17 Replies Latest reply: Apr 27, 2012 11:51 AM by SG... RSS
    "this will make the file too large" warning
    LMn0P Community Member
      Using Beta, and opened file that was created in cs5 PS that included Comps, maybe 4 of them.  There are many layers, but the file is only at 72 for web.
      I wasn't able to click on the different comps in the comp panel.  Each time the Beta just popped a warning message saying "this will make the file too large".
      Anyone know if this is a purposeful Beta restriction of some sort, feature change I'm not aware of, or a bug?  Opened back up in cs5 PS and no problem.
      Working in same file later in PS 6 without touching the Comps and it crashed to desktop.  No reason given.  No other trouble noticed.
      Using Windows 7 sp1 64bit.  Running an Nvidia Quadro 4000.
        • 1. Re: "this will make the file too large" warning
          Pete.Green Adobe Employee
          It sounds like you're running low on hard drive space.
          There aren't any file size restrictions implemented in the beta version of PS CS6, so something else is causing these messages to pop up.
          Can you please include your system info from Photoshop's Help > System Info dialog?
          Also, if you got crash logs, please send them off to Adobe if you get the option, or if not, please post the crash dumps here in the forums for us to look at!
          thanks!
          • 2. Re: "this will make the file too large" warning
            charles badland Community Member
            That does not tell you much... 72 ppi is just half of an equation.
            (plus the web does not look at ppi, it could be 720 for all that it matters)
            What are the pixel dimensions of your document?
            • 3. Re: "this will make the file too large" warning
              pasting info from PS help sys info:
              Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
              Operating System: Windows 7 64-bit
              Version: 6.1 Service Pack 1
              System architecture: Intel CPU Family:6, Model:10, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
              Physical processor count: 4
              Processor speed: 3200 MHz
              Built-in memory: 12271 MB
              Free memory: 8826 MB
              Memory available to Photoshop: 10984 MB
              Memory used by Photoshop: 60 %
              Image tile size: 128K
              Image cache levels: 4
              OpenGL Drawing: Enabled.
              OpenGL Drawing Mode: Advanced
              OpenGL Allow Normal Mode: True.
              OpenGL Allow Advanced Mode: True.
              OpenGL Allow Old GPUs: Not Detected.
              Video Card Vendor: NVIDIA Corporation
              Video Card Renderer: Quadro 4000/PCI/SSE2
              Display: 1
              Display Bounds:=  top: 0, left: 0, bottom: 1200, right: 1920
              Video Card Number: 1
              Video Card: NVIDIA Quadro 4000
              OpenCL Unavailable
              Driver Version: 8.17.12.5912
              Driver Date: 20100726000000.000000-000
              Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
              Video Mode: 1920 x 1200 x 4294967296 colors
              Video Card Caption: NVIDIA Quadro 4000
              Video Card Memory: 2048 MB
              Video Rect Texture Size: 16384
              Serial number: Tryout Version
              Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
              Temporary file path: C:\Users\XXXXXXX\AppData\Local\Temp\
              Photoshop scratch has async I/O enabled
              Scratch volume(s):
                Startup, 147.0G, 59.4G free
              Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
              Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
              Additional Plug-ins folder: not set
              Installed components:
                 A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                 ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                 adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                 AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                 AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                 AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                 AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1642
                 AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                 AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                 AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                 adobe_caps.dll   Adobe CAPS   5,0,10,0
                 AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                 ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                 aif_core.dll   AIF   3.0   62.490293
                 aif_ocl.dll   AIF   3.0   62.490293
                 aif_ogl.dll   AIF   3.0   62.490293
                 amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                 ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                 AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                 AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                 Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                 BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                 boost_date_time.dll   DVA Product   6.0.0
                 boost_signals.dll   DVA Product   6.0.0
                 boost_system.dll   DVA Product   6.0.0
                 boost_threads.dll   DVA Product   6.0.0
                 cg.dll   NVIDIA Cg Runtime   3.0.00007
                 cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                 CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                 CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                 data_flow.dll   AIF   3.0   62.490293
