,
              ULead Infinite Pin Tee,0x00200000,1,1,UInfTee.ax,1.00.0000.0011
              Roxio Smart AVC Video Decode,0x00800000,1,2,RoxioSmartAVCdec.ax,7.05.0000.0000
              Ulead MPEG-4 Encoder,0x00000000,0,0,,
              Ulead MPEG-4 Splitter,0x00000000,0,0,,
              Ulead MPEG-4 Audio Decoder,0x00000000,0,0,,
              Ulead MPEG-4 Video Decoder,0x00000000,0,0,,
              Ulead AMR Audio Decoder,0x00000000,0,0,,
              Ulead MPEG-4 ASP Video Decoder,0x00000000,0,0,,
              MainConcept Frame Rate Converter,0x00400000,1,1,mc_trans_video_framerate_ds.ax,8.05.0000.14265
              ROXIO BDAV Smart Render 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Audio decoder 2,0x00200001,1,1,ulDVDAudio.ax,2.00.0000.0057
              ROXIO ListImage Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Sonic MPEG-2 Video Decoder,0x00200000,2,2,sonic765m2vd.ax,7.05.0000.46181
              ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Parser,0x00000000,0,0,,
              MainConcept MPEG-2 Video Decoder,0x00800001,2,2,mc_dec_mp2v_ds.ax,8.05.0000.14265
              Roxio AMR Splitter,0x00000000,0,0,,
              MainConcept ImageScaler,0x00400000,1,1,mc_trans_video_imagescaler_ds.ax,8.05.0000.14265
              Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,12.02.0001.0082
              Sonic Cinemaster® VideoDecoder 4.3 (EMC12),0x005ffffe,2,2,CinemasterVideo.DLL,4.03.0001.0274
              Sonic Stream Parser,0x00200000,1,2,sonic765mpgdmx.ax,7.03.0000.46181
              ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              MainConcept Sink Filter,0x00200000,1,0,mc_render_fileindex_ds.ax,8.05.0000.14265
              Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,4.03.0000.0131
              Ulead MPEG Splitter,0x00200002,1,2,ulspmpeg.ax,1.00.0000.0147
              Ulead MPEG Audio Decoder,0x00400000,1,1,ulDVDAudio.ax,2.00.0000.0057
              Ulead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0090
              Ulead MPEG Encoder,0x00000000,0,0,,
              Ulead MPEG Audio Encoder,0x00200000,1,1,uleaMPEG.ax,1.00.0000.0022
              Ulead MPEG Muxer,0x00000000,0,0,,
              ULead File Writer,0x00000000,0,0,,
              ULead File Source (Async.),0x00400000,0,1,ulasync.ax,1.00.0000.0018
              Ulead H264 Decoder,0x00000000,0,0,,
              WD Audio Filter,0x00200000,0,1,WDAudioFilter.dll,2.01.0041.0000
              ROXIO Field Splitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              ImageSource,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TitleSource,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Camera Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              Techsmith Quicktime MOV Source,0x00600000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Sound Effects Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Flv Key Frame Setter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Floating Point Wave Filter,0x003fffff,1,1,CamtasiaFilters.dll,7.01.0001.1785
              Roxio FLV Video Decoder,0x00800000,1,1,RoxFLVDecoder.ax,1.00.0000.0001
              ROXIO VCFStationLogo 1.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
              ROXIO Pan Zoom 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFAlphaSplitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DV SubTitle Filter,0x00000000,0,0,,
              WDSource Filter,0x00200000,0,1,WDSourceFilter.dll,2.01.0041.0000
              ROXIO AC3 (5.1) Encoder,0x00200000,1,1,RoxioAC3EncEMC12.dll,1.00.0001.0004
              ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              LAME Audio Encoder,0x00100000,2,1,lame_dshow.ax,1.00.0054.50801
              ROXIO Scene Detector 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVB Parser,0x00000000,0,0,,
              Ulead Audio Dual Channel Filter,0x00000000,0,0,,
              ROXIO InputSelector 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead OggVorbis Decoder,0x00400000,1,1,ulOggVorbisDecoderFilter.ax,1.00.0000.0001
              ROXIO QT Source,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Intel®WiDi H264 encoder,0x00200000,1,1,h264_enc_filter.dll,
              MainConcept MPEG-4 Video Decoder,0x00800000,1,1,mc_dec_mp4v_ds.ax,8.05.0000.14265
              VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0088
              ROXIO VideoCombine 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              iZotope Vocal Enhancement,0x00200000,1,1,iZotope_VocalEnhancement.dll,1.00.0000.0024
              iZotope Consumer Restoration,0x00200000,1,1,iZotope_ConsumerRestoration.dll,1.00.0000.0024
              Video Compressors:
              Ligos MPEG-2 Encoder (Intel) v1.9-MT,0x00000000,1,1,LigosDMOVid.dll,2.01.0041.0000
              Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7601.17514
              TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
              XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
              Audio Compressors:
              DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.06.7601.17713
              DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.06.7601.17713
              MPEG Audio Layer3,0x00200000,1,1,quartz.dll,6.06.7601.17713
              Microphone (4- Jabra PRO 9470),0x00200000,0,0,qcap.dll,6.06.7601.17514
              Internal Microphone (Conexant 2,0x00200000,0,0,qcap.dll,6.06.7601.17514
              Microphone (HD Pro Webcam C910),0x00200000,0,0,qcap.dll,6.06.7601.17514
              PBDA CP Filters:
              Midi Renderers:
              ,0x00000000,0,0,,
              Conexant HD Audio capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              ,0x00000000,0,0,,
              HD Pro Webcam C910,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              Logitech HD Pro Webcam C910,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
              Integrated Camera,0x00200000,0,1,ksproxy.ax,6.01.7601.17514
              Jabra PRO 9470,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
              ,0x00000000,0,0,,
              ,0x00000000,0,0,,
              Conexant HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              MM-1,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              BDA CP/CA Filters:
              Audio Renderers:
              Speakers (MM-1),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DELL U2711-2 (NVIDIA High Defin,0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: DELL U2711-2 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (4- Jabra PRO 9470),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (Conexant 20672 SmartAudio HD),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (MM-1),0x00200000,1,0,quartz.dll,6.06.7601.17713
              Speakers (Conexant 20672 SmartA,0x00200000,1,0,quartz.dll,6.06.7601.17713
                Quality Flags: 2576
                  Enabled:
                  Force throttling
                  Allow scaling
                  Enabled:
                  Force throttling
                  Allow batching
                  Force scaling
                PowerFlags: 1424
                  Enabled:
                  Force throttling
                  Allow batching
                  Force scaling
              • 4. Re: Video investigation with Flash Player 11.2.202.228
                KenDude
                1 - Video with horizontal green bars or no video at all with green garbage
                2 - How do I disable Flash's hardware acceleration?
                3 - This video doesn't play (wait until after the commercial that plays first) : http://www.bing.com/videos/watch/video/man-launches-lego-shuttle-into-space/1jr25i6hr?q=di scovery%20science&from=en-us_msnhp&rel=msn&cpkey=6873d267-6f7a-4e16-b89b-3aaa1b11fa25%7cdi scovery+science%7cmsn%7c%7c
                Nvidia Driver - 285.66
                4 - DXDIAG Report:
                System Information
                Time of this report: 4/13/2012, 15:15:49
                       Machine name: KENPC12
                   Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
                           Language: English (Regional Setting: English)
                System Manufacturer: System manufacturer
                       System Model: System Product Name
                               BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
                          Processor: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4 CPUs), ~3.3GHz
                             Memory: 8192MB RAM
                Available OS Memory: 8168MB RAM
                          Page File: 2502MB used, 13830MB available
                        Windows Dir: C:\Windows
                    DirectX Version: DirectX 11
                DX Setup Parameters: Not found
                    DWM DPI Scaling: Disabled
                DxDiag Notes
                      Display Tab 1: No problems found.
                        Sound Tab 1: No problems found.
                        Sound Tab 2: No problems found.
                          Input Tab: No problems found.
                DirectX Debug Levels
                Direct3D:    0/4 (retail)
                DirectDraw:  0/4 (retail)
                DirectInput: 0/5 (retail)
                DirectMusic: 0/5 (retail)
                DirectPlay:  0/9 (retail)
                DirectSound: 0/5 (retail)
                DirectShow:  0/6 (retail)
                Display Devices
                          Card name: NVIDIA GeForce GTX 570
                          Chip type: GeForce GTX 570
                         Device Key: Enum\PCI\VEN_10DE&DEV_1086&SUBSYS_15733842&REV_A1
                     Display Memory: 4064 MB
                   Dedicated Memory: 1248 MB
                      Shared Memory: 2815 MB
                       Current Mode: 1920 x 1080 (32 bit) (60Hz)
                       Monitor Name: Generic PnP Monitor
                      Monitor Model: HP 2511
                         Monitor Id: HWP293C
                        Native Mode: 1920 x 1080(p) (60.000Hz)
                        Output Type: DVI
                Driver File Version: 8.17.0012.8566 (English)
                     Driver Version: 8.17.12.8566
                        DDI Version: 11
                       Driver Model: WDDM 1.1
                   Driver Date/Size: 10/20/2011 04:50:00, 15694144 bytes
                        WHQL Logo'd: Yes
                    WHQL Date Stamp:
                  Device Identifier: {D7B71E3E-53C6-11CF-847A-7F351FC2C535}
                          Vendor ID: 0x10DE
                          Device ID: 0x1086
                          SubSys ID: 0x15733842
                        Revision ID: 0x00A1
                Driver Strong Name: oem37.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.8566:pci\ven_10de&dev_1086
                     Rank Of Driver: 00E62001
                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                       D3D9 Overlay: Supported
                            DXVA-HD: Supported
                       DDraw Status: Enabled
                         D3D Status: Enabled
                         AGP Status: Enabled
                Sound Devices
                            Description: Speakers (Realtek High Definition Audio)
                Default Sound Playback: Yes
                Default Voice Playback: Yes
                            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438410&REV_1003
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            Driver Name: RTKVHD64.sys
                         Driver Version: 6.00.0001.6251 (English)
                            WHQL Logo'd: Yes
                          Date and Size: 11/23/2010 05:16:56, 2565736 bytes
                            Other Files:
                        Driver Provider: Realtek Semiconductor Corp.
                         HW Accel Level: Basic
                              Cap Flags: 0xF1F
                    Min/Max Sample Rate: 100, 200000
                Static/Strm HW Mix Bufs: 1, 0
                Static/Strm HW 3D Bufs: 0, 0
                              HW Memory: 0
                       Voice Management: No
                EAX(tm) 2.0 Listen/Src: No, No
                   I3DL2(tm) Listen/Src: No, No
                Sensaura(tm) ZoomFX(tm): No
                            Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
                Default Sound Playback: No
                Default Voice Playback: No
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            WHQL Logo'd: Yes
                            Other Files:
                              Cap Flags: 0xF1F
                              HW Memory: 0
                            Description: Realtek Digital Output (Realtek High Definition Audio)
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            WHQL Logo'd: Yes
                            Other Files:
                              Cap Flags: 0xF1F
                              HW Memory: 0
                Sound Capture Devices
                DirectInput Devices
                      Device Name: Mouse
                         Attached: 1
                    Controller ID: n/a
                Vendor/Product ID: n/a
                        FF Driver: n/a
                      Device Name: Keyboard
                         Attached: 1
                    Controller ID: n/a
                        FF Driver: n/a
                      Device Name: HID-compliant consumer control device
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0xFEEB, 0xDEEF
                        FF Driver: n/a
                      Device Name: Mass Storage Device
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0x058F, 0x6364
                        FF Driver: n/a
                      Device Name: EP2
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0x05A4, 0x9760
                        FF Driver: n/a
                      Device Name: EP2
                         Attached: 1
                    Controller ID: 0x0
                        FF Driver: n/a
                Poll w/ Interrupt: No
                USB Devices
                + USB Root Hub
                | Matching Device ID: usb\root_hub20
                | Service: usbhub
                +-+ Generic USB Hub
                | | Vendor/Product ID: 0x8087, 0x0024
                | | Matching Device ID: usb\class_09
                | | Service: usbhub
                Gameport Devices
                PS/2 Devices
                | Service: kbdhid
                + Terminal Server Keyboard Driver
                | Matching Device ID: root\rdp_kbd
                | Upper Filters: kbdclass
                | Service: TermDD
                | Vendor/Product ID: 0x1BCF, 0x0002
                | Service: mouhid
                + Terminal Server Mouse Driver
                | Matching Device ID: root\rdp_mou
                | Upper Filters: mouclass
                | Service: TermDD
                Disk & DVD/CD-ROM Drives
                      Drive: C:
                Free Space: 21.3 GB
                Total Space: 57.1 GB
                File System: NTFS
                      Model: OCZ-AGILITY3 ATA Device
                      Drive: D:
                Free Space: 889.1 GB
                Total Space: 953.9 GB
                File System: NTFS
                      Model: ST1000DM003-9YN162 ATA Device
                      Drive: E:
                      Model: HL-DT-ST BD-RE  WH12LS39 ATA Device
                System Devices
                     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
                Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_844D1043&REV_05\3&11583659&0&D0
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
                Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_844D1043&REV_B5\3&11583659&0&E1
                   Driver: n/a
                     Name: ASMedia XHCI Controller
                Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&108ABD8A&0&00E4
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
                Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_844D1043&REV_05\3&11583659&0&E8
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
                Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_844D1043&REV_B5\3&11583659&0&E0
                   Driver: n/a
                     Name: JMicron JMB36X Controller
                Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&20221DEA&0&00E3
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
                Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_844D1043&REV_05\3&11583659&0&FB
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family 6 Port SATA AHCI Controller - 1C02
                Device ID: PCI\VEN_8086&DEV_1C02&SUBSYS_844D1043&REV_05\3&11583659&0&FA
                   Driver: n/a
                     Name: NVIDIA GeForce GTX 570
                Device ID: PCI\VEN_10DE&DEV_1086&SUBSYS_15733842&REV_A1\4&80E7924&0&0008
                   Driver: n/a
                     Name: High Definition Audio Controller
                Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_84361043&REV_05\3&11583659&0&D8
                   Driver: n/a
                     Name: Intel(R) 82579V Gigabit Network Connection
                Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_849C1043&REV_05\3&11583659&0&C8
                   Driver: n/a
                Device ID: PCI\VEN_10DE&DEV_0E09&SUBSYS_15733842&REV_A1\4&80E7924&0&0108
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_844D1043&REV_B5\3&11583659&0&E7
                   Driver: n/a
                     Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
                Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_844D1043&REV_09\3&11583659&0&08
                   Driver: n/a
                     Name: Intel(R) 82801 PCI Bridge - 244E
                Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_844D1043&REV_B5\3&11583659&0&E6
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_844D1043&REV_B5\3&11583659&0&E4
                   Driver: n/a
                     Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0100
                Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_844D1043&REV_09\3&11583659&0&00
                   Driver: n/a
                     Name: Intel(R) Z68 Express Chipset Family LPC Interface Controller - 1C44
                Device ID: PCI\VEN_8086&DEV_1C44&SUBSYS_844D1043&REV_05\3&11583659&0&F8
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
                Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_844D1043&REV_B5\3&11583659&0&E3
                   Driver: n/a
                     Name: PCI standard PCI-to-PCI bridge
                Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_10801B21&REV_01\4&2B6CC657&0&00E6
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_844D1043&REV_04\3&11583659&0&B0
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C14&SUBSYS_844D1043&REV_B5\3&11583659&0&E2
                   Driver: n/a
                Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&DDEC341&0&00E1
                   Driver: n/a
                DirectShow Filters
                DirectShow Filters:
                WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
                CyberLink AVCHD Navigator,0x00600000,0,3,CLAVCHDNav.ax,2.00.0000.3405
                CyberLink Audio Effect (PDVD9),0x00200000,1,1,ClAudFx.ax,6.00.0000.7209
                CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
                CyberLink Editing Service 4.5 (Source),0x00200000,0,2,CLEdtKrn.dll,4.05.0000.3103
                Cyberlink Track Filter,0x00200000,1,1,YCTrack.ax,1.01.0000.0222
                CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,SE_CLEdtDemuxer.ax,1.02.0001.7003
                CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
                PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
                PP TV Audio Decoder,0x00200000,1,1,claudTV.ax,6.00.0000.4104
                DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
                CyberLink Audio Decoder(PDVD9 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3816
                CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
                Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                CyberLink TimeStretch Filter (PDVD9),0x00200000,1,1,clauts.ax,2.00.0000.2403
                CyberLink Audio Spectrum Analyzer(PDVD9 UPnP),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
                WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.5113
                CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
                CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.7826
                Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.4602
                Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.02.0001.3026
                AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                CyberLink Tzan Filter (PDVD9),0x00200000,1,1,CLTzan.ax,3.05.0000.3119
                PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.0000.5608
                StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.4301
                MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                PP Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
                MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
                VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
                PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
                Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                YC_EVRWindow,0x00200000,0,0,YCEvr.dll,1.00.0001.4504
                SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP Dump Filter,0x00200000,1,0,CLDump.ax,3.00.0000.10814
                CyberLink Push-Mode CLStream(PDVD9),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1627
                CyberLink MPEG-4 Splitter,0x00200000,1,2,SE_clm4splt.ax,1.00.0000.5210
                Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
                CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
                Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.1731
                CyberLink Audio Decoder (PDVD9),0x00201000,1,1,Claud.ax,8.04.0000.3223
                Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
                P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
                MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                CyberLink Mux Push Source,0x00200000,0,1,SE_CLMuxPushSrc.ax,1.00.0000.3314
                PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
                CyberLink Demultiplexer(PDVD9 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3022
                DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
                PP TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1917
                PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
                CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
                PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.6525
                Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
                CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
                PP Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1926
                Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.01.0000.2928
                CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.2906
                CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
                PP MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.02.0000.2424
                CyberLink Video/SP Decoder(PDVD9 UPnP),0x00200000,2,3,CLVSD.ax,6.01.0000.0916
                ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,1.00.0000.3702
                Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
                Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                CyberLink MPEGV Analyzer,0x00200000,1,1,SE_CLMPEGVAnalyzer.ax,1.00.0000.2709
                CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
                CyberLink SBE Source Filter,0x00200000,0,0,CLSBESrc.ax,1.00.0000.3628
                Cyberlink Dump Dispatch Filter,0x00200000,1,0,SE_CLDumpDispatch.ax,1.03.0000.1003
                VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
                CyberLink Stamp Effect,0x00200000,1,1,ppStampEffect.ax,1.00.0000.4125
                VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.7830
                File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
                CyberLink Streamming Filter(PDVD9),0x00200000,0,1,CLStream.ax,1.01.0000.2902
                iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
                CyberLink TL MPEG Splitter,0x00200000,1,2,SE_CLTLMSplter.ax,3.02.0000.4805
                CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
                PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.01.0000.3122
                PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
                Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
                CyberLink DVD Navigator (PDVD9),0x00200000,0,3,CLNavX.ax,8.01.0000.2006
                CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
                CyberLink TL MPEG Splitter,0x00200000,1,2,YCTLMSplter.ax,3.02.0000.2219
                CyberLink Audio Decoder,0x00200000,1,1,SE_claud.ax,8.01.0036.4505
                CyberLink WMV/WMA Demux(PDVD9),0x00600000,1,2,CLWMFDemux.ax,1.00.0000.1302
                CyberLink MPEG-4 Splitter (PDVD9),0x00200000,1,2,clm4splt.ax,1.01.0000.2911
                PP Audio Decoder,0x00200000,1,1,CLAud.ax,8.03.0000.2417
                CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
                DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
                CyberLink SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.4022
                PP MPEG Splitter,0x00200000,1,2,ppSplter.ax,3.03.0000.1917
                Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
                PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1805
                CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,2.00.0000.1521
                CyberLink H.264/AVC Decoder,0x00200000,1,2,cl264dec.ax,2.01.0000.1708
                CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.7246.2926
                PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
                RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
                CyberLink Video Decoder (PDVD9),0x00200000,1,2,CLCvd.ax,1.00.7246.2926
                SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                CyberLink WebCamera NULL Render,0x00200000,0,0,YCWEBCAMERARENDER.ax,2.00.10175.3910
                MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                CyberLink Video Regulator,0x00200000,1,1,YCRgl.ax,3.00.0000.1228
                CyberLink MPEGV Analyzer,0x00200000,1,1,CLMPEGVAnalyzer.ax,1.00.0000.3618
                StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
                CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
                Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
                AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
                PP Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1716
                PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.2617
                AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                CyberLink WMV Dumper,0x00200000,2,0,YCWMVDump.ax,1.00.0000.2625
                CyberLink SBE Filter,0x00200000,0,0,CLSBE.ax,1.00.0000.3628
                CyberLink MPEG Muxer,0x00200000,2,1,SE_MpgMux.ax,5.01.0000.2014
                Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
                CyberLink MPEG-4 Muxer,0x00200000,1,1,SE_clm4muxer.ax,1.00.0000.3920
                PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
                CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
                P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
                PP MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,6.04.0001.2702
                Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.4024
                Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                CyberLink Matroska Splitter (PDVD9),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1204
                BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
                CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.6622
                CyberLink MPEG-4 Muxer,0x00200000,1,1,clm4muxer.ax,1.00.0000.4724
                WDM Streaming Tee/Splitter Devices:
                Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Video Compressors:
                WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                Audio Compressors:
                WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
                CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
                PBDA CP Filters:
                PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                Midi Renderers:
                Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
                WDM Streaming Capture Devices:
                Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                WDM Streaming Rendering Devices:
                Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                BDA Network Providers:
                Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                Video Capture Sources:
                CyberLink Web Camera Filter,0x00200000,0,1,YCWebCameraSource.ax,2.00.10175.3910
                Multi-Instance Capable VBI Codecs:
                BDA Transport Information Renderers:
                BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
                MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                BDA CP/CA Filters:
                Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
                Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                WDM Streaming Communication Transforms:
                Audio Renderers:
                Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
                CyberLink Audio Renderer (PDVD9),0x00200000,1,0,cladr.ax,7.00.0000.3121
                Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
                DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                DirectSound: Realtek Digital Output(Optical) (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
                Realtek Digital Output(Optical),0x00200000,1,0,quartz.dll,6.06.7601.17713
                EVR Power Information
                Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                  Quality Flags: 2576
                    Enabled:
                    Force throttling
                    Allow half deinterlace
                    Allow scaling
                    Decode Power Usage: 100
                  Balanced Flags: 1424
                    Enabled:
                    Force throttling
                    Allow batching
                    Force half deinterlace
                    Force scaling
                    Decode Power Usage: 50
                  PowerFlags: 1424
                    Enabled:
                    Force throttling
                    Allow batching
                    Force scaling
                    Decode Power Usage: 0
                • 5. Re: Video investigation with Flash Player 11.2.202.228
                  KenDude Level 1
                  I just upgraded to drivers 296.1 from Nvidia and so far that seems to have fixed the problem.
                  • 6. Re: Video investigation with Flash Player 11.2.202.228
                    stevemidgley
                    1. What problem are you encountering?
                      1. Green bar at top of all videos. Apparent "3-d like" ghosting (double images of different colors) in the image itself
                    2. Try disabling Flash's hardware acceleration.  Does this fix the bug?
                      1. Yes - this fixed the problem.
                    3. What URL did you use to view video?  Please be specific (ie. we need something more than just "any youtube video")
                      1. I noticed this problem on every flash video I attempted to play but here's a non youtube example that was causing the problem:
                      2. http://www.amazon.com/Merantau/dp/B004HG44Y6 (playing the free trailer)
                    4. Please post your DxDiag report.  See these steps for details for creating the DxDiag.txt file.  Open this file and copy/paste the contents to your reply.
