20 Replies Latest reply: May 3, 2012 10:02 PM by John Hawkinson RSS
    [Ann] HTML/CHM for CS6 Javascript
    [Jongware] CommunityMVP
      I don't think I've ever been so fast before:
      http://www.jongware.com/idjshelp.html is updated, it now also contains my Friendly Help for CS6, as both HTML (separate files) and CHM (one compiled file for use with a Windows Help viewer).
      By way of experiment I added a "Full Index" to the HTML version. This is a single huge file, 2.7MB, but it contains links to all properties and methods in the entire set of files. So if you can't use the live one in the compiled CHM, you can still use this one to get a good overview of What to find Where.
      ... Enjoy!
        • 1. Re: [Ann] HTML/CHM for CS6 Javascript
          pkahrel Community Member
          Jognware,
          Thanks for that. Would it be possible for you to do a difference list, that is, to do a list with "what's new in CS6"? New properties, methods, and enumerations? I did a few of those in the past but it has become a bit of a hassle in recent years.
          Peter
          • 2. Re: [Ann] HTML/CHM for CS6 Javascript
            Aw, come on! I really like the layout of your lists (that nice font in particular ).
            I don't know if I can do the same; purely theoretically it ought to be possible with XSLT (which, I'm sure you know, I am using to process the data files). But I can't think of a good method off the top of my head.
            • 3. Re: [Ann] HTML/CHM for CS6 Javascript
              John Hawkinson CommunityMVP
              Yeah, it's been on my list before. I believe what you want to do is just produce a file with the suite and class for all properties. You know:
              Basics     Application     activeBook
              Basics     Application     activeDocument
              and then sort them and compare with diff. Similarly for the methods and enumerations and whatnot.
              And I guess we could skip the suite, since it's not as easy in the XSLT since you'd have to look it up in the <map/> rather than just noting the parent properties in the <package/>.
              Maybe I'll be enthused to try this before my idea of when Jongware wakes up :-)
              • 4. Re: [Ann] HTML/CHM for CS6 Javascript
                Right. So, here's some XSLT:
                <?xml version="1.0" encoding="UTF-8"?>
                <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
                  <xsl:output method="text"/>
                  <xsl:template match="text()|@*"/> <!-- Suppress default text output -->
                  <xsl:template match="property|method">
                    <xsl:call-template name="list-name-and-grandparent-name-with-tabs"/>
                  </xsl:template>
                  <xsl:template name="list-name-and-grandparent-name-with-tabs">
                    <xsl:value-of select="name()"/>
                    <xsl:if test="../../@enumeration">(enum)</xsl:if>
                    <xsl:text>&#9;</xsl:text>
                    <xsl:value-of select="name()"/><xsl:text>&#9;</xsl:text>
                    <xsl:value-of select="../../@name"/><xsl:text>&#9;</xsl:text>
                    <xsl:value-of select="@name"/><xsl:text>&#9;</xsl:text>
                    <xsl:text>&#10;</xsl:text>
                  </xsl:template>
                </xsl:stylesheet>
                Hopefully it's self-explanatory. I even added the "(enum)" to distinguish enums from regular properties. Just for you, Peter K!
                Then we just run it on the omv cachefiles, sort the output, and do some comparisons with "comm."
                That is:
                xsltproc omv.xsl omv\$indesign-7.5\$7.5.xml | sort > 7575.txt
                xsltproc omv.xsl omv\$indesign-8.0\$8.0.xml | sort > 8080.txt
                I hope it's not a dumb idea to put this all in one long post...
                For instance, the following 29 items were removed from CS5.5 to CS6 (comm -23 7575.txt 8080.txt):
                propertyButtonvisibilityInPdf
                propertyDocumentPreferencemasterTextFrame
                propertyDocumentPresetmasterTextFrame
                propertyEPubExportPreferencecssExportOption
                propertyEPubExportPreferenceexternalCSSPath
                propertyEPubExportPreferenceformat
                propertyEPubExportPreferencemarginUnit
                propertyEPubExportPreferencespaceUnit
                propertyEPubExportPreferenceuseTocStyle
                propertyHTMLExportPreferencebottomMargin
                propertyHTMLExportPreferenceexternalCSSPath
                propertyHTMLExportPreferencejavascriptURL
                propertyHTMLExportPreferenceleftMargin
                propertyHTMLExportPreferencelinkToJavascript
                propertyHTMLExportPreferencemarginUnit
                propertyHTMLExportPreferencerightMargin
                propertyHTMLExportPreferencespaceUnit
                propertyHTMLExportPreferencetopMargin
                propertyObjectExportOptioncustomImageAlignment
                propertyObjectExportOptionspaceUnit
                propertyPagesPanelverticalView
                property(enum)SpaceUnitTypeCSS_EM
                property(enum)SpaceUnitTypeCSS_PIXEL
                property(enum)StyleSheetExportOptionEXTERNAL_CSS
                property(enum)StyleSheetExportOptionSTYLE_NAME_ONLY
                property(enum)VisibilityInPdfHIDDEN_BUT_PRINTABLE_IN_PDF
                property(enum)VisibilityInPdfHIDDEN_IN_PDF
                property(enum)VisibilityInPdfVISIBLE_BUT_DOES_NOT_PRINT_IN_PDF
                property(enum)VisibilityInPdfVISIBLE_IN_PDF
                And the following 1,984 were added in CS6 (comm -13 7575.txt 8080.txt):
                methodButtoncontentPlace
                methodCellStyleMappingaddEventListener
                methodCellStyleMappinggetElements
                methodCellStyleMappingremove
                methodCellStyleMappingremoveEventListener
                methodCellStyleMappingtoSource
                methodCellStyleMappingtoSpecifier
                methodCellStyleMappings[]
                methodCellStyleMappingsadd
                methodCellStyleMappingsanyItem
                methodCellStyleMappingscount
                methodCellStyleMappingseveryItem
                methodCellStyleMappingsfirstItem
                methodCellStyleMappingsitem
                methodCellStyleMappingsitemByRange
                methodCellStyleMappingslastItem
                methodCellStyleMappingsmiddleItem
                methodCellStyleMappingsnextItem
                methodCellStyleMappingspreviousItem
                methodCellStyleMappingstoSource
                methodCharStyleMappingaddEventListener
                methodCharStyleMappinggetElements
                methodCharStyleMappingremove
                methodCharStyleMappingremoveEventListener
                methodCharStyleMappingtoSource
                methodCharStyleMappingtoSpecifier
                methodCharStyleMappings[]
                methodCharStyleMappingsadd
                methodCharStyleMappingsanyItem
                methodCharStyleMappingscount
                methodCharStyleMappingseveryItem
                methodCharStyleMappingsfirstItem
                methodCharStyleMappingsitem
                methodCharStyleMappingsitemByRange
                methodCharStyleMappingslastItem
                methodCharStyleMappingsmiddleItem
                methodCharStyleMappingsnextItem
