Passing Data from ComboBox to ListBox.
Avatar
Level 1
Hi everyone, I'm new with the whole flex 2 environment and
i'm need some help getting data passed from a ComboBox to ListBox.
I don't know whether i'm going about this the right way. Senario,
the person using this application will be able to select an item in
the ComboBox and based on the item selected, the listBox get
data(using an array variable) assigned to that item in the
ComboBox. I don't know the syntax that is used to achieve this.
I'll appreciate any information related to getting this problem
resolved.
Avatar
Level 3
Hi
Try this sample code
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
creationComplete="initApp()">
<mx:Script>
<![CDATA[
import mx.collections.*;
public var mylist:Array ;
private function initApp():void
mylist = [ {label:"a",data:[{label:"a1",data:1},
{label:"a2",data:2},{label:"a3",data:3}]},
{label:"b",data:[{label:"b1",data:1},
{label:"b2",data:1},{label:"b3",data:1}]},
{label:"c",data:[{label:"c1",data:1},
{label:"c2",data:1},{label:"c3",data:1}]},
{label:"d",data:[{label:"d1",data:1},
{label:"d2",data:1},{label:"d3",data:1}]}] ;
cb.dataProvider = new ArrayCollection(mylist);
</mx:Script>
<mx:ComboBox id="cb"
change="listbox.dataProvider=cb.selectedItem.data"/>
<mx:List id="listbox" width="100"/>
</mx:Application>
William Chan
Avatar
Level 1
Thanks for the feedback william, it was helpful but it still
not entirely what i want the list box and combo box to do. After
the array has been populated in the list box, a selection of item
can be made to display further details of the item in the list box.
A quick question will be can parallel array type be created in
Flex? Trying to accomplish department phone book. The people can
select the department and it will show the list of people in that
department. In the list box a selection of the person can be made
to display more detailed info about the person as name, phone
number, job title and etc. So far i'm not able to get the connect
between the combo and list box to display detail person info. Need
Help, all suggestions will be greatly appreciated. Here's my code
so far:
layout="absolute">
<mx:Style>
Panel
borderStyle: solid;
headerColors: #e7e7e7, #d9d9d9;
backgroundAlpha: 100;
paddingTop: 10;
</mx:Style>
<mx:ArrayCollection id="ITpeople">
<mx:Object>
<mx:image>images/andrewo.gif</mx:image>
<mx:name>John Doe</mx:name>
<mx:title>Weblayout Specialist</mx:title>
<mx:phonenum>ext. 1028</mx:phonenum>
<mx:description>IT Department</mx:description>
</mx:Object>
</mx:ArrayCollection>
<mx:ArrayCollection id="Company">
<mx:Object>
<mx:comp>IT</mx:comp>
</mx:Object>
<mx:Object>
<mx:comp>Accounting</mx:comp>
</mx:Object>
<mx:Object>
<mx:comp>Customer Service</mx:comp>
</mx:Object>
<mx:Script>
<![CDATA[
</mx:Script>
<mx:Panel layout="absolute" left="10" top="10" right="54"
bottom="200" title="ICM Phone Directory">
<mx:ComboBox x="10" y="32" id="cbxCompDept"
dataProvider="{Company}" labelField="comp" selectedIndex="0" >
</mx:ComboBox>
<mx:List id="names" dataProvider="{ITpeople}"
labelField="name" selectedIndex="0" x="10" y="95" height="268"
width="165"></mx:List>
<mx:VBox width="416" y="95" x="206">
<mx:Image id="picture"
source="{ITpeople.getItemAt(names.selectedIndex).image}"
autoLoad="true" />
<mx:Form id="details">
<mx:FormItem label="Name: ">
<mx:Label id="nameInput"
text="{ITpeople.getItemAt(names.selectedIndex).name}"/>
</mx:FormItem>
<mx:FormItem label="Title: ">
<mx:Label id="titleInput"
text="{ITpeople.getItemAt(names.selectedIndex).title}"/>
</mx:FormItem>
<mx:FormItem label="Phone Number: ">
<mx:Label id="phoneInput"
text="{ITpeople.getItemAt(names.selectedIndex).phonenum}"/>
</mx:FormItem>
<mx:FormItem label="Department/Company: ">
<mx:Label id="descInput"
text="{ITpeople.getItemAt(names.selectedIndex).description}"
height="120" width="200" />
</mx:FormItem>
</mx:Form>
</mx:VBox>
</mx:Panel>
</mx:Application>
Avatar
Level 3
Hi
To show the way you want should have a arraycolleciton of
department object, and the department contains its name and
arraycollection of employees. If you don't want to change your data
structure, you can use filterFunction. The code is posted on next
reply
William Chan
Avatar
Level 3
Filter Function solution:
<?xml version="1.0"?>
<Application xmlns="
<Script>
<![CDATA[
import mx.collections.ArrayCollection;
private var filFuncs:Array;
[Bindable]
public var employeeAC:ArrayCollection;
var employees:Array = [
{lastName:"Ada",firstName:"Red",department:"IT"},
{lastName:"Bill",firstName:"Green",department:"Marketing"},
{lastName:"Cathy",firstName:"Purple",department:"IT"},
{lastName:"David",firstName:"Orange",department:"Sales"},
{lastName:"Edward",firstName:"Blue",department:"Sales"}
employeeAC = new ArrayCollection(employees);
filFuncs = getUniques(employeeAC,"department");
depts.dataProvider=filFuncs;
employeeAC.filterFunction = filFuncs[0].data;
employeeAC.refresh();
private function getUniques(list:ArrayCollection,
field:String):Array
var map:Object = new Object();
var fieldValue:String;
var filter:Function;
var uniques:Array = new Array();
for (var i:int=0; i<list.length; i++)
fieldValue = list.getItemAt(i)[field];
if (map[fieldValue] == null)
map[fieldValue] = "exist";
filter = createFilter(field,fieldValue);
uniques.push({label:fieldValue,data:filter});
return uniques;
private function
createFilter(field:String,value:String):Function
return function (o:Object):Boolean {
if (o[field] == value)
return true;
else
return false;
</Script>
<ComboBox id="depts"
change="employeeAC.filterFunction=depts.selectedItem.data;employeeAC.refresh()"/>
<DataGrid dataProvider="{employeeAC}"/>
</Application>
Avatar
Level 3
you can just use one filterFunction:
<Script>
<![CDATA[
[Bindable]
employeeAC.filterFunction = deptFilter;
private var field:String;
field:String):Array
this.field = field;
map[fieldValue] = "";
uniques.push({label:fieldValue});
return uniques;
private function deptFilter(obj:Object):Boolean
if (obj[field] == depts.selectedLabel)
return true;
else
return false;
</Script>
<ComboBox id="depts" change="employeeAC.refresh()"/>
</Application>
Avatar
Level 3
Create a new Data Structure which work for combo + list
<Script>
<![CDATA[
private var newArray:Array;
private var employees:Array;
employees = [
newArray = newDataStructure(employees, "department");
depts.dataProvider = newArray;
private function newDataStructure(list:Array,
field:String):Array
fieldValue = list
[field];
map[fieldValue] = new Array();
uniques.push({label:fieldValue,data:map[fieldValue]});
map[fieldValue].push(list
trace( fieldValue+ ":"+ map[fieldValue].length);
return uniques;
</Script>
<ComboBox id="depts" />
<DataGrid dataProvider="{depts.selectedItem.data}"/>
</Application>