                      1. Machine is a T420s Lenovo laptop running windows 7 32 bit - dxdiag follows..
                    System Information
                    Time of this report: 4/15/2012, 19:41:06
                           Machine name: [suppressed]
                       Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
                                   BIOS: Default System BIOS
                              Processor: Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
                                 Memory: 4096MB RAM
                    Available OS Memory: 2980MB RAM
                              Page File: 1532MB used, 4426MB available
                       User DPI Setting: 120 DPI (125 percent)
                         DxDiag Version: 6.01.7601.17514 32bit Unicode
                    DxDiag Notes
                    Display Devices
                         Display Memory: 2227 MB
                          Shared Memory: 1234 MB
                           Current Mode: 1680 x 1050 (32 bit) (59Hz)
                          Monitor Model: VX2025wm
                             Monitor Id: VSCE51D
                            Native Mode: 1680 x 1050(p) (59.954Hz)
                            Output Type: DVI
                            Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
                            DDI Version: 11
                       Driver Date/Size: 8/12/2011 22:43:00, 12007528 bytes
                            WHQL Logo'd: Yes
                        WHQL Date Stamp:
                              Vendor ID: 0x10DE
                              Device ID: 0x1056
                            Revision ID: 0x00A1
                    Driver Strong Name: oem104.inf:NVIDIA_SetA_Devices.NTx86.6.1:Section097:8.17.12.7593:pci\ven_10de&dev_1056&su bsys_21d317aa
                         Rank Of Driver: 00E60001
                                DXVA-HD: Supported
                             D3D Status: Enabled
                             AGP Status: Enabled
                           Monitor Name: ViewSonic VG2230wm SERIES
                          Monitor Model: VG2230wm
                             Monitor Id: VSCA21E
                            Output Type: DVI
                            DDI Version: 11
                            WHQL Logo'd: Yes
                        WHQL Date Stamp:
                              Vendor ID: 0x10DE
                              Device ID: 0x1056
                            Revision ID: 0x00A1
                                DXVA-HD: Supported
                             D3D Status: Enabled
                             AGP Status: Enabled
                    Sound Devices
                            Manufacturer ID: 1
                                 Product ID: 100
                                       Type: WDM
                                Driver Name: CHDRT32.sys
                             Driver Version: 8.32.0023.0000 (English)
                                WHQL Logo'd: Yes
                              Date and Size: 2/9/2011 15:49:54, 1281152 bytes
                                Other Files:
                                  Cap Flags: 0xF1F
                                  HW Memory: 0
                      Default Sound Capture: Yes
                      Default Voice Capture: Yes
                                  Cap Flags: 0x1
                               Format Flags: 0xFFFFF
                    DirectInput Devices
                          Device Name: Mouse
                             Attached: 1
                        Controller ID: n/a
                            FF Driver: n/a
                             Attached: 1
                        Controller ID: n/a
                            FF Driver: n/a
                          Device Name: Microsoft Hardware USB Mouse
                             Attached: 1
                        Controller ID: 0x0
                    Vendor/Product ID: 0x045E, 0x00D1
                            FF Driver: n/a
                          Device Name: Natural® Ergonomic Keyboard 4000
                             Attached: 1
                        Controller ID: 0x0
                    Vendor/Product ID: 0x045E, 0x00DB
                            FF Driver: n/a
                    USB Devices
                    + USB Root Hub
                    | Vendor/Product ID: 0x8086, 0x1C26
                    | Service: usbhub
                    | Driver: usbhub.sys, 3/24/2011 22:58:37, 258560 bytes
                    | Driver: usbd.sys, 3/24/2011 22:57:53, 5888 bytes
                    +-+ Generic USB Hub
                    | | Service: usbhub
                    Gameport Devices
                    PS/2 Devices
                    + Standard PS/2 Keyboard
                    | Matching Device ID: *pnp0303
                    | Service: i8042prt
                    | Driver: i8042prt.sys, 7/13/2009 19:11:24, 80896 bytes
                    | Driver: kbdclass.sys, 7/13/2009 21:20:36, 42576 bytes
                    + Microsoft USB Natural Ergonomic Keyboard 4000 (IntelliType Pro)
                    | Matching Device ID: hid\vid_045e&pid_00db&mi_00
                    | Service: kbdhid
                    | Driver: kbdhid.sys, 11/20/2010 17:29:03, 28160 bytes
                    | Service: TermDD
                    | Upper Filters: SynTP
                    | Service: i8042prt
                    + Microsoft USB Comfort Optical Mouse 3000 (IntelliPoint)
                    | Matching Device ID: hid\vid_045e&pid_00d1&col02
                    | Upper Filters: Point32
                    | Service: mouhid
                    | Driver: point32.sys, 8/1/2011 16:56:42, 40936 bytes
                    | Driver: mouhid.sys, 7/13/2009 19:45:08, 26112 bytes
                    | Driver: mouclass.sys, 7/13/2009 21:20:44, 41552 bytes
                    | Driver: wdfcoinstaller01009.dll, 8/7/2009 11:49:36, 1461992 bytes
                    | Service: TermDD
                    | Driver: termdd.sys, 11/20/2010 17:29:03, 53120 bytes
                    | Driver: sermouse.sys, 7/13/2009 19:45:08, 19968 bytes
                          Drive: C:
                    Free Space: 23.0 GB
                    Total Space: 121.1 GB
                    File System: NTFS
                          Model: SAMSUNG MZ7PA128HMCD-010L1 ATA Device
                          Drive: M:
                    Free Space: 23.0 GB
                    File System: NTFS
                          Model: n/a
                          Drive: S:
                    Free Space: 23.0 GB
                    File System: NTFS
                          Model: n/a
                          Drive: W:
                    Free Space: 23.0 GB
                    File System: NTFS
                          Model: n/a
                          Drive: X:
                    Free Space: 23.0 GB
                    File System: NTFS
                          Model: n/a
                          Drive: E:
                          Model: HL-DT-ST DVDRAM GU40N ATA Device
                         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 17:29:03, 108544 bytes
                    System Devices
                         Name: Renesas Electronics USB 3.0 Host Controller
                       Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0032.0000 (English), 12/10/2010 14:50:12, 141440 bytes
                         Name: Standard AHCI 1.0 Serial ATA Controller
                       Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.01.7601.17514 (English), 11/20/2010 17:29:03, 28032 bytes
                       Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 21:19:03, 42560 bytes
                       Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 21:26:15, 21584 bytes
                       Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 17:29:03, 132992 bytes
                         Name: Standard Enhanced PCI to USB Host Controller
                       Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/24/2011 22:57:58, 43008 bytes
                       Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/24/2011 22:58:07, 284672 bytes
                       Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/24/2011 22:58:37, 258560 bytes
                         Name: Intel(R) 82579LM Gigabit Network Connection
                       Driver: C:\Windows\system32\DRIVERS\e1c6232.sys, 11.15.0016.0000 (English), 1/12/2012 00:28:58, 282792 bytes
                       Driver: C:\Windows\system32\e1c6232.din, 12/23/2009 21:12:56, 3109 bytes
                       Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 11:05:46, 28792 bytes
                       Driver: C:\Windows\system32\NicInstC.dll, 9.10.0074.0000 (English), 11/7/2011 13:28:56, 81600 bytes
                       Driver: C:\Windows\system32\e1cmsg.dll, 10.00.0099.0000 (English), 11/3/2011 11:54:02, 68264 bytes
                         Name: Intel(R) HD Graphics Family
                       Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 8.15.0010.2538 (English), 9/26/2011 02:26:04, 10857984 bytes
                       Driver: C:\Windows\system32\igdumd32.dll, 8.15.0010.2538 (English), 9/26/2011 02:30:20, 6323712 bytes
                       Driver: C:\Windows\system32\igfxcmrt32.dll, 9/26/2011 00:36:22, 171520 bytes
                       Driver: C:\Windows\system32\igfxcmjit32.dll, 9/26/2011 00:36:22, 1663488 bytes
                       Driver: C:\Windows\system32\IccLibDll.dll, 3/6/2011 21:07:58, 94208 bytes
                       Driver: C:\Windows\system32\igkrng600.bin, 3/6/2011 21:45:42, 963116 bytes
                       Driver: C:\Windows\system32\igcompkrng600.bin, 3/6/2011 21:45:44, 145804 bytes
                       Driver: C:\Windows\system32\igfcg600m.bin, 9/26/2011 02:21:02, 216000 bytes
                       Driver: C:\Windows\system32\igdde32.dll, 9/26/2011 02:20:52, 56832 bytes
                       Driver: C:\Windows\system32\iglhxs32.vp, 9/26/2011 03:06:12, 76432 bytes
                       Driver: C:\Windows\system32\iglhxo32.vp, 9/26/2011 00:36:22, 58683 bytes
                       Driver: C:\Windows\system32\iglhxc32.vp, 9/26/2011 00:36:22, 59244 bytes
                       Driver: C:\Windows\system32\iglhxg32.vp, 9/26/2011 00:36:22, 59020 bytes
                       Driver: C:\Windows\system32\iglhxa32.vp, 9/26/2011 00:36:22, 1074 bytes
                       Driver: C:\Windows\system32\iglhxa32.cpa, 9/26/2011 00:36:22, 1921265 bytes
                       Driver: C:\Windows\system32\iglhcp32.dll, 2.00.0002.0001 (English), 9/26/2011 00:36:22, 98304 bytes
                       Driver: C:\Windows\system32\iglhsip32.dll, 2.00.0002.0001 (English), 9/26/2011 00:36:22, 376832 bytes
                       Driver: C:\Windows\system32\hccutils.dll, 8.15.0010.2538 (English), 9/26/2011 00:38:34, 96256 bytes
                       Driver: C:\Windows\system32\igfxsrvc.dll, 9/26/2011 00:38:58, 57856 bytes
                       Driver: C:\Windows\system32\igfxsrvc.exe, 10/14/2011 00:42:20, 267544 bytes
                       Driver: C:\Windows\system32\igfxpph.dll, 9/26/2011 00:39:18, 306176 bytes
                       Driver: C:\Windows\system32\igfxcpl.cpl, 8.15.0010.2538 (English), 9/26/2011 00:39:08, 120320 bytes
                       Driver: C:\Windows\system32\igfxdev.dll, 8.15.0010.2538 (English), 9/26/2011 00:38:22, 294400 bytes
                       Driver: C:\Windows\system32\igfxdo.dll, 9/26/2011 00:38:40, 130048 bytes
                       Driver: C:\Windows\system32\igfxtray.exe, 10/14/2011 00:42:24, 142616 bytes
                       Driver: C:\Windows\system32\hkcmd.exe, 10/14/2011 00:42:10, 177432 bytes
                       Driver: C:\Windows\system32\igfxress.dll, 9/26/2011 00:38:00, 9030656 bytes
                       Driver: C:\Windows\system32\igfxpers.exe, 10/14/2011 00:42:16, 176408 bytes
                       Driver: C:\Windows\system32\igfxTMM.dll, 8.15.0010.2538 (English), 9/26/2011 00:39:16, 260608 bytes
                       Driver: C:\Windows\system32\TVWSetup.exe, 10/14/2011 00:42:32, 8198936 bytes
                       Driver: C:\Windows\system32\gfxSrvc.dll, 8.15.0010.2538 (English), 9/26/2011 00:38:26, 146944 bytes
                       Driver: C:\Windows\system32\GfxUI.exe, 10/14/2011 00:42:06, 4699416 bytes
                       Driver: C:\Windows\system32\GfxUI.exe.config, 9/26/2011 00:36:44, 151 bytes
                       Driver: C:\Windows\system32\IGFXDEVLib.dll, 9/26/2011 00:38:24, 4096 bytes
                       Driver: C:\Windows\system32\igfxext.exe, 8.15.0010.2538 (English), 10/14/2011 00:42:14, 188184 bytes
                       Driver: C:\Windows\system32\igfxexps.dll, 9/26/2011 00:39:10, 24576 bytes
                       Driver: C:\Windows\system32\igfxrara.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:40, 283136 bytes
                       Driver: C:\Windows\system32\igfxrchs.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:40, 280576 bytes
                       Driver: C:\Windows\system32\igfxrcht.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:42, 280576 bytes
                       Driver: C:\Windows\system32\igfxrdan.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:42, 283648 bytes
                       Driver: C:\Windows\system32\igfxrdeu.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:44, 284672 bytes
                       Driver: C:\Windows\system32\igfxrenu.lrc, 9/26/2011 00:38:00, 283648 bytes
                       Driver: C:\Windows\system32\igfxresn.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:52, 285184 bytes
                       Driver: C:\Windows\system32\igfxrfin.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:44, 284160 bytes
                       Driver: C:\Windows\system32\igfxrfra.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:44, 285184 bytes
                       Driver: C:\Windows\system32\igfxrheb.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:46, 283136 bytes
                       Driver: C:\Windows\system32\igfxrhrv.lrc, 9/26/2011 00:41:56, 284672 bytes
                       Driver: C:\Windows\system32\igfxrita.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:48, 284672 bytes
                       Driver: C:\Windows\system32\igfxrjpn.lrc, 9/26/2011 00:41:48, 281600 bytes
                       Driver: C:\Windows\system32\igfxrkor.lrc, 9/26/2011 00:41:48, 281088 bytes
                       Driver: C:\Windows\system32\igfxrnld.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:42, 284672 bytes
                       Driver: C:\Windows\system32\igfxrnor.lrc, 9/26/2011 00:41:50, 284160 bytes
                       Driver: C:\Windows\system32\igfxrplk.lrc, 9/26/2011 00:41:50, 284672 bytes
                       Driver: C:\Windows\system32\igfxrptb.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:50, 284160 bytes
                       Driver: C:\Windows\system32\igfxrptg.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:52, 284672 bytes
                       Driver: C:\Windows\system32\igfxrrom.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:58, 284672 bytes
                       Driver: C:\Windows\system32\igfxrrus.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:52, 284672 bytes
                       Driver: C:\Windows\system32\igfxrsky.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:56, 284672 bytes
                       Driver: C:\Windows\system32\igfxrslv.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:56, 284160 bytes
                       Driver: C:\Windows\system32\igfxrsve.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:54, 284160 bytes
                       Driver: C:\Windows\system32\igfxrtha.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:54, 283648 bytes
                       Driver: C:\Windows\system32\igfxrcsy.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:42, 284672 bytes
                       Driver: C:\Windows\system32\igfxrell.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:46, 285184 bytes
                       Driver: C:\Windows\system32\igfxrhun.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:46, 284160 bytes
                       Driver: C:\Windows\system32\igfxrtrk.lrc, 8.15.0010.2538 (English), 9/26/2011 00:41:54, 284160 bytes
                       Driver: C:\Windows\system32\Gfxres.ar-SA.resources, 9/26/2011 00:41:58, 156233 bytes
                       Driver: C:\Windows\system32\Gfxres.cs-CZ.resources, 9/26/2011 00:42:00, 133404 bytes
                       Driver: C:\Windows\system32\Gfxres.da-DK.resources, 9/26/2011 00:42:02, 128535 bytes
                       Driver: C:\Windows\system32\Gfxres.de-DE.resources, 9/26/2011 00:42:02, 137846 bytes
                       Driver: C:\Windows\system32\Gfxres.el-GR.resources, 9/26/2011 00:42:04, 198139 bytes
                       Driver: C:\Windows\system32\Gfxres.es-ES.resources, 9/26/2011 00:42:06, 137668 bytes
                       Driver: C:\Windows\system32\Gfxres.en-US.resources, 9/26/2011 00:41:38, 124056 bytes
                       Driver: C:\Windows\system32\Gfxres.fi-FI.resources, 9/26/2011 00:42:06, 132889 bytes
                       Driver: C:\Windows\system32\Gfxres.fr-FR.resources, 9/26/2011 00:42:08, 135626 bytes
                       Driver: C:\Windows\system32\Gfxres.he-IL.resources, 9/26/2011 00:42:08, 149009 bytes
                       Driver: C:\Windows\system32\Gfxres.hr-HR.resources, 9/26/2011 00:42:32, 131839 bytes
                       Driver: C:\Windows\system32\Gfxres.hu-HU.resources, 9/26/2011 00:42:10, 134384 bytes
                       Driver: C:\Windows\system32\Gfxres.it-IT.resources, 9/26/2011 00:42:12, 140216 bytes
                       Driver: C:\Windows\system32\Gfxres.ja-JP.resources, 9/26/2011 00:42:12, 153167 bytes
                       Driver: C:\Windows\system32\Gfxres.ko-KR.resources, 9/26/2011 00:42:14, 138727 bytes
                       Driver: C:\Windows\system32\Gfxres.nb-NO.resources, 9/26/2011 00:42:16, 128831 bytes
                       Driver: C:\Windows\system32\Gfxres.nl-NL.resources, 9/26/2011 00:42:16, 134412 bytes
                       Driver: C:\Windows\system32\Gfxres.pl-PL.resources, 9/26/2011 00:42:18, 133178 bytes
                       Driver: C:\Windows\system32\Gfxres.pt-BR.resources, 9/26/2011 00:42:20, 134836 bytes
                       Driver: C:\Windows\system32\Gfxres.pt-PT.resources, 9/26/2011 00:42:20, 133709 bytes
                       Driver: C:\Windows\system32\Gfxres.ro-RO.resources, 9/26/2011 00:42:34, 136603 bytes
                       Driver: C:\Windows\system32\Gfxres.ru-RU.resources, 9/26/2011 00:42:22, 182706 bytes
                       Driver: C:\Windows\system32\Gfxres.sk-SK.resources, 9/26/2011 00:42:24, 132788 bytes
                       Driver: C:\Windows\system32\Gfxres.sl-SI.resources, 9/26/2011 00:42:24, 128996 bytes
                       Driver: C:\Windows\system32\Gfxres.sv-SE.resources, 9/26/2011 00:42:26, 133846 bytes
                       Driver: C:\Windows\system32\Gfxres.th-TH.resources, 9/26/2011 00:42:28, 211303 bytes
                       Driver: C:\Windows\system32\Gfxres.tr-TR.resources, 9/26/2011 00:42:28, 135370 bytes
                       Driver: C:\Windows\system32\Gfxres.zh-CN.resources, 9/26/2011 00:42:30, 116348 bytes
                       Driver: C:\Windows\system32\Gfxres.zh-TW.resources, 9/26/2011 00:42:32, 117636 bytes
                       Driver: C:\Windows\system32\ig4icd32.dll, 9/26/2011 00:58:02, 13903360 bytes
                       Driver: C:\Windows\system32\igd10umd32.dll, 8.15.0010.2538 (English), 9/26/2011 01:53:10, 12340224 bytes
                       Driver: C:\Windows\system32\d3dx10_40.dll, 9.24.0950.2656 (English), 3/6/2011 21:07:58, 452440 bytes
                       Driver: C:\Windows\system32\igdumdx32.dll, 8.15.0010.2538 (English), 9/26/2011 02:19:20, 581120 bytes
                       Driver: C:\Windows\system32\igfxCoIn_v2538.dll, 1.02.0030.0000 (English), 9/26/2011 02:51:04, 81920 bytes
                         Name: SM Bus Controller
                       Driver: n/a
                         Name: PCI standard host CPU bridge
                       Driver: n/a
                       Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 17:29:03, 108544 bytes
                       Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 17:29:03, 153984 bytes
                         Name: Intel(R) Centrino(R) Ultimate-N 6300 AGN
                    Device ID: PCI\VEN_8086&DEV_4238&SUBSYS_11118086&REV_35\4&104CF0A&0&00E1
                       Driver: n/a
                         Name: PCI standard ISA bridge
                       Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 21:20:43, 13888 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 174184 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/12/2011 22:43:00, 309856 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 233064 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 6/1/2011 14:37:10, 4096 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 224360 bytes
                       Driver: C:\Program Files\NVIDIA Corporation\license.txt, 6/1/2011 14:37:06, 15511 bytes
                       Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 10755688 bytes
                       Driver: C:\Windows\system32\DRIVERS\nvpciflt.sys, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 23144 bytes
                       Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 8/12/2011 22:43:00, 57960 bytes
                       Driver: C:\Windows\system32\nvapi.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 2339432 bytes
                       Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 13011560 bytes
                       Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 5304424 bytes
                       Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 2082408 bytes
                       Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 2804840 bytes
                       Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 12007528 bytes
                       Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 300136 bytes
                       Driver: C:\Windows\system32\nvinfo.pb, 8/12/2011 22:43:00, 4215 bytes
                       Driver: C:\Windows\system32\nvinit.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 200808 bytes
                       Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 16468584 bytes
                       Driver: C:\Windows\system32\nvoptimusmft.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 326248 bytes
                       Driver: C:\Windows\system32\nvumdshim.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 696424 bytes
                       Driver: C:\Windows\system32\nvwgf2um.dll, 8.17.0012.7593 (English), 8/12/2011 22:43:00, 6558824 bytes
                       Driver: C:\Windows\system32\nvdispco3220150.dll, 2.00.0015.0000 (English), 8/12/2011 22:43:00, 899688 bytes
                       Driver: C:\Windows\system32\nvgenco3220103.dll, 2.00.0010.0003 (English), 8/12/2011 22:43:00, 875112 bytes
                         Name: PCI Serial Port
                       Driver: n/a
                         Name: Intel(R) Management Engine Interface
                       Driver: n/a
                    DirectShow Filters
                    DirectShow Filters:
                    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
                    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
                    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
                    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
                    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
                    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
                    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
                    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                    Video Compressors:
                    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Audio Compressors:
                    Audio Capture Sources:
                    PBDA CP Filters:
                    Midi Renderers:
                    Bluetooth Hands-free Audio,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
                    ,0x00000000,0,0,,
                    ,0x00000000,0,0,,
                    Google Camera Adapter 0,0x00000000,0,0,,
                    Google Camera Adapter 1,0x00000000,0,0,,
                    BDA CP/CA Filters:
                    Audio Renderers:
                      Quality Flags: 2576
                        Enabled:
                        Force throttling
                        Allow scaling
                        Enabled:
                        Force throttling
                        Allow batching
                        Force scaling
                      PowerFlags: 1424
                        Enabled:
                        Force throttling
                        Allow batching
                        Force scaling
                    • 7. Re: Video investigation with Flash Player 11.2.202.228
                      whatdotheyeat
                      http://www.youtube.com/watch?v=fxlqlozam_k&feature=youtu.be
                      1. What problem are you encountering? Green bar at the bottom. I've tried both night time and daytime vids. They all do the same thing. I updated my drivers before posting this.
                      2. Try disabling Flash's hardware acceleration.  Does this fix the bug? No
                      3. http://www.youtube.com/watch?v=fxlqlozam_k&feature=youtu.be
                      System Information
                      Time of this report: 4/16/2012, 13:43:54
                             Machine name: My-PC
                         Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.120305-0430)
                      System Manufacturer: Dell Inc.
                             System Model: Inspiron 530s
                                     BIOS: Phoenix - AwardBIOS v6.00PG
                                Processor: Pentium(R) Dual-Core  CPU      E5200  @ 2.50GHz (2 CPUs), ~2.5GHz
                                   Memory: 2036MB RAM
                                Page File: 1688MB used, 2624MB available
                           DxDiag Version: 7.00.6002.18107 32bit Unicode
                      DxDiag Notes
                            Display Tab 2: No problems found.
                      Display Devices
                              Card name: Intel(R) G33/G31 Express Chipset Family
                           Manufacturer: Intel Corporation
                              Chip type: Intel(R) GMA 3100
                               DAC type: Internal
                             Device Key: Enum\PCI\VEN_8086&DEV_29C2&SUBSYS_020D1028&REV_02
                         Display Memory: 286 MB
                      Dedicated Memory: 0 MB
                          Shared Memory: 286 MB
                                Monitor: HP S2331 Series Wide LCD Monitor
                            Driver Name: igdumdx32.dll
                         Driver Version: 7.15.0010.1666 (English)
                            DDI Version: 9Ex
                         BGRA Supported: Yes
                      Driver Attributes: Final Retail
                      Driver Date/Size: 2/26/2009 12:34:14, 536576 bytes
                            WHQL Logo'd: Yes
                        WHQL Date Stamp:
                      Device Identifier: {D7B78E66-6A82-11CF-1A75-0722A2C2CA35}
                              Vendor ID: 0x8086
                              Device ID: 0x29C2
                              SubSys ID: 0x020D1028
                            Revision ID: 0x0002
                            Revision ID: 0x0002
                            Video Accel: ModeMPEG2_A ModeMPEG2_C
                      Deinterlace Caps: {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                         {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                             D3D Status: Enabled
                             AGP Status: Enabled
                              Card name: Trigger USB Graphics Chipset Family (1P-E)
                           Manufacturer:
                              Chip type:
                               DAC type:
                             Device Key: Enum\MCT\USBVGA5100EXT
                           Current Mode: 1440 x 900 (32 bit) (60Hz)
                                Monitor: Generic Non-PnP Monitor
                            Driver Name:
                         Driver Version:  ()
                            DDI Version: unknown
                         BGRA Supported: Yes
                      Driver Date/Size: , 0 bytes
                            WHQL Logo'd: n/a
                        WHQL Date Stamp: n/a
                      Device Identifier: {D7B70EE0-4340-11CF-3265-0A20A0C2CA35}
                              Vendor ID: 0x0000
                              Device ID: 0x0000
                              SubSys ID: 0x00000000
                            Revision ID: 0x0000
                            Revision ID: 0x0000
                            Video Accel:
                      Deinterlace Caps: n/a
                           DDraw Status: Not Available
                             D3D Status: Not Available
                             AGP Status: Not Available
                      Sound Devices
                                  Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1028020D&REV_1000
                              Manufacturer ID: 1
                                   Product ID: 100
                                         Type: WDM
                                  Driver Name: RTKVHDA.sys
                               Driver Version: 6.00.0001.5555 (English)
                                  WHQL Logo'd: Yes
                                Date and Size: 1/24/2008 11:06:40, 2054872 bytes
                                  Other Files:
                                    Cap Flags: 0xF1F
                                    HW Memory: 0
                      DirectInput Devices
                            Device Name: Mouse
                               Attached: 1
                          Controller ID: n/a
                              FF Driver: n/a
                               Attached: 1
                          Controller ID: n/a
                              FF Driver: n/a
                      USB Devices
                      + USB Root Hub
                      | Vendor/Product ID: 0x8086, 0x2935
                      | Service: usbhub
                      | Driver: usbhub.sys, 4/11/2009 00:43:16, 196096 bytes
                      | Driver: usbd.sys, 1/20/2008 22:23:03, 5888 bytes
                      Gameport Devices
                      PS/2 Devices
                      + HID Keyboard Device
                      | Vendor/Product ID: 0x413C, 0x2105
                      | Matching Device ID: hid_device_system_keyboard
                      | Service: kbdhid
                      | Driver: kbdhid.sys, 4/11/2009 00:38:40, 17408 bytes
                      | Driver: kbdclass.sys, 1/20/2008 22:23:23, 35384 bytes
                      | Service: TermDD
                      | Driver: i8042prt.sys, 1/20/2008 22:23:20, 54784 bytes
                      + HID-compliant mouse
                      | Vendor/Product ID: 0x413C, 0x3012
                      | Matching Device ID: hid_device_system_mouse
                      | Service: mouhid
                      | Driver: mouhid.sys, 1/20/2008 22:23:20, 15872 bytes
                      | Driver: mouclass.sys, 1/20/2008 22:23:20, 34360 bytes
                      | Service: TermDD
                      | Driver: termdd.sys, 4/11/2009 02:32:52, 53224 bytes
                      | Driver: sermouse.sys, 1/20/2008 22:23:20, 19968 bytes
                            Drive: C:
                      Free Space: 133.7 GB
                      Total Space: 294.9 GB
                      File System: NTFS
                            Model: WDC WD3200AAKS-75L9A0 ATA Device
                            Drive: D:
                      Free Space: 2.9 GB
                      Total Space: 10.2 GB
                      File System: NTFS
                            Drive: E:
                            Model: Optiarc DVD+-RW AD-7200S ATA Device
                           Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/11/2009 00:39:17, 67072 bytes
                      System Devices
                           Name: Intel(R) G33/G31 Express Chipset Family
                      Device ID: PCI\VEN_8086&DEV_29C2&SUBSYS_020D1028&REV_02\3&2411E6FE&0&10
                         Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 7.15.0010.1666 (English), 2/26/2009 12:39:50, 4569088 bytes
                         Driver: C:\Windows\system32\igdumd32.dll, 7.15.0010.1666 (English), 2/26/2009 12:39:46, 3821568 bytes
                         Driver: C:\Windows\system32\iglhxs32.vp, 2/26/2009 13:15:24, 39872 bytes
                         Driver: C:\Windows\system32\iglhxo32.vp, 2/26/2009 11:57:46, 2096 bytes
                         Driver: C:\Windows\system32\iglhxc32.vp, 4/22/2008 02:17:42, 2096 bytes
                         Driver: C:\Windows\system32\hccutils.dll, 7.14.0010.1666 (English), 2/26/2009 12:03:52, 94208 bytes
                         Driver: C:\Windows\system32\igfxsrvc.dll, 7.14.0010.1666 (English), 2/26/2009 12:04:20, 51712 bytes
                         Driver: C:\Windows\system32\igfxsrvc.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:18, 252952 bytes
                         Driver: C:\Windows\system32\igfxpph.dll, 7.14.0010.1666 (English), 2/26/2009 12:04:42, 200192 bytes
                         Driver: C:\Windows\system32\igfxcpl.cpl, 7.14.0010.1666 (English), 2/26/2009 12:04:32, 119296 bytes
                         Driver: C:\Windows\system32\igfxcfg.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:14, 668696 bytes
                         Driver: C:\Windows\system32\igfxdev.dll, 7.14.0010.1666 (English), 2/26/2009 12:03:46, 210432 bytes
                         Driver: C:\Windows\system32\igfxdo.dll, 7.14.0010.1666 (English), 2/26/2009 12:04:02, 130048 bytes
                         Driver: C:\Windows\system32\igfxtray.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:20, 141848 bytes
                         Driver: C:\Windows\system32\hkcmd.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:12, 173592 bytes
                         Driver: C:\Windows\system32\igfxress.dll, 7.14.0010.1666 (English), 2/26/2009 12:03:46, 5702656 bytes
                         Driver: C:\Windows\system32\igfxpers.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:16, 150552 bytes
                         Driver: C:\Windows\system32\igfxTMM.dll, 7.14.0010.1666 (English), 2/26/2009 12:05:12, 257536 bytes
                         Driver: C:\Windows\system32\TVWSetup.exe, 1.00.0001.0000 (English), 2/26/2009 12:57:22, 8198680 bytes
                         Driver: C:\Windows\system32\igfxext.exe, 7.14.0010.1666 (English), 2/26/2009 12:57:14, 173080 bytes
                         Driver: C:\Windows\system32\igfxexps.dll, 7.14.0010.1666 (English), 2/26/2009 12:04:34, 23552 bytes
                         Driver: C:\Windows\system32\oemdspif.dll, 7.14.0010.1666 (English), 2/26/2009 12:05:04, 59392 bytes
                         Driver: C:\Windows\system32\igfxrara.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:02, 252416 bytes
                         Driver: C:\Windows\system32\igfxrchs.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:02, 178176 bytes
                         Driver: C:\Windows\system32\igfxrcht.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:02, 179712 bytes
                         Driver: C:\Windows\system32\igfxrdan.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:02, 280576 bytes
                         Driver: C:\Windows\system32\igfxrdeu.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:04, 303616 bytes
                         Driver: C:\Windows\system32\igfxrenu.lrc, 7.14.0010.1666 (English), 2/26/2009 12:03:46, 275968 bytes
                         Driver: C:\Windows\system32\igfxresp.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:04, 303104 bytes
                         Driver: C:\Windows\system32\igfxrfin.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:04, 281088 bytes
                         Driver: C:\Windows\system32\igfxrfra.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:06, 303104 bytes
                         Driver: C:\Windows\system32\igfxrheb.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:06, 249856 bytes
                         Driver: C:\Windows\system32\igfxrita.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:06, 304640 bytes
                         Driver: C:\Windows\system32\igfxrjpn.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:08, 206848 bytes
                         Driver: C:\Windows\system32\igfxrkor.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:08, 205312 bytes
                         Driver: C:\Windows\system32\igfxrnld.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:08, 299008 bytes
                         Driver: C:\Windows\system32\igfxrnor.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:08, 279552 bytes
                         Driver: C:\Windows\system32\igfxrplk.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:10, 287744 bytes
                         Driver: C:\Windows\system32\igfxrptb.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:10, 289280 bytes
                         Driver: C:\Windows\system32\igfxrptg.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:10, 294912 bytes
                         Driver: C:\Windows\system32\igfxrrus.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:10, 291328 bytes
                         Driver: C:\Windows\system32\igfxrsky.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:12, 282624 bytes
                         Driver: C:\Windows\system32\igfxrslv.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:12, 277504 bytes
                         Driver: C:\Windows\system32\igfxrsve.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:12, 282624 bytes
                         Driver: C:\Windows\system32\igfxrtha.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:12, 262656 bytes
                         Driver: C:\Windows\system32\igfxrcsy.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:02, 282624 bytes
                         Driver: C:\Windows\system32\igfxrell.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:04, 310784 bytes
                         Driver: C:\Windows\system32\igfxrhun.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:06, 288256 bytes
                         Driver: C:\Windows\system32\igfxrtrk.lrc, 7.14.0010.1666 (English), 2/26/2009 12:08:12, 279040 bytes
                         Driver: C:\Windows\system32\ig4icd32.dll, 7.15.0010.1666 (English), 2/26/2009 12:16:42, 4112384 bytes
                         Driver: C:\Windows\system32\ig4dev32.dll, 7.15.0010.1666 (English), 2/26/2009 12:16:54, 2674688 bytes
                         Driver: C:\Windows\system32\igdumdx32.dll, 7.15.0010.1666 (English), 2/26/2009 12:34:14, 536576 bytes
                         Driver: C:\Windows\system32\igfxCoIn_v1666.dll, 1.01.0016.0000 (English), 2/26/2009 12:49:24, 151552 bytes
                           Name: Intel(R) G33/G31/P35 Express Chipset PCI Express Root Port - 29C1
                      Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_020D1028&REV_02\3&2411E6FE&0&08
                         Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:55, 149480 bytes
                           Name: Intel(R) G33/G31/P35 Express Chipset Processor to I/O Controller - 29C0
                      Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_020D1028&REV_02\3&2411E6FE&0&00
                         Driver: n/a
                      Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D8
                         Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:42, 561152 bytes
                           Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
                      Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D7
                         Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:52, 39936 bytes
                         Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:57, 226304 bytes
                         Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18005 (English), 4/11/2009 00:43:16, 196096 bytes
                         Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 1/20/2008 22:23:03, 8704 bytes
                         Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/20/2008 22:23:03, 15872 bytes
                           Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
                      Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EF
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
                      Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D2
                         Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6001.18000 (English), 1/20/2008 22:23:03, 23552 bytes
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
                      Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D1
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
                      Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D0
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
                      Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EA
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
                      Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E9
                           Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
                      Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E8
                           Name: Intel(R) ICH9 Family SMBus Controller - 2930
                      Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FB
                         Driver: n/a
                           Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
                      Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FD
                         Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:49, 14312 bytes
                         Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:52, 43496 bytes
                         Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:26, 19944 bytes
                         Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:42, 109032 bytes
                           Name: Intel(R) ICH9 4 port Serial ATA Storage Controller 1 - 2920
                      Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FA