                 dvaaudiodevice.dll   DVA Product   6.0.0
                 dvacore.dll   DVA Product   6.0.0
                 dvamarshal.dll   DVA Product   6.0.0
                 dvamediatypes.dll   DVA Product   6.0.0
                 dvaplayer.dll   DVA Product   6.0.0
                 dvatransport.dll   DVA Product   6.0.0
                 dvaunittesting.dll   DVA Product   6.0.0
                 dynamiclink.dll   DVA Product   6.0.0
                 ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                 FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                 filter_graph.dll   AIF   3.0   62.490293
                 hydra_filters.dll   AIF   3.0   62.490293
                 icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                 icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                 image_compiler.dll   AIF   3.0   62.490293
                 image_flow.dll   AIF   3.0   62.490293
                 image_runtime.dll   AIF   3.0   62.490293
                 JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                 libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                 libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                 LogSession.dll   LogSession   2.1.2.1640
                 mediacoreif.dll   DVA Product   6.0.0
                 MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                 msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                 msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                 msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                 msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                 msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                 msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                 msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                 msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                 pdfsettings.dll   Adobe PDFSettings   1.04
                 Photoshop.dll   Adobe Photoshop CS6   CS6
                 Plugin.dll   Adobe Photoshop CS6   CS6
                 PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
                 PSArt.dll   Adobe Photoshop CS6   CS6
                 PSViews.dll   Adobe Photoshop CS6   CS6
                 SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                 ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                 tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                 tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                 TfFontMgr.dll   FontMgr   9.3.0.113
                 TfKernel.dll   Kernel   9.3.0.113
                 TFKGEOM.dll   Kernel Geom   9.3.0.113
                 TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                 updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                 WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                 wu3d.dll   U3D Writer   9.3.0.113
              Required plug-ins:
                 3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Accented Edges 13.0
                 Adaptive Wide Angle 13.0
                 ADM 3.11x01
                 Angled Strokes 13.0
                 Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Bas Relief 13.0
                 BMP 13.0
                 Camera Raw 7.0
                 Chalk & Charcoal 13.0
                 Charcoal 13.0
                 Chrome 13.0
                 Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Color Halftone 13.0
                 Colored Pencil 13.0
                 CompuServe GIF 13.0
                 Conté Crayon 13.0
                 Craquelure 13.0
                 Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Crop and Straighten Photos Filter 13.0
                 Crosshatch 13.0
                 Crystallize 13.0
                 Cutout 13.0
                 Dark Strokes 13.0
                 De-Interlace 13.0
                 Dicom 13.0
                 Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Diffuse Glow 13.0
                 Displace 13.0
                 Dry Brush 13.0
                 Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Embed Watermark 4.0
                 Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Extrude 13.0
                 FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Fibers 13.0
                 Film Grain 13.0
                 Filter Gallery 13.0
                 Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Fresco 13.0
                 Glass 13.0
                 Glowing Edges 13.0
                 Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Grain 13.0
                 Graphic Pen 13.0
                 Halftone Pattern 13.0
                 HDRMergeUI 13.0
                 IFF Format 13.0
                 Ink Outlines 13.0
                 JPEG 2000 13.0
                 Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Lens Blur 13.0
                 Lens Correction 13.0
                 Lens Flare 13.0
                 Liquify 13.0
                 Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Mezzotint 13.0
                 Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Mosaic Tiles 13.0
                 Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Neon Glow 13.0
                 Note Paper 13.0
                 NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Ocean Ripple 13.0
                 Oil Paint 13.0
                 OpenEXR 13.0
                 Paint Daubs 13.0
                 Palette Knife 13.0
                 Patchwork 13.0
                 Paths to Illustrator 13.0
                 PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Photocopy 13.0
                 Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Pinch 13.0
                 Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Plaster 13.0
