Hello everyone
I use RH 9 and the output is Webhelp.
I've created snippets with drop-down hotspots inside. These snippets are then included in HTML pages.
After help generation, the drop-down hotspots are working with IE but not with Mozilla (some of them are working but a few only).
Some are working in some HTML pages but not in another pages using the same snippet.
Is DHTML compatible with Mozilla Firefox ?
Yes, Dropdowns are compatible with Firefox. DHTML effects other than dropdown/expandspot/popup may not work however. Do you use any other events?
Is this project upgraded from a lower version of RH? If so, make a backup of your project and run Tools > Update DHTML effects in topics.
Greet,
Willam
Thank you for your answer.
My project is upgraded from RH 8 and I update DHTML.
My problem still remains.
There are images in the dropdown text.
Is the problem linked with snippet ? The dropdown are included in snippet.
When I generate my project using the prompt command, there’s still this message : “no baggage file description”. What’s it mean ?
Cordialement
Florence
Hmm,
Please check the following threads:
I don't think i'tll solve the dropdown problem, but it may help with the baggage file warning. Also check that the file rhbag.apj is available in your project root.
For the dropdowns: Can you post the HTML of a snippet so we can see what's going on? Try the FireBug extension for firefox. Do you receive any errors in the console of Firebug when you click a dropdown? Alternatively, can you share the project with me so I can take a look in the FF console? You can PM me for my e-mail.
Greet,
Willam
Here is the HTML of a snippet :
. La liste des renouvellements du
client s'affiche. (<span class="Menu_deroulant_a">Voir</span> )
!Liste_Renouvellement.jpg|style=border: none;|alt=|src=Liste_Renouvellement.jpg|border=0!
Remarque
: le numéro du renouvellement s'affiche ainsi que les produits
dispensés.
Le
logiciel demande le numéro du renouvellement. (<span class="Menu_deroulant_a">Voir</span> )
In the console of Firebug, there is this warning : "enabling javascript debugger to support console"
The rhbag.apj is available in the project root.
Cordialement
Florence
Can you paste the HTML using the browser? You snippet doesn't come through correctly in the replied e-mail.
Greet,
Willam
Just go to the forum site, in the top left corner, click Log in. In your thread click reply and paste the HTML in the message area.
Greet,
Willam
Here is the source HTML code of a snippet (from RH) :
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="topic-comment" content="Procédure du renouvellement actualisé" />
<meta name="generator" content="Adobe RoboHelp 9" />
<title>Renouvellement_Actualise</title>
<link rel="StyleSheet" href="Alliance_Premium.css" type="text/css" />
</head>
<body>
<?rh-script_start ?><script src="ehlpdhtm.js" type="text/javascript" language="JavaScript1.2"></script><?rh-script_end ?>
<h2 class="Texte">Réaliser le renouvellement</h2>
<p class="Texte">Suivre la procédure décrite ci-dessous pour réaliser un
renouvellement actualisé.</p>
<table class="Tableau_Gris" style="border: Double 1px #dbdbdb; margin-top: 2px;
margin-bottom: 2px; margin-right: 64px; left: 0px; top: 30px;
margin-left: 15px;" cellspacing="0">
<col width="35" />
<col width="682" />
<tr class="t1st" style="vertical-align: middle;">
<td style="border: Solid 1px #dbdbdb;" bgcolor="#6A7E93"><p class="Etape_Action"><span
style="text-transform: uppercase;">é</span>tape</p></td>
<td style="border-top: Solid 1px #dbdbdb; border-right: Solid 1px #dbdbdb;
border-bottom: Solid 1px #dbdbdb;" bgcolor="#6A7E93"><p class="Etape_Action">Action</p></td>
</tr>
<tr class="t2Row" style="vertical-align: middle;">
<td class="t1st" style="border-left: Solid 1px #dbdbdb; border-right: Solid 1px #dbdbdb;
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">1</p></td>
<td class="last" style="border-right: Solid 1px #dbdbdb; border-bottom: Solid 1px #dbdbdb;"><p
class="Texte_Tableau">En espace de travail, saisir le nom
du client et appuyer sur la touche <span class="Bouton">[F2 Reprise
facture]</span> du clavier.</p>
<ul>
<li class="Resultat_Tableau" style="color: #607284;"><p class="Texte_Tableau"
style="color: #607284;">La liste des menus s'affiche.