                methodCharStyleMappingspreviousItem
                methodCharStyleMappingstoSource
                methodCheckBoxaddEventListener
                methodCheckBoxapplyObjectStyle
                methodCheckBoxasynchronousExportFile
                methodCheckBoxautoTag
                methodCheckBoxbringForward
                methodCheckBoxbringToFront
                methodCheckBoxchangeObject
                methodCheckBoxclearObjectStyleOverrides
                methodCheckBoxclearTransformations
                methodCheckBoxcontentPlace
                methodCheckBoxconvertShape
                methodCheckBoxconvertToObject
                methodCheckBoxdetach
                methodCheckBoxduplicate
                methodCheckBoxexportFile
                methodCheckBoxextractLabel
                methodCheckBoxfindObject
                methodCheckBoxfit
                methodCheckBoxflipItem
                methodCheckBoxgetElements
                methodCheckBoxinsertLabel
                methodCheckBoxmarkup
                methodCheckBoxmove
                methodCheckBoxoverride
                methodCheckBoxplaceXML
                methodCheckBoxredefineScaling
                methodCheckBoxreframe
                methodCheckBoxremove
                methodCheckBoxremoveEventListener
                methodCheckBoxremoveOverride
                methodCheckBoxresize
                methodCheckBoxresolve
                methodCheckBoxselect
                methodCheckBoxsendBackward
                methodCheckBoxsendToBack
                methodCheckBoxstore
                methodCheckBoxtoSource
                methodCheckBoxtoSpecifier
                methodCheckBoxtransform
                methodCheckBoxtransformAgain
                methodCheckBoxtransformAgainIndividually
                methodCheckBoxtransformSequenceAgain
                methodCheckBoxtransformSequenceAgainIndividually
                methodCheckBoxtransformValuesOf
                methodCheckBoxes[]
                methodCheckBoxesadd
                methodCheckBoxesanyItem
                methodCheckBoxescount
                methodCheckBoxeseveryItem
                methodCheckBoxesfirstItem
                methodCheckBoxesitem
                methodCheckBoxesitemByID
                methodCheckBoxesitemByName
                methodCheckBoxesitemByRange
                methodCheckBoxeslastItem
                methodCheckBoxesmiddleItem
                methodCheckBoxesnextItem
                methodCheckBoxespreviousItem
                methodCheckBoxestoSource
                methodClearFormBehavioraddEventListener
                methodClearFormBehaviorextractLabel
                methodClearFormBehaviorgetElements
                methodClearFormBehaviorinsertLabel
                methodClearFormBehaviorremove
                methodClearFormBehaviorremoveEventListener
                methodClearFormBehaviortoSource
                methodClearFormBehaviortoSpecifier
                methodClearFormBehaviors[]
                methodClearFormBehaviorsadd
                methodClearFormBehaviorsanyItem
                methodClearFormBehaviorscount
                methodClearFormBehaviorseveryItem
                methodClearFormBehaviorsfirstItem
                methodClearFormBehaviorsitem
                methodClearFormBehaviorsitemByID
                methodClearFormBehaviorsitemByName
                methodClearFormBehaviorsitemByRange
                methodClearFormBehaviorslastItem
                methodClearFormBehaviorsmiddleItem
                methodClearFormBehaviorsnextItem
                methodClearFormBehaviorspreviousItem
                methodClearFormBehaviorstoSource
                methodComboBoxaddEventListener
                methodComboBoxapplyObjectStyle
                methodComboBoxasynchronousExportFile
                methodComboBoxautoTag
                methodComboBoxbringForward
                methodComboBoxbringToFront
                methodComboBoxchangeObject
                methodComboBoxclearObjectStyleOverrides
                methodComboBoxclearTransformations
                methodComboBoxcontentPlace
                methodComboBoxconvertShape
                methodComboBoxconvertToObject
                methodComboBoxdetach
                methodComboBoxduplicate
                methodComboBoxexportFile
                methodComboBoxextractLabel
                methodComboBoxfindObject
                methodComboBoxfit
                methodComboBoxflipItem
                methodComboBoxgetElements
                methodComboBoxinsertLabel
                methodComboBoxmarkup
                methodComboBoxmove
                methodComboBoxoverride
                methodComboBoxplaceXML
                methodComboBoxredefineScaling
                methodComboBoxreframe
                methodComboBoxremove
                methodComboBoxremoveEventListener
                methodComboBoxremoveOverride
                methodComboBoxresize
                methodComboBoxresolve
                methodComboBoxselect
                methodComboBoxsendBackward
                methodComboBoxsendToBack
                methodComboBoxstore
                methodComboBoxtoSource
                methodComboBoxtoSpecifier
                methodComboBoxtransform
                methodComboBoxtransformAgain
                methodComboBoxtransformAgainIndividually
                methodComboBoxtransformSequenceAgain
                methodComboBoxtransformSequenceAgainIndividually
                methodComboBoxtransformValuesOf
                methodComboBoxes[]
                methodComboBoxesadd
                methodComboBoxesanyItem
                methodComboBoxescount
                methodComboBoxeseveryItem
                methodComboBoxesfirstItem
                methodComboBoxesitem
                methodComboBoxesitemByID
                methodComboBoxesitemByName
                methodComboBoxesitemByRange
                methodComboBoxeslastItem
                methodComboBoxesmiddleItem
                methodComboBoxesnextItem
                methodComboBoxespreviousItem
                methodComboBoxestoSource
                methodContentPlacerObjectaddEventListener
                methodContentPlacerObjectgetElements
                methodContentPlacerObjectload
                methodContentPlacerObjectremoveEventListener
                methodContentPlacerObjecttoSource
                methodContentPlacerObjecttoSpecifier
                methodDocumentcreateAlternateLayout
                methodDocumentdeleteAlternateLayout
                methodEPScontentPlace
                methodEPSTextcontentPlace
                methodFontLockingPreferenceaddEventListener
                methodFontLockingPreferencegetElements
                methodFontLockingPreferenceremoveEventListener
                methodFontLockingPreferencetoSource
                methodFontLockingPreferencetoSpecifier
                methodFormFieldcontentPlace
                methodGraphiccontentPlace
                methodGraphicLinecontentPlace
                methodGroupcontentPlace
                methodGuideresolve
                methodGuidetransformValuesOf
                methodHtmlItemaddEventListener
                methodHtmlItemapplyObjectStyle
                methodHtmlItemasynchronousExportFile
                methodHtmlItemautoTag
                methodHtmlItemchangeObject
