1. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
m!ndl0rdApr 23, 2012 3:15 PM (in response to shark2)
1 person found this helpfulThe error message poped up in CS3 because the license files were not transfered. You can follow the knowledge base link below to work on the issue but its recommended to install CS3 and then serializing it.
http://helpx.adobe.com/x-productkb/global/error-licensing-stopped-mac-os.html
2. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
shark2 Apr 23, 2012 3:43 PM (in response to m!ndl0rd)Thanks.
If I can't find my install disc for CS3, can you give me a link to download CS3?
I have the serial number because I registered CS3 with Adobe when I bought it and looked that up under MyAdobe.
3. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
m!ndl0rdApr 23, 2012 3:50 PM (in response to shark2)
CS3 is EOL and would be hard to get but there are links available for few products to download.
Which CS3 application do you seek for? You mentioned Illustrator, is it?
4. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
Mylenium Apr 23, 2012 10:33 PM (in response to shark2)1 person found this helpful1. how to fix without reinstalling?
It can't be done. you must reinstall. If you do no longer have the disks, that would be problematic, though.... Adobe doesn't hold legacy versions.
Mylenium
5. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
Manish-SharmaApr 23, 2012 11:03 PM (in response to Mylenium)
1 person found this helpfulWhat Mylenium is saying is correct...MIgration tool never work for transfering Adobe product , you have to re-install
Check this link , it may help http://prodesigntools.com/download-adobe-cs4-and-cs3-free-trials-here.html
6. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
Arpit KapoorApr 24, 2012 2:12 AM (in response to shark2)
1 person found this helpfulHi Shark2,
As already stated by everyone, the only option left for you is to uninstall CS3 completely from your machine and then re-install it.
Follow the below suggestions to uninstall CS3.
- Uninstall CS3 using its uninstaller from Utilities->Adobe Installers Folder
- Download and install the Adobe Creative Suite Cleaner Tool and remove the reminents of Creative Suite applications.
- Empty the Temp folder(Go->Go To Folder->/tmp)
- Empty the Trash.
- Reboot the machine.
Download the respective CS3 application or suite from http://prodesigntools.com/download-adobe-cs4-and-cs3-free-trials-here.html and try to install it and check if everything works fine.
Please feel free to respond to this thread if you have any questions about the steps listed. It would be appreciated.
Regards
Arpit
7. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
shark2 Apr 26, 2012 9:44 AM (in response to shark2)Thanks everyone. I've made some progress due to all your help.
But I've got a new problem: when I reinstalled CS3 using the original discs, CS3 Indesign and CS3 Acrobat did not install properly.
My questions:
1. Got any ideas how to fix without uninstalling the whole CS3, running the cleaner tool, and reinstalling everything again? I tried to rerun the installer just for InDesign and Acrobat Pro but I got the same result -- no install.
2. Installing CS3 takes forever -- at least several hours. Is it because I'm sending it over my wireless network? (I'm "sharing" the DVD drive on my other Macbook because my Air doesn't have one.)
Thanks so much!!
8. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
Arpit KapoorApr 30, 2012 7:18 AM (in response to shark2)
Hi Shark2,
You donot need the CS3 disc to uninstall CS3. Just follow the steps i mentioned above to "Uninstall CS3" from your machine.
That will help you to fix your issue.
Regards
Arpit
9. Re: Why didn't Adobe CS3 migrate properly using Mac's Migration Assistant?
Larsons Robert Oct 17, 2012 8:46 PM (in response to Arpit Kapoor)I am still making use of CS3 and that i aren't believe that AI nonetheless does not have a suitable variety tool through version five. Which is crazy. A lasso device should choose all of the items within it again since the arrears. Not all the particular factors, all of the items. I don't know regarding one, but I avoid draw factors, I draw items. Certain, there can be some other key-controlled selections, however the nearly all intuitive ought to be the arrears. Only those people that have just utilized AI claim this particular. This, and the inability to obtain circles or anything besides different types of parallelograms, offers indeed kept the application almost unusable. Painting and certainly Freehand are usually sorely skipped on the Macintosh aspect.
Larsons Robert
Hear my music
