5 Replies Latest reply: Apr 24, 2012 12:15 AM by LRuser24 RSS
    Develop Settings
    AudoWarp Community Member
      I have a PC, and I just upgraded to Production Premium 5.5 and bought Lightroom 4
      Do develop settings applied in ACR show up in Lightroom 4?
      Develope settings applied in Lightroom 4 do not appear in Bridge......
      Are they the same "devlop settings"?
        • 1. Re: Develop Settings
          Ian Lyons CommunityMVP
          ACR setting will show up in Lr when you import them via the Read Metadata from File command (Metadata>Read Metadata from File... menu item). Develop settings from Lr need to be saved to the file before they are visible to Bridge (Ctrl/Cmd+S or Metadata>Save Metadata to File menu item). Remember to slect the relevant files before using the menu command or shortcut.
          Yes they are the same settings, although not always a direct match (see below for matching settings).
          Lr 2 = Camera Raw 5 (CS4)
          Lr 3 = Camera Raw 6 (CS5 and CS5.5)
          Lr 4 = Camera Raw 7 (CS6)
          • 2. Re: Develop Settings
            "Lr 4 = Camera Raw 7 (CS6)"
            So does that mean I won't be able to work in both LR4 and ACR interchangeably until cs6 comes out?
            (Oh, and thatnks for your help =)
            • 3. Re: Develop Settings
              Cornelia-I Community Member
              You can bridge the time until final release of CS6-Camera Raw7.0
              by using the RC version of Camera Raw 6.7, which is available for download at Adobe labs.
              • 4. Re: Develop Settings
                The new Process Version 2012 develop settings will not be available in any version of Camera Raw prior to version 7. Therefore, images sent from Lr4 to CS5 or earlier will be converted to PV2010 or earlier. If you want/need a direct 1:1 match you'll need to upgrade to Photoshop CS6 when it ships in a few weeks.
                PS CS6 http://www.adobe.com/products/photoshop.html
                or CS6 http://www.adobe.com/products/creativesuite.html
                • 5. Re: Develop Settings
                  LRuser24 Community Member
                  I thought that ACR 6.7 will able to interpret PV 2012. The only drawback in ACR 6.7 will be that the new PV 2012 settings will not be changeable in the ACR GUI. And this is already the case for ACR 6.7 RC (with a few rendering differences compared to LR4).
                  Quote from the lightroom journal:
                  The correct plug-in for Lightroom 4 and Photoshop CS5 compatibility is Camera Raw 6.7, currently available on Adobe Labs Please keep in mind that currently Camera Raw 6.7 is a a Release Candidate version of the plug-in.
                  ...or did I misunderstand something?
