9 Replies Latest reply on Apr 27, 2012 12:23 PM by tdieng
    Spry Menu Bar Problem: Changes on default page not inherited on other pages
    tdieng Level 1
      Hi folks,
      I have no experience in web designing but my job requires me to do it all at times. I'm an IT tech\Network engineer and been using common sense to edit our main website with dreamweaver. So far everything i did worked fine until editing the menu bar on the main page. Researches and watching tutorials didn't help so hopefully someone here can. Thanks in advance.
      So all i did was edit some stuff on the menu by removing some sub menus and adding a link. All was done from the default.aspx file which is the main page. Everythign works fine but when i go to another page it seems like my changes were never done. All other pages have the spry menu code embedded in gray and can't be edited. After taking a good look i realized it was the old code showing. My question is how do i apply my changes to all pages at once?
      Here is the code after i made the changes. The previous version had just some extra href lines.
      <ul id="MenuBar1" class="MenuBarHorizontal">
            <li style="width:90px;"><a href="default.aspx" style="width:90px; text-align:center;  padding-left:0px;">Home</a></li>
            <li style="width:90px;"><a class="MenuBarItemSubmenu" href="#" style="text-align:center; width:90px; padding-left:0px;">Directory</a>
            <ul>
              <li><a href="judges-dir.aspx">Judicial Staff</a></li>
              <li><a href="case-support.aspx">Administrative Staff</a></li>
            </ul>
        </li>
        <li style="width:136px;"><a href="#" class="MenuBarItemSubmenu" style="text-align:center; width:136px;  padding-left:0px;">Procedural Rules</a>
            <ul>
              <li><a href="documents/procedures/organization-osah.pdf">Organization of OSAH</a></li>
              <li><a href="documents/procedures/administrative-rules-osah.pdf">Administrative Rules of Procedure</a></li>
            </ul>
        </li>
        <li style="width:130px;"><a href="/agency-ref-word.html" class="MenuBarItemSubmenu" style="text-align:center; width:130px;  padding-left:0px;">Case Referral</a> </li>
        <li style="width:142px;"><a href="#" class="MenuBarItemSubmenu" style="text-align:center; width:142px;  padding-left:0px;">Court Information </a>
            <ul>
              <li><a href="calendar-options.aspx">Court Calendar</a></li>
              <li><a href="get-decision.php">Decisions</a></li>
              <li><a href="judges-circuit.html">Judicial Circuits</a> </li>
              <li><a href="directions.html">Directions to Court</a></li>
              <li><a href="#" class="MenuBarItemSubmenu">Frequently Asked Questions</a>
                  <ul>
                    <li><a href="questions.html">English</a></li>
                    <li><a href="questions-espanol.html">Espa&ntilde;ol</a></li>
                  </ul>
              </li>
              <li><a href="comments.aspx">Questions</a></li>
            </ul>
        </li>
        <li style="width:98px;"><a href="/court-forms.html" style="text-align:center; width:98px;  padding-left:0px;">Court Forms</a></li>
        <li style="width:104px;"><a href="#" class="MenuBarItemSubmenu" style="text-align:center; width:104px;  padding-left:0px;">About Us</a>
            <ul>
              <li><a href="documents/OSAH_FY_2011.pdf" target="_blank" class="MenuBarItemSubmenu">Annual Report</a>
                 </li>
      <li><a href="contact-us.html">Contact Us</a></li>
            </ul>
        </li>
          </ul>
      UPDATE: Here is the code embedded in all other pages. I guess i need to know where to go or how to edit it.