                      Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_020D1028&REV_02\3&2411E6FE&0&F8
                         Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/20/2008 22:23:01, 16440 bytes
                      Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_020D1028&REV_92\3&2411E6FE&0&F0
                           Name: Intel(R) 82562V-2 10/100 Network Connection
                      Device ID: PCI\VEN_8086&DEV_10C0&SUBSYS_020D1028&REV_02\3&2411E6FE&0&C8
                         Driver: C:\Windows\system32\DRIVERS\e1e6032.sys, 9.08.0020.0000 (English), 4/29/2007 04:42:24, 228224 bytes
                         Driver: C:\Windows\system32\Prounstl.exe, 9.01.0001.0000 (English), 4/29/2007 04:42:26, 154496 bytes
                         Driver: C:\Windows\system32\e1e6032.din, 4/29/2007 04:42:24, 2689 bytes
                         Driver: C:\Windows\system32\NicCo6.dll, 2.00.0001.0000 (English), 4/29/2007 04:42:26, 28536 bytes
                         Driver: C:\Windows\system32\NicInE6.dll, 9.08.0001.0000 (English), 4/29/2007 04:42:26, 39288 bytes
                         Driver: C:\Windows\system32\e1000msg.dll, 9.07.0000.0000 (English), 4/29/2007 04:42:24, 179048 bytes
                           Name: Broadcom 802.11g Network Adapter
                      Device ID: PCI\VEN_14E4&DEV_4318&SUBSYS_100F1043&REV_02\4&22B40817&0&00F0
                         Driver: C:\Windows\system32\DRIVERS\BCMWL6.SYS, 5.10.0079.0007 (English), 2/25/2009 00:20:52, 1880568 bytes
                         Driver: C:\Windows\system32\bcmihvsrv.dll, 5.10.0079.0007 (English), 2/25/2009 00:20:48, 3854336 bytes
                         Driver: C:\Windows\system32\bcmihvui.dll, 5.10.0079.0007 (English), 2/25/2009 00:20:50, 3538944 bytes
                         Driver: C:\Windows\system32\bcmwlcoi.dll, 5.10.0079.0007 (English), 2/25/2009 00:20:52, 91376 bytes
                      DirectShow Filters
                      DirectShow Filters:
                      WMAudio Decoder DMO,0x00800800,1,1,,
                      WMAPro over S/PDIF DMO,0x00600800,1,1,,
                      WMSpeech Decoder DMO,0x00600800,1,1,,
                      MP3 Decoder DMO,0x00600800,1,1,,
                      G2M Session Decoder,0x00600000,1,1,,
                      Mpeg4s Decoder DMO,0x00800001,1,1,,
                      WMV Screen decoder DMO,0x00600800,1,1,,
                      WMVideo Decoder DMO,0x00800001,1,1,,
                      Mpeg43 Decoder DMO,0x00800001,1,1,,
                      Mpeg4 Decoder DMO,0x00800001,1,1,,
                      Full Screen Renderer,0x00200000,1,0,,6.06.6002.18533
                      WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
                      Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
                      WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
                      WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
                      WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
                      WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8051.1204
                      WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
                      Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
                      WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
                      WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
                      DV Muxer,0x00400000,0,0,,6.06.6001.18000
                      Color Space Converter,0x00400001,1,1,,6.06.6002.18533
                      WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
                      WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
                      Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
                      AVI Splitter,0x00600000,1,1,,6.06.6002.18533
                      VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18533
                      Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
                      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                      WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
                      9x8Resize,0x00200000,1,1,WMM2FILT.dll,
                      StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
                      WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
                      Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
                      MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18533
                      CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
                      MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18533
                      SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18533
                      VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
                      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
                      WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
                      Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
                      Stretch Video,0x00200000,1,1,WMM2FILT.dll,
                      Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18533
                      MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18533
                      DV Splitter,0x00600000,1,2,,6.06.6001.18000
                      Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18533
                      Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
                      Frame Eater,0x00200000,1,1,WMM2FILT.dll,
                      Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
                      ACM Wrapper,0x00600000,1,1,,6.06.6002.18533
                      Video Renderer,0x00800001,1,0,,6.06.6002.18533
                      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
                      Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
                      Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
                      Video Port Manager,0x00600000,2,1,,6.06.6002.18533
                      Video Renderer,0x00400000,1,0,,6.06.6002.18533
                      Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
                      Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
                      File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
                      Proxy Source,0x00200000,0,1,WMM2FILT.dll,
                      WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
                      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
                      WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
                      File writer,0x00200000,1,0,,6.06.6001.18000
                      WAV Dest,0x00000000,0,0,,
                      DVD Navigator,0x00200000,0,3,,6.06.6002.18533
                      WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
                      Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
                      AVI Draw,0x00600064,9,1,,6.06.6002.18533
                      Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
                      WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
                      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                      Record Queue,0x00200000,1,1,WMM2FILT.dll,
                      DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
                      SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.18005
                      Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.18005
                      WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
                      MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
                      Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
                      WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
                      StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
                      Smart Tee,0x00200000,1,2,,6.06.6001.18000
                      Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
                      AVI Decompressor,0x00600000,1,1,,6.06.6002.18533
                      WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
                      Audible Words Codec,0x00500000,1,1,awrdscdc.ax,5.01.0000.0011
                      NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
                      AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18533
                      WMT Volume,0x00200000,1,1,WMM2FILT.dll,
                      Wave Parser,0x00400000,1,1,,6.06.6002.18533
                      MIDI Parser,0x00400000,1,1,,6.06.6002.18533
                      Multi-file Parser,0x00400000,1,1,,6.06.6002.18533
                      File stream renderer,0x00400000,1,1,,6.06.6002.18533
                      WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
                      Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
                      AVI Mux,0x00200000,1,0,,6.06.6001.18000
                      Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18533
                      File Source (Async.),0x00400000,0,1,,6.06.6002.18533
                      File Source (URL),0x00400000,0,1,,6.06.6002.18533
                      Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
                      AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
                      AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
                      SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
                      Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
                      WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
                      Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
                      Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
                      BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
                      MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18533
                      Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
                      Video Compressors:
                      WMVideo8 Encoder DMO,0x00600800,1,1,,
                      WMVideo9 Encoder DMO,0x00600800,1,1,,
                      MSScreen 9 encoder DMO,0x00600800,1,1,,
                      DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
                      MJPEG Compressor,0x00200000,0,0,,6.06.6002.18533
                      Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
                      Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
                      Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
                      Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
                      Audio Compressors:
                      WM Speech Encoder DMO,0x00600800,1,1,,
                      WMAudio Encoder DMO,0x00600800,1,1,,
                      IMA ADPCM,0x00200000,1,1,,6.06.6002.18533
                      Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18533
                      GSM 6.10,0x00200000,1,1,,6.06.6002.18533
                      Messenger Audio Codec,0x00200000,1,1,,6.06.6002.18533
                      CCITT A-Law,0x00200000,1,1,,6.06.6002.18533
                      CCITT u-Law,0x00200000,1,1,,6.06.6002.18533
                      MPEG Layer-3,0x00200000,1,1,,6.06.6002.18533
                      Midi Renderers:
                      Default MidiOut Device,0x00800000,1,0,,6.06.6002.18533
                      Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18533
                      ,0x00000000,0,0,,
                      ,0x00000000,0,0,,
                      ,0x00000000,0,0,,
                      ,0x00000000,0,0,,
                      Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
                      Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                      Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                      Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                      Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                      Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
                      BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
                      MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
                      BDA CP/CA Filters:
                      Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
                      Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                      XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                      Audio Renderers:
                      Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18533
                      Default DirectSound Device,0x00800000,1,0,,6.06.6002.18533
                      Default WaveOut Device,0x00200000,1,0,,6.06.6002.18533
                      DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
                      • 8. Re: Video investigation with Flash Player 11.2.202.228
                        chris.campbell Adobe Employee
                        Thank you to everyone that has provided details so far.  I'm taking this to our team but please keep the reports coming!
                        Chris
                        • 9. Re: Video investigation with Flash Player 11.2.202.228
                          niroo21
                              Same as your captured screen shot, green bar, overlaped two color
                              Does not work
                              http://sports.news.naver.com/videoCenter/index.nhn?uCategory=kbaseball&category=kbo&id=225 63
                              after commercial video, please, see main streaming video
                          System Information
                          Time of this report: 4/17/2012, 18:23:47
                                 Machine name: xxxxx
                             Operating System: Windows 7 Home Premium K 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
                                     Language: Korean (Regional Setting: Korean)
                          System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
                                 System Model: RF511/RF411/RF711
                                         BIOS: AMIBIOS Version 09HX.M027.20110323.SSH
                                    Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
                                       Memory: 4096MB RAM
                          Available OS Memory: 4008MB RAM
                                    Page File: 1886MB used, 6128MB available
                                  Windows Dir: C:\windows
                              DirectX Version: DirectX 11
                          DX Setup Parameters: Not found
                             User DPI Setting: Using System DPI
                          System DPI Setting: 96 DPI (100 percent)
                              DWM DPI Scaling: Disabled
                          DxDiag Notes
                                Display Tab 1: No problems found.
                                  Sound Tab 1: No problems found.
                                    Input Tab: No problems found.
                          DirectX Debug Levels
                          Direct3D:    0/4 (retail)
                          DirectDraw:  0/4 (retail)
                          DirectInput: 0/5 (retail)
                          DirectMusic: 0/5 (retail)
                          DirectPlay:  0/9 (retail)
                          DirectSound: 0/5 (retail)
                          DirectShow:  0/6 (retail)
                          Display Devices
                                    Card name: Intel(R) HD Graphics Family
                                    Chip type: Intel(R) HD Graphics Family
                                     DAC type: Internal
                                   Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_C0A5144D&REV_09
                               Display Memory: 2741 MB
                             Dedicated Memory: 993 MB
                                Shared Memory: 1748 MB
                                 Current Mode: 1366 x 768 (32 bit) (60Hz)
                                 Monitor Name: 일반 PnP 모니터
                                Monitor Model: unknown
                                   Monitor Id: SEC364A
                                  Native Mode: 1366 x 768(p) (60.072Hz)
                                  Output Type: Internal
                                  Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
                          Driver File Version: 8.15.0010.2622 (English)
                               Driver Version: 8.15.10.2622
                                  DDI Version: 11
                                 Driver Model: WDDM 1.1
                             Driver Date/Size: 1/10/2012 14:28:30, 8313856 bytes
                                  WHQL Logo'd: Yes
                              WHQL Date Stamp:
                            Device Identifier: {D7B78E66-4256-11CF-ED6D-A9E0B7C2C535}
                                    Vendor ID: 0x10DE
                                    Device ID: 0x0DF4
                                    SubSys ID: 0xC0A5144D
                                  Revision ID: 0x00A1
                          Driver Strong Name: oem7.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2622:pci\ven_8086&dev_0116
                               Rank Of Driver: 00E62001
                                  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
                             Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                 D3D9 Overlay: Supported
                                      DXVA-HD: Supported
                                 DDraw Status: Enabled
                                   D3D Status: Enabled
                                   AGP Status: Enabled
                          Sound Devices
                                      Description: 스피커(Realtek High Definition Audio)
                          Default Sound Playback: Yes
                          Default Voice Playback: Yes
                                      Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_144DC0A5&REV_1001
                                  Manufacturer ID: 1
                                       Product ID: 100
                                             Type: WDM
                                      Driver Name: RTKVHD64.sys
                                   Driver Version: 6.00.0001.6246 (English)
                                      WHQL Logo'd: Yes
                                    Date and Size: 11/17/2010 11:12:44, 2556776 bytes
                                      Other Files:
                                  Driver Provider: Realtek Semiconductor Corp.
                                   HW Accel Level: Basic
                                        Cap Flags: 0xF1F
                              Min/Max Sample Rate: 100, 200000
                          Static/Strm HW Mix Bufs: 1, 0
                          Static/Strm HW 3D Bufs: 0, 0
                                        HW Memory: 0
                                 Voice Management: No
                          EAX(tm) 2.0 Listen/Src: No, No
                             I3DL2(tm) Listen/Src: No, No
                          Sensaura(tm) ZoomFX(tm): No
                          Sound Capture Devices
                                      Description: 마이크(Realtek High Definition Audio)
                                        Cap Flags: 0x1
                          DirectInput Devices
                                Device Name: 마우스
                                   Attached: 1
                              Controller ID: n/a
                          Vendor/Product ID: n/a
                                  FF Driver: n/a
                                Device Name: 키보드
                                   Attached: 1
                              Controller ID: n/a
                                  FF Driver: n/a
                          Poll w/ Interrupt: No
                          USB Devices
                          + USB Root Hub
                          | Vendor/Product ID: 0x8086, 0x1C2D
                          | Matching Device ID: usb\root_hub20
                          | Service: usbhub
                          +-+ Generic USB Hub
                          | | Vendor/Product ID: 0x8087, 0x0024
                          | | Matching Device ID: usb\class_09
                          | | Service: usbhub
                          Gameport Devices
                          PS/2 Devices
                          + 표준 PS/2 키보드
                          | Service: i8042prt
                          + 터미널 서버 키보드 드라이버
                          | Matching Device ID: root\rdp_kbd
                          | Upper Filters: kbdclass
                          | Service: TermDD
                          + ELAN PS/2 Port Smart-Pad
                          | Matching Device ID: *etd0b00
                          | Upper Filters: ETD
                          | Service: i8042prt
                          + HID 규격 마우스
                          | Vendor/Product ID: 0x093A, 0x2510
                          | Service: mouhid
                          + 터미널 서버 마우스 드라이버
                          | Matching Device ID: root\rdp_mou
                          | Upper Filters: mouclass
                          | Service: TermDD
                          Disk & DVD/CD-ROM Drives
                                Drive: C:
                          Free Space: 149.9 GB
                          Total Space: 236.5 GB
                          File System: NTFS
                                Model: SAMSUNG HM641JI
                                Drive: D:
                          Free Space: 59.8 GB
                          Total Space: 352.5 GB
                          File System: NTFS
                                Drive: E:
                                Model: Optiarc DVD RW AD-7717H
                               Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Korean), , 0 bytes
                                Drive: H:
                                Model: DTSoftBusCd00
                                Drive: F:
                                Model: DTSoftBusCd01
                          System Devices
                               Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
                          Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_C0A5144D&REV_04\3&11583659&0&FB
                             Driver: n/a
                               Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0104
                          Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_C0A5144D&REV_09\3&11583659&0&00
                             Driver: n/a
                          Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_C0A5144D&REV_04\4&2256EFDC&0&00E4
                             Driver: n/a
                               Name: High Definition Audio 컨트롤러
                          Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_C0A5144D&REV_04\3&11583659&0&D8
                             Driver: n/a
                               Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
                          Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_C0A5144D&REV_09\3&11583659&0&08
                             Driver: n/a
                               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
                          Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_C0A5144D&REV_B4\3&11583659&0&E4
                             Driver: n/a
                               Name: Broadcom 802.11n 네트워크 어댑터
                          Device ID: PCI\VEN_14E4&DEV_4727&SUBSYS_051A185F&REV_01\4&31291047&0&00E0
                             Driver: n/a
                               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
                          Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_C0A5144D&REV_B4\3&11583659&0&E3
                             Driver: n/a
                               Name: Realtek PCIe GBE Family Controller
                          Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_C0A5144D&REV_06\4&12BF8F7C&0&00E3
                             Driver: n/a
                               Name: Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49
                          Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_C0A5144D&REV_04\3&11583659&0&F8
                             Driver: n/a
                               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
                          Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_C0A5144D&REV_B4\3&11583659&0&E0
                             Driver: n/a
                               Name: NVIDIA GeForce GT 540M
                          Device ID: PCI\VEN_10DE&DEV_0DF4&SUBSYS_C0A5144D&REV_A1\4&21A9360A&0&0008
                             Driver: n/a
                          Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_C0A5144D&REV_04\3&11583659&0&B0
                             Driver: n/a
                               Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
                          Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_C0A5144D&REV_04\3&11583659&0&FA
                             Driver: n/a
                               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
                          Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_C0A5144D&REV_04\3&11583659&0&D0
                             Driver: n/a
                               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
                          Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_C0A5144D&REV_04\3&11583659&0&E8
                             Driver: n/a
                          Device ID: PCI\VEN_8086&DEV_0116&SUBSYS_C0A5144D&REV_09\3&11583659&0&10
                             Driver: n/a
                          DirectShow Filters
                          DirectShow Filters:
                          WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                          WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                          WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                          MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                          Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                          WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                          WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                          Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                          Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                          Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,
                          WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                          Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                          WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                          WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
                          WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                          WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
                          WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                          CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
                          Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,
                          CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
                          DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                          CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
                          Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                          WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                          CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
                          Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                          AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                          VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
                          Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                          CyberLink Line21 Decoder (PDVD10),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
                          AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                          CyberLink DVD Navigator (PDVD10),0x00200000,0,3,CLNavX.ax,8.01.0000.2129
                          CyberLink AudioCD Filter (PDVD10),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
                          StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                          Sim AudioSwitch,0x00200000,1,1,Simfilter.dll,
                          MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                          SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
                          CyberLink Matroska Splitter(PDVD10),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1902
                          CyberLink TimeStretch Filter (PDVD10),0x00200000,1,1,clauts.ax,2.00.0000.3404
                          VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                          CyberLink RealMedia Splitter(PDVD10),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1706
                          Mpeg2Dec Filter,0x00600000,1,1,Mpeg2DecFilter.ax,1.00.0000.0000
                          MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                          Internal LMRT Renderer,0x00800001,1,0,LMRTREND.dll,6.00.0004.0827
                          Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                          MPEG Audio Decoder (MAD),0x00600000,1,1,MpaDecFilter.ax,1.00.0000.0000
                          SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                          Gretech Video Filter,0x00200000,1,1,GVF.ax,
                          Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                          CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
                          P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
                          MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                          CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.3408
                          Gretech OGG Source Filter2,0x00200000,0,1,GSFU.ax,
                          TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0001
                          Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,
                          Gretech MPEG Source Filter2,0x00200000,0,1,GSFU.ax,
                          DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                          CyberLink Audio Decoder (PDVD10),0x00201000,1,1,Claud.ax,8.04.0000.3420
                          CyberLink Video/SP Decoder (PDVD10),0x00602000,2,3,CLVsd.ax,8.04.0000.1913
                          CyberLink HD/BD Mixer (PDVD10),0x00200000,1,2,CLHBMixer.ax,2.00.0000.3407
                          Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                          CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
                          DENNY's DTS/AC3Filter,0x00800001,1,1,DtsFilter.ax,0.01.0000.0000
                          Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,
                          CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
                          CyberLink Audio Effect (PDVD10),0x00200000,1,1,ClAudFx.ax,6.00.0000.7225
                          Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                          CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.2307
                          CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
                          CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
                          ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                          Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,
                          Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                          Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,
                          MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
                          Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                          Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                          CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
                          File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
                          VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                          WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                          Gretech Audio Filter,0x00200000,1,1,GAF.ax,
                          CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
                          VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                          File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                          iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                          Gretech Network(FLV) Filter,0x00200000,0,1,GNF.ax,
                          iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                          Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,
                          Cyberlink SubTitle Importor (PDVD10),0x00200000,2,1,CLSubTitle.ax,2.00.0000.1021
                          Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,
                          Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
                          CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
                          Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
                          CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
                          Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,
                          CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
                          DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
                          Cutlist File Source,0x00200000,0,1,qcut.dll,6.00.0002.0902
                          CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.0000.2229
                          RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                          Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                          WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                          MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                          DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                          CyberLink Tzan Filter (PDVD10),0x00200000,1,1,CLTzan.ax,3.05.0000.3426
                          Gretech Network(SHOUTcast) Filter,0x00200000,0,1,GNF.ax,
                          URL StreamRenderer,0x00600000,1,0,LMRTREND.dll,6.00.0004.0827
                          Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,
                          Gretech AAC Source Filter,0x00200000,0,1,GSFU.ax,
                          SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                          Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                          CyberLink RealVideo Decoder(PDVD10),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
                          MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                          Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                          Gretech MP3 Source Filter,0x00200000,0,1,GSFU.ax,
                          Cyberlink SubTitle Importor 2.0 (PDVD10),0x00200000,1,0,CLSubTitle.ax,2.00.0000.1021
                          StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
                          Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                          CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
                          AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                          CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
                          CyberLink Video Decoder (PDVD10),0x00200000,1,2,CLCvd.ax,1.00.0000.2229
                          GomTV Streamer Network Filter,0x00200000,0,1,GomTVStreamerNF.ax,1.00.0000.0009
                          Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,
                          AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                          Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                          CyberLink MPEG-4 Splitter (PDVD10),0x00600000,1,2,clm4splt.ax,1.01.0000.2906
                          CyberLink RealAudio Decoder(PDVD10),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
                          Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                          StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                          AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                          Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                          File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                          File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                          P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
                          P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
                          CyberLink FLV Splitter(PDVD10),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.2027
                          Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.2123
                          Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                          Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                          BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                          MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                          CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
                          WDM Streaming Tee/Splitter Devices:
                          Tee/Sink-to-Sink 변환기,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          Video Compressors:
                          WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                          WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                          MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                          DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                          MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                          Radius에서 제공하는 Cinepak 코덱,0x00200000,1,1,qcap.dll,6.06.7601.17514
                          Intel IYUV 코덱,0x00200000,1,1,qcap.dll,6.06.7601.17514
                          Audio Compressors:
                          WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                          WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                          IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
                          마이크(Realtek High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
                          PBDA CP Filters:
                          PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                          PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                          PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                          Midi Renderers:
                          Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                          Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
                          WDM Streaming Capture Devices:
                          Bluetooth 오디오,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
                          Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          CyberLink Webcam Splitter,0x00200000,0,1,ksproxy.ax,6.01.7601.17514
                          WebCam SCB-1100N,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
                          WDM Streaming Rendering Devices:
                          Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                          BDA Network Providers:
                          Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                          Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                          Video Capture Sources:
                          Multi-Instance Capable VBI Codecs:
                          BDA Transport Information Renderers:
                          BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
                          MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                          BDA CP/CA Filters:
                          Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
                          Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                          PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                          XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                          WDM Streaming Communication Transforms:
                          Audio Renderers:
                          스피커(Realtek High Definition Aud,0x00200000,1,0,quartz.dll,6.06.7601.17713
                          CyberLink Audio Renderer (PDVD10),0x00200000,1,0,cladr.ax,7.00.0000.3502
                          Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                          Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
                          DirectSound: 스피커(Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                          EVR Power Information
                          Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
                            Quality Flags: 2576
                              Enabled:
                              Force throttling
                              Allow half deinterlace
                              Allow scaling
                              Decode Power Usage: 100
                            Balanced Flags: 1424
                              Enabled:
                              Force throttling
                              Allow batching
                              Force half deinterlace
                              Force scaling
                              Decode Power Usage: 50
                            PowerFlags: 1424
                              Enabled:
                              Force throttling
                              Allow batching
                              Force scaling
                              Decode Power Usage: 0
                          thanks and regards.