                methodHtmlItemclearObjectStyleOverrides
                methodHtmlItemclearTransformations
                methodHtmlItemcontentPlace
                methodHtmlItemconvertShape
                methodHtmlItemdetach
                methodHtmlItemduplicate
                methodHtmlItemexportFile
                methodHtmlItemextractLabel
                methodHtmlItemfindObject
                methodHtmlItemfit
                methodHtmlItemflipItem
                methodHtmlItemgetElements
                methodHtmlIteminsertLabel
                methodHtmlItemmarkup
                methodHtmlItemmove
                methodHtmlItemoverride
                methodHtmlItemplace
                methodHtmlItemplaceXML
                methodHtmlItemredefineScaling
                methodHtmlItemreframe
                methodHtmlItemremove
                methodHtmlItemremoveEventListener
                methodHtmlItemremoveOverride
                methodHtmlItemresize
                methodHtmlItemresolve
                methodHtmlItemselect
                methodHtmlItemstore
                methodHtmlItemtoSource
                methodHtmlItemtoSpecifier
                methodHtmlItemtransform
                methodHtmlItemtransformAgain
                methodHtmlItemtransformAgainIndividually
                methodHtmlItemtransformSequenceAgain
                methodHtmlItemtransformSequenceAgainIndividually
                methodHtmlItemtransformValuesOf
                methodHtmlItems[]
                methodHtmlItemsadd
                methodHtmlItemsanyItem
                methodHtmlItemscount
                methodHtmlItemseveryItem
                methodHtmlItemsfirstItem
                methodHtmlItemsitem
                methodHtmlItemsitemByID
                methodHtmlItemsitemByName
                methodHtmlItemsitemByRange
                methodHtmlItemslastItem
                methodHtmlItemsmiddleItem
                methodHtmlItemsnextItem
                methodHtmlItemspreviousItem
                methodHtmlItemstoSource
                methodImagecontentPlace
                methodImportedPagecontentPlace
                methodLinkgoToSource
                methodLinkedPageItemOptionaddEventListener
                methodLinkedPageItemOptiongetElements
                methodLinkedPageItemOptionremoveEventListener
                methodLinkedPageItemOptiontoSource
                methodLinkedPageItemOptiontoSpecifier
                methodListBoxaddEventListener
                methodListBoxapplyObjectStyle
                methodListBoxasynchronousExportFile
                methodListBoxautoTag
                methodListBoxbringForward
                methodListBoxbringToFront
                methodListBoxchangeObject
                methodListBoxclearObjectStyleOverrides
                methodListBoxclearTransformations
                methodListBoxcontentPlace
                methodListBoxconvertShape
                methodListBoxconvertToObject
                methodListBoxdetach
                methodListBoxduplicate
                methodListBoxexportFile
                methodListBoxextractLabel
                methodListBoxfindObject
                methodListBoxfit
                methodListBoxflipItem
                methodListBoxgetElements
                methodListBoxinsertLabel
                methodListBoxmarkup
                methodListBoxmove
                methodListBoxoverride
                methodListBoxplaceXML
                methodListBoxredefineScaling
                methodListBoxreframe
                methodListBoxremove
                methodListBoxremoveEventListener
                methodListBoxremoveOverride
                methodListBoxresize
                methodListBoxresolve
                methodListBoxselect
                methodListBoxsendBackward
                methodListBoxsendToBack
                methodListBoxstore
                methodListBoxtoSource
                methodListBoxtoSpecifier
                methodListBoxtransform
                methodListBoxtransformAgain
                methodListBoxtransformAgainIndividually
                methodListBoxtransformSequenceAgain
                methodListBoxtransformSequenceAgainIndividually
                methodListBoxtransformValuesOf
                methodListBoxes[]
                methodListBoxesadd
                methodListBoxesanyItem
                methodListBoxescount
                methodListBoxeseveryItem
                methodListBoxesfirstItem
                methodListBoxesitem
                methodListBoxesitemByID
                methodListBoxesitemByName
                methodListBoxesitemByRange
                methodListBoxeslastItem
                methodListBoxesmiddleItem
                methodListBoxesnextItem
                methodListBoxespreviousItem
                methodListBoxestoSource
                methodMasterSpreadcontentPlace
                methodMediaItemcontentPlace
                methodMoviecontentPlace
                methodMultiStateObjectcontentPlace
                methodOvalcontentPlace
                methodPDFcontentPlace
                methodPICTcontentPlace
                methodPNGExportPreferenceaddEventListener
                methodPNGExportPreferencegetElements
                methodPNGExportPreferenceremoveEventListener
                methodPNGExportPreferencetoSource
                methodPNGExportPreferencetoSpecifier
                methodPagecontentPlace
                methodPagedeleteAllLayoutSnapshots
                methodPagedeleteLayoutSnapshot
                methodPagesnapshotCurrentLayout
                methodPageItemcontentPlace
                methodParaStyleMappingaddEventListener
                methodParaStyleMappinggetElements
                methodParaStyleMappingremove
                methodParaStyleMappingremoveEventListener
                methodParaStyleMappingtoSource
                methodParaStyleMappingtoSpecifier
                methodParaStyleMappings[]
                methodParaStyleMappingsadd
                methodParaStyleMappingsanyItem
                methodParaStyleMappingscount
                methodParaStyleMappingseveryItem
                methodParaStyleMappingsfirstItem
                methodParaStyleMappingsitem
                methodParaStyleMappingsitemByRange
                methodParaStyleMappingslastItem
                methodParaStyleMappingsmiddleItem
                methodParaStyleMappingsnextItem
                methodParaStyleMappingspreviousItem
                methodParaStyleMappingstoSource
                methodPolygoncontentPlace
                methodPrintFormBehavioraddEventListener
                methodPrintFormBehaviorextractLabel
                methodPrintFormBehaviorgetElements
                methodPrintFormBehaviorinsertLabel
                methodPrintFormBehaviorremove
                methodPrintFormBehaviorremoveEventListener
                methodPrintFormBehaviortoSource
                methodPrintFormBehaviortoSpecifier
                methodPrintFormBehaviors[]
                methodPrintFormBehaviorsadd
                methodPrintFormBehaviorsanyItem
                methodPrintFormBehaviorscount
                methodPrintFormBehaviorseveryItem
                methodPrintFormBehaviorsfirstItem
                methodPrintFormBehaviorsitem
                methodPrintFormBehaviorsitemByID
                methodPrintFormBehaviorsitemByName