                 Plastic Wrap 13.0
                 PNG 13.0
                 Pointillize 13.0
                 Polar Coordinates 13.0
                 Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Poster Edges 13.0
                 Radial Blur 13.0
                 Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Read Watermark 4.0
                 Reticulation 13.0
                 Ripple 13.0
                 Rough Pastels 13.0
                 Save for Web 13.0
                 ScriptingSupport 13.0
                 Shear 13.0
                 Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Smart Blur 13.0
                 Smudge Stick 13.0
                 Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Spatter 13.0
                 Spherize 13.0
                 Sponge 13.0
                 Sprayed Strokes 13.0
                 Stained Glass 13.0
                 Stamp 13.0
                 Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Sumi-e 13.0
                 Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Targa 13.0
                 Texturizer 13.0
                 Tiles 13.0
                 Torn Edges 13.0
                 Twirl 13.0
                 U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Underpainting 13.0
                 Vanishing Point 13.0
                 Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Water Paper 13.0
                 Watercolor 13.0
                 Wave 13.0
                 Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 Wind 13.0
                 Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                 ZigZag 13.0
              Optional and third party plug-ins: NONE
              Plug-ins that failed to load: NONE
              Flash:
                 Mini Bridge
                 Kuler
              Installed TWAIN devices: NONE
              • 4. Re: "this will make the file too large" warning
                Charles,
                The file is 1055px wide X 795px high   @72ppi. (14.653 in X11.042 in)  RGB, 8bpc, PS6's file size info in the lower left of window is reporting data size of 2.40M/451.5M.
                I only mentioned 72 initially to help explain that the file size isn't approaching the insane as it can with files @300 or above, where there often can be issues just because of that alone.
                I have 7 files this size representing page views of a responsive site we are working on.   All of them have comps and many layers.  There are no "adjustment layers" however.  Just groups of regular layers.  The comps each have text comments of them in the comps panel. Each one shifts positions of layered items around or visibility on/off.   And it seems for every single one of these files, PS6 refuses to allow the use of the Comps panel to switch through them, popping up the same error code which I can repeatedly repeat. "could not complete your request because the result would be too big."
                Hope this info helps.
                • 5. Re: "this will make the file too large" warning
                  Chris Cox Adobe Employee
                  Hmm, something in those comps makes Photoshop think that it would create a document greater than 300,000 pixels in one dimension.
                  Weird.
                  Could you send Pete a copy of that document?
                  • 6. Re: "this will make the file too large" warning
                    I've also now tried setting the other drive as my scratch disk, just incase th 50+gbs of free space on the startup drive wasn't enough.  Restarted PS6 beta, and now using over 700+gb free space drive.  Still no deal, same errors are occuring.
                    • 7. Re: "this will make the file too large" warning
                      I could send the file, would the best way be email?
                      • 8. Re: "this will make the file too large" warning
                        I've sent a private post to Pete with a link to download the file.  Just let me know if you would like one as well Chris.
                        • 9. Re: "this will make the file too large" warning
                          Thanks - but if Pete has a copy, it'll get routed the the right engineers (which isn't *always* me).
                          • 10. Re: "this will make the file too large" warning
                            ok, file sent Pete's way.   I see someone else just ran into this issue on another post.  http://forums.adobe.com/message/4363921#4363921
                            Maybe between both our files the issue can be figured out.
                            Message was edited by: FTML
                            • 11. Re: "this will make the file too large" warning
                              Yep!
                              Thanks FTML, I've received your file, and passed it on to a few of the engineers who are looking at the file.
                              Will update here if there's any news
                              • 13. Re: "this will make the file too large" warning
                                SG... Adobe Employee
                                I still don't undertand the root cause, but hopefully have a workaround for you. In appears something that is save in the Layer Comp 'Position' option is causing the warning. In your sampe file I don't see where you might be taking advantage of that option.
                                I opened the sample file in Ps CS5 and turned off that option for each comp, saved out a copy, and opened the result in Ps CS6 (Mac 10.6.8). Now I can cycle thru the Layer Comps without getting any warnings.
                                Have you been seeing this warning on multiple files or just the sample provided?
                                Hope this helps,
                                steve
                                • 14. Re: "this will make the file too large" warning
                                  Hi SG..