                          • 10. Re: Video investigation with Flash Player 11.2.202.228
                            KenInMaine Level 1
                            Chris,
                            I'm following up on your request for details to help track down the green bar issue. I have made sure my system has been fully updated.  When hardware acceleration is turned on for Flash Player I see a green bar for all Flash videos (e.g. the Daily Show with Jon Stewart).  When hardware acceleration is turned off videos display just fine.  My DxDiag details follow:
                            System Information
                            Time of this report: 4/20/2012, 15:04:57
                                   Machine name: W520
                               Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
                                       Language: English (Regional Setting: English)
                            System Manufacturer: LENOVO
                                   System Model: 4270CTO
                                           BIOS: Default System BIOS
                                      Processor: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
                                         Memory: 8192MB RAM
                            Available OS Memory: 8076MB RAM
                                      Page File: 3200MB used, 12948MB available
                                    Windows Dir: C:\Windows
                               User DPI Setting: 96 DPI (100 percent)
                                 DxDiag Version: 6.01.7601.17514 64bit Unicode
                            DxDiag Notes
                            Display Devices
                                       DAC type: Internal
                                     Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_21D117AA&REV_09
                                 Display Memory: 1700 MB
                               Dedicated Memory: 2014 MB
                                  Shared Memory: 3781 MB
                                   Current Mode: 1600 x 900 (32 bit) (60Hz)
                                   Monitor Name: ThinkPad Display 1600x900
                                     Monitor Id: LEN40B1
                                    Native Mode: 1600 x 900(p) (59.990Hz)
                            Driver File Version: 8.15.0010.2538 (English)
                                 Driver Version: 8.15.10.2538
                                    DDI Version: 11
                               Driver Date/Size: 9/26/2011 03:44:56, 8313856 bytes
                                    WHQL Logo'd: Yes
                                WHQL Date Stamp:
                              Device Identifier: {D7B78E66-4266-11CF-B369-DD01B7C2C535}
                                      Vendor ID: 0x8086
                                      Device ID: 0x0126
                                      SubSys ID: 0x21D117AA
                                    Revision ID: 0x0009
                            Driver Strong Name: oem36.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2538:pci\ven_8086&dev_0126&subsys_21d117aa
                                 Rank Of Driver: 00E60001
                                    Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
                               Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                 {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                        DXVA-HD: Supported
                                     D3D Status: Enabled
                                     AGP Status: Enabled
                                      Card name: NVIDIA Quadro 1000M
                                   Manufacturer: NVIDIA
                                      Chip type: Quadro 1000M
                                       DAC type: Integrated RAMDAC
                                     Device Key: Enum\PCI\VEN_10DE&DEV_0DFA&SUBSYS_21D117AA&REV_A1
                                   Current Mode: 1360 x 768 (32 bit) (60Hz)
                                   Monitor Name: Generic PnP Monitor
                                  Monitor Model: SHARP LCD
                                     Monitor Id: SHP0FFC
                                    Native Mode: 1400 x 1050(p) (59.978Hz)
                                    Output Type: HD15
                                    Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                            Driver File Version: 8.17.0012.7593 (English)
                                 Driver Version: 8.17.12.7593
                                    DDI Version: 11
                               Driver Date/Size: 8/13/2011 00:18:00, 15241832 bytes
                                    WHQL Logo'd: Yes
                                WHQL Date Stamp:
                              Device Identifier: {D7B71E3E-4EBA-11CF-B369-DD011FC2C535}
                                      Vendor ID: 0x10DE
                                      Device ID: 0x0DFA
                                    Revision ID: 0x00A1
                            Driver Strong Name: oem27.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section094:8.17.12.7593:pci\ven_10de&dev_0dfa&s ubsys_21d117aa
                                        DXVA-HD: Supported
                                     D3D Status: Enabled
                                     AGP Status: Enabled
                            Sound Devices
                                        Description: Speakers (Conexant 20672 SmartAudio HD)
                                        Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_506E&SUBSYS_17AA21CF&REV_1000
                                    Manufacturer ID: 1
                                         Product ID: 100
                                               Type: WDM
                                        Driver Name: CHDRT64.sys
                                     Driver Version: 8.32.0023.0002 (English)
                                        WHQL Logo'd: Yes
                                      Date and Size: 10/3/2011 16:46:40, 1577088 bytes
                                        Other Files:
                                    Driver Provider: Conexant
                                          Cap Flags: 0xF1F
                                          HW Memory: 0
                                        Description: Internal Microphone (Conexant 20672 SmartAudio HD)
                              Default Sound Capture: Yes
                              Default Voice Capture: Yes
                                          Cap Flags: 0x1
                                       Format Flags: 0xFFFFF
                            DirectInput Devices
                                  Device Name: Mouse
                                     Attached: 1
                                Controller ID: n/a
                                    FF Driver: n/a
                                  Device Name: Keyboard
                                     Attached: 1
                                Controller ID: n/a
                                    FF Driver: n/a
                                  Device Name: GlidePoint 3.5 USB Combo (Mercury)
                                     Attached: 1
                                Controller ID: 0x0
                            Vendor/Product ID: 0x0488, 0x00DF
                                    FF Driver: n/a
                                     Attached: 1
                                Controller ID: 0x0
                                    FF Driver: n/a
                                     Attached: 1
                                Controller ID: 0x0
                                    FF Driver: n/a
                            USB Devices
                            + USB Root Hub
                            | Service: usbhub
                            | Driver: usbhub.sys, 10/4/2011 23:41:46, 343040 bytes
                            | Driver: usbd.sys, 10/4/2011 23:41:03, 7936 bytes
                            +-+ Generic USB Hub
                            | | Service: usbhub
                            | +-+ Generic USB Hub
                            | | | Vendor/Product ID: 0x17EF, 0x100A
                            | | | Service: usbhub
                            | | +-+ GlidePoint 3.5 USB Combo (Mercury)
                            | | | | Matching Device ID: usb\vid_0488&pid_00df
                            | | | | Lower Filters: glideusb
                            | | | | Service: HidUsb
                            | | | | Driver: glideusb.sys, 6/9/2009 12:37:31, 99240 bytes
                            | | | | Driver: hidusb.sys, 11/20/2010 23:23:47, 30208 bytes
                            | | | | Driver: hidclass.sys, 11/20/2010 23:23:47, 76800 bytes
                            | | | | Driver: hidparse.sys, 7/13/2009 20:06:17, 32896 bytes
                            | | | | Driver: glideuci.dll, 6/9/2009 12:37:31, 156456 bytes
                            | | | +-+ HID-compliant consumer control device
                            | | | | | Matching Device ID: hid_device_up:000c_u:0001
                            | | | +-+ HID-compliant device
                            | | | +-+ HID Keyboard Device
                            | | | | | Service: kbdhid
                            | | | | | Driver: kbdhid.sys, 11/20/2010 23:23:47, 33280 bytes
                            | | | | | Driver: kbdclass.sys, 7/13/2009 21:48:04, 50768 bytes
                            | | | +-+ HID-compliant mouse
                            | | | | | Service: mouhid
                            | | | | | Driver: mouhid.sys, 7/13/2009 20:00:20, 31232 bytes
                            | | | | | Driver: mouclass.sys, 7/13/2009 21:48:27, 49216 bytes
                            Gameport Devices
                            PS/2 Devices
                            + Standard PS/2 Keyboard
                            | Matching Device ID: *pnp0303
                            | Service: i8042prt
                            | Driver: i8042prt.sys, 7/13/2009 19:19:57, 105472 bytes
                            + Terminal Server Keyboard Driver
                            | Service: TermDD
                            + ThinkPad UltraNav Pointing Device
                            | Matching Device ID: *len0015
                            | Upper Filters: SynTP
                            | Service: i8042prt
                            + Terminal Server Mouse Driver
                            | Service: TermDD
                            | Driver: termdd.sys, 11/20/2010 23:23:47, 63360 bytes
                            | Driver: sermouse.sys, 7/13/2009 20:00:20, 26624 bytes
                                  Drive: C:
                            Free Space: 246.4 GB
                            Total Space: 459.4 GB
                            File System: NTFS
                                  Model: HITACHI HTS727550A9E364
                                  Drive: Q:
                            Free Space: 5.2 GB
                            Total Space: 16.0 GB
                            File System: NTFS
                            System Devices
                            Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_21CF17AA&REV_09\3&42FFD25&0&00
                               Driver: n/a
                                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 7 - 1C1C
                            Device ID: PCI\VEN_8086&DEV_1C1C&SUBSYS_21CF17AA&REV_B4\3&42FFD25&0&E6
                               Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 184704 bytes
                                 Name: Intel(R) Centrino(R) Ultimate-N 6300 AGN
                            Device ID: PCI\VEN_8086&DEV_4238&SUBSYS_11118086&REV_3E\4&237C4943&0&00E1
                               Driver: n/a
                            Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_21CF17AA&REV_09\3&42FFD25&0&08
                            Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_21CF17AA&REV_B4\3&42FFD25&0&E4
                                 Name: Intel(R) QM67 Express Chipset Family LPC Interface Controller - 1C4F
                            Device ID: PCI\VEN_8086&DEV_1C4F&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&F8
                               Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 21:48:27, 15424 bytes
                            Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_21CF17AA&REV_B4\3&42FFD25&0&E3
                                 Name: Intel(R) Active Management Technology - SOL (COM3)
                            Device ID: PCI\VEN_8086&DEV_1C3D&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&B3
                               Driver: n/a
                                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
                            Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_21CF17AA&REV_B4\3&42FFD25&0&E1
                                 Name: Intel(R) Management Engine Interface
                            Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&B0
                               Driver: n/a
                                 Name: NVIDIA Quadro 1000M
                            Device ID: PCI\VEN_10DE&DEV_0DFA&SUBSYS_21D117AA&REV_A1\4&2E01E21D&0&0008
                               Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 213096 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/13/2011 00:18:00, 309856 bytes
                               Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 233064 bytes
                               Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 6/1/2011 00:37:24, 4096 bytes
                               Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 224360 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 259072 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 6/1/2011 00:37:24, 4096 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 248320 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\license.txt, 6/1/2011 00:37:14, 15511 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8/13/2011 00:18:00, 168552 bytes
                               Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8/13/2011 00:18:00, 161896 bytes
                               Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 13380200 bytes
                               Driver: C:\Windows\system32\DRIVERS\nvpciflt.sys, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 27240 bytes
                               Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 8/13/2011 00:18:00, 67176 bytes
                               Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 2648168 bytes
                               Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 18583144 bytes
                               Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 7130216 bytes
                               Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.7593 (English), 8/13/2011 00:18:00, 2213480 bytes
                               Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 2944104 bytes
                               Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 15241832 bytes
                               Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 362600 bytes
                               Driver: C:\Windows\system32\nvinfo.pb, 8/13/2011 00:18:00, 7240 bytes
                               Driver: C:\Windows\system32\nvinitx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 239720 bytes
                               Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 22304872 bytes
                               Driver: C:\Windows\system32\nvoptimusmft.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 366696 bytes
                               Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 834664 bytes
                               Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 8871016 bytes
                               Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 8/13/2011 00:18:00, 57960 bytes
                               Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 2339432 bytes
                               Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 13011560 bytes
                               Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 5304424 bytes
                               Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.7593 (English), 8/13/2011 00:18:00, 2082408 bytes
                               Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 2804840 bytes
                               Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 12007528 bytes
                               Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 300136 bytes
                               Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 200808 bytes
                               Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 16468584 bytes
                               Driver: C:\Windows\SysWow64\nvoptimusmft.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 326248 bytes
                               Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 696424 bytes
                               Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.7593 (English), 8/13/2011 00:18:00, 6558824 bytes
                               Driver: C:\Windows\system32\nvdispco6420150.dll, 2.00.0015.0000 (English), 8/13/2011 00:18:00, 1496168 bytes
                               Driver: C:\Windows\system32\nvgenco6420103.dll, 2.00.0010.0003 (English), 8/13/2011 00:18:00, 1450600 bytes
                            Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_21CF17AA&REV_B4\3&42FFD25&0&E0
                            Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&D0
                               Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17701 (English), 10/4/2011 23:41:10, 52736 bytes
                               Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17701 (English), 10/4/2011 23:41:20, 325120 bytes
                               Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17701 (English), 10/4/2011 23:41:46, 343040 bytes
                            Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&FA
                               Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 10.06.0000.1002 (English), 5/20/2011 09:53:44, 557848 bytes
                            Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&E8
                                 Name: Intel(R) 82579LM Gigabit Network Connection
                            Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_21CE17AA&REV_04\3&42FFD25&0&C8
                               Driver: C:\Windows\system32\DRIVERS\e1c62x64.sys, 11.15.0016.0000 (English), 1/11/2012 12:30:58, 360624 bytes
                               Driver: C:\Windows\system32\e1c62x64.din, 12/23/2009 05:12:56, 3114 bytes
                               Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/25/2009 20:05:46, 36472 bytes
                               Driver: C:\Windows\system32\NicInstC.dll, 9.10.0074.0000 (English), 11/7/2011 01:28:54, 98496 bytes
                               Driver: C:\Windows\system32\e1cmsg.dll, 10.00.0099.0000 (English), 11/3/2011 00:54:02, 68264 bytes
                                 Name: Renesas Electronics USB 3.0 Host Controller
                            Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_21CF17AA&REV_04\4&2421062D&0&00E6
                               Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0032.0000 (English), 12/10/2010 00:50:36, 181248 bytes
                            Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&FB
                               Driver: n/a
                                 Name: Intel(R) HD Graphics Family
                            Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_21D117AA&REV_09\3&42FFD25&0&10
                               Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 8.15.0010.2538 (English), 9/26/2011 03:40:28, 12309440 bytes
                               Driver: C:\Windows\system32\igdumd64.dll, 8.15.0010.2538 (English), 9/26/2011 03:44:56, 8313856 bytes
                               Driver: C:\Windows\system32\igd10umd64.dll, 8.15.0010.2538 (English), 9/26/2011 03:12:36, 14592000 bytes
                               Driver: C:\Windows\system32\igfxcmrt64.dll, 2.00.0000.1001 (English), 9/26/2011 01:36:22, 148480 bytes
                               Driver: C:\Windows\system32\igfxcmjit64.dll, 2.00.0000.1001 (English), 9/26/2011 01:36:22, 2177536 bytes
                               Driver: C:\Windows\system32\IccLibDll_x64.dll, 3/6/2011 07:07:58, 94208 bytes
                               Driver: C:\Windows\system32\igkrng600.bin, 3/6/2011 07:50:34, 963116 bytes
                               Driver: C:\Windows\system32\igcompkrng600.bin, 3/6/2011 07:50:34, 145804 bytes
                               Driver: C:\Windows\system32\igfcg600m.bin, 9/26/2011 03:35:58, 216000 bytes
                               Driver: C:\Windows\SysWow64\igkrng600.bin, 3/6/2011 07:50:34, 963116 bytes
                               Driver: C:\Windows\SysWow64\igcompkrng600.bin, 3/6/2011 07:50:34, 145804 bytes
                               Driver: C:\Windows\SysWow64\igfcg600m.bin, 9/26/2011 03:35:58, 216000 bytes
                               Driver: C:\Windows\system32\igdde64.dll, 9/26/2011 03:36:08, 75776 bytes
                               Driver: C:\Windows\SysWow64\igdde32.dll, 9/26/2011 03:20:52, 56832 bytes
                               Driver: C:\Windows\system32\iglhxs64.vp, 9/26/2011 04:06:16, 17460 bytes
                               Driver: C:\Windows\system32\iglhxo64.vp, 9/26/2011 01:36:22, 59243 bytes
                               Driver: C:\Windows\system32\iglhxc64.vp, 9/26/2011 01:36:22, 59062 bytes
                               Driver: C:\Windows\system32\iglhxg64.vp, 9/26/2011 01:36:22, 59174 bytes
                               Driver: C:\Windows\system32\iglhxa64.vp, 9/26/2011 01:36:22, 1074 bytes
                               Driver: C:\Windows\system32\iglhxa64.cpa, 9/26/2011 01:36:22, 1981696 bytes
                               Driver: C:\Windows\system32\iglhcp64.dll, 2.00.0002.0001 (English), 9/26/2011 01:36:22, 98304 bytes
                               Driver: C:\Windows\system32\iglhsip64.dll, 2.00.0002.0001 (English), 9/26/2011 01:36:22, 376832 bytes
                               Driver: C:\Windows\SysWow64\igdumd32.dll, 8.15.0010.2538 (English), 9/26/2011 03:30:20, 6323712 bytes
                               Driver: C:\Windows\SysWow64\igdumdx32.dll, 8.15.0010.2538 (English), 9/26/2011 03:19:20, 581120 bytes
                               Driver: C:\Windows\SysWow64\igfxdv32.dll, 8.15.0010.2538 (English), 9/26/2011 01:38:22, 294400 bytes
                               Driver: C:\Windows\SysWow64\igd10umd32.dll, 8.15.0010.2538 (English), 9/26/2011 02:53:10, 12340224 bytes
                               Driver: C:\Windows\SysWow64\iglhcp32.dll, 2.00.0002.0001 (English), 9/26/2011 01:36:22, 98304 bytes
                               Driver: C:\Windows\SysWow64\iglhsip32.dll, 2.00.0002.0001 (English), 9/26/2011 01:36:22, 376832 bytes
                               Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 2.00.0000.1001 (English), 9/26/2011 01:36:22, 171520 bytes
                               Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 2.00.0000.1001 (English), 9/26/2011 01:36:22, 1663488 bytes
                               Driver: C:\Windows\system32\difx64.exe, 1.03.0001.0000 (English), 10/14/2011 02:27:56, 184600 bytes
                               Driver: C:\Windows\system32\hccutils.dll, 8.15.0010.2538 (English), 9/26/2011 01:43:46, 110080 bytes
                               Driver: C:\Windows\system32\igfxsrvc.dll, 8.15.0010.2538 (English), 9/26/2011 01:44:14, 62464 bytes
                               Driver: C:\Windows\system32\igfxsrvc.exe, 8.15.0010.2538 (English), 10/14/2011 02:28:12, 510232 bytes
                               Driver: C:\Windows\system32\igfxpph.dll, 8.15.0010.2538 (English), 9/26/2011 01:44:46, 375808 bytes
                               Driver: C:\Windows\system32\igfxcpl.cpl, 8.15.0010.2538 (English), 9/26/2011 01:45:12, 126976 bytes
                               Driver: C:\Windows\system32\igfxdev.dll, 8.15.0010.2538 (English), 9/26/2011 01:43:34, 390144 bytes
                               Driver: C:\Windows\system32\igfxdo.dll, 8.15.0010.2538 (English), 9/26/2011 01:42:54, 142336 bytes
                               Driver: C:\Windows\system32\igfxtray.exe, 8.15.0010.2321 (English), 3/10/2011 03:31:42, 167960 bytes
                               Driver: C:\Windows\system32\hkcmd.exe, 8.15.0010.2321 (English), 3/10/2011 03:31:26, 391704 bytes
                               Driver: C:\Windows\system32\igfxress.dll, 8.15.0010.2538 (English), 9/26/2011 01:42:54, 9014784 bytes
                               Driver: C:\Windows\system32\igfxpers.exe, 8.15.0010.2321 (English), 3/10/2011 03:31:34, 418840 bytes
                               Driver: C:\Windows\system32\igfxTMM.dll, 8.15.0010.2538 (English), 9/26/2011 01:44:54, 378368 bytes
                               Driver: C:\Windows\system32\gfxSrvc.dll, 8.15.0010.2538 (English), 9/26/2011 01:43:36, 146432 bytes
                               Driver: C:\Windows\system32\GfxUI.exe, 8.15.0010.2538 (English), 10/14/2011 02:27:58, 4378392 bytes
                               Driver: C:\Windows\system32\GfxUI.exe.config, 3/6/2011 07:11:06, 151 bytes
                               Driver: C:\Windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 9/26/2011 01:43:36, 4096 bytes
                               Driver: C:\Windows\system32\igfxext.exe, 8.15.0010.2538 (English), 10/14/2011 02:28:06, 239896 bytes
                               Driver: C:\Windows\system32\igfxexps.dll, 8.15.0010.2538 (English), 9/26/2011 01:44:28, 28672 bytes
                               Driver: C:\Windows\SysWow64\igfxexps32.dll, 8.15.0010.2538 (English), 9/26/2011 01:39:10, 24576 bytes
                               Driver: C:\Windows\system32\igfxrara.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:14, 285184 bytes
                               Driver: C:\Windows\system32\igfxrchs.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:14, 282624 bytes
                               Driver: C:\Windows\system32\igfxrcht.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:16, 282624 bytes
                               Driver: C:\Windows\system32\igfxrdan.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:16, 285696 bytes
                               Driver: C:\Windows\system32\igfxrdeu.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:18, 286720 bytes
                               Driver: C:\Windows\system32\igfxrenu.lrc, 8.15.0010.2321 (English), 3/6/2011 07:18:26, 285696 bytes
                               Driver: C:\Windows\system32\igfxresn.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:26, 287232 bytes
                               Driver: C:\Windows\system32\igfxrfin.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:18, 286208 bytes
                               Driver: C:\Windows\system32\igfxrfra.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:18, 287232 bytes
                               Driver: C:\Windows\system32\igfxrheb.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:20, 285184 bytes
                               Driver: C:\Windows\system32\igfxrhrv.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:30, 286720 bytes
                               Driver: C:\Windows\system32\igfxrita.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:22, 286720 bytes
                               Driver: C:\Windows\system32\igfxrjpn.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:22, 283648 bytes
                               Driver: C:\Windows\system32\igfxrkor.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:22, 283136 bytes
                               Driver: C:\Windows\system32\igfxrnld.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:18, 286720 bytes
                               Driver: C:\Windows\system32\igfxrnor.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:24, 286208 bytes
                               Driver: C:\Windows\system32\igfxrplk.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:24, 286720 bytes
                               Driver: C:\Windows\system32\igfxrptb.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:24, 286208 bytes
                               Driver: C:\Windows\system32\igfxrptg.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:24, 286720 bytes
                               Driver: C:\Windows\system32\igfxrrom.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:32, 286720 bytes
                               Driver: C:\Windows\system32\igfxrrus.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:26, 286720 bytes
                               Driver: C:\Windows\system32\igfxrsky.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:30, 286720 bytes
                               Driver: C:\Windows\system32\igfxrslv.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:30, 286208 bytes
                               Driver: C:\Windows\system32\igfxrsve.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:28, 286208 bytes
                               Driver: C:\Windows\system32\igfxrtha.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:28, 285696 bytes
                               Driver: C:\Windows\system32\igfxrcsy.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:16, 286720 bytes
                               Driver: C:\Windows\system32\igfxrell.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:20, 287232 bytes
                               Driver: C:\Windows\system32\igfxrhun.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:20, 286208 bytes
                               Driver: C:\Windows\system32\igfxrtrk.lrc, 8.15.0010.2538 (English), 9/26/2011 01:45:28, 286208 bytes
                               Driver: C:\Windows\system32\Gfxres.ar-SA.resources, 9/26/2011 01:45:32, 156233 bytes
                               Driver: C:\Windows\system32\Gfxres.cs-CZ.resources, 9/26/2011 01:45:34, 133404 bytes
                               Driver: C:\Windows\system32\Gfxres.da-DK.resources, 9/26/2011 01:45:34, 128535 bytes
                               Driver: C:\Windows\system32\Gfxres.de-DE.resources, 9/26/2011 01:45:36, 137846 bytes
                               Driver: C:\Windows\system32\Gfxres.el-GR.resources, 9/26/2011 01:45:38, 198139 bytes
                               Driver: C:\Windows\system32\Gfxres.es-ES.resources, 9/26/2011 01:45:38, 137668 bytes
                               Driver: C:\Windows\system32\Gfxres.en-US.resources, 9/26/2011 01:45:14, 124056 bytes
                               Driver: C:\Windows\system32\Gfxres.fi-FI.resources, 9/26/2011 01:45:40, 132889 bytes
                               Driver: C:\Windows\system32\Gfxres.fr-FR.resources, 9/26/2011 01:45:42, 135626 bytes
                               Driver: C:\Windows\system32\Gfxres.he-IL.resources, 9/26/2011 01:45:42, 149009 bytes
                               Driver: C:\Windows\system32\Gfxres.hr-HR.resources, 9/26/2011 01:46:06, 131839 bytes
                               Driver: C:\Windows\system32\Gfxres.hu-HU.resources, 9/26/2011 01:45:44, 134384 bytes
                               Driver: C:\Windows\system32\Gfxres.it-IT.resources, 9/26/2011 01:45:46, 140216 bytes
                               Driver: C:\Windows\system32\Gfxres.ja-JP.resources, 9/26/2011 01:45:46, 153167 bytes
                               Driver: C:\Windows\system32\Gfxres.ko-KR.resources, 9/26/2011 01:45:48, 138727 bytes
                               Driver: C:\Windows\system32\Gfxres.nb-NO.resources, 9/26/2011 01:45:48, 128831 bytes
                               Driver: C:\Windows\system32\Gfxres.nl-NL.resources, 9/26/2011 01:45:50, 134412 bytes
                               Driver: C:\Windows\system32\Gfxres.pl-PL.resources, 9/26/2011 01:45:52, 133178 bytes
                               Driver: C:\Windows\system32\Gfxres.pt-BR.resources, 9/26/2011 01:45:52, 134836 bytes
                               Driver: C:\Windows\system32\Gfxres.pt-PT.resources, 9/26/2011 01:45:54, 133709 bytes
                               Driver: C:\Windows\system32\Gfxres.ro-RO.resources, 9/26/2011 01:46:06, 136603 bytes
                               Driver: C:\Windows\system32\Gfxres.ru-RU.resources, 9/26/2011 01:45:56, 182706 bytes
                               Driver: C:\Windows\system32\Gfxres.sk-SK.resources, 9/26/2011 01:45:56, 132788 bytes
                               Driver: C:\Windows\system32\Gfxres.sl-SI.resources, 9/26/2011 01:45:58, 128996 bytes
                               Driver: C:\Windows\system32\Gfxres.sv-SE.resources, 9/26/2011 01:46:00, 133846 bytes
                               Driver: C:\Windows\system32\Gfxres.th-TH.resources, 9/26/2011 01:46:00, 211303 bytes
                               Driver: C:\Windows\system32\Gfxres.tr-TR.resources, 9/26/2011 01:46:02, 135370 bytes
                               Driver: C:\Windows\system32\Gfxres.zh-CN.resources, 9/26/2011 01:46:04, 116348 bytes
                               Driver: C:\Windows\system32\Gfxres.zh-TW.resources, 9/26/2011 01:46:04, 117636 bytes
                               Driver: C:\Windows\system32\ig4icd64.dll, 8.15.0010.2538 (English), 9/26/2011 02:26:56, 18651136 bytes
                               Driver: C:\Windows\SysWow64\ig4icd32.dll, 9/26/2011 01:58:02, 13903360 bytes
                               Driver: C:\Windows\system32\igfxCoIn_v2538.dll, 1.02.0030.0000 (English), 9/26/2011 03:52:20, 90112 bytes
                                 Name: High Definition Audio Controller
                            Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_21CF17AA&REV_04\3&42FFD25&0&D8
                               Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 122368 bytes
                            DirectShow Filters
                            DirectShow Filters:
                            ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.2991
                            ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.2991
                            ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.2991
                            Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                            CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
                            Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                            ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0007.2991
                            NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
                            ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0007.2991
                            Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
                            AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                            AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                            SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                            Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                            Video Compressors:
                            ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0007.2991
                            Audio Compressors:
                            Audio Capture Sources:
                            Internal Microphone (Conexant 2,0x00200000,0,0,qcap.dll,6.06.7601.17514
                            PBDA CP Filters:
                            Midi Renderers:
                            Conexant HD Audio capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                            ,0x00000000,0,0,,
                            ,0x00000000,0,0,,
                            Integrated Camera,0x00200000,0,1,ksproxy.ax,6.01.7601.17514
                            ,0x00000000,0,0,,
                            ,0x00000000,0,0,,
                            ,0x00000000,0,0,,
                            Conexant HD Audio headphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                            Conexant HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                            BDA CP/CA Filters:
                            Audio Renderers:
                            Speakers (Conexant 20672 SmartA,0x00200000,1,0,quartz.dll,6.06.7601.17713
                            DirectSound: Speakers (Conexant 20672 SmartAudio HD),0x00200000,1,0,quartz.dll,6.06.7601.17713
                            Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                              Quality Flags: 2576
                                Enabled:
                                Force throttling
                                Allow scaling
                                Enabled:
                                Force throttling
                                Allow batching
                                Force scaling
                              PowerFlags: 1424
                                Enabled:
                                Force throttling
                                Allow batching
                                Force scaling
                            • 11. Re: Video investigation with Flash Player 11.2.202.228
                              SallyAlyKarram
                              Hi Chris, refrence to the a/m subject, i updated my nvidia driver, and it is back to normal currently..
                              Hope it will be a premenant solution
                              Many thanks Chris as i was totally confused about what happened till i found your reply,, many thanks
                              • 12. Re: Video investigation with Flash Player 11.2.202.228
                                deadeyz
                                Hi! Chris,
                                1. The flash player in full screen becomes sluggish and audio video gets out of sync.  It use to run ok without full screen but for the last week even in normal mode (not full screen) the video is sluggish and audio video is out of synce.
                                2. Disabling Flash's hardwre accelration hasn't helped at all.
                                3. http://www.tvcatchup.com/watch.html?c=4 This is the link that does not work.
                                4. Following is Dxdiag report:
                                System Information
                                Time of this report: 4/22/2012, 00:15:58
                                       Machine name: TIMES-LAPTOP
                                   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
                                System Manufacturer: TimeComputers
                                       System Model: VT8372
                                               BIOS: Insyde Software MobilePRO BIOS Version 4.00.01
                                          Processor: mobile AMD Athlon(tm) XP 2000+,  MMX,  3DNow, ~1.7GHz
                                             Memory: 1248MB RAM
                                          Page File: 809MB used, 2790MB available
                                        Windows Dir: C:\WINDOWS
                                    DirectX Version: DirectX 9.0c (4.09.0000.0904)
                                     DxDiag Version: 5.03.2600.5512 32bit Unicode
                                DxDiag Notes
                                  DirectX Files Tab: No problems found.
                                          Music Tab: No problems found.
                                        Network Tab: No problems found.
                                Direct3D:    0/4 (n/a)
                                DirectInput: 0/5 (n/a)
                                DirectMusic: 0/5 (n/a)
                                Display Devices
                                        Card name: S3 Graphics ProSavageDDR
                                     Manufacturer: S3 Graphics Co., Ltd.
                                        Chip type: S3 ProSavage DDR
                                         DAC type: S3 SDAC
                                       Device Key: Enum\PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00
                                   Display Memory: 32.0 MB
                                     Current Mode: 1024 x 768 (32 bit) (60Hz)
                                          Monitor: Digital Flat Panel (1024x768)
                                  Monitor Max Res:
                                      Driver Name: s3gnb.dll
                                   Driver Version: 6.14.0010.0025 (English)
                                      DDI Version: 9 (or higher)
                                Driver Attributes: Final Retail
                                Driver Date/Size: 3/2/2004 14:02:26, 402048 bytes
                                      WHQL Logo'd: Yes
                                  WHQL Date Stamp: n/a
                                              VDD: n/a
                                         Mini VDD: s3gnbm.sys
                                    Mini VDD Date: 3/2/2004 14:02:30, 167040 bytes
                                Device Identifier: {D7B75DD3-CE44-11CF-D873-7FA3A1C2CB35}
                                        Vendor ID: 0x5333
                                        Device ID: 0x8D04
                                        SubSys ID: 0x83751071
                                      Revision ID: 0x0000
                                      Revision ID: 0x0000
                                      Video Accel: ModeMPEG2_C ModeMPEG2_A ModeMPEG2_D
                                Deinterlace Caps: n/a
                                         Registry: OK
                                       D3D Status: Enabled
                                       AGP Status: Enabled
                                DDraw Test Result: Not run
                                D3D7 Test Result: Not run
                                D3D8 Test Result: Not run
                                D3D9 Test Result: Not run
                                Sound Devices
                                            Description: Vinyl AC'97 Audio (WAVE)
                                            Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_83751071&REV_50
                                        Manufacturer ID: 1
                                             Product ID: 100
                                                   Type: WDM
                                            Driver Name: vinyl97.sys
                                         Driver Version: 6.14.0001.4170 (English)
                                            WHQL Logo'd: Yes
                                          Date and Size: 8/10/2006 07:32:14, 204672 bytes
                                            Other Files:
                                        Driver Provider: VIA Technologies, Inc.