                methodPrintFormBehaviorsitemByRange
                methodPrintFormBehaviorslastItem
                methodPrintFormBehaviorsmiddleItem
                methodPrintFormBehaviorsnextItem
                methodPrintFormBehaviorspreviousItem
                methodPrintFormBehaviorstoSource
                methodRadioButtonaddEventListener
                methodRadioButtonapplyObjectStyle
                methodRadioButtonasynchronousExportFile
                methodRadioButtonautoTag
                methodRadioButtonbringForward
                methodRadioButtonbringToFront
                methodRadioButtonchangeObject
                methodRadioButtonclearObjectStyleOverrides
                methodRadioButtonclearTransformations
                methodRadioButtoncontentPlace
                methodRadioButtonconvertShape
                methodRadioButtonconvertToObject
                methodRadioButtondetach
                methodRadioButtonduplicate
                methodRadioButtonexportFile
                methodRadioButtonextractLabel
                methodRadioButtonfindObject
                methodRadioButtonfit
                methodRadioButtonflipItem
                methodRadioButtongetElements
                methodRadioButtoninsertLabel
                methodRadioButtonmarkup
                methodRadioButtonmove
                methodRadioButtonoverride
                methodRadioButtonplaceXML
                methodRadioButtonredefineScaling
                methodRadioButtonreframe
                methodRadioButtonremove
                methodRadioButtonremoveEventListener
                methodRadioButtonremoveOverride
                methodRadioButtonresize
                methodRadioButtonresolve
                methodRadioButtonselect
                methodRadioButtonsendBackward
                methodRadioButtonsendToBack
                methodRadioButtonstore
                methodRadioButtontoSource
                methodRadioButtontoSpecifier
                methodRadioButtontransform
                methodRadioButtontransformAgain
                methodRadioButtontransformAgainIndividually
                methodRadioButtontransformSequenceAgain
                methodRadioButtontransformSequenceAgainIndividually
                methodRadioButtontransformValuesOf
                methodRadioButtons[]
                methodRadioButtonsadd
                methodRadioButtonsanyItem
                methodRadioButtonscount
                methodRadioButtonseveryItem
                methodRadioButtonsfirstItem
                methodRadioButtonsitem
                methodRadioButtonsitemByID
                methodRadioButtonsitemByName
                methodRadioButtonsitemByRange
                methodRadioButtonslastItem
                methodRadioButtonsmiddleItem
                methodRadioButtonsnextItem
                methodRadioButtonspreviousItem
                methodRadioButtonstoSource
                methodRectanglecontentPlace
                methodSignatureFieldaddEventListener
                methodSignatureFieldapplyObjectStyle
                methodSignatureFieldasynchronousExportFile
                methodSignatureFieldautoTag
                methodSignatureFieldbringForward
                methodSignatureFieldbringToFront
                methodSignatureFieldchangeObject
                methodSignatureFieldclearObjectStyleOverrides
                methodSignatureFieldclearTransformations
                methodSignatureFieldcontentPlace
                methodSignatureFieldconvertShape
                methodSignatureFieldconvertToObject
                methodSignatureFielddetach
                methodSignatureFieldduplicate
                methodSignatureFieldexportFile
                methodSignatureFieldextractLabel
                methodSignatureFieldfindObject
                methodSignatureFieldfit
                methodSignatureFieldflipItem
                methodSignatureFieldgetElements
                methodSignatureFieldinsertLabel
                methodSignatureFieldmarkup
                methodSignatureFieldmove
                methodSignatureFieldoverride
                methodSignatureFieldplaceXML
                methodSignatureFieldredefineScaling
                methodSignatureFieldreframe
                methodSignatureFieldremove
                methodSignatureFieldremoveEventListener
                methodSignatureFieldremoveOverride
                methodSignatureFieldresize
                methodSignatureFieldresolve
                methodSignatureFieldselect
                methodSignatureFieldsendBackward
                methodSignatureFieldsendToBack
                methodSignatureFieldstore
                methodSignatureFieldtoSource
                methodSignatureFieldtoSpecifier
                methodSignatureFieldtransform
                methodSignatureFieldtransformAgain
                methodSignatureFieldtransformAgainIndividually
                methodSignatureFieldtransformSequenceAgain
                methodSignatureFieldtransformSequenceAgainIndividually
                methodSignatureFieldtransformValuesOf
                methodSignatureFields[]
                methodSignatureFieldsadd
                methodSignatureFieldsanyItem
                methodSignatureFieldscount
                methodSignatureFieldseveryItem
                methodSignatureFieldsfirstItem
                methodSignatureFieldsitem
                methodSignatureFieldsitemByID
                methodSignatureFieldsitemByName
                methodSignatureFieldsitemByRange
                methodSignatureFieldslastItem
                methodSignatureFieldsmiddleItem
                methodSignatureFieldsnextItem
                methodSignatureFieldspreviousItem
                methodSignatureFieldstoSource
                methodSoundcontentPlace
                methodSplineItemcontentPlace
                methodSpreadcontentPlace
                methodSubmitFormBehavioraddEventListener
                methodSubmitFormBehaviorextractLabel
                methodSubmitFormBehaviorgetElements
                methodSubmitFormBehaviorinsertLabel
                methodSubmitFormBehaviorremove
                methodSubmitFormBehaviorremoveEventListener
                methodSubmitFormBehaviortoSource
                methodSubmitFormBehaviortoSpecifier
                methodSubmitFormBehaviors[]
                methodSubmitFormBehaviorsadd
                methodSubmitFormBehaviorsanyItem
                methodSubmitFormBehaviorscount
                methodSubmitFormBehaviorseveryItem
                methodSubmitFormBehaviorsfirstItem
                methodSubmitFormBehaviorsitem
                methodSubmitFormBehaviorsitemByID
                methodSubmitFormBehaviorsitemByName
                methodSubmitFormBehaviorsitemByRange
                methodSubmitFormBehaviorslastItem
                methodSubmitFormBehaviorsmiddleItem
                methodSubmitFormBehaviorsnextItem
                methodSubmitFormBehaviorspreviousItem
                methodSubmitFormBehaviorstoSource
                methodTableStyleMappingaddEventListener
                methodTableStyleMappinggetElements
                methodTableStyleMappingremove
                methodTableStyleMappingremoveEventListener
                methodTableStyleMappingtoSource
                methodTableStyleMappingtoSpecifier
                methodTableStyleMappings[]
                methodTableStyleMappingsadd