      <!-- InstanceEndEditable -->
      <link rel="../shortcut icon" href="/favicon.ico" >
      <link href="CSS/theme4.css" rel="stylesheet" type="text/css" >
      <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
      <script type="text/javascript" src="SpryAssets/SpryMenuBar.js" language="javascript"></script>
      <!-- InstanceBeginEditable name="head" --><style type="text/css">
      body {
      background-image: url(Images/bg_grad.jpg);
      </style><!-- InstanceEndEditable -->
      body {font-size:12px;}
      #MenuBar1 ul, #MenuBar1 ul li {
      width:170px;
      #MenuBar1 span {
      margin:0;
      padding:2px;
      padding-left:22px;
      display:block;
      background-position:0% 50%;
      background-repeat:no-repeat;
      #MenuBar1 #item1 {
      background-image:url(Images/home.gif);
      </style>
      <script type="text/javascript">
        var _gaq = _gaq || [];
        _gaq.push(['_setAccount', 'UA-17672437-1']);
        _gaq.push(['_trackPageview']);
        (function() {
          var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
          ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
          var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
      </script>
      </head>
      <body >
      <div id="wrapper">
      <div id="header"><a href="default.aspx" style="text-decoration:none; font-style:normal; color:#FFFFFF;"></a><img src="Images/header-new4.jpg" alt="header" width="800" height="120" border="0" usemap="#Map" />
      <map name="Map" id="Map"><area shape="rect" coords="6,3,791,93" href="default.aspx" alt="" />
      </map>
      <div id="nav">
            <ul>
            </ul>
        </li>
            <ul>
            </ul>
        </li>
            <ul>
                  <ul>
                  </ul>
              </li>
            </ul>
        </li>
        <li style="width:98px;"><a href="#" class="MenuBarItemSubmenu" style="text-align:center; width:98px;  padding-left:0px;">Court Forms</a>
            <ul>
              <li><a href="documents/motions/10-Entry%20of%20Appearance.doc" target="_blank">Entry of Appearance</a> </li>
              <li><a href="motions.html">Motions</a></li>
              <li><a href="documents/subpoenas/subpoena.pdf" target="_blank">Subpoena</a></li>
            </ul>
        </li>
            <ul>
              <li><a href="#" class="MenuBarItemSubmenu">Annual Reports</a>
                  <ul>
                    <li><a href="documents/OSAH_FY_2010.pdf">Annual Report 2010</a></li>
                    <li><a href="documents/OSAH_FY_2009.pdf">Annual Report 2009</a></li>
                    <li><a href="documents/ANNUAL REPORT 2008.pdf" target="blank">Annual Report 2008</a></li>
                    <li><a href="documents/OSAH_FY_2007.pdf" target="blank">Annual Report 2007</a></li>
                    <li><a href="documents/OSAH_FY_2006.pdf" target="blank">Annual Report 2006</a></li>
                    <li><a href="documents/OSAH_FY_2005.pdf" target="blank">Annual Report 2005</a></li>
                  </ul>
              </li>
              <li><a href="#" class="MenuBarItemSubmenu">News</a>
                  <ul>
                    <li><a href="documents/ABA Regulatory News Article.pdf" target="blank">Administrative and Regulatory Law News  (Summer 2008)</a></li>
                    <li><a href="documents/CSS article.pdf" target="blank">Child Support Services Newsletter (2008)</a></li>
                    <li><a href="documents/CustomerServiceNewsletterl.pdf" target="blank">Georgia Office of Customer Service Newsletter (Mar. 2006)</a></li>
                    <li><a href="documents/GaStatementArticle.pdf" target="blank">Issue of The Georgia Statement (Summer 2005)</a></li>
                    <li><a href="documents/RideTrail.pdf" target="blank">&quot;Ride the Circuit&quot; - Georgia Bar Journal (Feb. 2004)</a></li>
                    <li><a href="documents/awardpaper.pdf" target="blank">2004 Recipient, Georgia Focus Recognition - Georgia Oglethorpe Award Process, Inc.</a></li>
                    <li><a href="documents/Journal_Excel.pdf" target="blank">Journal of Organizational Excellence (Autumn 2004)</a></li>
                  </ul>
              </li>
              <li><a href="documents/Georgia's_Court_System_09.pdf" target="_blank">Georgia's Court System</a></li>
            </ul>
        </li>
          </ul>
          </div>
      </div><!-- End of Header //-->