                                         HW Accel Level: Full
                                              Cap Flags: 0xF5F
                                    Min/Max Sample Rate: 8000, 48000
                                              HW Memory: 0
                                               Registry: OK
                                      Sound Test Result: Not run
                                              Cap Flags: 0x41
                                           Format Flags: 0xFFF
                                DirectMusic
                                        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
                                     DLS Version: 1.00.0016.0002
                                    Acceleration: n/a
                                           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                                                  Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
                                                  Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                                  Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                        Registry: OK
                                DirectInput Devices
                                      Device Name: Mouse
                                         Attached: 1
                                    Controller ID: n/a
                                        FF Driver: n/a
                                         Attached: 1
                                    Controller ID: n/a
                                        FF Driver: n/a
                                         Registry: OK
                                USB Devices
                                + USB Root Hub
                                | Vendor/Product ID: 0x1106, 0x3038
                                | Service: usbhub
                                | Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes
                                | Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
                                Gameport Devices
                                PS/2 Devices
                                + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
                                | Service: i8042prt
                                | Driver: i8042prt.sys, 4/13/2008 20:18:00, 52480 bytes
                                | Driver: kbdclass.sys, 4/13/2008 19:39:47, 24576 bytes
                                | Service: TermDD
                                | Driver: termdd.sys, 4/14/2008 01:13:20, 40840 bytes
                                + Microsoft PS/2 Mouse
                                | Matching Device ID: *pnp0f03
                                | Service: i8042prt
                                | Driver: mouclass.sys, 4/13/2008 19:39:47, 23040 bytes
                                | Vendor/Product ID: 0x192F, 0x0716
                                | Matching Device ID: hid_device_system_mouse
                                | Service: mouhid
                                | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
                                | Service: TermDD
                                DirectPlay Service Providers
                                DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
                                IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
                                Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
                                Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
                                DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
                                DirectPlay Test Result: Not run
                                Registry: OK
                                DirectPlay Adapters
                                DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
                                DirectPlay Voice Codecs
                                Voxware VR12 1.4kbit/s
                                Voxware SC06 6.4kbit/s
                                Voxware SC03 3.2kbit/s
                                MS-PCM 64 kbit/s
                                MS-ADPCM 32.8 kbit/s
                                Microsoft GSM 6.10 13 kbit/s
                                TrueSpeech(TM) 8.6 kbit/s
                                DirectPlay Lobbyable Apps
                                      Drive: C:
                                Free Space: 14.9 GB
                                Total Space: 30.1 GB
                                File System: NTFS
                                      Model: TOSHIBA MK4032GAX
                                      Drive: D:
                                Free Space: 2.4 GB
                                Total Space: 8.0 GB
                                File System: NTFS
                                      Drive: E:
                                      Model: SONY CD-RW  CRX835E
                                     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:46, 62976 bytes
                                System Devices
                                     Name: S3 Graphics ProSavageDDR
                                Device ID: PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00\4&26E5833C&0&0008
                                   Driver: C:\WINDOWS\system32\DRIVERS\s3gnbm.sys, 6.14.0010.0025 (English), 3/2/2004 14:02:30, 167040 bytes
                                   Driver: C:\WINDOWS\system32\s3gnb.dll, 6.14.0010.0025 (English), 3/2/2004 14:02:26, 402048 bytes
                                   Driver: C:\WINDOWS\system32\nbicdnt.dll, 2.40.0121.0000 (English), 12/19/2003 18:12:38, 761856 bytes
                                   Driver: C:\WINDOWS\help\S3DspWST.hlp, 9/23/2003 02:06:12, 176152 bytes
                                   Driver: C:\WINDOWS\help\S3DspCHS.hlp, 9/23/2003 02:06:04, 18279 bytes
                                   Driver: C:\WINDOWS\help\S3DspCHT.hlp, 9/23/2003 02:06:08, 16534 bytes
                                   Driver: C:\WINDOWS\help\S3DspJPN.hlp, 9/23/2003 02:06:08, 17373 bytes
                                   Driver: C:\WINDOWS\help\S3DspKOR.hlp, 9/23/2003 02:06:08, 18736 bytes
                                   Driver: C:\WINDOWS\system32\S3Disply.dll, 2.00.0007.0922 (English), 9/23/2003 02:07:26, 458752 bytes
                                   Driver: C:\WINDOWS\system32\S3Disply.cfg, 9/23/2003 02:07:38, 62392 bytes
                                   Driver: C:\WINDOWS\system32\S3Displ2.cfg, 9/23/2003 02:07:38, 60904 bytes
                                   Driver: C:\WINDOWS\help\s3in2wst.hlp, 2/10/2004 04:27:02, 39845 bytes
                                   Driver: C:\WINDOWS\help\s3in2chs.hlp, 2/10/2004 04:27:04, 8596 bytes
                                   Driver: C:\WINDOWS\help\s3in2cht.hlp, 2/10/2004 04:27:04, 8645 bytes
                                   Driver: C:\WINDOWS\help\s3in2jpn.hlp, 2/10/2004 04:27:02, 9065 bytes
                                   Driver: C:\WINDOWS\help\s3in2kor.hlp, 2/10/2004 04:27:02, 9067 bytes
                                   Driver: C:\WINDOWS\system32\S3Info2.dll, 2.00.0008.0209 (English), 2/10/2004 04:26:56, 229376 bytes
                                   Driver: C:\WINDOWS\system32\S3Info2.cfg, 2/10/2004 04:27:02, 38191 bytes
                                   Driver: C:\WINDOWS\system32\S3uninst.exe, 1.00.0010.0922 (English), 9/23/2003 01:46:32, 69690 bytes
                                   Driver: C:\WINDOWS\system32\VTPreset.exe, 1.01.0000.0102 (English), 2/24/2004 20:17:18, 45056 bytes
                                   Driver: C:\WINDOWS\help\S3Gm2WST.hlp, 1/20/2004 03:08:38, 129194 bytes
                                   Driver: C:\WINDOWS\help\S3Gm2CHS.hlp, 1/20/2004 03:08:38, 17215 bytes
                                   Driver: C:\WINDOWS\help\S3Gm2CHT.hlp, 1/20/2004 03:08:36, 17492 bytes
                                   Driver: C:\WINDOWS\help\S3Gm2JPN.hlp, 1/20/2004 03:08:36, 16804 bytes
                                   Driver: C:\WINDOWS\help\S3Gm2KOR.hlp, 1/20/2004 03:08:36, 19691 bytes
                                   Driver: C:\WINDOWS\system32\S3Gamma2.dll, 2.00.0009.0119 (English), 1/20/2004 03:09:18, 352256 bytes
                                   Driver: C:\WINDOWS\system32\S3Gamma2.cfg, 1/20/2004 03:09:18, 48879 bytes
                                   Driver: C:\WINDOWS\help\s3ovlwst.hlp, 2/18/2004 03:40:44, 55911 bytes
                                   Driver: C:\WINDOWS\help\s3ovlchs.hlp, 2/18/2004 03:40:48, 9762 bytes
                                   Driver: C:\WINDOWS\help\s3ovlcht.hlp, 2/18/2004 03:40:46, 9732 bytes
                                   Driver: C:\WINDOWS\help\s3ovljpn.hlp, 2/18/2004 03:40:46, 10153 bytes
                                   Driver: C:\WINDOWS\help\s3ovlkor.hlp, 2/18/2004 03:40:46, 10363 bytes
                                   Driver: C:\WINDOWS\system32\S3Ovrlay.dll, 2.00.0010.0217 (English), 2/18/2004 03:41:56, 339968 bytes
                                   Driver: C:\WINDOWS\system32\S3Ovrlay.cfg, 8/6/2003 06:44:38, 54112 bytes
                                     Name: Generic CardBus Controller
                                Device ID: PCI\VEN_1524&DEV_1410&SUBSYS_83751071&REV_00\3&61AAA01&0&48
                                   Driver: C:\WINDOWS\system32\DRIVERS\pcmcia.sys, 5.01.2600.5512 (English), 4/13/2008 19:36:43, 120192 bytes
                                     Name: VIA CPU to AGP Controller
                                Device ID: PCI\VEN_1106&DEV_B091&SUBSYS_00000000&REV_00\3&61AAA01&0&08
                                   Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP.SYS, 5.01.2600.5512 (English), 4/13/2008 19:36:40, 42240 bytes
                                     Name: PCI standard ISA bridge
                                Device ID: PCI\VEN_1106&DEV_3177&SUBSYS_00000000&REV_00\3&61AAA01&0&88
                                   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 19:36:41, 37248 bytes
                                     Name: PCI standard host CPU bridge
                                Device ID: PCI\VEN_1106&DEV_3156&SUBSYS_00000000&REV_00\3&61AAA01&0&00
                                   Driver: n/a
                                     Name: VIA USB Enhanced Host Controller
                                Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_83751071&REV_82\3&61AAA01&0&83
                                   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 30208 bytes
                                   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 143872 bytes
                                   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 01:12:08, 74240 bytes
                                   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:37, 59520 bytes
                                   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 01:11:54, 7168 bytes
                                     Name: PCI Simple Communications Controller
                                Device ID: PCI\VEN_1106&DEV_3068&SUBSYS_83751071&REV_80\3&61AAA01&0&8E
                                   Driver: n/a
                                     Name: VIA Rhine II Fast Ethernet Adapter
                                Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_83751071&REV_74\3&61AAA01&0&90
                                   Driver: C:\WINDOWS\system32\DRIVERS\fetnd5bv.sys, 3.41.0000.0426 (English), 12/16/2004 14:36:30, 42496 bytes
                                   Driver: C:\WINDOWS\system32\vuins32.dll, 1.04.0000.0009 (English), 9/17/2004 18:37:42, 61440 bytes
                                     Name: Vinyl AC'97 Codec Combo Driver (WDM)
                                Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_83751071&REV_50\3&61AAA01&0&8D
                                   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/14/2008 01:11:56, 4096 bytes
                                   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/14/2008 01:12:42, 129536 bytes
                                   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/13/2008 20:16:36, 141056 bytes
                                   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:14, 60160 bytes
                                   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 20:19:41, 146048 bytes
                                   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/13/2008 19:45:15, 49408 bytes
                                   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 01:12:45, 23552 bytes
                                   Driver: C:\WINDOWS\system32\drivers\vinyl97.sys, 6.14.0001.4170 (English), 8/10/2006 07:32:14, 204672 bytes
                                     Name: VIA OHCI Compliant IEEE 1394 Host Controller
                                Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_83751071&REV_80\3&61AAA01&0&58
                                   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 61696 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 53376 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 61824 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 60800 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
                                     Name: VIA Rev 5 or later USB Universal Host Controller
                                Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_83751071&REV_80\3&61AAA01&0&81
                                   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 20608 bytes
                                Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_83751071&REV_80\3&61AAA01&0&80
                                     Name: VIA Bus Master IDE Controller
                                Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_83751071&REV_06\3&61AAA01&0&89
                                   Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 4/13/2008 19:40:31, 5376 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:29, 24960 bytes
                                   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:30, 96512 bytes
                                DirectX Components
                                   ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 279552 bytes
                                ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 27136 bytes
                                   dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
                                    d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 1179648 bytes
                                d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 8192 bytes
                                    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 1689088 bytes
                                   d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
                                d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:51 824320 bytes
                                d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
                                   d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
                                  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
                                d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
                                   dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
                                  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 229888 bytes
                                dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 23552 bytes
                                dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
                                dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 57344 bytes
                                dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:17 29696 bytes
                                  dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:17 17920 bytes
                                   dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 375296 bytes
                                dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:20 3072 bytes
                                dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:19 3072 bytes
                                dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 212480 bytes
                                dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:18 83456 bytes
                                  dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 116736 bytes
                                  dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 21504 bytes
                                dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 35328 bytes
                                dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 60928 bytes
                                dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
                                  dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 158720 bytes
                                dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 181760 bytes
                                   dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
                                diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
                                     joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:41 68608 bytes
                                   gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
                                     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:02 35328 bytes
                                  dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 367616 bytes
                                dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 1293824 bytes
                                  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 19456 bytes
                                   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 181248 bytes
                                dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 71680 bytes
                                  dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 104448 bytes
                                  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 28672 bytes
                                dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 61440 bytes
                                   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 181248 bytes
                                dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 35840 bytes
                                dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 105984 bytes
                                dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 103424 bytes
                                dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 82432 bytes
                                   dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 619008 bytes
                                   dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 1227264 bytes
                                dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:52 2113536 bytes
                                   mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 07:53:25 954368 bytes
                                   mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 14:33:55 978944 bytes
                                wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 01:12:10 22528 bytes
                                amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:11:49 70656 bytes
                                devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:11:51 59904 bytes
                                  dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 01:11:52 498742 bytes
                                mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:11:56 35328 bytes
                                mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:42 148992 bytes
                                   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:11:59 14336 bytes
                                  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:53 20480 bytes
                                    qasf.dll: 10.00.0000.4332 English Final Retail 1/16/2007 21:07:55 221184 bytes
                                    qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:03 192512 bytes
                                     qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:03 279040 bytes
                                    qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 16:28:36 386048 bytes
                                   qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:03 562176 bytes
                                qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:21:32 733696 bytes
                                  quartz.dll: 6.05.2600.6169 English Final Retail 11/3/2011 16:28:36 1292288 bytes
                                strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 09:00:21 247326 bytes
                                iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 01:12:42 199680 bytes
                                  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 01:12:42 848384 bytes
                                ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 01:11:55 120320 bytes
                                ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 01:11:55 338432 bytes
                                ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 01:11:55 755200 bytes
                                ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 01:11:55 200192 bytes
                                ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 01:11:55 183808 bytes
                                   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 01:12:42 154624 bytes
                                mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 10:01:48 204800 bytes
                                      ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 20:16:36 141056 bytes
                                  ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:42 129536 bytes
                                  ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:11:56 4096 bytes
                                  stream.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:45:15 49408 bytes
                                mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:39:50 5376 bytes
                                   mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 19:39:51 4992 bytes
                                mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:39:52 7552 bytes
                                  swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:39:53 4352 bytes
                                mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:42 118272 bytes
                                msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 01:12:01 1428992 bytes
                                  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:42 30208 bytes
                                   msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 18:11:44 17920 bytes
                                wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 01:12:10 50688 bytes
                                DirectShow Filters
                                DirectShow Filters:
                                WMAudio Decoder DMO,0x00800800,1,1,,
                                WMAPro over S/PDIF DMO,0x00600800,1,1,,
                                WMSpeech Decoder DMO,0x00600800,1,1,,
                                WMVideo Advanced Decoder DMO,0x00800001,1,1,,
                                Mpeg4s Decoder DMO,0x00800001,1,1,,
                                WMV Screen decoder DMO,0x00800001,1,1,,
                                WMVideo Decoder DMO,0x00800001,1,1,,
                                Mpeg43 Decoder DMO,0x00800001,1,1,,
                                Mpeg4 Decoder DMO,0x00800001,1,1,,
                                WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
                                Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6169
                                DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
                                Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6169
                                WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.4332
                                AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
                                Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
                                AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
                                WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
                                WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
                                WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
                                MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6169
                                SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
                                MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
                                ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
                                Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
                                MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6169
                                File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
                                WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
                                Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
                                Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
                                Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
                                WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
                                NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
                                Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
                                Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
                                Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
                                Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6169
                                WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
                                Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6169
                                WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.4332
                                WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
                                Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
                                File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
                                WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
                                DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
                                Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
                                AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6169
                                .RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
                                WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
                                MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
                                DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
                                Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
                                Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
                                ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
                                9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
                                Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
                                Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
                                WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
                                WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
                                Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
                                Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
                                AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6169
                                QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6169
                                XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
                                AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
                                Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6169
                                File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6169
                                File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6169
                                WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
                                MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6169
                                Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
                                Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
                                WDM Streaming Data Transforms:
                                Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
                                Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
                                Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
                                Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
                                Video Compressors:
                                MSScreen encoder DMO,0x00600800,1,1,,
                                WMVideo9 Encoder DMO,0x00600800,1,1,,
                                WMVideo Advanced Encoder DMO,0x00600800,1,1,,
                                MSScreen 9 encoder DMO,0x00600800,1,1,,
                                DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
                                Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
                                MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6169
                                Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                Audio Compressors:
                                WM Speech Encoder DMO,0x00600800,1,1,,
                                WMAudio Encoder DMO,0x00600800,1,1,,
                                IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6169
                                Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6169
                                Vinyl AC'97 Audio (WAVE),0x00200000,0,0,qcap.dll,6.05.2600.5512
                                Midi Renderers:
                                Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
                                Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6169
                                WDM Streaming Capture Devices:
                                Vinyl AC'97 Audio (WAVE),0x00200000,3,2,,5.03.2600.5512
                                WDM Streaming Rendering Devices:
                                BDA Transport Information Renderers:
                                MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
                                WDM Streaming Mixer Devices:
                                Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
                                BDA CP/CA Filters:
                                Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
                                Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
                                XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
                                Audio Renderers:
                                Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.6169
                                Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
                                Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6169
                                DirectSound: Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.6169
                                WDM Streaming System Devices:
                                Vinyl AC'97 Audio (WAVE),0x00200000,12,2,,5.03.2600.5512
                                • 13. Re: Video investigation with Flash Player 11.2.202.228
                                  chris.campbell Adobe Employee
                                  We'll be releasing a new beta of Flash Player 11.3 within the next few days that should address most problems reported in this thread.  I'll post back with more info as soon as the release is available.
                                  Chris
                                  • 15. Re: Video investigation with Flash Player 11.2.202.228
                                    Beta 3 was released this afternoon.  When you have some time, please give it a try and let us know how it works for you.
                                    Chris
                                    • 16. Re: Video investigation with Flash Player 11.2.202.228
                                      Adam Skovron Level 1
                                      Hi Chris
                                      Unfortunately still have the same problems... here is a screenshot of the page (on adobe.com) with the player version showing and the green bar persisting.
                                      http://dl.dropbox.com/u/4412332/adobe-flash-v11-3-beta-20120505.png
                                      [nb: link will be deleted once issue is resolved]
                                      Let me know if you want/need more info.
                                      Adam
                                      • 17. Re: Video investigation with Flash Player 11.2.202.228
                                        dru222
                                        All flash video players, including all of youtube, jwplayer, ALL browsers, have the green overlay at the top and color shift down.  This started after one of the recent flash player updates.
                                        All 20 computers at my company are doing it. Win 7
                                        • 18. Re: Video investigation with Flash Player 11.2.202.228
                                          Adam - We're still investigating.  Hoping to have another test for you shortly.
                                          dru222 - Sorry you're running into this.  Did you update your drivers as noted in my first post?  Did you try using Beta 3 to see if that helped?
                                          Chris
                                          • 19. Re: Video investigation with Flash Player 11.2.202.228
                                            jaylan42
                                            Beta 3 seems to fix the problem but it crashed constantly.
                                            System Information
                                            Time of this report: 5/16/2012, 13:04:09
                                                   Machine name: ----------
                                               Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
                                                       Language: English (Regional Setting: English)
                                            System Manufacturer: Dell Inc.
                                                   System Model: Latitude E6520
                                                           BIOS: Default System BIOS
                                                      Processor: Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz (4 CPUs), ~2.7GHz
                                                         Memory: 8192MB RAM
                                            Available OS Memory: 8074MB RAM
                                                      Page File: 6786MB used, 9358MB available
                                                    Windows Dir: C:\Windows
                                                DirectX Version: DirectX 11
                                            DX Setup Parameters: Not found
                                               User DPI Setting: Using System DPI
                                            System DPI Setting: 96 DPI (100 percent)
                                                DWM DPI Scaling: Disabled
                                                 DxDiag Version: 6.01.7601.17514 32bit Unicode
                                            • 20. Re: Video investigation with Flash Player 11.2.202.228
                                              KenInMaine Level 1
                                              The test build of Flash has also been crashing freqently for me. Again I'm on Win7 64bit Professional and primarily use Firefox as my webbrowser.
                                              • 21. Re: Video investigation with Flash Player 11.2.202.228
                                                Are you both finding that it crashes with video or using any Flash content?  Would you mind grabbing a couple crash ID's for me so I can follow up internally?
                                                http://helpx.adobe.com/flash-player/kb/report-flash-player-crash.html#main_Mozilla_Firefox _on_Windows
                                                Chris
                                                • 22. Re: Video investigation with Flash Player 11.2.202.228
                                                  KenInMaine Level 1
                                                  I'll try to keep an eye on it.  I haven't had a Flash crash for a few days now.  Frequently what I see is just a Firefox plugin crashed message.  Frequently it was in some ad slot so I didn't really care that much.  I also noticed crashes a few times if there were too many embedded YouTube videos on one page.  Not very helpful I know.
                                                  • 23. Re: Video investigation with Flash Player 11.2.202.228
                                                    jaylan42 Level 1
                                                    Is this enough?
                                                    Problem signature:
                                                      Problem Event Name:    APPCRASH
                                                      Application Name:    FlashPlayerPlugin_11_3_300_250.exe
                                                      Application Version:    11.3.300.250
                                                      Application Timestamp:    4fa1e5dd
                                                      Fault Module Name:    NPSWF32_11_3_300_250.dll
                                                      Fault Module Version:    11.3.300.250
                                                      Fault Module Timestamp:    4fa1e7ac
                                                      Exception Code:    c0000005
                                                      Exception Offset:    0016b4bd
                                                      OS Version:    6.1.7601.2.1.0.256.1
                                                      Locale ID:    1033
                                                      Additional Information 1:    0a9e
                                                      Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
                                                      Additional Information 3:    0a9e
                                                      Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
                                                    • 24. Re: Video investigation with Flash Player 11.2.202.228
                                                      jaylan42 Level 1
                                                      Just happened again.. Crashed with Google's stock watcher. I wasn't actually even using Firefox when it crashed.
                                                      http://www.google.com/finance?q=NASDAQ%3AFB
                                                      Problem signature:
                                                        Exception Offset:    000ccb60
                                                        Locale ID:    1033
                                                      • 25. Re: Video investigation with Flash Player 11.2.202.228
                                                        jaylan42 - Could you type "about:crashes" in Firefox's address field and paste the contents in a reply or email it to me at ccampbel@adobe.com?
                                                        Chris
                                                        • 26. Re: Video investigation with Flash Player 11.2.202.228
                                                          rollirudd
                                                          1. The green line at top of videos and degraded colour reported by others.
                                                          2. After making sure both my display device drivers were up to date, I disabled hardware acceleration, which seems to have fixed the problem.
                                                          3. Most recently, on http://www.abc.net.au/iview/# but also on You-Tube and on other embedded videos running Flash on sites such as www.elephantjournal.com.
                                                          4.
                                                          System Information
                                                          Time of this report: 6/9/2012, 18:30:29
        Machine name: TRACY-PC
                                                             Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
                                                          System Manufacturer: Acer
        System Model: Aspire 5742G
        BIOS: InsydeH2O Version V1.07
        Processor: Intel(R) Core(TM) i3 CPU       M 370  @ 2.40GHz (4 CPUs), ~2.4GHz
        Memory: 4096MB RAM
                                                          Available OS Memory: 3766MB RAM
        Page File: 2869MB used, 4661MB available
                                                          DxDiag Notes
        Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Input Tab: No problems found.
                                                          DirectX Debug Levels
                                                          Direct3D:    0/4 (retail)
                                                          DirectDraw:  0/4 (retail)
                                                          DirectInput: 0/5 (retail)
                                                          DirectMusic: 0/5 (retail)
                                                          DirectPlay:  0/9 (retail)
                                                          DirectSound: 0/5 (retail)
                                                          DirectShow:  0/6 (retail)
                                                          Display Devices
        Card name: Intel(R) HD Graphics
        Manufacturer: Intel Corporation
        Chip type: Intel(R) HD Graphics (Core i3)
        DAC type: Internal
        Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_04881025&REV_02
                                                               Display Memory: 1755 MB
                                                             Dedicated Memory: 128 MB
        Shared Memory: 1627 MB
        Current Mode: 1366 x 768 (32 bit) (60Hz)
        Monitor Model: unknown
        Monitor Id: AUO22EC
        Native Mode: 1366 x 768(p) (60.042Hz)
        Output Type: Internal
        Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
                                                          Driver File Version: 8.15.0010.2622 (English)
                                                               Driver Version: 8.15.10.2622
        DDI Version: 10
        Driver Model: WDDM 1.1
                                                             Driver Date/Size: 1/10/2012 22:28:32, 8313856 bytes
        WHQL Logo'd: Yes
                                                              WHQL Date Stamp:
                                                            Device Identifier: {D7B78E66-4306-11CF-AB79-8224A2C2C535}
        Vendor ID: 0x8086
        Device ID: 0x0046
        SubSys ID: 0x04881025
        Revision ID: 0x0002
                                                          Driver Strong Name: oem35.inf:IntelGfx.NTamd64.6.0:iILKM0:8.15.10.2622:pci\ven_8086&dev_0046
                                                               Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
                                                             Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        D3D9 Overlay: Supported
        DXVA-HD: Supported
        DDraw Status: Enabled
        D3D Status: Enabled
        AGP Status: Enabled
                                                          Sound Devices
        Description: Speakers (Realtek High Definition Audio)
                                                          Default Sound Playback: Yes
                                                          Default Voice Playback: Yes
        Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0272&SUBSYS_10250487&REV_1000
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        Driver Name: RTKVHD64.sys
        Driver Version: 6.00.0001.6141 (English)
        WHQL Logo'd: Yes
        Date and Size: 6/22/2010 20:03:10, 2399848 bytes
        Other Files:
        Driver Provider: Realtek Semiconductor Corp.
