2 Replies Latest reply on Apr 23, 2012 2:22 AM by g_w_master
    FMS 4.5 recorder video bug
    g_w_master
      i record video stream and then when i play him
      i get
      lay time : 6.663
      play time : 6.914
      play time : 7.164
      play time : 7.413
      play time : 7.713
      play time : 7.963
      play time : 32.594  <-- WTF!!!!!!!!!!
      play time : 32.895
      play time : 33.144
      from 0-7 only command (          _outgoingStream.send )
      7- 32 vide + commands
      32 - .. video + audio + command
      if i play this video on Adobe media player he jump to 32 and play the audioi video
      please help!!!!!!
        • 1. Re: FMS 4.5 recorder video bug
          Amit Kumar Pioneer
          Can you explain more on what exactly you are recording? Is it plain server side record or recording using livepkgr app. Are you playing rtmp or http?
          • 2. Re: FMS 4.5 recorder video bug
            g_w_master Newcomer
            FMS 4.5 local on PC and Amazon
            connection: rtmfp rtmp or rtrmpt
            _outgoingStream = new NetStream(_netConnection, NetStream.DIRECT_CONNECTIONS);
            _outgoingStream.publish(_userName,"record");
            _outgoingStream.attachCamera ..
            _outgoingStream.attachAudio ..
            play from http but eben Adobe media player that play local play at same vay
            private var recordTimer:Timer = new Timer(1000);
                                private function setarRecord():void{
                                          recordTimer.addEventListener(TimerEvent.TIMER,sendToStream);
                                          recordTimer.start();
                                          sendToStream();
            private function sendToStream(e:Event = null):void{
                                          //call function on Partcipiant.as
                                          _outgoingStream.send("r");
            record comman every 1 secound that stream will have somthing if there no audio and no video
            and the problem when i play the video
            when only video is recordet it's dont showen
            when i play i print time i the reslout is
            jump from 7sec to 32sec when audio begin
            if its help i can record example video and send you
            thenks...
