1. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
John Hawkinson Apr 27, 2012 9:52 PM (in response to jenahilton)What's your concern? That's a perfectly reasonable machine. It can run any version of InDesign from CS3 through CS6; of course today you should use CS5.5, which is current. CS6 comes out next month.
InDesign doesn't tend to use a lot of RAM, usually under 1 GB, so I wouldn't worry too much about upgrading until you try it.
2. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
Peter Spier Apr 28, 2012 2:37 AM (in response to jenahilton)If you purchase CS5.5 now, you'll get CS6 for free. http://www.adobe.com/products/discount-software-coupons.html?PID=2159997
3. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
BobLevine Apr 28, 2012 5:32 AM (in response to jenahilton)My MacBook has a 2Ghz Core2Duo with 4 gigs of RAM. Screamer? No. Perfectly adequate for I do with it? Absolutely, including CS6.
I would certainly recommend a RAM upgrade if you plan on running more than just InDesign but other than that you should be fine.
BTW, Amazon appears to be cutting prices a bit on CS5.5 upgrades. Buying there will still get you a free upgrade to CS6. http://amzn.to/JsMDAI
Bob
4. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
jenahilton Apr 30, 2012 5:40 AM (in response to jenahilton)Thanks for all the help - it is confusing though. I tried to download the trial version of CS5.5 to explore before buying the student version and the program download froze. I have deleted the doadload assistant and spoke with Adobe who told me my machine would not be compatible unless I upgraded - maybe the RAM to 4GB. I was not sure if my Core 2 Duo was the same as a Multi processor that most of what I read said I needed. The advise here suggests maybe the RAM upgrade is all I need to run a CS 5.5. Is the advise also suggesting I can run InDesign as a stand alone package now and not part of the Create Suite? Thanks again for all the help!!!
5. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
jenahilton Apr 30, 2012 5:54 AM (in response to jenahilton)PS I am running OS 10.5.8
6. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
John Hawkinson Apr 30, 2012 6:05 AM (in response to jenahilton)Thanks for all the help - it is confusing though. I tried to download the trial version of CS5.5 to explore before buying the student version and the program download froze. I have deleted the doadload assistant and spoke with Adobe who told me my machine would not be compatible unless I upgraded - maybe the RAM to 4GB.
You got bad (wrong) advice.
If the download didn't work, it has nothing to do with the performance characteristics of your machine. You could download CS5.5 on a low-end PC from 10 years ago, it doesn't take much.
Unfortunately Adobe's download manager is a bit flakey. Best advice is to use Firefox and try the download again.
It doesn't have anything to do with the power of your computer, be it speed, processor type, or RAM.
Make sure you're using FIrefox (if not, download and install it first), and then try the download again.
Also, the download manager depends on Java. Make sure you have Java installed (but I think you must, because otherwise the download would not have started?).
If it still doesn't work, give us some more detail. Error message? Screenshot?
7. Re: Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
jenahilton May 1, 2012 8:20 AM (in response to John Hawkinson)Thanks John for your ongoing help! I got the full CS 5.5 trial downloaded when I connected to the internet and was attempting as a wireless connection - I also used Firefox as you suggested. Now the real fun begins!
Thank you