                                  You are right.  Turning off the position option on each comps while in CS5, and then opening in CS6 beta does allow me to now flip through the comps.  However there definitely are layered items that are having their position changed.  With comps, I was showing the views of a lot of items on this site that slide completely, or partially, off screen.  A lot of them are just turning the layer on or off, but a few are moving position.  One for instance is the "portfolio tab text" and "TAB background transparent" layers towards the bottom of the layers list.  (they are non colored layers right below the red colored "arrow" layers).  In the last comp "closed container", that tab moves all the way to the right of the file.
                                  Turning off all positioning also oddly just turned off all the semi-transparent white background layers. (layers at the bottom of the layer list "CONTENT DIV WHITE...", "TRANS DIV small trans.." and others (there are a couple unused copies there).   Those two with layer titles in CAPS are being slid off the screen by positioning with that last Comp. Oddly, they started on screen. and the last comp was made to slide their position off screen.  That large section of white is maybe 2thirds the width of the whole file.  So I suppose when that slides off the screen by a changed position, it would make the file dimensions wider if it is including items that are off the working region.  I doubt it makes it 300,000px wide.  But maybe something wierd is now happening when items go outside the working artboard region.  CS5 doesn't seem to care.
                                  Either way, even the items I had the positions sliding on could be handled by duplicate layers that just turn on and off instead as a good work around for now.  Thank you for finding that out. That's helps for now.
                                  In the future files though, that would maybe add up to almost double the amount of layers needed to show the same different comp layouts that we could show in CS5 with positioning changes to layers. Since I'm still on CS5 and just using the beta of CS6, I'll probably be keenly watching for a possible fix on this or not while we contemplate the upgrade to our master collections soon.  The other features of CS6 PS look great so far.
                                  Just to answer your other questions a bit...   Yes I do have a whole set of files based on this same site that all of the same issue.  Some of them have different and smaller items that are changing positioning in different areas on the file, all of them near the borders of it. But they also had the larger white box layers. They are showing slide-up/slide-dn divs from the upper right and lower left of the file. So those maybe would be increasing the height of the file.  I just tested one of those with the vertical position change items, by deleting the large white backgrounds that slide off the page from each comp.  So the only items that reposition off the working screen are items that move vertically.  Then opened up in CS6beta and attempted to hit the comps.  Still sparks the error.
                                  I'm testing some simple new files with positioning comps right now...
                                  • 15. Re: "this will make the file too large" warning
                                    I created some simple 1024x768 72ppi files in cs5 with small boxes that move within the work area.  Other files with the small boxes of color moving just outsdie the work area, and another file with a massive oversized color box that starts off screen and a comp pulls it back in view with positioning.   Opened all and checked comps in cs6 beta and they all work.  No errors.   I did notice a delay a couple times when I first hit a different the button for a different comp to show.  Only happened right after opening the file in cs6.  But the comp still opened.  This file was simple, just moving that one box of color layer around with three positioned comps.  I don't know if a lot more would be an issue or not.  But with these working, it doesn't appear to be an issue simply of how large of an item layer is positioned off the working area. Not with just one of them anyway.
                                    I also added a very large amount of text into the comments area of one of the comps since i had comments in all comps on the offending files.  But no error.
                                    • 16. Re: "this will make the file too large" warning
                                      I've now created a new file with maybe 5 to 7 items moving around, with over ten comps, including an oversized Tiff image I copied into the file and scaled down.  No errors when opening and flipping through comps in CS6.    I have no idea why all those other older cs5 files spark errors.  The only difference I can see is the shear number of layers in those offending files.  I opened one similar older file that is not at 72ppi (rather 96ppi) that has a few less layers then the one I sent in, but still many. That older file does spark the errors when trying to open the comps too.  I have no clue.  I'll wait and check back here to see if anything more certain about what causes this is found out.
                                      • 17. Re: "this will make the file too large" warning
                                        Thanks for all the extra data points. I have logged a bug report so this can be investigated further by developers. I tried looking at the pixel data that's off the canvas and didn't see anything obvious either. We'll need to debug with your sample file to get a better understanding of what's happening.
                                        I'll send you a private message so we can exchange contact info.
                                        regards,
                                        steve