                methodTableStyleMappingsanyItem
                methodTableStyleMappingscount
                methodTableStyleMappingseveryItem
                methodTableStyleMappingsfirstItem
                methodTableStyleMappingsitem
                methodTableStyleMappingsitemByRange
                methodTableStyleMappingslastItem
                methodTableStyleMappingsmiddleItem
                methodTableStyleMappingsnextItem
                methodTableStyleMappingspreviousItem
                methodTableStyleMappingstoSource
                methodTextBoxaddEventListener
                methodTextBoxapplyObjectStyle
                methodTextBoxasynchronousExportFile
                methodTextBoxautoTag
                methodTextBoxbringForward
                methodTextBoxbringToFront
                methodTextBoxchangeObject
                methodTextBoxclearObjectStyleOverrides
                methodTextBoxclearTransformations
                methodTextBoxcontentPlace
                methodTextBoxconvertShape
                methodTextBoxconvertToObject
                methodTextBoxdetach
                methodTextBoxduplicate
                methodTextBoxexportFile
                methodTextBoxextractLabel
                methodTextBoxfindObject
                methodTextBoxfit
                methodTextBoxflipItem
                methodTextBoxgetElements
                methodTextBoxinsertLabel
                methodTextBoxmarkup
                methodTextBoxmove
                methodTextBoxoverride
                methodTextBoxplaceXML
                methodTextBoxredefineScaling
                methodTextBoxreframe
                methodTextBoxremove
                methodTextBoxremoveEventListener
                methodTextBoxremoveOverride
                methodTextBoxresize
                methodTextBoxresolve
                methodTextBoxselect
                methodTextBoxsendBackward
                methodTextBoxsendToBack
                methodTextBoxstore
                methodTextBoxtoSource
                methodTextBoxtoSpecifier
                methodTextBoxtransform
                methodTextBoxtransformAgain
                methodTextBoxtransformAgainIndividually
                methodTextBoxtransformSequenceAgain
                methodTextBoxtransformSequenceAgainIndividually
                methodTextBoxtransformValuesOf
                methodTextBoxes[]
                methodTextBoxesadd
                methodTextBoxesanyItem
                methodTextBoxescount
                methodTextBoxeseveryItem
                methodTextBoxesfirstItem
                methodTextBoxesitem
                methodTextBoxesitemByID
                methodTextBoxesitemByName
                methodTextBoxesitemByRange
                methodTextBoxeslastItem
                methodTextBoxesmiddleItem
                methodTextBoxesnextItem
                methodTextBoxespreviousItem
                methodTextBoxestoSource
                methodTextFramecontentPlace
                methodWMFcontentPlace
                propertyApplicationcellStyleMappings
                propertyApplicationcharStyleMappings
                propertyApplicationcontentPlacer
                propertyApplicationfontLockingPreferences
                propertyApplicationlinkedPageItemOptions
                propertyApplicationparaStyleMappings
                propertyApplicationpngExportPreferences
                propertyApplicationselectionKeyObject
                propertyApplicationtableStyleMappings
                propertyButtonclearFormBehaviors
                propertyButtonhiddenUntilTriggered
                propertyButtonhorizontalLayoutConstraints
                propertyButtonlinkedPageItemOptions
                propertyButtonprintFormBehaviors
                propertyButtonprintableInPdf
                propertyButtonsubmitFormBehaviors
                propertyButtonverticalLayoutConstraints
                propertyCellcheckBoxes
                propertyCellcomboBoxes
                propertyCelllistBoxes
                propertyCellradioButtons
                propertyCellsignatureFields
                propertyCelltextBoxes
                propertyCellStyleMappingdestinationStyleName
                propertyCellStyleMappingeventListeners
                propertyCellStyleMappingevents
                propertyCellStyleMappingindex
                propertyCellStyleMappingisValid
                propertyCellStyleMappingmappingRuleType
                propertyCellStyleMappingparent
                propertyCellStyleMappingproperties
                propertyCellStyleMappingsourceStyleName
                propertyCellStyleMappingslength
                propertyChangeGrepPreferenceparagraphKashidaWidth
                propertyChangeObjectPreferenceautoSizingReferencePoint
                propertyChangeObjectPreferenceautoSizingType
                propertyChangeObjectPreferenceminimumHeightForAutoSizing
                propertyChangeObjectPreferenceminimumWidthForAutoSizing
                propertyChangeObjectPreferenceuseMinimumHeightForAutoSizing
                propertyChangeObjectPreferenceuseMinimumWidthForAutoSizing
                propertyChangeObjectPreferenceuseNoLineBreaksForAutoSizing
                propertyChangeTextPreferenceparagraphKashidaWidth
                propertyCharStyleMappingdestinationStyleName
                propertyCharStyleMappingeventListeners
                propertyCharStyleMappingevents
                propertyCharStyleMappingindex
                propertyCharStyleMappingisValid
                propertyCharStyleMappingmappingRuleType
                propertyCharStyleMappingparent
                propertyCharStyleMappingproperties
                propertyCharStyleMappingsourceStyleName
                propertyCharStyleMappingslength
                propertyCharactercheckBoxes
                propertyCharactercomboBoxes
                propertyCharacterlistBoxes
                propertyCharacterparagraphKashidaWidth
                propertyCharacterradioButtons
                propertyCharactersignatureFields
                propertyCharactertextBoxes
                propertyCheckBoxAFTER_PLACE
                propertyCheckBoxBEFORE_PLACE
                propertyCheckBoxabsoluteFlip
                propertyCheckBoxabsoluteHorizontalScale
                propertyCheckBoxabsoluteRotationAngle
                propertyCheckBoxabsoluteShearAngle
                propertyCheckBoxabsoluteVerticalScale
                propertyCheckBoxactiveStateIndex
                propertyCheckBoxallArticles
                propertyCheckBoxallGraphics
                propertyCheckBoxallPageItems
                propertyCheckBoxallowOverrides
                propertyCheckBoxanchoredObjectSettings
                propertyCheckBoxanimationSettings
                propertyCheckBoxappliedObjectStyle
                propertyCheckBoxassociatedXMLElement
                propertyCheckBoxbehaviors
                propertyCheckBoxbottomLeftCornerOption
                propertyCheckBoxbottomLeftCornerRadius
                propertyCheckBoxbottomRightCornerOption
                propertyCheckBoxbottomRightCornerRadius
                propertyCheckBoxcheckedByDefault
                propertyCheckBoxclearFormBehaviors
                propertyCheckBoxcontentTransparencySettings
                propertyCheckBoxdescription
                propertyCheckBoxendCap
                propertyCheckBoxendJoin
                propertyCheckBoxepss