        HW Accel Level: Basic
        Cap Flags: 0xF1F
                                                              Min/Max Sample Rate: 100, 200000
                                                          Static/Strm HW Mix Bufs: 1, 0
                                                          Static/Strm HW 3D Bufs: 0, 0
        HW Memory: 0
        Voice Management: No
                                                          EAX(tm) 2.0 Listen/Src: No, No
                                                             I3DL2(tm) Listen/Src: No, No
                                                          Sensaura(tm) ZoomFX(tm): No
                                                          Sound Capture Devices
        Description: Microphone (Realtek High Definition Audio)
                                                            Default Sound Capture: Yes
                                                            Default Voice Capture: Yes
        Cap Flags: 0x1
        Format Flags: 0xFFFFF
                                                          DirectInput Devices
        Device Name: Mouse
        Attached: 1
                                                              Controller ID: n/a
                                                          Vendor/Product ID: n/a
        FF Driver: n/a
        Device Name: Keyboard
        Attached: 1
                                                              Controller ID: n/a
        FF Driver: n/a
                                                          Poll w/ Interrupt: No
                                                          USB Devices
                                                          + USB Root Hub
                                                          | Vendor/Product ID: 0x8086, 0x3B34
                                                          | Matching Device ID: usb\root_hub20
                                                          | Service: usbhub
                                                          +-+ Generic USB Hub
                                                          | | Vendor/Product ID: 0x8087, 0x0020
                                                          | | Matching Device ID: usb\class_09
                                                          | | Service: usbhub
                                                          Gameport Devices
                                                          PS/2 Devices
                                                          + Standard PS/2 Keyboard
                                                          | Matching Device ID: *pnp0303
                                                          | Service: i8042prt
                                                          + Terminal Server Keyboard Driver
                                                          | Matching Device ID: root\rdp_kbd
                                                          | Upper Filters: kbdclass
                                                          | Service: TermDD
                                                          + Synaptics PS/2 Port TouchPad
                                                          | Matching Device ID: *syn1b16
                                                          | Upper Filters: SynTP
                                                          | Service: i8042prt
                                                          + Terminal Server Mouse Driver
                                                          | Matching Device ID: root\rdp_mou
                                                          | Upper Filters: mouclass
                                                          | Service: TermDD
                                                          Disk & DVD/CD-ROM Drives
        Drive: C:
                                                          Free Space: 276.6 GB
                                                          Total Space: 463.5 GB
                                                          File System: NTFS
        Model: Hitachi HTS545050B9A300
        Drive: D:
        Model: HL-DT-ST DVDRAM GT32N
                                                               Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
                                                          System Devices
                                                               Name: QuickPath Architecture System Address Decoder - 2D01
                                                          Device ID: PCI\VEN_8086&DEV_2D01&SUBSYS_04871025&REV_02\3&4F11E61&0&01
                                                             Driver: n/a
                                                               Name: NVIDIA GeForce GT 420M
                                                          Device ID: PCI\VEN_10DE&DEV_0DF1&SUBSYS_04881025&REV_A1\4&6FAB1F9&0&0008
                                                             Driver: n/a
                                                               Name: Intel(R) Turbo Boost Technology Driver
                                                          Device ID: PCI\VEN_8086&DEV_3B32&SUBSYS_04871025&REV_05\3&11583659&0&FE
                                                             Driver: n/a
                                                               Name: QuickPath Architecture Generic Non-core Registers - 2C62
                                                          Device ID: PCI\VEN_8086&DEV_2C62&SUBSYS_04871025&REV_02\3&4F11E61&0&00
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
                                                          Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_04871025&REV_05\3&11583659&0&FB
                                                             Driver: n/a
                                                               Name: Intel(R) 82801 PCI Bridge - 2448
                                                          Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_04871025&REV_A5\3&11583659&0&F0
                                                             Driver: n/a
                                                               Name: Intel(R) Management Engine Interface
                                                          Device ID: PCI\VEN_8086&DEV_3B64&SUBSYS_04871025&REV_06\3&11583659&0&B0
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series 4 Port SATA AHCI Controller
                                                          Device ID: PCI\VEN_8086&DEV_3B29&SUBSYS_04871025&REV_05\3&11583659&0&FA
                                                             Driver: n/a
                                                          Device ID: PCI\VEN_8086&DEV_0046&SUBSYS_04881025&REV_02\3&11583659&0&10
                                                             Driver: n/a
                                                          Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_04871025&REV_05\3&11583659&0&D8
                                                             Driver: n/a
                                                               Name: Intel(R) HM55 Express Chipset LPC Interface Controller - 3B09
                                                          Device ID: PCI\VEN_8086&DEV_3B09&SUBSYS_04871025&REV_05\3&11583659&0&F8
                                                             Driver: n/a
                                                               Name: Intel(R) processor PCI Express Root Port - 0045
                                                          Device ID: PCI\VEN_8086&DEV_0045&SUBSYS_04871025&REV_02\3&11583659&0&08
                                                             Driver: n/a
                                                               Name: Reserved - 2D13
                                                          Device ID: PCI\VEN_8086&DEV_2D13&SUBSYS_04871025&REV_02\3&4F11E61&0&13
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 2 - 3B44
                                                          Device ID: PCI\VEN_8086&DEV_3B44&SUBSYS_04871025&REV_05\3&11583659&0&E1
                                                             Driver: n/a
                                                               Name: Intel(R) processor DRAM Controller - 0044
                                                          Device ID: PCI\VEN_8086&DEV_0044&SUBSYS_04871025&REV_02\3&11583659&0&00
                                                             Driver: n/a
                                                               Name: Reserved - 2D12
                                                          Device ID: PCI\VEN_8086&DEV_2D12&SUBSYS_04871025&REV_02\3&4F11E61&0&12
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
                                                          Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_04871025&REV_05\3&11583659&0&E0
                                                             Driver: n/a
                                                               Name: Broadcom 802.11n Network Adapter
                                                          Device ID: PCI\VEN_14E4&DEV_4357&SUBSYS_E021105B&REV_01\4&539EEA8&0&00E1
                                                             Driver: n/a
                                                               Name: QPI Physical 0 - 2D11
                                                          Device ID: PCI\VEN_8086&DEV_2D11&SUBSYS_04871025&REV_02\3&4F11E61&0&11
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
                                                          Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_04871025&REV_05\3&11583659&0&D0
                                                             Driver: n/a
                                                               Name: Broadcom NetLink (TM) Gigabit Ethernet
                                                          Device ID: PCI\VEN_14E4&DEV_1692&SUBSYS_036D1025&REV_01\4&14D14F08&0&00E0
                                                             Driver: n/a
                                                               Name: QPI Link 0 - 2D10
                                                          Device ID: PCI\VEN_8086&DEV_2D10&SUBSYS_04871025&REV_02\3&4F11E61&0&10
                                                             Driver: n/a
                                                               Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
                                                          Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_04871025&REV_05\3&11583659&0&E8
                                                             Driver: n/a
                                                          DirectShow Filters
                                                          DirectShow Filters:
                                                          Emuzed AMR-NB Decoder-DMO,0x00400000,1,1,EmzAMRNBDec.dll,2.35.0000.0000
                                                          WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                                                          WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                                                          WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                                                          MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                                                          Emuzed AMR-WB Decoder-DMO,0x00400000,1,1,EzdAMRWBDec.dll,2.35.0000.0000
                                                          G2M Session Decoder,0x00600000,1,1,G2M.dll,5.01.0000.0880
                                                          Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                                                          WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                                                          WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                                                          Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                                                          Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                                                          CyberLink Audio Effect (PDVD9),0x00200000,1,1,ClAudFx.ax,6.00.0000.7209
                                                          WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
                                                          Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
                                                          WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
                                                          WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
                                                          WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
                                                          WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8117.0416
                                                          WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
                                                          Emuzed AMR/3GPP/MP4/MP3 Multiplexer-Filter,0x00200000,1,0,EzdMP4MuxFilter.dll,2.35.0000.0000
                                                          Emuzed MP3 Source/Decoder Filter,0x00400000,0,1,EmzMP3SourceFilter.dll,2.35.0000.0000
                                                          DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                                                          Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                                                          CyberLink Digest Filter (PDVD9),0x00200000,2,2,DigestFilter.dll,1.00.0000.3314
                                                          CyberLink TimeStretch Filter (PDVD9),0x00200000,1,1,clauts.ax,2.00.0000.3811
                                                          WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                                                          Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                                                          AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                                          Track2Filter,0x00200000,0,0,Track2Filter.dll,
                                                          VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                                                          Emuzed AMR/QCP/3GPP/MP4/3G2 Source Filter,0x00400000,0,1,EmzMp4Source.dll,2.35.0000.0000
                                                          AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                                                          CyberLink Tzan Filter (PDVD9),0x00200000,1,1,CLTzan.ax,3.05.0000.3509
                                                          StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                                          MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                                                          SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          Nokia MPEG4ASP Decoder Filter,0x00400000,1,1,NokiaDecMP4ASP_H263.dll,2.00.0000.0009
                                                          CyberLink HD/BD Mixer (PDVD9),0x00200000,1,2,CLHBMixer.ax,2.00.0000.2422
                                                          VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                                                          SlideShow,0x00200000,0,1,SlideShow.ax,
                                                          CyberLink Video/SP Decoder (PDVD9),0x00602000,2,3,CLVsd.ax,8.04.0000.1913
                                                          MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                                                          CyberLink AudioCD Filter (PDVD9),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
                                                          Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                                                          SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                                                          Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.1731
                                                          CyberLink Audio Decoder (PDVD9),0x00201000,1,1,Claud.ax,8.04.0000.3525
                                                          Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                                                          Cyberlink SubTitle Importor (PDVD9),0x00200000,2,1,CLSubTitle.ax,2.00.0000.0416
                                                          MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                                                          Nokia H264Dec HP/MP Filter,0x00400000,1,1,NokiaH264HPMPDecTFilter.dll,2.00.0000.0009
                                                          Liteon Pause Audio,0x00200000,1,1,lopa.ax,
                                                          DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                                                          Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                          CyberLink Line21 Decoder (PDVD9),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
                                                          Haali Media Splitter,0x00800001,0,1,splitter.ax,1.10.0348.0015
                                                          Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.10.0348.0015
                                                          Emuzed AAC/AAC+ Decoder TFilter,0x00400000,1,1,EmzAACDecFilter.dll,2.35.0000.0000
                                                          Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                                                          CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.2906
                                                          ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                                          Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                                                          MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
                                                          Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                                                          Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                                                          Emuzed MP4SP/H263 Video Decoder-Filter,0x00400000,1,1,EmzDecMP4_H263.dll,2.35.0000.0000
                                                          Cyberlink SubTitle Importor 2.0 (PDVD9),0x00200000,1,0,CLSubTitle.ax,2.00.0000.0416
                                                          CyberLink FLV Splitter (PDVD9),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.1030
                                                          Haali Video Renderer,0x00200000,1,0,dxr.dll,
                                                          File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
                                                          VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                                                          WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                                                          VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                                                          CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
                                                          File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                                                          iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                                                          CyberLink Audio Spectrum Analyzer (PDVD9),0x00200000,1,1,CLAudSpa.ax,1.00.0000.7113
                                                          iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                                                          Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.10.0348.0015
                                                          CyberLink DVD Navigator (PDVD9),0x00200000,0,3,CLNavX.ax,8.01.0001.1725
                                                          CyberLink MPEG-4 Splitter (PDVD9),0x00200000,1,2,clm4splt.ax,1.01.0000.2911
                                                          CyberLink RealMedia Splitter (PDVD9),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1103
                                                          WAV Dest,0x00000000,0,0,,
                                                          DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
                                                          Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
                                                          Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.10.0348.0015
                                                          AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
                                                          RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                                                          Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                                                          WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                                                          MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                                                          CyberLink RealAudio Decoder (PDVD9),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
                                                          DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                                                          Emuzed H264 Video Decoder-Filter,0x00200000,1,1,EzdH264DecTFilter.dll,2.37.0000.0000
                                                          Liteon Down Scaler,0x00200000,1,1,lods.ax,1.00.0000.0005
                                                          SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                                                          Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                                                          MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                                                          Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                                                          StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                                                          CyberLink RealVideo Decoder (PDVD9),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
                                                          Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
                                                          AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                                          AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                                                          Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                                          Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                                                          StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                                          AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                                                          Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                                                          File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                                                          File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                                                          Haali Video Sink,0x00200000,1,0,splitter.ax,1.10.0348.0015
                                                          Track1Filter,0x00200000,0,0,Track1Filter.dll,
                                                          Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                                                          CyberLink Matroska Splitter (PDVD9),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1728
                                                          BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                                                          MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                                                          Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2227
                                                          Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2227
                                                          Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2227
                                                          Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2227
                                                          Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2227
                                                          Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2227
                                                          Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2227
                                                          Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2227
                                                          Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2227
                                                          Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2227
                                                          Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2227
                                                          Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2227
                                                          Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl.dll,1.01.0000.2227
                                                          Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Track Compressor,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2227
                                                          Sony Dither,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2227
                                                          Sony Chorus,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Distortion,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          Sony Gapper/Snipper,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          Sony Simple Delay,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Reverb,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Multi-Tap Delay,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Track Noise Gate,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2227
                                                          Sony Graphic EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Track EQ,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2227
                                                          Sony Smooth/Enhance,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          Sony Resonant Filter,0x00200000,1,1,sfresfilter.dll,1.01.0000.2227
                                                          Sony Parametric EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Time Stretch,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Noise Gate,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Paragraphic EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Vibrato,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          Sony Pan,0x00200000,1,1,sffrgpnv.dll,1.01.0000.2227
                                                          Sony Pitch Shift,0x00200000,1,1,sfppack1.dll,1.01.0000.2227
                                                          Sony Volume,0x00200000,1,1,sffrgpnv.dll,1.01.0000.2227
                                                          Sony Flange/Wah-wah,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          Sony Graphic Dynamics,0x00200000,1,1,sfppack2.dll,1.01.0000.2227
                                                          Sony Amplitude Modulation,0x00200000,1,1,sfppack3.dll,1.01.0000.2227
                                                          WDM Streaming Tee/Splitter Devices:
                                                          Video Compressors:
                                                          Emuzed H263 Video Encoder-DMO,0x00400000,1,1,EmzH263Enc.dll,2.35.0000.0000
                                                          WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                                                          WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                                                          Emuzed H.264 Encoder-DMO,0x00400000,1,1,EzdH264Enc.dll,2.35.0000.0000
                                                          Emuzed MPEG-4 SP Encoder-DMO,0x00400000,1,1,EmzMP4VideoEnc.DLL,2.35.0000.0000
                                                          MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                                                          DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                                                          MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                                                          Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox DVCPRO,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox DVCPRO50,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox DVCPRO HD,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox DV/DVCAM,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Lossless RGBA compression,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox Uncompressed SD,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox Uncompressed HD,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox Uncompressed SD + Alpha,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox Uncompressed HD + Alpha,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox EZ-MXF AVI (playback only),0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox MPEG-2 I-frame HD,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox Offline HD,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox HDV (playback only),0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox MPEG-2 I-frame + Alpha,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox MPEG-2 I-frame HD + Alpha,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox M-JPEG (playback only),0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Matrox MPEG-2 I-frame,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                                          Audio Compressors:
                                                          WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                                                          Emuzed GSM AMR-NB Encoder-DMO,0x00400000,1,1,EmzAMRNBEnc.DLL,2.35.0000.0000
                                                          Emuzed GSM AMR-WB Encoder DMO,0x00400000,1,1,EmzAMRWBEnc.DLL,2.35.0000.0000
                                                          WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                                                          Emuzed MP3 Encoder-DMO,0x00400000,1,1,EmzMP3EncDMO.DLL,2.35.0000.0000
                                                          Emuzed AAC Encoder-DMO,0x00400000,1,1,EmzAACEnc.dll,2.35.0000.0000
                                                          IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                                          Audio Capture Sources:
                                                          Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
                                                          PBDA CP Filters:
                                                          PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                                                          PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                                                          PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                                                          Midi Renderers:
                                                          Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                                                          Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                          Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                          Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                          1.3M WebCam,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                          Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                          BDA Network Providers:
                                                          Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                                          Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                                          Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                                          Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                                          Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                                                          Video Capture Sources:
                                                          Multi-Instance Capable VBI Codecs:
                                                          BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
                                                          MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                                                          BDA CP/CA Filters:
                                                          Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
                                                          Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                                          PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                                          XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                                          WDM Streaming Communication Transforms:
                                                          Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                          Audio Renderers:
                                                          Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                          CyberLink Audio Renderer (PDVD9),0x00200000,1,0,cladr.ax,7.00.0000.2807
                                                          Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                                                          Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                          DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                          EVR Power Information
                                                          Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
                                                            Quality Flags: 2576
                                                              Enabled:
                                                              Force throttling
                                                              Allow half deinterlace
                                                              Allow scaling
                                                              Decode Power Usage: 100
                                                            Balanced Flags: 1424
                                                              Enabled:
                                                              Force throttling
                                                              Allow batching
                                                              Force half deinterlace
                                                              Force scaling
                                                              Decode Power Usage: 50
                                                            PowerFlags: 1424
                                                              Enabled:
                                                              Force throttling
                                                              Allow batching
                                                              Force scaling
                                                              Decode Power Usage: 0
                                                          • 27. Re: Video investigation with Flash Player 11.2.202.228
                                                            ReverendTed
                                                            1. What problem are you encountering?
                                                            I'm getting completely green video with working audio on many (but not all) embedded videos.  Disabling CrossFireX used to fix it, but no longer appears to work.  (One bit of information I'm not sure is or isn't communicated in the DxDiag report is that I'm on Vista 64bit.  I seem to recall noticing this problem first after the first Flash update that warned me Vista 64bit wasn't supported.)
                                                            2. Try disabling Flash's hardware acceleration.  Does this fix the bug?
                                                            Maybe.  I disabled it (Right-Click, Settings, Unchecked Hardware Accelleration) and still had the green screen until I reloaded the tab.  Video appears to be playing correctly now.
                                                            3. What URL did you use to view video?
                                                            http://www.escapistmagazine.com/videos/view/zero-punctuation/5893-Max-Payne-3
                                                            4. DxDiag Report
                                                            System Information
                                                            Time of this report: 6/11/2012, 18:50:01
        Machine name: MEGACROTTE
                                                               Operating System: Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.120402-0336)
        System Model: XPS 630i
        BIOS: Phoenix - AwardBIOS v6.00PG
        Processor: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz (4 CPUs), ~3.0GHz
        Memory: 4092MB RAM
        Page File: 2985MB used, 5408MB available
        DxDiag Version: 7.00.6002.18107 32bit Unicode
                                                            DxDiag Notes
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
                                                            Display Devices
        Card name: ATI Radeon HD 4800 Series
        Manufacturer: Advanced Micro Devices, Inc.
        Chip type: ATI display adapter (0x9442)
        DAC type: Internal DAC(400MHz)
        Device Key: Enum\PCI\VEN_1002&DEV_9442&SUBSYS_05021028&REV_00
                                                               Display Memory: 2295 MB
                                                            Dedicated Memory: 505 MB
        Shared Memory: 1790 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
        Monitor: Generic PnP Monitor
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
                                                               Driver Version: 8.17.0010.1124 (English)
        DDI Version: 10.1
                                                               BGRA Supported: Yes
                                                            Driver Attributes: Final Retail
                                                            Driver Date/Size: 4/5/2012 21:20:04, 1067520 bytes
        WHQL Logo'd: n/a
                                                              WHQL Date Stamp: n/a
                                                            Device Identifier: {D7B71EE2-D702-11CF-FC77-0825BEC2C535}
        Vendor ID: 0x1002
        Device ID: 0x9442
        SubSys ID: 0x05021028
        Revision ID: 0x0000
        Revision ID: 0x0000
                                                            Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
        {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        D3D Status: Enabled
        AGP Status: Enabled
                                                            Sound Devices
        Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10280249&REV_1001
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        Driver Version: 6.00.0001.6449 (English)
        WHQL Logo'd: n/a
        Date and Size: 8/30/2011 17:28:46, 3069032 bytes
        Other Files:
        Cap Flags: 0xF1F
        HW Memory: 0
        Description: Realtek HDMI Output (Realtek High Definition Audio)
                                                            Default Sound Playback: No
                                                            Default Voice Playback: No
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        WHQL Logo'd: n/a
        Other Files:
        Cap Flags: 0xF1F
        HW Memory: 0
        Description: Realtek Digital Output (Realtek High Definition Audio)
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        WHQL Logo'd: n/a
        Other Files:
        Cap Flags: 0xF1F
        HW Memory: 0
        Description: Realtek Digital Input (Realtek High Definition Audio)
        Cap Flags: 0x1
                                                            DirectInput Devices
        Device Name: Mouse
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Device Name: ESA FW Update
        Attached: 1
        Controller ID: 0x0
                                                            Vendor/Product ID: 0x0955, 0x000A
        FF Driver: n/a
        Device Name: Dell USB Keyboard Hub
        Attached: 1
        Controller ID: 0x0
                                                            Vendor/Product ID: 0x413C, 0x2006
        FF Driver: n/a
        Attached: 1
        Controller ID: 0x0
        FF Driver: n/a
        Attached: 1
        Controller ID: 0x0
        FF Driver: n/a
                                                            USB Devices
                                                            + USB Root Hub
                                                            | Vendor/Product ID: 0x10DE, 0x026D
                                                            | Service: usbhub
                                                            +-+ Generic USB Hub
                                                            | | Vendor/Product ID: 0x413C, 0x1004
                                                            | | Service: usbhub
                                                            +-+ USB Human Interface Device
                                                            | | Vendor/Product ID: 0x046D, 0xC01D
                                                            | | Matching Device ID: usb\class_03&subclass_01
                                                            | | Service: HidUsb
                                                            | +-+ HID-compliant mouse
                                                            | | | Matching Device ID: hid_device_system_mouse
                                                            | | | Service: mouhid
                                                            | | Matching Device ID: generic_hid_device
                                                            | | Service: HidUsb
                                                            | +-+ HID-compliant device
                                                            Gameport Devices
                                                            PS/2 Devices
                                                            + HID Keyboard Device
                                                            | Matching Device ID: hid_device_system_keyboard
                                                            | Service: kbdhid
                                                            | Service: TermDD
                                                            | Service: TermDD
        Drive: C:
                                                            Free Space: 181.2 GB
                                                            Total Space: 466.9 GB
                                                            File System: NTFS
        Model: ST350062 0AS SCSI Disk Device
        Drive: G:
                                                            Free Space: 1391.4 GB
                                                            Total Space: 1907.7 GB
                                                            File System: NTFS
        Model: WD Ext HDD 1021 USB Device
        Drive: D:
        Model: TSSTcorp DVD+-RW TS-H653F SCSI CdRom Device
        Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), , 0 bytes
                                                            System Devices
        Name: AGERE OHCI Compliant IEEE 1394 Host Controller
                                                            Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_00000000&REV_70\4&239594EF&0&2880
                                                               Driver: n/a
        Name: PCI standard RAM Controller
                                                            Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_02491028&REV_A1\3&2411E6FE&0&11
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_02491028&REV_A1\3&2411E6FE&0&12
                                                               Driver: n/a
        Name: PCI standard PCI-to-PCI bridge
                                                            Device ID: PCI\VEN_10DE&DEV_03B8&SUBSYS_000010DE&REV_A1\3&2411E6FE&0&28
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_000010DE&REV_A1\3&2411E6FE&0&18
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_02491028&REV_A1\3&2411E6FE&0&10
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_02491028&REV_A1\3&2411E6FE&0&06
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_02491028&REV_A1\3&2411E6FE&0&07
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_02491028&REV_A1\3&2411E6FE&0&0E
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_02491028&REV_A1\3&2411E6FE&0&0D
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_02491028&REV_A1\3&2411E6FE&0&0C
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_02491028&REV_A1\3&2411E6FE&0&0B
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_02491028&REV_A1\3&2411E6FE&0&0A
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_02491028&REV_A1\3&2411E6FE&0&09
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_02491028&REV_A1\3&2411E6FE&0&08
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_02491028&REV_A1\3&2411E6FE&0&01
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_02491028&REV_A1\3&2411E6FE&0&04
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_02491028&REV_A1\3&2411E6FE&0&02
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_02491028&REV_A1\3&2411E6FE&0&03
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_02491028&REV_A2\3&2411E6FE&0&05
                                                               Driver: n/a
        Name: PCI standard host CPU bridge
                                                            Device ID: PCI\VEN_10DE&DEV_03A3&SUBSYS_02491028&REV_A2\3&2411E6FE&0&00
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_02491028&REV_A3\3&2411E6FE&0&52
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_02491028&REV_A2\3&2411E6FE&0&48
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&80
                                                               Driver: n/a
        Name: Standard Enhanced PCI to USB Host Controller
                                                            Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_02491028&REV_A3\3&2411E6FE&0&59
                                                               Driver: n/a
        Name: Standard OpenHCD USB Host Controller
                                                            Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_02491028&REV_A3\3&2411E6FE&0&58
                                                               Driver: n/a
        Name: High Definition Audio Controller
                                                            Device ID: PCI\VEN_10DE&DEV_026C&SUBSYS_02491028&REV_A2\3&2411E6FE&0&81
                                                               Driver: n/a
        Name: NVIDIA nForce 10/100/1000 Mbps Ethernet
                                                            Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_02491028&REV_A3\3&2411E6FE&0&A0
                                                               Driver: n/a
        Name: NVIDIA nForce Serial ATA Controller
                                                            Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_02491028&REV_A1\3&2411E6FE&0&78
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_02491028&REV_A1\3&2411E6FE&0&70
                                                               Driver: n/a
        Name: Standard Dual Channel PCI IDE Controller
                                                            Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_02491028&REV_A1\3&2411E6FE&0&68
                                                               Driver: n/a
        Name: NVIDIA nForce System Management
                                                            Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_02491028&REV_A3\3&2411E6FE&0&51
                                                               Driver: n/a
        Name: PCI standard ISA bridge
                                                            Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_02491028&REV_A3\3&2411E6FE&0&50
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301028&REV_00\4&311910C0&0&0128
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301028&REV_00\4&1FF9B3FA&0&0118
                                                               Driver: n/a
        Name: ATI Radeon HD 4800 Series
                                                            Device ID: PCI\VEN_1002&DEV_9442&SUBSYS_05021028&REV_00\4&311910C0&0&0028
                                                               Driver: n/a
                                                            Device ID: PCI\VEN_1002&DEV_9442&SUBSYS_05021028&REV_00\4&1FF9B3FA&0&0018
                                                               Driver: n/a
                                                            DirectShow Filters
                                                            DirectShow Filters:
                                                            QuickTime Audio Decoder Filter,0x00600800,1,1,,
                                                            MP3 Decoder DMO,0x00600800,1,1,,
                                                            WMV Screen decoder DMO,0x00600800,1,1,,
                                                            QuickTime Video Decoder Filter,0x00600800,1,1,,
                                                            Full Screen Renderer,0x00200000,1,0,,6.06.6002.18533
                                                            ATI Ticker,0x00200000,0,1,Ticker.ax,
                                                            DV Muxer,0x00400000,0,0,,6.06.6001.18000
                                                            Color Space Converter,0x00400001,1,1,,6.06.6002.18533
                                                            WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
                                                            Audio Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
                                                            Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
                                                            AVI Splitter,0x00600000,1,1,,6.06.6002.18533
                                                            VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18533
                                                            Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
                                                            AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                                                            DivX AAC Decoder,0x00800000,1,1,daac.ax,8.08.0000.41966
                                                            StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
                                                            MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18533
                                                            WDM Capture Device,0x00200000,1,0,wmesrcwp.dll,7.01.0000.3055
                                                            MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18533
                                                            SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18533
                                                            VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
                                                            MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
                                                            Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6002.18005
                                                            Canon MDP Motion-JPEG Decoder,0x00200001,1,1,CanonMDPMJPEGDecoder.ax,2.05.0000.0005
                                                            Logitech Virtual Camera Filter,0x00800000,0,1,VSF.ax,
                                                            Canon Motion-JPEG Encoder,0x00200000,1,1,CanonMJPEGEncoder.ax,3.02.0000.0004
                                                            Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18533
                                                            MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18533
                                                            MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
                                                            Canon Mov File Parser Filter,0x00600001,1,1,CanonH264Filter.ax,1.03.0001.0015
                                                            DV Splitter,0x00600000,1,2,,6.06.6001.18000
                                                            Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18533
                                                            Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6002.18005
                                                            Color Converter,0x00200000,1,1,declrds.ax,7.01.0000.3055
                                                            ACM Wrapper,0x00600000,1,1,,6.06.6002.18533
                                                            Video Renderer,0x00800001,1,0,,6.06.6002.18533
                                                            MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
                                                            Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
                                                            Video Port Manager,0x00600000,2,1,,6.06.6002.18533
                                                            DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
                                                            Video Renderer,0x00400000,1,0,,6.06.6002.18533
                                                            DivX Demux Filter,0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
                                                            DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
                                                            WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
                                                            DivX Demux Filter (Unrestricted Edition),0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
                                                            Canon Custom Resizer SaveMode,0x00200000,1,1,CanonDESResizer.ax,3.02.0000.0009
                                                            VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
                                                            Canon Text Source Filter,0x00200000,0,1,CanonTextSourceFilter.ax,3.02.0000.0013
                                                            MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
                                                            File writer,0x00200000,1,0,,6.06.6001.18000
                                                            Canon Image Rotation Filter,0x00200000,1,1,CanonRotateFilter.dll,1.05.0001.0018
                                                            Canon Motion-JPEG Decoder,0x00200001,1,1,CanonMJPEGDecoder.ax,3.02.0000.0006
                                                            DVD Navigator,0x00200000,0,3,,6.06.6002.18533
                                                            MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
                                                            Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
                                                            AVI Draw,0x00600064,9,1,,6.06.6002.18533
                                                            Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6002.18005
                                                            WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
                                                            MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                                                            DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
                                                            Canon Actual Data Length Setter,0x00200000,1,1,CanonActualDataLengthSetter.ax,3.02.0000.0005
                                                            Canon H.264 Decode Filter 1.3,0x00600001,1,1,CanonH264Filter.ax,1.03.0001.0015
                                                            Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,7.01.0000.3055
                                                            SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.18005
                                                            Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.18005
                                                            MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
                                                            Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6002.18005
                                                            Canon H.264 Encoder 1.1,0x00200001,1,1,CanonH264Encoder.ax,1.01.0000.0018
                                                            StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
                                                            Smart Tee,0x00200000,1,2,,6.06.6001.18000
                                                            Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
                                                            AVI Decompressor,0x00600000,1,1,,6.06.6002.18533
                                                            Canon Resizer,0x00200000,1,1,CanonResizer.ax,3.02.0000.0006
                                                            AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18533
                                                            Wave Parser,0x00400000,1,1,,6.06.6002.18533
                                                            MIDI Parser,0x00400000,1,1,,6.06.6002.18533
                                                            Multi-file Parser,0x00400000,1,1,,6.06.6002.18533
                                                            File stream renderer,0x00400000,1,1,,6.06.6002.18533
                                                            Canon WAV Dest,0x00200000,0,0,CanonWavDest.ax,3.02.0000.0004
                                                            Video Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
                                                            Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
                                                            AVI Mux,0x00200000,1,0,,6.06.6001.18000
                                                            Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18533
                                                            File Source (Async.),0x00400000,0,1,,6.06.6002.18533
                                                            File Source (URL),0x00400000,0,1,,6.06.6002.18533
                                                            Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
                                                            Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
                                                            BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
                                                            MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18533
                                                            psWav Dest,0x00200000,0,0,psWavDes.ax,1.01.0000.0002
                                                            Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
                                                            Video Compressors:
                                                            WMVideo8 Encoder DMO,0x00600800,1,1,,
                                                            DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
                                                            MJPEG Compressor,0x00200000,0,0,,6.06.6002.18533
                                                            Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
                                                            DivX 6.9.2 Codec (4 Logical CPUs),0x00200000,1,1,,6.06.6001.18000
                                                            Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
                                                            Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
                                                            Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
                                                            DivX 6.9.2 YV12 Decoder,0x00200000,1,1,,6.06.6001.18000
                                                            Audio Compressors:
                                                            IMA ADPCM,0x00200000,1,1,,6.06.6002.18533
                                                            Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18533
                                                            GSM 6.10,0x00200000,1,1,,6.06.6002.18533
                                                            CCITT A-Law,0x00200000,1,1,,6.06.6002.18533
                                                            CCITT u-Law,0x00200000,1,1,,6.06.6002.18533
                                                            MPEG Layer-3,0x00200000,1,1,,6.06.6002.18533
                                                            Realtek Digital Input (Realtek ,0x00200000,0,0,,6.06.6001.18000
                                                            Midi Renderers:
                                                            Default MidiOut Device,0x00800000,1,0,,6.06.6002.18533
                                                            Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18533
                                                            ,0x00000000,0,0,,
                                                            ,0x00000000,0,0,,
                                                            Realtek HD Digital input,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HD Audio Front Mic input,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HD Audio Line input,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HD Audio Mic input,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HD Audio Stereo input,0x00200000,1,1,,6.00.6001.18000
                                                            AMD HD Audio HDMI out #0,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HDA HDMI Out,0x00200000,1,1,,6.00.6001.18000
                                                            Realtek HDA SPDIF Out,0x00200000,1,1,,6.00.6001.18000
                                                            Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                                                            Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                                                            Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                                                            Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                                                            Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
                                                            BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
                                                            MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
                                                            BDA CP/CA Filters:
                                                            Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
                                                            Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                                                            XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                                                            Audio Renderers:
                                                            Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18533
                                                            Default DirectSound Device,0x00800000,1,0,,6.06.6002.18533
                                                            Default WaveOut Device,0x00200000,1,0,,6.06.6002.18533
                                                            DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
                                                            DirectSound: Realtek HDMI Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
                                                            DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
                                                            Realtek Digital Output (Realtek,0x00200000,1,0,,6.06.6002.18533
                                                            Realtek HDMI Output (Realtek Hi,0x00200000,1,0,,6.06.6002.18533
                                                            • 28. Re: Video investigation with Flash Player 11.2.202.228
                                                              reise_pt
                                                              0. Using Flash player 11.3.300.257
                                                              1. Flash videos appear the the bottom 2/3 witt the green as in your screenshot
                                                              2. If I disable hardware acceleration the problems foes away
                                                              3. http://www.youtube.com/watch?feature=player_embedded&v=KiPNMTKgn0Q
                                                              4.