(<a class="dropspot" href="javascript:TextPopup(this)" id="a1"><span
class="Menu_deroulant_a">Voir</span></a>)</p>
<div class="droptext" id="POPUP507750580" style="display: none;">
<p><img src="Menus_F2_EspaceTravail.jpg" alt="" style="border: none;"
border="0" /></p>
</div></li>
</ul>
<p class="Remarque"><span style="font-weight: bold;">Remarque</span>
: vous pouvez également accéder au renouvellement actualisé d'une
facture, via la touche <span style="font-weight: bold;">[F5]</span>,
puis sélectionner la facture concernée, appuyer sur la touche
<span style="font-weight: bold;"><Entrée></span> et cliquer
sur<span style="font-weight: bold;"> [renouvt aCtualisé]. </span></p></td>
</tr>
<tr class="t1Row" style="vertical-align: middle;">
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">2</p></td>
class="Texte_Tableau">Cliquer sur <span class="Bouton">[liste
des renouVellements client]</span>.</p>
<ul>
style="color: #607284;">La liste des renouvellements du
client s'affiche. (<a class="dropspot" href="javascript:TextPopup(this)"
id="a2"><span class="Menu_deroulant_a">Voir</span></a>)</p>
<div class="droptext" id="POPUP448612676" style="display: none;">
<p><img src="Liste_Renouvellement.jpg" alt="" style="border: none;"
border="0" /></p>
</div></li>
</ul>
dispensés.</p></td>
</tr>
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">3</p></td>
class="Texte_Tableau">Sélectionner la dispensation à renouveler
et appuyer sur la touche<span class="Bouton"> [A renouvellement
Actualisé]</span>.</p>
: sélectionner en premier la dispensation et ensuite les lignes
de la dispensation. SI vous sélectionnez une ligne avant la dispensation,
le message suivant s'affiche. <span style="color: #607284;">(</span><a
class="dropspot" href="javascript:TextPopup(this)" id="a5"><span
class="Menu_deroulant_a">Voir</span></a><span style="color: #607284;">)</span></p>
<div class="droptext" id="POPUP440995091_1_1_1" style="display: none;">
<p><img src="Message_Selection_Lignes_Dispensation_Rnvt.jpg"
alt="" style="border: none;" border="0" /></p>
</div>
<ul>
<li class="Resultat_Tableau"><p class="Texte_Tableau" style="color: #607284;">Le
logiciel demande le numéro du renouvellement. (<a class="dropspot"
href="javascript:TextPopup(this)" id="a3"><span class="Menu_deroulant_a">Voir</span></a>)</p>
<div class="droptext" id="POPUP448653551" style="display: none;">
<p><img src="Demande_Numero_Renouvellement.jpg" alt=""
</div></li>
</ul></td>
</tr>
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">4</p></td>
class="Texte_Tableau">Indiquer le numéro du renouvellement.</p>
<ul>
style="color: #607284;">Le logiciel rapatrie les informations
de la facture dans l'espace de travail.</p></li>
</ul></td>
</tr>
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">5</p></td>
class="Texte_Tableau">Valider la vente via la touche <span
class="Bouton"><*></span>.</p>
<ul>
<li class="Resultat_Tableau"><p class="Texte_Tableau"><span
style="color: #607284;">Le numéro de renouvellement s'affiche
dans la zone </span><span style="color: #607284; font-weight: bold;">Renouvellement</span><span
style="color: #607284;">. (</span><a class="dropspot" href="javascript:TextPopup(this)"
id="a4"><span class="Menu_deroulant_a">Voir</span></a><span
<div class="droptext" id="POPUP484680565_1_1_1" style="display: none;">
<p><img src="Zone_Renouvellement_Modifiable.jpg" alt=""
</div></li>
</ul>
: vous pouvez encore modifier le numéro de renouvellement à cette
étape.</p></td>
</tr>
border-bottom: Solid 1px #dbdbdb;"><p class="Num_etape">6</p></td>
class="Texte_Tableau">Terminer la vente.</p></td>
</tr>
</table>
<?rh-script_start ?><script type="text/javascript" language="JavaScript1.2">//<![CDATA[
if( typeof( TextPopupInit ) != 'function' ) TextPopupInit = new Function();
TextPopupInit('a1', 'POPUP507750580');
TextPopupInit('a2', 'POPUP448612676');
TextPopupInit('a5', 'POPUP440995091_1_1_1');
TextPopupInit('a3', 'POPUP448653551');
TextPopupInit('a4', 'POPUP484680565_1_1_1');
//]]></script><?rh-script_end ?>
</body>
</html>
Sorry, Florence, you can’t attach files to posts on the forum – they get stripped off.
