Locked
Push a View by converting a string to a class?
Apr 27, 2012 Apr 27, 2012
I am currently working in Flashbuilder 4.6 creating a mobile application and I wish to push the users to a view by based on the menu item they select. My code below shows how I have tried to convert a string from a selected list item into a class object and then pass that into the parameter for the pushView:
    <fx:Script>
        <![CDATA[
            import mx.collections.*;
            import spark.components.SplitViewNavigator;
            import spark.components.ViewNavigator;
            import spark.events.IndexChangeEvent;
            import spark.events.ViewNavigatorEvent;
            import spark.managers.PersistenceManager;
            import spark.skins.mobile.SplitViewNavigatorSkin;
            public var menuAC:ArrayCollection;
            public var j_array:Array = [{label:"Home", data:"NLView"},
                {label:"All Jobs", data:"JList"},
                {label:"Company Profiles", data:"SView"},
                {label:"Search By Sector", data:"JView"}];
            protected function list_changeHandler(event:IndexChangeEvent):void
                var selectedItem:String = new String(list.selectedItem.data);
                //trace("Selected Item = " + selectedItem);
                var splitNavigator:SplitViewNavigator = navigator.parentNavigator as SplitViewNavigator;
                var detailNavigator:ViewNavigator = splitNavigator.getViewNavigatorAt(0) as ViewNavigator;
                splitNavigator.hideViewNavigatorPopUp();
                if(list.selectedItem.data == "NewListView")
                    var myClass:Class = getDefinitionByName(selectedItem) as Class;
                    trace("View Class = " + myClass);
                    detailNavigator.pushView(myClass);
                else if(list.selectedItem.data)
            protected function view1_viewActivateHandler(event:ViewNavigatorEvent):void
                if(data.view == "JSFilt")
                    menuAC = new ArrayCollection(j_array);
                list.dataProvider = menuAC;
                // TODO Auto-generated method stub
                var detailNavigator:ViewNavigator = splitNavigator.getViewNavigatorAt(1) as ViewNavigator;
    </fx:Script>
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <s:BitmapImage width="100%" height="100%" source="@Embed('assets/images/sidebg.png')" fillMode="repeat"/>
    <s:BitmapImage horizontalCenter="0" top="5" width="175" height="130" source="@Embed('assets/images/G_S_Logo_170x130.png')"/>
    <s:List id="list" left="0" right="0"
            color="0xFFFFFF" contentBackgroundColor="0x101010"
            fontSize="20" width="280"
            alternatingItemColors="[0x202020,0x2a2a2a]"
            top="140" horizontalCenter="0" bottom="200"
            downColor="0x70B2EE"
            selectionColor="0x70B2EE"
            change="list_changeHandler(event)">
        <s:itemRenderer>
            <fx:Component>
                <s:IconItemRenderer messageStyleName="myFontStyle" fontSize="22" height="70"
                                    labelField="label"
                                    messageField=""
            </fx:Component>
        </s:itemRenderer>
    </s:List>
I have also tried using the following command which also did not work:
var viewClass:Class = Class(getDefinitionByName(getQualifiedClassName(selectedItem)));
Has anyone got anyidea how to look at a value selected on a list and then use that string name to push the App to the view as the pushView method wont accept a string??
704
Apr 28, 2012 Apr 28, 2012
Is there no one who can help on this forum, I post questions here and no one ever answers them?!?
I have tried to use the following code in replacement of what I had:
    var myClass:Class = getDefinitionByName(selectedItem.data);
I should maybe just keep this simple and explain what I want to do. I want to pass a string into the "ViewNavigator.pushView()" that usually only accepts a View Class Object. So I would have the name of the view I want to navigate to stored as a String and then i want to execute the follwoing code, where "MyView" is a String:
    var MyView:String = new String("RightView");
    ViewNavigator.pushView(MyView);
This seems like a simple concept to me but the "viewNavigator.pushView()" only seems to accept a View Class being passed to it. Can someone please help me?
