11 Replies Latest reply: Nov 20, 2013 3:57 AM by Peter Stnsz RSS
    Finding the end of line
    Sami Artur Community Member
      Is It possible to find and change a character in the end of each line from a block text?
      I know Indesign GREP can't do this, GREP only finds the end of paragraph, not lines.
      I understand this is a problem because every time the text frame is modified, you have another character being changed.
      Is It possible to do this with a script?
      I have attached an image of what I would like to do.
      The text in the image is Hebrew (R2L language) and the end of line is in the left.
      Any help would be great.
      Sami
        • 1. Re: Finding the end of line
          TᴀW ACP/MVP
          Well, if you've got some text (paragraphs, story, whatever):
          myText.lines.characters[-1]
          will get you the last character on the line.
          If you want to change what it is,
          myText.lines.characters[-1].contents = "Z"
          etc.
          Ariel
          • 2. Re: Finding the end of line
            Thank you Ariel, but I am receiving this message:
            Object does not support the property or method 'characters'
            Sami
            • 3. Re: Finding the end of line
              TᴀW ACP/MVP
              It depends on how you're getting hold of the block of text.
              Let's say you select a paragraph in InDesign.
              So then  you can say:
              myPara = app.selection[0];
              then the lines in this paragraph are:
              myLines = myPara.lines;
              so now you can do a loop:
              for (var i =0; i<myLines.length; i++){
              now let's say you've set you app.findTextPreferences and app.changeTextPreferences to whatever you want, you can search the line as follows:
              myFinds = myLines[i].findText();
              and the last find on the line will be:
              myFinds[-1]
              so you can change that to whatever you want:
              myFinds[-1].contents = "Z";
              If you want to substitute justification alternatives with regular letters it's obviously a little more complicated (you've got to find the unicode values, etc.) but this is the basic idea.
              One thing you've got to be careful about is that if you make a replacement, the lines shouldn't change. If the line breaks change, myLines will no longer be valid and you can get some weird results.
              HTH,
              Ariel
              • 4. Re: Finding the end of line
                Thank's again Ariel,
                I am a beginner in Java Script and I don't know what I am doing wrong.
                Please take a look:
                main();
                function main(){
                          mySetup();
                          mySnippet();
                          myTeardown();
                function mySetup(){
                function mySnippet(){
                          if (app.documents.length != 0){
                                    if (app.selection.length == 1){
                                              switch (app.selection[0].constructor.name){
                                                        case "InsertionPoint":
                                                        case "Character":
                                                        case "Word":
                                                        case "TextStyleRange":
                                                        case "Line":
                                                        case "Paragraph":
                                                        case "TextColumn":
                                                        case "Text":
                                                        case "Story":
        myProcessText(app.selection[0]);
                                                        break;
                                                        case "TextFrame":
        myProcessText(app.selection[0].texts.item(0));
        break;
                                                        default:
        alert("The selected object is not a text object. Select some text and try again.");
        break;
                                    else{
                                              alert("Please select some text and try again.");
                function myTeardown(){
                function myProcessText(myTextObject){
                var myDocument = app.documents.item(0);
                var myPage = myDocument.pages.item(0);
                var myTextFrame = myPage.textFrames.item(0);
                var myTextObject = myTextFrame.parentStory.characters.item(0);
                var myStory = myDocument.stories.item(0);
                var myStringArray = myTextFrame.lines.everyItem().contents;
                    myFinds = myLines[i].findText(ת);
                myFinds[-1].contents = "z";
                Sami
                • 5. Re: Finding the end of line
                  Jump_Over Community Member
                  Assuming your text is inside one or more text frames which are connected. Select one of them and run this:
                  myLines = app.selection[0].parentStory.lines;
                  for (k=0; k<myLines.length; k++){
                       if(myLines[k].characters[-1] == "\r")                         // if there is an end of paragraph
                            myLines[k].characters[-2].contents = "z";          // change a second last character to "z"
                       else myLines[k].characters[-1].contents = "z";     // otherwise change a last character to "z"
                  This is just for show the way.
                  Hope you step into
                  • 6. Re: Finding the end of line
                    Thank you very much Jump_Over!
                    It works!
                    Now I am doing the final adjustments.
                    Sami
                    • 7. Re: Finding the end of line
                      Peter Stnsz Community Member
                      Hi there!
                      I am trying to figure out how to modify the script that can look for last one or two last words (widows/orphans) in the line that starts after the period. Would script be able to add No Break GREP or character style?
                      Peter
                      • 8. Re: Finding the end of line
                        It could work with nested Grep which is applying "noBreak" charStyle.
                        expression for the last word: \x{20}\b\w+\b.$
                        expression for two last words: (\x{20}\b\w+\b){2}.$
                        Jarek
                        • 9. Re: Finding the end of line
                          Hi Jarek,
                          Thank you for the answer. Your GREP works, however not the way I wanted. Works quite similar to the solution that I am using at the moment: nested NoBreak style with GREP .{8}$ (so It won't leave any short words at the end of the paragraph).
                          The solution I am looking for is to find a script that will push these words to the next line (within the paragraph, not only at the end of the paragraph), here is what I mean - I would like to move this 'orphan' word to the next line:
                          I presume I will be not able to make that with GREP itself?
                          Peter
                          • 10. Re: Finding the end of line
                            so maybe try:
                            \b.{2}\b\s
                            Jarek
                            • 11. Re: Finding the end of line
                              Hello Jarek,
                              This will actually work. Thanks!