                propertyCheckBoxepstexts
                propertyCheckBoxeventListeners
                propertyCheckBoxevents
                propertyCheckBoxexportValue
                propertyCheckBoxfillColor
                propertyCheckBoxfillTint
                propertyCheckBoxfillTransparencySettings
                propertyCheckBoxflip
                propertyCheckBoxgapColor
                propertyCheckBoxgapTint
                propertyCheckBoxgeometricBounds
                propertyCheckBoxgotoAnchorBehaviors
                propertyCheckBoxgotoFirstPageBehaviors
                propertyCheckBoxgotoLastPageBehaviors
                propertyCheckBoxgotoNextPageBehaviors
                propertyCheckBoxgotoNextViewBehaviors
                propertyCheckBoxgotoPreviousPageBehaviors
                propertyCheckBoxgotoPreviousViewBehaviors
                propertyCheckBoxgotoURLBehaviors
                propertyCheckBoxgradientFillAngle
                propertyCheckBoxgradientFillLength
                propertyCheckBoxgradientFillStart
                propertyCheckBoxgradientStrokeAngle
                propertyCheckBoxgradientStrokeLength
                propertyCheckBoxgradientStrokeStart
                propertyCheckBoxgraphicLines
                propertyCheckBoxgraphics
                propertyCheckBoxgroups
                propertyCheckBoxhiddenUntilTriggered
                propertyCheckBoxhorizontalLayoutConstraints
                propertyCheckBoxhorizontalScale
                propertyCheckBoxid
                propertyCheckBoximages
                propertyCheckBoxindex
                propertyCheckBoxisValid
                propertyCheckBoxitemLayer
                propertyCheckBoxlabel
                propertyCheckBoxleftLineEnd
                propertyCheckBoxlinkedPageItemOptions
                propertyCheckBoxlocalDisplaySetting
                propertyCheckBoxlocked
                propertyCheckBoxmiterLimit
                propertyCheckBoxmovieBehaviors
                propertyCheckBoxname
                propertyCheckBoxnonprinting
                propertyCheckBoxopenFileBehaviors
                propertyCheckBoxovals
                propertyCheckBoxoverprintFill
                propertyCheckBoxoverprintGap
                propertyCheckBoxoverprintStroke
                propertyCheckBoxoverridden
                propertyCheckBoxoverriddenMasterPageItem
                propertyCheckBoxpageItems
                propertyCheckBoxparent
                propertyCheckBoxparentPage
                propertyCheckBoxpdfs
                propertyCheckBoxpicts
                propertyCheckBoxpolygons
                propertyCheckBoxpreferences
                propertyCheckBoxprintFormBehaviors
                propertyCheckBoxprintableInPdf
                propertyCheckBoxproperties
                propertyCheckBoxreadOnly
                propertyCheckBoxrectangles
                propertyCheckBoxrequired
                propertyCheckBoxrightLineEnd
                propertyCheckBoxrotationAngle
                propertyCheckBoxshearAngle
                propertyCheckBoxshowHideFieldsBehaviors
                propertyCheckBoxsoundBehaviors
                propertyCheckBoxsplineItems
                propertyCheckBoxstates
                propertyCheckBoxstrokeAlignment
                propertyCheckBoxstrokeColor
                propertyCheckBoxstrokeCornerAdjustment
                propertyCheckBoxstrokeDashAndGap
                propertyCheckBoxstrokeTint
                propertyCheckBoxstrokeTransparencySettings
                propertyCheckBoxstrokeType
                propertyCheckBoxstrokeWeight
                propertyCheckBoxsubmitFormBehaviors
                propertyCheckBoxtextFrames
                propertyCheckBoxtextWrapPreferences
                propertyCheckBoxtimingSettings
                propertyCheckBoxtopLeftCornerOption
                propertyCheckBoxtopLeftCornerRadius
                propertyCheckBoxtopRightCornerOption
                propertyCheckBoxtopRightCornerRadius
                propertyCheckBoxtransparencySettings
                propertyCheckBoxverticalLayoutConstraints
                propertyCheckBoxverticalScale
                propertyCheckBoxviewZoomBehaviors
                propertyCheckBoxvisible
                propertyCheckBoxvisibleBounds
                propertyCheckBoxwmfs
                propertyCheckBoxeslength
                propertyClearFormBehaviorbehaviorEvent
                propertyClearFormBehaviorenableBehavior
                propertyClearFormBehavioreventListeners
                propertyClearFormBehaviorevents
                propertyClearFormBehaviorid
                propertyClearFormBehaviorindex
                propertyClearFormBehaviorisValid
                propertyClearFormBehaviorlabel
                propertyClearFormBehaviorname
                propertyClearFormBehaviorparent
                propertyClearFormBehaviorproperties
                propertyClearFormBehaviorslength
                propertyComboBoxAFTER_PLACE
                propertyComboBoxBEFORE_PLACE
                propertyComboBoxabsoluteFlip
                propertyComboBoxabsoluteHorizontalScale
                propertyComboBoxabsoluteRotationAngle
                propertyComboBoxabsoluteShearAngle
                propertyComboBoxabsoluteVerticalScale
                propertyComboBoxactiveStateIndex
                propertyComboBoxallArticles
                propertyComboBoxallGraphics
                propertyComboBoxallPageItems
                propertyComboBoxallowOverrides
                propertyComboBoxanchoredObjectSettings
                propertyComboBoxanimationSettings
                propertyComboBoxappliedObjectStyle
                propertyComboBoxassociatedXMLElement
                propertyComboBoxbehaviors
                propertyComboBoxbottomLeftCornerOption
                propertyComboBoxbottomLeftCornerRadius
                propertyComboBoxbottomRightCornerOption
                propertyComboBoxbottomRightCornerRadius
                propertyComboBoxchoiceList
                propertyComboBoxclearFormBehaviors
                propertyComboBoxcontentTransparencySettings
                propertyComboBoxdescription
                propertyComboBoxendCap
                propertyComboBoxendJoin
                propertyComboBoxepss
                propertyComboBoxepstexts
                propertyComboBoxeventListeners
                propertyComboBoxevents
                propertyComboBoxfillColor
                propertyComboBoxfillTint
                propertyComboBoxfillTransparencySettings
                propertyComboBoxflip
                propertyComboBoxfontSize
                propertyComboBoxgapColor
                propertyComboBoxgapTint
                propertyComboBoxgeometricBounds
                propertyComboBoxgotoAnchorBehaviors
                propertyComboBoxgotoFirstPageBehaviors
                propertyComboBoxgotoLastPageBehaviors
                propertyComboBoxgotoNextPageBehaviors
                propertyComboBoxgotoNextViewBehaviors
                propertyComboBoxgotoPreviousPageBehaviors
                propertyComboBoxgotoPreviousViewBehaviors
                propertyComboBoxgotoURLBehaviors
                propertyComboBoxgradientFillAngle
                propertyComboBoxgradientFillLength
                propertyComboBoxgradientFillStart
                propertyComboBoxgradientStrokeAngle
