Hi jha900
I think what DilbertG meant to convey was that you can force
full motion recording from inside Captivate. Normally, Captivate
only automatically shifts into full motion recording mode for
clicks and drags. But it can also be forced into this mode via
keystroke. Unless you have changed the recording keys, the
keystroke is F9 to begin full motion capture and F10 to end it.
Sooo, you could theoretically press F9 to begin full motion
capture mode, capture the animation, then press F10 once the
animation is complete. Repeat as necessary. However, your end
results may not be to your satisfaction. Why? Captivate was never
intended to record in this mode. Only as a supplement when
recording. So the results will vary.
Cheers... Rick