                                                              System Information
                                                              Time of this report: 6/20/2012, 16:06:22
        Machine name: L-4A044211H
        Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
        Language: Portuguese (Regional Setting: Portuguese)
                                                              System Manufacturer: TOSHIBA
        System Model: TECRA R10
        BIOS: v3.00
        Processor: Intel(R) Core(TM)2 Duo CPU     P9400  @ 2.40GHz (2 CPUs), ~2.4GHz
        Memory: 8192MB RAM
                                                              Available OS Memory: 8124MB RAM
        Page File: 4090MB used, 4031MB available
        DxDiag Version: 6.01.7601.17514 64bit Unicode
                                                              DxDiag Notes
                                                              Display Devices
        Card name: NVIDIA Quadro NVS 150M
        Manufacturer: NVIDIA
        Chip type: Quadro NVS 150M
        DAC type: Integrated RAMDAC
        Device Key: Enum\PCI\VEN_10DE&DEV_06EA&SUBSYS_00021179&REV_A1
        Display Memory: 3689 MB
        Dedicated Memory: 105 MB
        Shared Memory: 3583 MB
        Current Mode: 1440 x 900 (32 bit) (60Hz)
        Monitor Name: Generic PnP Monitor
        Monitor Model: Internal LCD
        Monitor Id: TOS508B
        Native Mode: 1440 x 900(p) (60.382Hz)
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                                                              Driver File Version: 8.17.0012.9688 (English)
        Driver Version: 8.17.12.9688
        DDI Version: 10
        Driver Date/Size: 5/31/2012 21:18:00, 17678696 bytes
        WHQL Logo'd: Yes
        WHQL Date Stamp:
        Device Identifier: {D7B71E3E-45AA-11CF-1157-0E201FC2C535}
        Vendor ID: 0x10DE
        Device ID: 0x06EA
        SubSys ID: 0x00021179
        Revision ID: 0x00A1
                                                              Driver Strong Name: oem44.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section014:8.17.12.9688:pci\ven_10de&dev_06ea&s ubsys_00021179
        Rank Of Driver: 00E60001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
        Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        DXVA-HD: Supported
        D3D Status: Enabled
        AGP Status: Enabled
                                                              Sound Devices
        Description: Speakers (Realtek High Definition Audio (With EC))
        Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0268&SUBSYS_11790608&REV_1000
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        Driver Version: 6.00.0001.5904 (English)
        WHQL Logo'd: Yes
        Date and Size: 7/28/2009 21:00:14, 1966624 bytes
        Other Files:
        Cap Flags: 0xF1F
        HW Memory: 0
        Description: Microphone (Realtek High Definition Audio (With EC))
        Cap Flags: 0x1
                                                              DirectInput Devices
        Device Name: Mouse
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Device Name: Microsoft Notebook Optical
        Attached: 1
        Controller ID: 0x0
                                                              Vendor/Product ID: 0x045E, 0x00D2
        FF Driver: n/a
                                                              USB Devices
                                                              + USB Root Hub
                                                              | Vendor/Product ID: 0x8086, 0x2936
                                                              | Service: usbhub
                                                              | Driver: usbhub.sys, 3/25/2011 04:29:26, 343040 bytes
                                                              | Driver: usbd.sys, 3/25/2011 04:28:59, 7936 bytes
                                                              Gameport Devices
                                                              PS/2 Devices
                                                              | Service: i8042prt
                                                              | Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
                                                              | Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
                                                              | Service: TermDD
                                                              + Alps Pointing-device
                                                              | Matching Device ID: *pnp0f13
                                                              | Upper Filters: ApfiltrService
                                                              | Service: i8042prt
                                                              | Driver: Apfiltr.sys, 2/7/2008 00:29:08, 195632 bytes
                                                              | Driver: Vxdif.dll, 1/19/2008 16:53:46, 97792 bytes
                                                              | Driver: Apoint.exe, 12/15/2007 15:32:40, 237056 bytes
                                                              | Driver: ApntEx.exe, 10/25/2007 17:23:26, 22528 bytes
                                                              | Driver: EzPopup.exe, 9/11/2006 18:14:48, 31232 bytes
                                                              | Driver: Ezcapt.exe, 12/13/2007 00:24:10, 202752 bytes
                                                              | Driver: ApInst.dll, 10/18/2006 20:39:16, 50176 bytes
                                                              | Driver: Uninstap.exe, 1/22/2008 19:58:28, 275240 bytes
                                                              | Driver: ApCommon.dll, 12/14/2007 19:32:14, 123904 bytes
                                                              | Driver: ApTabCtl.dll, 2/7/2008 21:36:56, 41472 bytes
                                                              | Driver: ApMain.dll, 8/19/2006 17:49:20, 68096 bytes
                                                              | Driver: ApDual.dll, 8/19/2006 16:44:06, 65024 bytes
                                                              | Driver: ApStick.dll, 8/19/2006 12:33:32, 134656 bytes
                                                              | Driver: ApPad.dll, 12/13/2007 20:52:44, 429056 bytes
                                                              | Driver: ApOthers.dll, 12/18/2007 20:03:26, 72704 bytes
                                                              | Driver: ApString.dll, 12/18/2007 20:29:08, 392192 bytes
                                                              | Driver: ApMouse.dll, 8/23/2006 10:35:34, 89600 bytes
                                                              | Driver: EzCapt.dll, 8/19/2006 10:52:44, 70656 bytes
                                                              | Driver: EzAuto.dll, 9/10/2007 13:11:04, 32256 bytes
                                                              | Driver: EzLaunch.dll, 12/13/2007 20:45:08, 151040 bytes
                                                              | Driver: hidfind.exe, 9/8/2006 15:37:26, 48640 bytes
                                                              | Driver: ApMsgFwd.exe, 9/12/2007 14:44:24, 64808 bytes
                                                              | Driver: ApHelp04.01, 12/17/2007 20:21:40, 8409 bytes
                                                              | Driver: ApHelp04.02, 12/17/2007 20:29:40, 8391 bytes
                                                              | Driver: ApHelp07.01, 12/17/2007 19:28:14, 16132 bytes
                                                              | Driver: ApHelp09.01, 12/17/2007 22:45:18, 12972 bytes
                                                              | Driver: ApHelp10.01, 12/17/2007 19:45:46, 17541 bytes
                                                              | Driver: ApHelp0A.03, 12/17/2007 19:52:38, 16117 bytes
                                                              | Driver: ApHelp0C.01, 12/17/2007 19:37:08, 16269 bytes
                                                              | Driver: ApHelp11.01, 3/23/2004 15:12:38, 11879 bytes
                                                              | Driver: ApHelp12.01, 12/17/2007 20:57:52, 11513 bytes
                                                              | Driver: ApHelp05.01, 12/17/2007 21:06:32, 12479 bytes
                                                              | Driver: ApHelp06.01, 12/17/2007 21:23:44, 12836 bytes
                                                              | Driver: ApHelp0B.01, 12/17/2007 21:31:58, 13301 bytes
                                                              | Driver: ApHelp08.01, 12/17/2007 21:40:44, 17029 bytes
                                                              | Driver: ApHelp13.01, 12/17/2007 21:47:46, 14738 bytes
                                                              | Driver: ApHelp14.01, 12/17/2007 21:56:06, 13111 bytes
                                                              | Driver: ApHelp15.01, 12/17/2007 22:03:38, 15313 bytes
                                                              | Driver: ApHelp16.02, 12/17/2007 22:38:50, 14934 bytes
                                                              | Driver: ApHelp19.01, 12/17/2007 22:13:58, 14938 bytes
                                                              | Driver: ApHelp1D.01, 12/17/2007 22:21:30, 12289 bytes
                                                              | Driver: ApHelp1F.01, 12/17/2007 22:57:48, 13404 bytes
                                                              | Driver: ApHelp1B.01, 12/17/2007 19:12:08, 13308 bytes
                                                              | Driver: ApHelp0E.01, 12/17/2007 22:31:02, 14079 bytes
                                                              | Driver: ball_hit.avi, 6/11/1997 14:52:00, 10752 bytes
                                                              | Driver: ball_ini.avi, 6/11/1997 14:52:00, 5120 bytes
                                                              | Driver: Logo.bmp, 10/25/2002 10:44:00, 1344 bytes
                                                              | Driver: GPEnable.bmp, 6/30/2008 20:30:20, 19772 bytes
                                                              | Driver: SPEnable.bmp, 6/30/2008 20:30:42, 20016 bytes
                                                              | Driver: GPDisabl.bmp, 6/30/2008 20:30:06, 19632 bytes
                                                              | Driver: SPDisabl.bmp, 6/30/2008 20:30:36, 19700 bytes
                                                              | Driver: SpBtn.bmp, 6/30/2008 20:30:30, 63512 bytes
                                                              | Driver: MouBtn2.bmp, 10/30/2002 05:16:54, 32400 bytes
                                                              | Driver: MouBtn3.bmp, 10/30/2002 05:17:26, 32400 bytes
                                                              | Driver: MouBtnW.bmp, 10/30/2002 05:16:18, 32400 bytes
                                                              | Driver: BtnScrol.ico, 10/28/2002 23:38:38, 766 bytes
                                                              | Driver: DragLock.ico, 10/24/2002 08:43:10, 2238 bytes
                                                              | Driver: GpSpeed.ico, 10/24/2002 07:15:44, 2238 bytes
                                                              | Driver: Tapping.ico, 10/24/2002 07:20:56, 2238 bytes
                                                              | Driver: TapType.ico, 10/24/2002 08:01:30, 2238 bytes
                                                              | Driver: TouchSen.ico, 10/24/2002 07:21:32, 2238 bytes
                                                              | Driver: PadScrl.ico, 10/24/2002 07:18:28, 2238 bytes
                                                              | Driver: Browser.ico, 10/24/2002 07:09:44, 2238 bytes
                                                              | Driver: Corner.ico, 10/24/2002 07:11:14, 2238 bytes
                                                              | Driver: ElMenu.ico, 10/24/2002 07:13:18, 2238 bytes
                                                              | Driver: ElPos.ico, 10/24/2002 07:14:00, 2238 bytes
                                                              | Driver: ElScut.ico, 10/24/2002 07:14:44, 2238 bytes
                                                              | Driver: OthIcon.ico, 10/24/2002 08:42:40, 2238 bytes
                                                              | Driver: OthIme.ico, 10/24/2002 07:55:48, 2238 bytes
                                                              | Driver: OthSound.ico, 10/24/2002 07:17:46, 2238 bytes
                                                              | Driver: OthUsbm.ico, 3/4/2004 16:30:34, 2238 bytes
                                                              | Driver: SpScroll.ico, 10/24/2002 07:19:42, 2238 bytes
                                                              | Driver: SpSpeed.ico, 10/24/2002 07:20:10, 2238 bytes
                                                              | Driver: InerMov.ico, 10/24/2002 07:16:28, 2238 bytes
                                                              | Driver: EcaPen.ico, 10/24/2002 08:44:12, 2238 bytes
                                                              | Driver: EcaSize.ico, 10/24/2002 07:12:26, 2238 bytes
                                                              | Driver: EcaStore.ico, 10/24/2002 08:43:46, 2238 bytes
                                                              | Driver: MouSpeed.ico, 10/24/2002 07:17:12, 2238 bytes
                                                              | Driver: MouWheel.ico, 10/24/2002 07:57:30, 2238 bytes
                                                              | Driver: scr_wh.ico, 1/21/1999 20:59:02, 766 bytes
                                                              | Driver: TPad.bmp, 10/31/2002 01:36:14, 30648 bytes
                                                              | Driver: BackFord.bmp, 10/30/2002 08:04:14, 2928 bytes
                                                              | Driver: InerMov0.bmp, 10/30/2002 08:02:00, 2264 bytes
                                                              | Driver: InerMov1.bmp, 10/30/2002 08:02:32, 1728 bytes
                                                              | Driver: InerMov2.bmp, 10/30/2002 08:03:08, 1728 bytes
                                                              | Driver: InerMov3.bmp, 10/30/2002 08:03:38, 2264 bytes
                                                              | Driver: SetFunc.bmp, 10/30/2002 07:58:40, 1212 bytes
                                                              | Driver: HScroll.bmp, 10/30/2002 08:09:38, 2432 bytes
                                                              | Driver: VScroll.bmp, 10/30/2002 08:09:02, 1928 bytes
                                                              | Driver: TPad.bmp, 12/15/2002 03:28:32, 30648 bytes
                                                              | Driver: BackFord.bmp, 12/13/2002 15:35:14, 2840 bytes
                                                              | Driver: InerMov0.bmp, 12/13/2002 15:28:02, 1128 bytes
                                                              | Driver: InerMov1.bmp, 12/13/2002 15:29:20, 724 bytes
                                                              | Driver: InerMov2.bmp, 12/13/2002 15:31:04, 1728 bytes
                                                              | Driver: InerMov3.bmp, 12/13/2002 15:31:40, 2136 bytes
                                                              | Driver: HScroll.bmp, 12/13/2002 15:34:00, 2224 bytes
                                                              | Driver: VScroll.bmp, 12/13/2002 15:33:10, 1928 bytes
                                                              | Driver: TPad.bmp, 12/16/2002 15:28:52, 30646 bytes
                                                              | Driver: BackFord.bmp, 12/13/2002 15:46:48, 2840 bytes
                                                              | Driver: InerMov0.bmp, 12/13/2002 15:43:10, 2104 bytes
                                                              | Driver: InerMov1.bmp, 12/13/2002 15:43:36, 1680 bytes
                                                              | Driver: InerMov2.bmp, 12/13/2002 15:44:10, 1680 bytes
                                                              | Driver: InerMov3.bmp, 12/13/2002 15:44:50, 2104 bytes
                                                              | Driver: HScroll.bmp, 12/13/2002 15:46:02, 2172 bytes
                                                              | Driver: VScroll.bmp, 12/13/2002 15:45:24, 1832 bytes
                                                              | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
                                                              | Driver: WdfCoinstaller01005.dll, 11/2/2006 08:04:56, 1919968 bytes
                                                              | Service: mouhid
                                                              | Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
                                                              | Service: TermDD
                                                              | Driver: termdd.sys, 11/20/2010 05:33:58, 63360 bytes
                                                              | Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
        Drive: C:
                                                              Free Space: 23.3 GB
                                                              Total Space: 59.9 GB
                                                              File System: NTFS
        Model: Hitachi HTS723232L9A360
        Drive: E:
                                                              Free Space: 87.7 GB
                                                              Total Space: 245.2 GB
                                                              File System: NTFS
        Drive: D:
        Model: CD-ROM Drive
        Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Portuguese), 11/20/2010 01:19:22, 147456 bytes
                                                              System Devices
        Name: Mobile Intel(R) 4 Series Chipset PCI Express Root Port - 2A41
                                                              Device ID: PCI\VEN_8086&DEV_2A41&SUBSYS_00011179&REV_07\3&33FD14CA&0&08
        Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 05:33:50, 184704 bytes
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
                                                              Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_00011179&REV_03\3&33FD14CA&0&D2
        Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:03, 30720 bytes
        Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:14, 325120 bytes
        Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:26, 343040 bytes
                                                              Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00011179&REV_93\3&33FD14CA&0&F0
        Name: Mobile Intel(R) 4 Series Chipset Processor to DRAM Controller - 2A40
                                                              Device ID: PCI\VEN_8086&DEV_2A40&SUBSYS_00011179&REV_07\3&33FD14CA&0&00
        Driver: n/a
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
                                                              Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_00011179&REV_03\3&33FD14CA&0&D1
        Name: Intel(R) 82567LM Gigabit Network Connection
                                                              Device ID: PCI\VEN_8086&DEV_10F5&SUBSYS_00011179&REV_03\3&33FD14CA&0&C8
        Driver: C:\Windows\system32\DRIVERS\e1y62x64.sys, 10.01.0014.0000 (Portuguese), 7/26/2011 17:55:16, 302808 bytes
        Driver: C:\Windows\system32\e1y62x64.din, 3/6/2009 00:52:06, 3315 bytes
        Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 17:05:46, 36472 bytes
        Driver: C:\Windows\system32\NicInstY.dll, 9.10.0069.0000 (English), 6/16/2011 08:06:18, 98496 bytes
        Driver: C:\Windows\system32\e1000msg.dll, 9.08.0000.0000 (English), 12/14/2007 21:06:06, 121440 bytes
        Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
                                                              Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_00011179&REV_03\3&33FD14CA&0&E2
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
                                                              Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_00011179&REV_03\3&33FD14CA&0&D0
        Name: SDA Standard Compliant SD Host Controller
                                                              Device ID: PCI\VEN_1180&DEV_0822&SUBSYS_00011179&REV_22\4&1D19FBE0&0&58F0
        Driver: C:\Windows\system32\DRIVERS\sdbus.sys, 6.01.7601.17514 (English), 11/20/2010 01:37:44, 109056 bytes
        Name: Intel(R) ICH9 Family PCI Express Root Port 2 - 2942
                                                              Device ID: PCI\VEN_8086&DEV_2942&SUBSYS_00011179&REV_03\3&33FD14CA&0&E1
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
                                                              Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_00011179&REV_03\3&33FD14CA&0&EA
        Name: NVIDIA Quadro NVS 150M
                                                              Device ID: PCI\VEN_10DE&DEV_06EA&SUBSYS_00021179&REV_A1\4&2126D75A&0&0008
        Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 224104 bytes
        Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/31/2012 21:18:00, 329348 bytes
        Driver: C:\Windows\System32\DriverStore\FileRepository\nvts.inf_amd64_neutral_0f259eb8e45cca0d\Nv CplSetupInt.exe, 1.00.0001.0000 (Portuguese), 5/31/2012 21:18:00, 71612176 bytes
        Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/31/2012 21:18:00, 21892 bytes
        Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/31/2012 21:18:00, 61288 bytes
        Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 5/31/2012 21:18:00, 68968 bytes
        Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 14412648 bytes
        Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2688360 bytes
        Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 25224552 bytes
        Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 8047976 bytes
        Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2874216 bytes
        Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2674536 bytes
        Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 17678696 bytes
        Driver: C:\Windows\system32\nvinfo.pb, 5/31/2012 21:18:00, 12780 bytes
        Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 25632616 bytes
        Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 9752936 bytes
        Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2327400 bytes
        Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 17543528 bytes
        Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 5925736 bytes
        Driver: C:\Windows\SysWow64\nvcuvenc.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2439528 bytes
        Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 2518888 bytes
        Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 15039848 bytes
        Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 19514728 bytes
        Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.9688 (English), 5/31/2012 21:18:00, 7745896 bytes
        Driver: C:\Windows\system32\nvdispco64.dll, 2.00.0025.0001 (English), 5/31/2012 21:18:00, 1737576 bytes
        Driver: C:\Windows\system32\nvgenco64.dll, 2.00.0014.0000 (English), 5/31/2012 21:18:00, 1466216 bytes
        Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
                                                              Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00011179&REV_03\3&33FD14CA&0&E0
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
                                                              Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_00011179&REV_03\3&33FD14CA&0&E9
                                                              Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_00011179&REV_03\3&33FD14CA&0&D8
        Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 02:43:44, 122368 bytes
        Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
                                                              Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_00011179&REV_03\3&33FD14CA&0&E8
        Name: Intel(R) WiFi Link 5100 AGN
                                                              Device ID: PCI\VEN_8086&DEV_4232&SUBSYS_13018086&REV_00\4&347A5AC2&0&00E0
        Driver: C:\Windows\system32\DRIVERS\NETw5s64.sys, 13.01.0001.0001 (English), 1/13/2010 16:37:18, 7675392 bytes
        Driver: C:\Windows\system32\NETw5c64.dll, 13.00.0000.0007 (English), 9/15/2009 19:18:46, 787456 bytes
        Driver: C:\Windows\system32\NETw5r64.dll, 13.00.0000.0007 (English), 9/15/2009 19:19:58, 2747904 bytes
        Driver: C:\Windows\system32\drivers\vwifibus.sys, 6.01.7600.16385 (English), 7/14/2009 01:07:21, 24576 bytes
        Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
                                                              Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_00011179&REV_03\3&33FD14CA&0&D7
        Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 52736 bytes
        Name: Intel(R) ICH9M-E/M SATA AHCI Controller
                                                              Device ID: PCI\VEN_8086&DEV_2929&SUBSYS_00011179&REV_03\3&33FD14CA&0&FA
        Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 8.09.0000.1023 (English), 6/4/2009 18:54:36, 408600 bytes
                                                              Device ID: PCI\VEN_8086&DEV_2A44&SUBSYS_00011179&REV_07\3&33FD14CA&0&18
        Driver: C:\Windows\system32\DRIVERS\HECIx64.sys, 4.00.0001.1074 (English), 3/26/2008 15:13:40, 56344 bytes
        Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
                                                              Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_00011179&REV_03\3&33FD14CA&0&EF
        Name: Intel(R) ICH9M-E LPC Interface Controller - 2917
                                                              Device ID: PCI\VEN_8086&DEV_2917&SUBSYS_00011179&REV_03\3&33FD14CA&0&F8
        Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
                                                              DirectShow Filters
                                                              DirectShow Filters:
                                                              Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                                                              CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
                                                              Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                                                              NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
                                                              Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
                                                              AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                                                              AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                                                              SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                                                              Video Compressors:
                                                              Audio Compressors:
                                                              PBDA CP Filters:
                                                              Midi Renderers:
                                                              WDM Streaming Capture Devices:
                                                              ,0x00000000,0,0,,
                                                              ,0x00000000,0,0,,
                                                              USB 2.0 Camera,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                                              WDM Streaming Rendering Devices:
                                                              BDA Transport Information Renderers:
                                                              BDA CP/CA Filters:
                                                              Audio Renderers:
                                                              DirectSound: Speakers (Realtek High Definition Audio (With EC)),0x00200000,1,0,quartz.dll,6.06.7601.17713
                                                              Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
        Quality Flags: 2576
        Enabled:
        Force throttling
        Allow scaling
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
                                                              • 29. Re: Video investigation with Flash Player 11.2.202.228
        chris.campbell Adobe Employee
        reise,
        What browser are you using?
        Chris
        • 30. Re: Video investigation with Flash Player 11.2.202.228
        darchooker
        1. What problem are you encountering? Same as above, green bar at the bottom of Flash videos and incorrect colors or severe artifacting. Same issue is seen in Chrome (v19.0.1084.56), FireFox (v13.0.1) and IE (v9.0.8112.16421) browsers.
        2. Try disabling Flash's hardware acceleration.  Does this fix the bug? Yes.
        3. What URL did you use to view video?  http://www.youtube.com/watch?v=Uwg4OiYgTIw&feature=context-vrec
        4. Please post your DxDiag report.
        Two files with dxdiag info here:
        https://skydrive.live.com/?cid=1a756953df78cdda&resid=1A756953DF78CDDA!277&id=1A756953DF78 CDDA%21277
        DxDiag.txt
        DxDiagx64.txt (from the run x64 version of dxdiag)
        • 31. Re: Video investigation with Flash Player 11.2.202.228
        reise_pt Level 1
        Chris,
        I'm using Firefox 13.0.1
        • 32. Re: Video investigation with Flash Player 11.2.202.228
        Michael171
        Hi Chris,
        I found this thread by accident while researching this problem.  I am using the following hardware and software:
        • HP Z800 Workstation - latest BIOS and updates from HP
        • Windows 7 Professional 64bit - latest updates from within Windows Update
        • Internet Explorer 9 64bit - latest updates from Windows Update
        • NVIDIA NVS295 - latest drivers from NVIDIA website
        • Adobe Flash verison 11.3.300.257
        I really appreciate your hardwork in providing a solutions based approach to this problem.  I am experiencing this problem on randon youtube.com videos, one specifically if you search for "MacBook Pro Retina MobileTech."  However, there is no predictable pattern.  Sometimes the advertisements work and sometimes they do not.  Sometimes the videos work and sometimes they do not.  Sometimes I can get the videos to work only on 240 or 360 resolution.  Howver, if I choose 720p I either get green bars or IE crashes.  Again I want to emphasize that some video do however work in 720p.  It is purely random, I could give you maybe 30 different videos that I have tried to watch with some success and other not so much.
        I have remedied the problem by disabling Hardware Acceleration.
        • 33. Re: Video investigation with Flash Player 11.2.202.228
        horizon23
        Hello Chris,
        I get green artifacts in Flash videos, including a flashing green layer over the entire video which will sometimes change into one or more green bars at the top and/or bottom of the video. This happens in many videos, but one example link would be here. I am using Firefox 13.0.1 on Windows 7 Pro 64-bit with Flash 11.3.300.262, which I understand is the most recent for my OS/Browser. My video chip is an Nvidia Quadro NVS 140M, with Nvidia driver version 296.88, which according to the Nvidia website is the most current release version. Disabling hardware acceleration DOES fix this problem. DxDiag below:
        System Information
        Time of this report: 6/25/2012, 11:35:07
        Machine name: JOEL-LAPTOP
        Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
        Language: English (Regional Setting: English)
        System Manufacturer: LENOVO
        System Model: 7662CTO
        BIOS: Ver 1.00PARTTBLx
        Processor: Intel(R) Core(TM)2 Duo CPU     T7300  @ 2.00GHz (2 CPUs), ~2.0GHz
        Memory: 4096MB RAM
        Available OS Memory: 4030MB RAM
        Page File: 1795MB used, 6263MB available
        Windows Dir: C:\Windows
        DirectX Version: DirectX 11
        DX Setup Parameters: Not found
        User DPI Setting: Using System DPI
        System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
        DxDiag Version: 6.01.7601.17514 32bit Unicode
        DxDiag Notes
        Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Input Tab: No problems found.