                propertyComboBoxgradientStrokeLength
                propertyComboBoxgradientStrokeStart
                propertyComboBoxgraphicLines
                propertyComboBoxgraphics
                propertyComboBoxgroups
                propertyComboBoxhiddenUntilTriggered
                propertyComboBoxhorizontalLayoutConstraints
                propertyComboBoxhorizontalScale
                propertyComboBoxid
                propertyComboBoximages
                propertyComboBoxindex
                propertyComboBoxisValid
                propertyComboBoxitemLayer
                propertyComboBoxlabel
                propertyComboBoxleftLineEnd
                propertyComboBoxlinkedPageItemOptions
                propertyComboBoxlocalDisplaySetting
                propertyComboBoxlocked
                propertyComboBoxmiterLimit
                propertyComboBoxmovieBehaviors
                propertyComboBoxname
                propertyComboBoxnonprinting
                propertyComboBoxopenFileBehaviors
                propertyComboBoxovals
                propertyComboBoxoverprintFill
                propertyComboBoxoverprintGap
                propertyComboBoxoverprintStroke
                propertyComboBoxoverridden
                propertyComboBoxoverriddenMasterPageItem
                propertyComboBoxpageItems
                propertyComboBoxparent
                propertyComboBoxparentPage
                propertyComboBoxpdfs
                propertyComboBoxpicts
                propertyComboBoxpolygons
                propertyComboBoxpreferences
                propertyComboBoxprintFormBehaviors
                propertyComboBoxprintableInPdf
                propertyComboBoxproperties
                propertyComboBoxreadOnly
                propertyComboBoxrectangles
                propertyComboBoxrequired
                propertyComboBoxrightLineEnd
                propertyComboBoxrightToLeftField
                propertyComboBoxrotationAngle
                propertyComboBoxshearAngle
                propertyComboBoxshowHideFieldsBehaviors
                propertyComboBoxsortChoices
                propertyComboBoxsoundBehaviors
                propertyComboBoxsplineItems
                propertyComboBoxstrokeAlignment
                propertyComboBoxstrokeColor
                propertyComboBoxstrokeCornerAdjustment
                propertyComboBoxstrokeDashAndGap
                propertyComboBoxstrokeTint
                propertyComboBoxstrokeTransparencySettings
                propertyComboBoxstrokeType
                propertyComboBoxstrokeWeight
                propertyComboBoxsubmitFormBehaviors
                propertyComboBoxtextFrames
                propertyComboBoxtextWrapPreferences
                propertyComboBoxtimingSettings
                propertyComboBoxtopLeftCornerOption
                propertyComboBoxtopLeftCornerRadius
                propertyComboBoxtopRightCornerOption
                propertyComboBoxtopRightCornerRadius
                propertyComboBoxtransparencySettings
                propertyComboBoxverticalLayoutConstraints
                propertyComboBoxverticalScale
                propertyComboBoxviewZoomBehaviors
                propertyComboBoxvisible
                propertyComboBoxvisibleBounds
                propertyComboBoxwmfs
                propertyComboBoxeslength
                propertyContentPlacerObjecteventListeners
                propertyContentPlacerObjectevents
                propertyContentPlacerObjectisValid
                propertyContentPlacerObjectloaded
                propertyContentPlacerObjectparent
                propertyContentPlacerObjectproperties
                propertyDocumentcellStyleMappings
                propertyDocumentcharStyleMappings
                propertyDocumentcheckBoxes
                propertyDocumentcomboBoxes
                propertyDocumentlinkedPageItemOptions
                propertyDocumentlistBoxes
                propertyDocumentparaStyleMappings
                propertyDocumentradioButtons
                propertyDocumentselectionKeyObject
                propertyDocumentsignatureFields
                propertyDocumenttableStyleMappings
                propertyDocumenttextBoxes
                propertyDocumentPreferencecreatePrimaryTextFrame
                propertyDocumentPresetcreatePrimaryTextFrame
                propertyEPShorizontalLayoutConstraints
                propertyEPSlinkedPageItemOptions
                propertyEPSverticalLayoutConstraints
                propertyEPSTexthorizontalLayoutConstraints
                propertyEPSTextlinkedPageItemOptions
                propertyEPSTextverticalLayoutConstraints
                propertyEPubExportPreferenceexternalStyleSheets
                propertyEPubExportPreferencejavascripts
                propertyEPubExportPreferenceversion
                propertyFindGrepPreferenceparagraphKashidaWidth
                propertyFindObjectPreferenceautoSizingReferencePoint
                propertyFindObjectPreferenceautoSizingType
                propertyFindObjectPreferenceminimumHeightForAutoSizing
                propertyFindObjectPreferenceminimumWidthForAutoSizing
                propertyFindObjectPreferenceuseMinimumHeightForAutoSizing
                propertyFindObjectPreferenceuseMinimumWidthForAutoSizing
                propertyFindObjectPreferenceuseNoLineBreaksForAutoSizing
                propertyFindTextPreferenceparagraphKashidaWidth
                propertyFontLockingPreferenceeventListeners
                propertyFontLockingPreferenceevents
                propertyFontLockingPreferencefontChangeLocking
                propertyFontLockingPreferencefontInputLocking
                propertyFontLockingPreferenceisValid
                propertyFontLockingPreferenceparent
                propertyFontLockingPreferenceproperties
                propertyFormFieldhorizontalLayoutConstraints
                propertyFormFieldlinkedPageItemOptions
                propertyFormFieldverticalLayoutConstraints
                propertyGeneralPreferencecreateLinksOnContentPlace
                propertyGeneralPreferencecustomMonitorPpi
                propertyGeneralPreferencegreekVectorGraphicsOnDrag
                propertyGeneralPreferencemainMonitorPpi
                propertyGeneralPreferencemapStylesOnContentPlace
                propertyGeneralPreferencepreviewPages
                propertyGeneralPreferenceshowConveyor
                propertyGeneralPreferenceuseCustomMonitorResolution
                propertyGraphichorizontalLayoutConstraints
                propertyGraphiclinkedPageItemOptions
                propertyGraphicverticalLayoutConstraints
                propertyGraphicLinecheckBoxes
                propertyGraphicLinecomboBoxes
                propertyGraphicLinehorizontalLayoutConstraints
                propertyGraphicLinehtmlItems
                propertyGraphicLinelinkedPageItemOptions
                propertyGraphicLinelistBoxes
                propertyGraphicLineradioButtons
                propertyGraphicLinesignatureFields
                propertyGraphicLinetextBoxes
                propertyGraphicLineverticalLayoutConstraints
                propertyGroupcheckBoxes
                propertyGroupcomboBoxes
                propertyGrouphorizontalLayoutConstraints
                propertyGrouplinkedPageItemOptions
                propertyGrouplistBoxes
                propertyGroupradioButtons
                propertyGroupsignatureFields
