29 Replies Latest reply: May 2, 2012 6:19 AM by Jonathan Fortis RSS
    truncate text to the end of a word
    Jonathan Fortis Community Member
      i have made a truncate using the code i will shown by bregent, however i want to extend this to make sure the full word is shown rather than cutting off
      code here
      $query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, LEFT(tk_job_desc, 80) as truncated_job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
      $query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
      $Recordset1 = mysql_query($query_limit_Recordset1, $hostprop) or die(mysql_error());
      $row_Recordset1 = mysql_fetch_assoc($Recordset1);
      and the result of the truncate is
      <?php echo $row_Recordset1['truncated_job_desc']; ?>
      what do i do to make sre a word is complete?
      thanks in advance
        • 1. Re: truncate text to the end of a word
          sudarshan.t CommunityMVP
          At the moment, how many letters is it showing by default after you run your truncate function? 80?
          If it is showing 80 characters, change the highlited string in the following code. This will display 150 characters.
          $query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, LEFT(tk_job_desc, 150) as truncated_job_desc FROM
          • 2. Re: truncate text to the end of a word
            Also, if you'd like to truncate to the nearest word, you should visit string position - strpos function. You can read about it here:
            http://www.ambrosite.com/blog/truncate-long-titles-to-the-nearest-whole-word-using-php-str rpos
            • 3. Re: truncate text to the end of a word
              hi, i know how to chanhe the amount of characters showing i need to know how to show complete words rather than breaking them of half half way throught the word
              • 4. Re: truncate text to the end of a word
                ok so i should change the
                LEFT(tk_job_desc, 150) as truncated_job_desc FROM in the sql statement and use the example you used to truncate the text then specify the length
                echo substr( $title, 0, strrpos( substr( $title, 0, 35), ' ' ) );
                <?php
                echo substr $row_Recordset1['tk_job_desc'], 0 , strrpos( $row_Recordset1['tk_job_desc'], 0, 80), ' ' ) );
                would that work?
                • 6. Re: truncate text to the end of a word
                  so can i change the sql statement from
                  to
                  job_desc FROM
                  • 7. Re: truncate text to the end of a word
                    Yes. Your SQL query will return the entire data available in 'job_desc' and your strrpos statement will truncate it
                    • 8. Re: truncate text to the end of a word
                      i have tried using <?php echo substr $row_Recordset1['tk_job_desc'], 0 , strrpos( $row_Recordset1['tk_job_desc'], 0, 80), ' ' ) ); ?>
                      and it is showing a sytnax error in dreamweaver
                      • 9. Re: truncate text to the end of a word
                        i looked again and added two more brackets
                        <?php echo substr ( $row_Recordset1['tk_job_desc'], 0 , strrpos( substr( $row_Recordset1['tk_job_desc'], 0, 80), ' ' ) ); ?>
                        but the results didnt display anything
                        • 10. Re: truncate text to the end of a word
                          Can you post your full PHP + HTML Code here so I can take a look at what might be going wrong and where.
                          • 11. Re: truncate text to the end of a word
                            the sql statement is currently
                            mysql_select_db($database_hostprop, $hostprop);
                            the output
                            the changed version is
                            $query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
                            if you need anymore code let me know
                            • 12. Re: truncate text to the end of a word
                              Can you upload your site and post a link here?
                              • 13. Re: truncate text to the end of a word
                                ok here is a link to the page its in the Latest job section (ignore the rest of the formatting)
                                http://www.thinkfuturerecruitment.co.uk/beta/what-we-do.php
                                • 14. Re: truncate text to the end of a word
                                  Can you define a variable in PHP to call your data from the job_desc table?
                                  Once you read the data from your desired column, assign it to a variable something like
                                  $jobdesc = "your-definition-of-the-variable-from-db;
                                  Then, you could use a function to truncate the called text.
                                  function truncateDesc($input, $numwords, $padding=""){
                                      $output = strtok($input, " \n"); while(--$numwords > 0) $output .= " " . strtok(" \n"); if ($output != $input) $output .= $padding; return $output;
                                  Your next variable would be to truncate the data that is read using the previous function defined above:
                                  $truncated = truncateDesc($jobdesc, 10, "...");
                                  Then finally, once $truncate variable is defined, you could echo it in your HTML:
                                  echo "<p>$truncated</p>";
                                  A static example of this code will be as follows:
                                  <?PHP
                                  $longtext = "This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description.";
                                  function truncateLong($input, $numwords, $padding="")
                                  { $output = strtok($input, " \n"); while(--$numwords > 0) $output .= " " . strtok(" \n"); if($output != $input) $output .= $padding; return $output; }
                                  $truncated = truncateLong($longtext, 10, "...");
                                  This should ideally work.