        DirectX Debug Levels
        Direct3D:    0/4 (retail)
        DirectDraw:  0/4 (retail)
        DirectInput: 0/5 (retail)
        DirectMusic: 0/5 (retail)
        DirectPlay:  0/9 (retail)
        DirectSound: 0/5 (retail)
        DirectShow:  0/6 (retail)
        Display Devices
        Card name: NVIDIA Quadro NVS 140M
        Chip type: Quadro NVS 140M
        Device Key: Enum\PCI\VEN_10DE&DEV_0429&SUBSYS_20D817AA&REV_A1
        Display Memory: 1872 MB
        Dedicated Memory: 113 MB
        Shared Memory: 1759 MB
        Current Mode: 1280 x 800 (32 bit) (60Hz)
        Monitor Model: unknown
        Monitor Id: LEN4031
        Native Mode: 1280 x 800(p) (60.001Hz)
        Output Type: Internal
        DDI Version: 10
        Driver Model: WDDM 1.1
        Driver Date/Size: 5/31/2012 13:18:00, 17678696 bytes
        WHQL Logo'd: Yes
        WHQL Date Stamp:
        Device Identifier: {D7B71E3E-4769-11CF-C251-D4001FC2C535}
        Vendor ID: 0x10DE
        Device ID: 0x0429
        SubSys ID: 0x20D817AA
        Revision ID: 0x00A1
        Driver Strong Name: oem21.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section010:8.17.12.9688:pci\ven_10de&dev_0429&s ubsys_20d817aa
        {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
        D3D9 Overlay: Supported
        DXVA-HD: Supported
        DDraw Status: Enabled
        D3D Status: Enabled
        AGP Status: Enabled
        Sound Devices
        Description: Speakers (SoundMAX Integrated Digital HD Audio)
        Default Sound Playback: Yes
        Default Voice Playback: Yes
        Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_1984&SUBSYS_17AA20D7&REV_1004
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        Driver Name: ADIHdAud.sys
        Driver Version: 6.10.0002.5510 (English)
        WHQL Logo'd: Yes
        Date and Size: 12/7/2007 10:13:02, 457728 bytes
        Other Files:
        Driver Provider: AnalogDevices
        HW Accel Level: Basic
        Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
        Static/Strm HW Mix Bufs: 1, 0
        Static/Strm HW 3D Bufs: 0, 0
        HW Memory: 0
        Voice Management: No
        EAX(tm) 2.0 Listen/Src: No, No
        I3DL2(tm) Listen/Src: No, No
        Sensaura(tm) ZoomFX(tm): No
        Description: SPDIF Interface (SoundMAX Integrated Digital HD Audio)
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        WHQL Logo'd: Yes
        Other Files:
        Cap Flags: 0xF1F
        HW Memory: 0
        Sound Capture Devices
        Description: Microphone (SoundMAX Integrated Digital HD Audio)
        Default Sound Capture: Yes
        Default Voice Capture: Yes
        Cap Flags: 0x1
        Format Flags: 0xFFFFF
        DirectInput Devices
        Device Name: Mouse
        Attached: 1
        Controller ID: n/a
        Vendor/Product ID: n/a
        FF Driver: n/a
        Device Name: Keyboard
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Poll w/ Interrupt: No
        USB Devices
        + USB Root Hub
        | Vendor/Product ID: 0x8086, 0x2832
        | Matching Device ID: usb\root_hub
        | Service: usbhub
        Gameport Devices
        PS/2 Devices
        + Standard PS/2 Keyboard
        | Matching Device ID: *pnp0303
        | Service: i8042prt
        + Terminal Server Keyboard Driver
        | Matching Device ID: root\rdp_kbd
        | Upper Filters: kbdclass
        | Service: TermDD
        + ThinkPad UltraNav Pointing Device
        | Matching Device ID: *ibm0057
        | Upper Filters: SynTP
        | Service: i8042prt
        | Vendor/Product ID: 0x046D, 0xC00F
        | Service: mouhid
        + Terminal Server Mouse Driver
        | Matching Device ID: root\rdp_mou
        | Upper Filters: mouclass
        | Service: TermDD
        Disk & DVD/CD-ROM Drives
        Drive: C:
        Free Space: 13.7 GB
        Total Space: 61.1 GB
        File System: NTFS
        Model: M4-CT064M4SSD2 ATA Device
        Drive: D:
        Free Space: 127.2 GB
        Total Space: 305.2 GB
        File System: NTFS
        Model: WDC WD3200BEVT-00ZCT0 ATA Device
        System Devices
        Name: Mobile Intel(R) PM965/GM965/GL960/GS965 Express PCI Express Root Port - 2A01
        Device ID: PCI\VEN_8086&DEV_2A01&SUBSYS_20B217AA&REV_0C\3&21436425&0&08
        Driver: n/a
        Name: Intel(R) ICH8 Family PCI Express Root Port 1 - 283F
        Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_20AD17AA&REV_03\3&21436425&0&E0
        Driver: n/a
        Name: Intel(R) ICH8 Family USB Universal Host Controller - 2830
        Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_20AA17AA&REV_03\3&21436425&0&E8
        Driver: n/a
        Name: NVIDIA Quadro NVS 140M
        Device ID: PCI\VEN_10DE&DEV_0429&SUBSYS_20D817AA&REV_A1\4&1B98CE63&0&0008
        Driver: n/a
        Name: Mobile Intel(R) PM965/GM965/GL960/GS965 Express Processor to DRAM Controller - 2A00
        Device ID: PCI\VEN_8086&DEV_2A00&SUBSYS_20B117AA&REV_0C\3&21436425&0&00
        Driver: n/a
        Name: Intel(R) ICH8 Family SMBus Controller - 283E
        Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_20A917AA&REV_03\3&21436425&0&FB
        Driver: n/a
        Name: Intel(R) ICH8M SATA AHCI Controller - 2829
        Device ID: PCI\VEN_8086&DEV_2829&SUBSYS_20A717AA&REV_03\3&21436425&0&FA
        Driver: n/a
        Name: Intel(R) ICH8M Ultra ATA Storage Controllers - 2850
        Device ID: PCI\VEN_8086&DEV_2850&SUBSYS_20A617AA&REV_03\3&21436425&0&F9
        Driver: n/a
        Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
        Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_20AB17AA&REV_03\3&21436425&0&D7
        Driver: n/a
        Name: Intel(R) ICH8M-E LPC Interface Controller - 2811
        Device ID: PCI\VEN_8086&DEV_2811&SUBSYS_20B617AA&REV_03\3&21436425&0&F8
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_20AC17AA&REV_03\3&21436425&0&D8
        Driver: n/a
        Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
        Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_20AB17AA&REV_03\3&21436425&0&EF
        Driver: n/a
        Name: Intel(R) 82801 PCI Bridge - 2448
        Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_20AE17AA&REV_F3\3&21436425&0&F0
        Driver: n/a
        Name: Intel(R) ICH8 Family PCI Express Root Port 5 - 2847
        Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_20AD17AA&REV_03\3&21436425&0&E4
        Driver: n/a
        Name: Intel(R) ICH8 Family USB Universal Host Controller - 2835
        Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_20AA17AA&REV_03\3&21436425&0&D1
        Driver: n/a
        Name: Intel(R) 82566MM Gigabit Network Connection
        Device ID: PCI\VEN_8086&DEV_1049&SUBSYS_20B917AA&REV_03\3&21436425&0&C8
        Driver: n/a
        Name: Intel(R) ICH8 Family PCI Express Root Port 4 - 2845
        Device ID: PCI\VEN_8086&DEV_2845&SUBSYS_20AD17AA&REV_03\3&21436425&0&E3
        Driver: n/a
        Name: Intel(R) ICH8 Family USB Universal Host Controller - 2834
        Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_20AA17AA&REV_03\3&21436425&0&D0
        Driver: n/a
        Name: 11a/b/g Wireless LAN Mini PCI Express Adapter
        Device ID: PCI\VEN_168C&DEV_1014&SUBSYS_058A1014&REV_01\4&2A3E6892&0&00E1
        Driver: n/a
        Name: Intel(R) ICH8 Family PCI Express Root Port 3 - 2843
        Device ID: PCI\VEN_8086&DEV_2843&SUBSYS_20AD17AA&REV_03\3&21436425&0&E2
        Driver: n/a
        Name: Intel(R) ICH8 Family USB Universal Host Controller - 2832
        Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_20AA17AA&REV_03\3&21436425&0&EA
        Driver: n/a
        Name: Ricoh 1394 OHCI Compliant Host Controller
        Device ID: PCI\VEN_1180&DEV_0832&SUBSYS_20C717AA&REV_04\4&DED4CEB&0&01F0
        Driver: n/a
        Name: Intel(R) ICH8 Family PCI Express Root Port 2 - 2841
        Device ID: PCI\VEN_8086&DEV_2841&SUBSYS_20AD17AA&REV_03\3&21436425&0&E1
        Driver: n/a
        Name: Intel(R) ICH8 Family USB Universal Host Controller - 2831
        Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_20AA17AA&REV_03\3&21436425&0&E9
        Driver: n/a
        Name: Ricoh R/RL/5C476(II) or Compatible CardBus Controller
        Device ID: PCI\VEN_1180&DEV_0476&SUBSYS_20C617AA&REV_BA\4&DED4CEB&0&00F0
        Driver: n/a
        DirectShow Filters
        DirectShow Filters:
        WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
        WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
        WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
        MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
        Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
        WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
        WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
        Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
        Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
        DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
        Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
        WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
        Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
        AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
        VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
        SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
        Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
        AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
        StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
        MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
        MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
        SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
        VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
        MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
        Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
        SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
        Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
        Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
        MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
        DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
        Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
        Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
        ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
        Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
        MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
        Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
        Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
        Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
        VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
        WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
        VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
        File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
        iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
        iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
        WAV Dest,0x00000000,0,0,,
        DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
        Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
        AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
        RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
        Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
        WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
        MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
        DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
        SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
        Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
        MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
        Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
        StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
        Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
        Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
        AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
        AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
        Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
        MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
        Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
        File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
        Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
        StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
        AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
        Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
        File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
        File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
        Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
        Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
        BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
        MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
        WDM Streaming Tee/Splitter Devices:
        Video Compressors:
        WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
        WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
        MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
        DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
        MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
        Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
        Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
        Audio Compressors:
        Microphone (SoundMAX Integrated,0x00200000,0,0,qcap.dll,6.06.7601.17514
        PBDA CP Filters:
        Midi Renderers:
        ,0x00000000,0,0,,
        SoundMAX HD Audio I,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        ,0x00000000,0,0,,
        HD Audio digital out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        ,0x00000000,0,0,,
        SoundMAX HD Audio O,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        BDA CP/CA Filters:
        Audio Renderers:
        Speakers (SoundMAX Integrated D,0x00200000,1,0,quartz.dll,6.06.7601.17713
        DirectSound: SPDIF Interface (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
        DirectSound: Speakers (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
        SPDIF Interface (SoundMAX Integ,0x00200000,1,0,quartz.dll,6.06.7601.17713
        Quality Flags: 2576
        Enabled:
        Force throttling
        Allow scaling
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        • 34. Re: Video investigation with Flash Player 11.2.202.228
        stnkpalm Level 1
        1. Green bar at the bottom of Flash Video Content. Red and blue color components shifted up.
        2. Disabling hardware accelleration in Flash does seem to fix the problem.
        3. http://www.youtube.com/watch?v=nZaCpLU1mzs&feature=g-vrec
        I'm running a HP z600 Workstation with an NVIDIA Quadro 4000 GPU. The NVIDIA Driver version is 296.88. This problem happens in IE 9 and in Firefox version 13.0.1. My Flash version is 11,3,300,262.
        System Information
        Time of this report: 7/10/2012, 08:21:59
        Machine name: Z600
        System Manufacturer: Hewlett-Packard
        System Model: HP Z600 Workstation
        BIOS: Default System BIOS
        Processor: Intel(R) Xeon(R) CPU           E5620  @ 2.40GHz (8 CPUs), ~2.4GHz
        Memory: 12288MB RAM
        Available OS Memory: 12272MB RAM
        Page File: 1887MB used, 22653MB available
        DxDiag Notes
        Display Devices
        Card name: NVIDIA Quadro 4000
        Chip type: Quadro 4000
        Device Key: Enum\PCI\VEN_10DE&DEV_06DD&SUBSYS_0780103C&REV_A3
        Display Memory: 3783 MB
        Dedicated Memory: 1999 MB
        Shared Memory: 1783 MB
        Current Mode: 1920 x 1200 (32 bit) (59Hz)
        Monitor Name: HP LP2465 LCD Monitor
        Monitor Model: HP LP2465
        Monitor Id: HWP2676
        Native Mode: 1920 x 1200(p) (59.950Hz)
        Output Type: DVI
        DDI Version: 11
        WHQL Logo'd: Yes
        WHQL Date Stamp:
        Device Identifier: {D7B71E3E-459D-11CF-5456-8C271DC2C535}
        Vendor ID: 0x10DE
        Device ID: 0x06DD
        SubSys ID: 0x0780103C
        Revision ID: 0x00A3
        Driver Strong Name: oem38.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section018:8.17.12.9688:pci\ven_10de&dev_06dd
        Rank Of Driver: 00E62001
        DXVA-HD: Supported
        D3D Status: Enabled
        AGP Status: Enabled
        Sound Devices
        Description: Speakers (Realtek High Definition Audio)
        Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0262&SUBSYS_103C130A&REV_1002
        Manufacturer ID: 1
        Product ID: 100
        Type: WDM
        Driver Name: RTKVHD64.sys
        Driver Version: 6.00.0001.6080 (English)
        WHQL Logo'd: Yes
        Date and Size: 3/31/2010 18:08:54, 2332192 bytes
        Other Files:
        Driver Provider: Realtek Semiconductor Corp.
        Cap Flags: 0xF1F
        HW Memory: 0
        DirectInput Devices
        Device Name: Mouse
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        Attached: 1
        Controller ID: n/a
        FF Driver: n/a
        USB Devices
        + USB Root Hub
        | Vendor/Product ID: 0x8086, 0x3A36
        | Service: usbhub
        | Driver: usbhub.sys, 5/23/2012 17:04:32, 343040 bytes
        | Driver: usbd.sys, 5/23/2012 17:04:32, 7936 bytes
        Gameport Devices
        PS/2 Devices
        | Service: i8042prt
        | Driver: i8042prt.sys, 7/13/2009 16:19:57, 105472 bytes
        | Driver: kbdclass.sys, 7/13/2009 18:48:04, 50768 bytes
        | Service: TermDD
        | Vendor/Product ID: 0x046D, 0xC078
        | Service: mouhid
        | Driver: mouhid.sys, 7/13/2009 17:00:20, 31232 bytes
        | Driver: mouclass.sys, 7/13/2009 18:48:27, 49216 bytes
        | Service: TermDD
        | Driver: termdd.sys, 11/20/2010 20:23:47, 63360 bytes
        | Driver: sermouse.sys, 7/13/2009 17:00:20, 26624 bytes
        Drive: C:
        Free Space: 399.8 GB
        Total Space: 474.9 GB
        File System: NTFS
        Model: Hitachi HDS721050CLA660
        Drive: D:
        Free Space: 947.4 GB
        Total Space: 953.9 GB
        File System: NTFS
        Model: ST31000524AS
        Drive: X:
        Free Space: 679.8 GB
        File System: NTFS
        Model: Hitachi HDS722020ALA330
        Drive: E:
        Model: hp BD-RE  BH38L
        Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 20:23:47, 147456 bytes
        Drive: F:
        Model: DTSOFT Virtual CdRom Device
        System Devices
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
        Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_130A103C&REV_00\3&11583659&0&D2
        Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 5/23/2012 17:04:32, 30720 bytes
        Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 5/23/2012 17:04:32, 325120 bytes
        Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 5/23/2012 17:04:32, 343040 bytes
        Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
        Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&11583659&0&A0
        Driver: n/a
        Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
        Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_130A103C&REV_13\3&11583659&0&18
        Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 20:23:47, 184704 bytes
        Device ID: PCI\VEN_8086&DEV_2DB1&SUBSYS_130A103C&REV_02\3&2411E6FE&2&31
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA9&SUBSYS_130A103C&REV_02\3&2411E6FE&2&29
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA1&SUBSYS_130A103C&REV_02\3&2411E6FE&2&21
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D99&SUBSYS_130A103C&REV_02\3&2411E6FE&2&19
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D93&SUBSYS_130A103C&REV_02\3&2411E6FE&2&13
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D81&SUBSYS_130A103C&REV_02\3&2411E6FE&2&01
        Driver: n/a
        Name: NVIDIA Quadro 4000
        Device ID: PCI\VEN_10DE&DEV_06DD&SUBSYS_0780103C&REV_A3\4&95673C&0&0018
        Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 224104 bytes
        Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/31/2012 13:18:00, 329348 bytes
        Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_d76212e600585fd5 \NvCplSetupInt.exe, 1.00.0001.0000 (English), 5/31/2012 13:18:00, 71612176 bytes
        Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 236392 bytes
        Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 5/31/2012 13:18:00, 4096 bytes
        Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 182120 bytes
        Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 260608 bytes
        Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 5/31/2012 13:18:00, 4096 bytes
        Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 202240 bytes
        Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/31/2012 13:18:00, 21892 bytes
        Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 5/31/2012 13:18:00, 32471 bytes
        Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 5/31/2012 13:18:00, 202600 bytes
        Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 5/31/2012 13:18:00, 315752 bytes
        Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/31/2012 13:18:00, 61288 bytes
        Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 5/31/2012 13:18:00, 68968 bytes
        Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 14412648 bytes
        Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2688360 bytes
        Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 25224552 bytes
        Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 8047976 bytes
        Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2874216 bytes
        Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2674536 bytes
        Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 17678696 bytes
        Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 364392 bytes
        Driver: C:\Windows\system32\nvinfo.pb, 5/31/2012 13:18:00, 12780 bytes
        Driver: C:\Windows\system32\nvinitx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 260968 bytes
        Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 25632616 bytes
        Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 963944 bytes
        Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 9752936 bytes
        Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2327400 bytes
        Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 17543528 bytes
        Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 5925736 bytes
        Driver: C:\Windows\SysWow64\nvcuvenc.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2439528 bytes
        Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 2518888 bytes
        Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 15039848 bytes
        Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 301416 bytes
        Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 215400 bytes
        Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 19514728 bytes
        Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 813928 bytes
        Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.9688 (English), 5/31/2012 13:18:00, 7745896 bytes
        Driver: C:\Windows\system32\nvdispco64.dll, 2.00.0025.0001 (English), 5/31/2012 13:18:00, 1737576 bytes
        Driver: C:\Windows\system32\nvgenco64.dll, 2.00.0014.0000 (English), 5/31/2012 13:18:00, 1466216 bytes
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
        Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_130A103C&REV_00\3&11583659&0&D1
        Name: Intel(R) 5520/5500 Routing and Protocol Layer Register Port 1 - 3428
        Device ID: PCI\VEN_8086&DEV_3428&SUBSYS_00000000&REV_13\3&11583659&0&89
        Driver: n/a
        Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
        Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_130A103C&REV_13\3&11583659&0&08
        Device ID: PCI\VEN_8086&DEV_2DB0&SUBSYS_130A103C&REV_02\3&36CB97A3&0&30
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA8&SUBSYS_130A103C&REV_02\3&36CB97A3&0&28
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA0&SUBSYS_130A103C&REV_02\3&36CB97A3&0&20
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D98&SUBSYS_130A103C&REV_02\3&36CB97A3&0&18
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D92&SUBSYS_130A103C&REV_02\3&36CB97A3&0&12
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2C70&SUBSYS_130A103C&REV_02\3&36CB97A3&0&00
        Driver: n/a
        Name: Texas Instruments XHCI Controller
        Device ID: PCI\VEN_104C&DEV_8241&SUBSYS_80401B5B&REV_02\4&93B8581&0&0008
        Driver: C:\Windows\system32\DRIVERS\tixhci.sys, 1.12.0009.0000 (English), 6/17/2011 21:16:02, 405064 bytes
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
        Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_130A103C&REV_00\3&11583659&0&D0
        Name: Intel(R) 5520/5500 Physical and Link Layer Registers Port 1 - 3427
        Device ID: PCI\VEN_8086&DEV_3427&SUBSYS_00000000&REV_13\3&11583659&0&88
        Driver: n/a
        Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3406
        Device ID: PCI\VEN_8086&DEV_3406&SUBSYS_130A103C&REV_13\3&11583659&0&00
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DB0&SUBSYS_130A103C&REV_02\3&2411E6FE&2&30
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA8&SUBSYS_130A103C&REV_02\3&2411E6FE&2&28
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA0&SUBSYS_130A103C&REV_02\3&2411E6FE&2&20
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D98&SUBSYS_130A103C&REV_02\3&2411E6FE&2&18
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D92&SUBSYS_130A103C&REV_02\3&2411E6FE&2&12
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2C70&SUBSYS_130A103C&REV_02\3&2411E6FE&2&00
        Driver: n/a
        Name: Texas Instruments 1394 OHCI Compliant Host Controller
        Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_010A1B5B&REV_00\4&CD0DDE3&0&48F0
        Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17662 (English), 5/23/2012 17:07:53, 229888 bytes
        Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
        Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_130A103C&REV_00\3&11583659&0&E5
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
        Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_130A103C&REV_00\3&11583659&0&EA
        Name: Intel(R) 5520/5500/X58 Routing and Protocol Layer Registers Port 0 - 3426
        Device ID: PCI\VEN_8086&DEV_3426&SUBSYS_00000000&REV_13\3&11583659&0&81
        Driver: n/a
        Name: PCI standard host CPU bridge
        Device ID: PCI\VEN_8086&DEV_2DB3&SUBSYS_130A103C&REV_02\3&36CB97A3&0&33
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DAB&SUBSYS_130A103C&REV_02\3&36CB97A3&0&2B
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA3&SUBSYS_130A103C&REV_02\3&36CB97A3&0&23
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D9C&SUBSYS_130A103C&REV_02\3&36CB97A3&0&1C
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D95&SUBSYS_130A103C&REV_02\3&36CB97A3&0&15
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D91&SUBSYS_130A103C&REV_02\3&36CB97A3&0&11
        Driver: n/a
        Name: Intel(R) ICH8R/ICH9R/ICH10R/DO/5 Series/3400 Series SATA RAID Controller
        Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_130A103C&REV_00\3&11583659&0&FA
        Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 9.06.0000.1014 (English), 3/3/2010 19:51:40, 540696 bytes
        Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
        Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_130A103C&REV_00\3&11583659&0&E0
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
        Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_130A103C&REV_00\3&11583659&0&E9
        Name: Intel(R) 5520/5500/X58 Physical and Link Layer Registers Port 0 - 3425
        Device ID: PCI\VEN_8086&DEV_3425&SUBSYS_00000000&REV_13\3&11583659&0&80
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DB3&SUBSYS_130A103C&REV_02\3&2411E6FE&2&33
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DAB&SUBSYS_130A103C&REV_02\3&2411E6FE&2&2B
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA3&SUBSYS_130A103C&REV_02\3&2411E6FE&2&23
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D9C&SUBSYS_130A103C&REV_02\3&2411E6FE&2&1C
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D95&SUBSYS_130A103C&REV_02\3&2411E6FE&2&15
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D91&SUBSYS_130A103C&REV_02\3&2411E6FE&2&11
        Driver: n/a
        Name: Intel(R) 82801 PCI Bridge - 244E
        Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_130A103C&REV_90\3&11583659&0&F0
        Name: High Definition Audio Controller
        Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_130A103C&REV_00\3&11583659&0&D8
        Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 20:23:47, 122368 bytes
        Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
        Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_130A103C&REV_00\3&11583659&0&E8
        Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
        Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&11583659&0&A2
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DB2&SUBSYS_130A103C&REV_02\3&36CB97A3&0&32
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DAA&SUBSYS_130A103C&REV_02\3&36CB97A3&0&2A
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA2&SUBSYS_130A103C&REV_02\3&36CB97A3&0&22
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D9A&SUBSYS_130A103C&REV_02\3&36CB97A3&0&1A
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D94&SUBSYS_130A103C&REV_02\3&36CB97A3&0&14
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D90&SUBSYS_130A103C&REV_02\3&36CB97A3&0&10
        Driver: n/a
        Name: Broadcom NetXtreme Gigabit Ethernet
        Device ID: PCI\VEN_14E4&DEV_1684&SUBSYS_130A103C&REV_10\4&1CF1F980&0&00E5
        Driver: n/a
        Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
        Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_130A103C&REV_00\3&11583659&0&D7
        Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 5/23/2012 17:04:32, 52736 bytes
        Name: Intel(R) ICH10R LPC Interface Controller - 3A16
        Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_130A103C&REV_00\3&11583659&0&F8
        Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 18:48:27, 15424 bytes
        Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
        Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&11583659&0&A1
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DB2&SUBSYS_130A103C&REV_02\3&2411E6FE&2&32
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DAA&SUBSYS_130A103C&REV_02\3&2411E6FE&2&2A
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA2&SUBSYS_130A103C&REV_02\3&2411E6FE&2&22
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D9A&SUBSYS_130A103C&REV_02\3&2411E6FE&2&1A
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D94&SUBSYS_130A103C&REV_02\3&2411E6FE&2&14
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D90&SUBSYS_130A103C&REV_02\3&2411E6FE&2&10
        Driver: n/a
        Name: LSI 1394 OHCI Compliant Host Controller
        Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_130A103C&REV_70\4&CD0DDE3&0&28F0
        Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
        Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_130A103C&REV_00\3&11583659&0&EF
        Name: Intel(R) 5520/5500/X58 Trusted Execution Technology Registers - 342F
        Device ID: PCI\VEN_8086&DEV_342F&SUBSYS_00000000&REV_13\3&11583659&0&A8
        Driver: n/a
        Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
        Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_130A103C&REV_13\3&11583659&0&38
        Device ID: PCI\VEN_8086&DEV_2DB1&SUBSYS_130A103C&REV_02\3&36CB97A3&0&31
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA9&SUBSYS_130A103C&REV_02\3&36CB97A3&0&29
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2DA1&SUBSYS_130A103C&REV_02\3&36CB97A3&0&21
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D99&SUBSYS_130A103C&REV_02\3&36CB97A3&0&19
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D93&SUBSYS_130A103C&REV_02\3&36CB97A3&0&13
        Driver: n/a
        Device ID: PCI\VEN_8086&DEV_2D81&SUBSYS_130A103C&REV_02\3&36CB97A3&0&01
        Driver: n/a
        Device ID: PCI\VEN_10DE&DEV_0BE5&SUBSYS_0780103C&REV_A1\4&95673C&0&0118
        DirectShow Filters
        DirectShow Filters:
        Line 21 Decoder,0x00600000,1,1,,
        DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
        Overlay Mixer2,0x00200000,1,1,,
        Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        Video Compressors:
        Audio Compressors:
        WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
        WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
        IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
        Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
        GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
        CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
        CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
        MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
        PBDA CP Filters:
        PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
        PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
        PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
        Midi Renderers:
        Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
        Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
        Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
        BDA Network Providers:
        Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
        Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
        Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
        Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
        Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
        Multi-Instance Capable VBI Codecs:
        BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
        MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
        BDA CP/CA Filters:
        Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
        Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
        PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
        XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
        WDM Streaming Communication Transforms:
        Audio Renderers:
        Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
        Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
        Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
        DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
        EVR Power Information
        Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
        Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
        PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
        • 35. Re: Video investigation with Flash Player 11.2.202.228
        horizon23 Level 1
        Hello Chris,
        I updated my Nvidia drivers to version 301.42 (the newest release for my chip) and all of the problems have gone away.
        -Joel
        • 36. Re: Video investigation with Flash Player 11.2.202.228
        Paul Gauci Level 1
        Chris
        I apologise for taking long to respond to your post, in reply to my most recent post in
        http://forums.adobe.com/message/4319285#4319285
        I experienced my 'green screen' problems mainly when going through videos in this website:
        http://www.timesofmalta.com
        The following is the videos page of the above-mentioned website:
        http://www.timesofmalta.com/videos
        As I pointed out in an earlier post the 'green screen' problem was resolved after I disabled the 'Enable hardware acceleration' feature.
        Regards
        Paul
        • 37. Re: Video investigation with Flash Player 11.2.202.228
        Hi Paul,
        This leads me to believe that we're dealing with a driver issue.  Can you post (or point me to) your dxdiag files so we can take a look?
        Chris
        • 38. Re: Video investigation with Flash Player 11.2.202.228
        Paul Gauci Level 1
        Chris
        The DxDiag.txt file can be retrieved through this link: https://dl.dropbox.com/u/68338767/DxDiag.txt
        Regards
        Paul
        • 39. Re: Video investigation with Flash Player 11.2.202.228
        Thanks, I took a look and it's possible this might be fixed with an updated driver.  The one installed on your system was dated 2011, but the latest release from Nvidia is 6/13/2012.
        http://www.nvidia.com/object/quadro-notebook-win7-winvista-64bit-296.88-whql-driver.html
        1 2 Previous Next
