10 Replies Latest reply: May 3, 2012 11:55 PM by BKBK RSS
    Creating objects in application scope or session scope?
    domgghghgh
      Hi there
      I have a queries.cfc with functions which are getting or setting fields in a database. The application runs on CF 9 and has a lot of parallel users. To speed up the function calls I create the object in the Application.cfc like this:
      <cffunction name="onSessionStart" returntype="boolean" output="true">
           <cfset structDelete(session, "queriesObject")>
           <cfset SESSION.queriesObject = new components.queries() >
           <cfreturn true>
      </cffunction>
      What is the better way to create the object: in the application or session scope? In the application scope I would create the object once and in the session scope I would create the object for every user. That needs more memory but every user has an own object.
      What is about the locking mechanism if multiple users call the same function from the object?
      Thanks for answers and discussions...
        • 1. Re: Creating objects in application scope or session scope?
          Dan Bracuk Community Member
          If the queryobject is the same for every user, and the cfc does not have any global variables that the user can change, the application scope is appropriate.
          • 2. Re: Creating objects in application scope or session scope?
            domgghghgh Community Member
            Thanks for your answer Dan. Do you know what exactly happens with this global obejct in the application scope if multiple users access the same function? Does coldfusion generate for every user/request an instance of this object? If no, isn't it a bottleneck concerning performance?
            • 3. Re: Creating objects in application scope or session scope?
              12Robots Community Member
              No and No
              1. You are creating the instance and sticking it in the App scope. ColdFusion does not create it again when you call it.
              2. ColdFusion is multi-threaded, so if two users make a request to the same function in the object they will both run in parralel. Which is why it is VERY important to properly scope your function variables (var them). Unless it is a long running function and you have lots of simultaneous users, I doubt you would experience any performance issues.
              Jason
              • 4. Re: Creating objects in application scope or session scope?
                BKBK ACP/MVP
                This shouldn't sound like a choice between programming styles. It is your requirements or specifications that determine the choice.
                If, as Dan says, nothing about the component's variables changes from one user-session to the next, then you should store the object in the application scope (in onApplicationStart). If the component has any dependency on the user or session, the session scope and onSessionStart would be more appropriate.
                You need no lock for application scoped code within onApplicationStart or for session scoped code within onSessionStart.
                • 5. Re: Creating objects in application scope or session scope?
                  BKBK ACP/MVP
                  On the contrary, the more instances (such as when they are stored in the session scope), the higher the chances of a bottleneck.
                  • 6. Re: Creating objects in application scope or session scope?
                    Thanks guys. I have another question which is also about creating objects and the application scope. In a database I have a table with configuration parameters which I want to provide in an application variable. I see two alternatives.
                    In the first one I explicit create an object and call the function:
                    <cffunction name="onApplicationStart" returntype="boolean" output="true">
                        <cfset tblConfiguration = "tblConf">
                        <cfset structDelete(application, "configObject")>
                        <cfset configObject = new components.config()>
                        <cfset APPLICATION.Configuration = configObject.getConfiguration(tblConfiguration)> <!--- function returns a struct --->
                        <cfreturn true>
                    </cffunction>
                    What is the lifetime and the scope of the configObject in that case without <cfset var configObject... ?
                    In the second one I call directly the function:
                        <cfset structDelete(application, "Configuration")>
                        <cfset APPLICATION.Configuration = new components.config().getConfiguration(tblConfiguration)> <!--- function returns a struct --->
                        <cfreturn true>
                    </cffunction>
                    I guess that Coldfusion has to create the object to call the function getConfiguration. Is it only a temporarily object? What is the lifetime of this object? I am really interested in the the lifetimes of objects in CF to understand better the mechanism.
                    • 7. Re: Creating objects in application scope or session scope?
                      First, you don't need structDelete.  The function is onApplicationStart so the structure can't possibly exist.
                      In your first example, the configObject stays in memory for the life of the application.  In the second, whatever object is created goes away.  If you don't need the object, your second method is more efficient.
                      As an aside, because one can never have too many choices, the cfinvoke tag is equivalent to your second method.
                      • 8. Re: Creating objects in application scope or session scope?
                        BKBK ACP/MVP
                            <cfreturn true>
                        </cffunction>
                        Lifetime = the duration of the call to onApplicationStart (usually infinitesimally small), for example, when the application starts.
                        Scope = variables.
                            <cfreturn true>
                        </cffunction>
                        Yes, components.config() is a temporary object. There is no difference with the prior example. Its lifetime is the duration of the onApplicationStart event.
                        However, remember that onApplicationStart need not only run at the beginning of the application. If you place the line <cfset onApplicationStart()> in onRequestStart, then the object components.config() will be defined at every request.
                        • 9. Re: Creating objects in application scope or session scope?
                          I've modified the first example and have written for both the lifetime and scope of the object. What do you think about this, is it correct?
                              <cfset APPLICATION.configObject = new components.config()>
                              <cfreturn true>
                          </cffunction>
                          Lifetime of configObject = Lifetime of application
                          Scope of configObject = application
                              <cfreturn true>
                          </cffunction>
                          Lifetime of configObject = very short, after calling the function, the temp. object will be destroyed (like cfinvoke)
                          Scope of configObject = variables, but only a very short time
                          • 10. Re: Creating objects in application scope or session scope?
                            BKBK ACP/MVP
                            Yes. At least, in my opinion. But there is one exception. if you write
                            x = new components.config();
                            then object x is in variables scope. However, if you write
                            new components.config().someFunction();
                            then  new components.config() is not in variables scope.
                            Message edited by: BKBK