                                  Undo the previous strpos function that you've defined earlier before trying this.
                                  • 15. Re: truncate text to the end of a word
                                    the table name isjob_desc
                                    is that what you mean?
                                    • 16. Re: truncate text to the end of a word
                                      I meant define a variable that loads the data from job_desc field that is located inside a table in your database.
                                      • 17. Re: truncate text to the end of a word
                                        sorry how would i do that then? seems confusing
                                        • 18. Re: truncate text to the end of a word
                                          Something like this:
                                          Your SQL code:
                                          mysql_select_db($database_testconnection, $testconnection);
                                          $query_Recordset1 = "SELECT job_desc FROM think_jobsearch";
                                          $Recordset1 = mysql_query($query_Recordset1, $testconnection) or die(mysql_error());
                                          $totalRows_Recordset1 = mysql_num_rows($Recordset1);
                                          In your main HTML body, if you give this:
                                          <?php echo $row_Recordset1['job_desc']; ?>
                                          You'll get all data in all rows from your table
                                          Now that we're able to echo the result in the page, we need to truncate it to achieve our objective. For this, look at the code below:
                                          <?PHP
                                          $description = $row_Recordset1['job_desc'];
                                          function truncateWords($input, $numwords, $padding="")
                                          $truncated = truncateWords($description, 10, "...");
                                          This will cut it to 10 words and add ellipsis (...) to the text beyond 10 words.
                                          I guess you could figure out to explode the results from your recordset column into different rows and order them as per the Job_ID or something.
                                          Hope this helps.
                                          • 19. Re: truncate text to the end of a word
                                            thanks getting there....i inserted the above code in the top of the php code and amended the correct fields..however its now just showing all the text with no truncating
                                            • 20. Re: truncate text to the end of a word
                                              Post your current code here
                                              • 21. Re: truncate text to the end of a word
                                                php
                                                <?php require_once('Connections/hostprop.php'); ?>
                                                <?PHP
                                                $description = $row_Recordset1['tk_job_desc'];
                                                <?php
                                                if (!function_exists("GetSQLValueString")) {
                                                function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
                                                  if (PHP_VERSION < 6) {
                                                    $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
                                                  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
                                                  switch ($theType) {
                                                    case "text":
                                                      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
                                                      break;
                                                    case "long":
                                                    case "int":
                                                      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
                                                      break;
                                                    case "double":
                                                      $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
                                                      break;
                                                    case "date":
                                                      break;
                                                    case "defined":
                                                      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
                                                      break;
                                                  return $theValue;
                                                <?php
                                                // *** Validate request to login to this site.
                                                if (!isset($_SESSION)) {
                                                  session_start();
                                                $loginFormAction = $_SERVER['PHP_SELF'];
                                                if (isset($_GET['accesscheck'])) {
                                                  $_SESSION['PrevUrl'] = $_GET['accesscheck'];
                                                if (isset($_POST['userid'])) {
                                                  $loginUsername=$_POST['userid'];
                                                  $password=$_POST['password'];
                                                  $MM_fldUserAuthorization = "";
                                                  $MM_redirectLoginSuccess = "signup/signup-complete.php";
                                                  $MM_redirectLoginFailed = "failed.php";
                                                  $MM_redirecttoReferrer = false;
                                                  $LoginRS__query=sprintf("SELECT userid, password FROM think_signup WHERE userid=%s AND password=%s",
                                                    GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
                                                  $LoginRS = mysql_query($LoginRS__query, $hostprop) or die(mysql_error());
                                                  $loginFoundUser = mysql_num_rows($LoginRS);
                                                  if ($loginFoundUser) {
                                                     $loginStrGroup = "";
                                                          if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
                                                    //declare two session variables and assign them
                                                    $_SESSION['MM_Username'] = $loginUsername;
                                                    $_SESSION['MM_UserGroup'] = $loginStrGroup;
                                                    if (isset($_SESSION['PrevUrl']) && false) {
                                                      $MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
