1. Re: Save standard set of metadata settings
RikkFlohr Apr 25, 2012 6:06 AM (in response to badchess)Yes, you do this via a Metadata Preset. You can construct one (or many) and apply them at import or to large groups of images in the Grid mode of the Library module.
Goto: Metadata>Edit Metadata Presets… and construct what you want and then save it as a preset
2. Re: Save standard set of metadata settings
Jim Wilde Apr 25, 2012 6:09 AM (in response to badchess)Metadata Menu>Edit Metadata Presets.
In the ensuing dialog box, check which items you want to include in your preset and enter the relevant information. When you are done, click Done and you will be prompted with the option to save the settings as a new preset. Enter the name you want, click Create and you are done. You can then apply that preset automatically on import, or retrospectively by selecting images in Library and then in the Metadata pane in the right-hand panel click the two small arrows in the "Preset" box (top entry below the Metadata Pane header)....the list of available presets will drop down, click on the one you want to apply.
3. Re: Save standard set of metadata settings
badchess Apr 25, 2012 7:17 AM (in response to Jim Wilde)Excellent, thanks guys.
I just decided to switch from bibblepro to lightroom, so I'm still feeling my way around.