                                                    header("Location: " . $MM_redirectLoginSuccess );
                                                  else {
                                                    header("Location: ". $MM_redirectLoginFailed );
                                                <?php
                                                  switch ($theType) {
                                                    case "text":
                                                      break;
                                                    case "long":
                                                    case "int":
                                                      break;
                                                    case "double":
                                                      break;
                                                    case "date":
                                                      break;
                                                    case "defined":
                                                      break;
                                                  return $theValue;
                                                $maxRows_Recordset1 = 9;
                                                $pageNum_Recordset1 = 0;
                                                if (isset($_GET['pageNum_Recordset1'])) {
                                                  $pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
                                                $startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
                                                $query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, tk_job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
                                                if (isset($_GET['totalRows_Recordset1'])) {
                                                  $totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
                                                } else {
                                                  $all_Recordset1 = mysql_query($query_Recordset1);
                                                  $totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
                                                $query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, tk_job_desc FROM think_jobsearch ORDER BY tk_job_ID DESC";
                                                $Recordset1 = mysql_query($query_Recordset1, $hostprop) or die(mysql_error());
                                                $maxRows_Recordset2 = 3;
                                                $pageNum_Recordset2 = 0;
                                                if (isset($_GET['pageNum_Recordset2'])) {
                                                  $pageNum_Recordset2 = $_GET['pageNum_Recordset2'];
                                                $startRow_Recordset2 = $pageNum_Recordset2 * $maxRows_Recordset2;
                                                $query_Recordset2 = "SELECT ID, FirstName, Surname, PositionReq, SalaryReq, skills_offered, location, LEFT(CanAdminInfo, 100) as truncated_CanAdminInfo FROM think_signup ORDER BY ID DESC";
                                                $query_limit_Recordset2 = sprintf("%s LIMIT %d, %d", $query_Recordset2, $startRow_Recordset2, $maxRows_Recordset2);
                                                $Recordset2 = mysql_query($query_limit_Recordset2, $hostprop) or die(mysql_error());
                                                $row_Recordset2 = mysql_fetch_assoc($Recordset2);
                                                if (isset($_GET['totalRows_Recordset2'])) {
                                                  $totalRows_Recordset2 = $_GET['totalRows_Recordset2'];
                                                } else {
                                                  $all_Recordset2 = mysql_query($query_Recordset2);
                                                  $totalRows_Recordset2 = mysql_num_rows($all_Recordset2);
                                                $totalPages_Recordset2 = ceil($totalRows_Recordset2/$maxRows_Recordset2)-1;
                                                $query_Recordset3 = "SELECT * FROM think_wwd";
                                                $Recordset3 = mysql_query($query_Recordset3, $hostprop) or die(mysql_error());
                                                $row_Recordset3 = mysql_fetch_assoc($Recordset3);
                                                $totalRows_Recordset3 = mysql_num_rows($Recordset3);
                                                results <?php echo $row_Recordset1['job_desc']; ?>
                                                • 22. Re: truncate text to the end of a word
                                                  The last line of your code has
                                                  this is why it's displaying all data. Actually your truncate code is not doing its job.
                                                  Try removing the last line and replace it with
                                                  <?PHP
                                                  See if it works
                                                  • 23. Re: truncate text to the end of a word
                                                    this is what i already have in the code which looks the same as above?
                                                    <?PHP
                                                    • 24. Re: truncate text to the end of a word
                                                      I know that. But, I asked you to change where it is placed. And to remove the last line with
                                                      • 25. Re: truncate text to the end of a word
                                                        so remove this <?php echo $row_Recordset1['job_desc']; ?>
                                                        and replace with this
                                                        <?PHP
                                                        • 26. Re: truncate text to the end of a word
                                                          Yes mate. You should remove that code from the top of your PHP page. It should be present at the bottom.
                                                          • 27. Re: truncate text to the end of a word
                                                            got an error
                                                            Fatal error: Cannot redeclare truncatewords() (previously declared in /usr/users1/jonfort/public_html/think/beta/what-we-do.php:5) in /usr/users1/jonfort/public_html/think/beta/what-we-do.php on line 424
                                                            that line of code shows
                                                            • 28. Re: truncate text to the end of a word
                                                              As adviced, you already have the function present between lines 421 an 431. The same function between lines 2 and 11 are redundant. Remove these lines 2 till 11 and it should ideally work.
                                                              Cheers,
                                                              ST
                                                              • 29. Re: truncate text to the end of a word
        ok thanks i will try this out and let you know how i get on thanks