                propertyGrouptextBoxes
                propertyGroupverticalLayoutConstraints
                propertyGuideguideType
                propertyGuideguideZone
                propertyHTMLExportPreferenceexternalStyleSheets
                propertyHTMLExportPreferencejavascripts
                propertyHtmlItemAFTER_PLACE
                propertyHtmlItemBEFORE_PLACE
                propertyHtmlItemabsoluteFlip
                propertyHtmlItemabsoluteHorizontalScale
                propertyHtmlItemabsoluteRotationAngle
                propertyHtmlItemabsoluteShearAngle
                propertyHtmlItemabsoluteVerticalScale
                propertyHtmlItemallArticles
                propertyHtmlItemallGraphics
                propertyHtmlItemallPageItems
                propertyHtmlItemallowOverrides
                propertyHtmlItemanimationSettings
                propertyHtmlItemappliedObjectStyle
                propertyHtmlItemassociatedXMLElement
                propertyHtmlItembottomLeftCornerOption
                propertyHtmlItembottomLeftCornerRadius
                propertyHtmlItembottomRightCornerOption
                propertyHtmlItembottomRightCornerRadius
                propertyHtmlItemcontentTransparencySettings
                propertyHtmlItemendCap
                propertyHtmlItemendJoin
                propertyHtmlItemeventListeners
                propertyHtmlItemevents
                propertyHtmlItemfillColor
                propertyHtmlItemfillTint
                propertyHtmlItemfillTransparencySettings
                propertyHtmlItemfixedDimensions
                propertyHtmlItemflip
                propertyHtmlItemgapColor
                propertyHtmlItemgapTint
                propertyHtmlItemgeometricBounds
                propertyHtmlItemgradientFillAngle
                propertyHtmlItemgradientFillLength
                propertyHtmlItemgradientFillStart
                propertyHtmlItemgradientStrokeAngle
                propertyHtmlItemgradientStrokeLength
                propertyHtmlItemgradientStrokeStart
                propertyHtmlItemhorizontalLayoutConstraints
                propertyHtmlItemhorizontalScale
                propertyHtmlItemhtmlContent
                propertyHtmlItemid
                propertyHtmlItemindex
                propertyHtmlItemisValid
                propertyHtmlItemitemLayer
                propertyHtmlItemlabel
                propertyHtmlItemleftLineEnd
                propertyHtmlItemlinkedPageItemOptions
                propertyHtmlItemlocalDisplaySetting
                propertyHtmlItemlocked
                propertyHtmlItemmiterLimit
                propertyHtmlItemname
                propertyHtmlItemnonprinting
                propertyHtmlItemoverprintFill
                propertyHtmlItemoverprintGap
                propertyHtmlItemoverprintStroke
                propertyHtmlItemoverridden
                propertyHtmlItemoverriddenMasterPageItem
                propertyHtmlItemparent
                propertyHtmlItemparentPage
                propertyHtmlItempreferences
                propertyHtmlItemproperties
                propertyHtmlItemrightLineEnd
                propertyHtmlItemrotationAngle
                propertyHtmlItemshearAngle
                propertyHtmlItemstrokeAlignment
                propertyHtmlItemstrokeColor
                propertyHtmlItemstrokeCornerAdjustment
                propertyHtmlItemstrokeDashAndGap
                propertyHtmlItemstrokeTint
                propertyHtmlItemstrokeTransparencySettings
                propertyHtmlItemstrokeType
                propertyHtmlItemstrokeWeight
                propertyHtmlItemtextWrapPreferences
                propertyHtmlItemtimingSettings
                propertyHtmlItemtopLeftCornerOption
                propertyHtmlItemtopLeftCornerRadius
                propertyHtmlItemtopRightCornerOption
                propertyHtmlItemtopRightCornerRadius
                propertyHtmlItemtransparencySettings
                propertyHtmlItemverticalLayoutConstraints
                propertyHtmlItemverticalScale
                propertyHtmlItemvisible
                propertyHtmlItemvisibleBounds
                propertyHtmlItemslength
                propertyIMEPreferenceuseNativeDigits
                propertyImagehorizontalLayoutConstraints
                propertyImagelinkedPageItemOptions
                propertyImageverticalLayoutConstraints
                propertyImportedPagehorizontalLayoutConstraints
                propertyImportedPagelinkedPageItemOptions
                propertyImportedPageverticalLayoutConstraints
                propertyInsertionPointcheckBoxes
                propertyInsertionPointcomboBoxes
                propertyInsertionPointlistBoxes
                propertyInsertionPointparagraphKashidaWidth
                propertyInsertionPointradioButtons
                propertyInsertionPointsignatureFields
                propertyInsertionPointtextBoxes
                propertyInteractivePDFExportPreferenceusePDFStructureForTabOrder
                propertyLayercheckBoxes
                propertyLayercomboBoxes
                propertyLayerlistBoxes
                propertyLayerradioButtons
                propertyLayersignatureFields
                propertyLayertextBoxes
                propertyLayoutWindowselectionKeyObject
                propertyLinecheckBoxes
                propertyLinecomboBoxes
                propertyLinelistBoxes
                propertyLineparagraphKashidaWidth
                propertyLineradioButtons
                propertyLinesignatureFields
                propertyLinetextBoxes
                propertyLinkedPageItemOptioneventListeners
                propertyLinkedPageItemOptionevents
                propertyLinkedPageItemOptionisValid
                propertyLinkedPageItemOptionparent
                propertyLinkedPageItemOptionpreserveAppearance
                propertyLinkedPageItemOptionpreserveFrameContent
                propertyLinkedPageItemOptionpreserveInteractivity
                propertyLinkedPageItemOptionpreserveOthers
                propertyLinkedPageItemOptionpreserveSizeAndShape
                propertyLinkedPageItemOptionproperties
                propertyLinkedPageItemOptionupdateLinkWhileSaving
                propertyLinkedPageItemOptionwarnOnUpdateOfEditedPageItem
                propertyLinkedStoryOptionapplyStyleMappings
                propertyListBoxAFTER_PLACE
                propertyListBoxBEFORE_PLACE
                propertyListBoxabsoluteFlip
                propertyListBoxabsoluteHorizontalScale
                propertyListBoxabsoluteRotationAngle
                propertyListBoxabsoluteShearAngle
                propertyListBoxabsoluteVerticalScale
                propertyListBoxactiveStateIndex
                propertyListBoxallArticles
                propertyListBoxallGraphics
                propertyListBoxallPageItems
                propertyListBoxallowOverrides
                propertyListBoxanchoredObjectSettings
                propertyListBoxanimationSettings
                propertyListBoxappliedObjectStyle
                propertyListBoxassociatedXMLElement
                propertyListBoxbehaviors
                propertyListBoxbottomLeftCornerOption
                propertyListBoxbottomLeftCornerRadius
                propertyListBoxbottomRightCornerOption
                propertyListBoxbottomRightCornerRadius
                propertyListBoxchoiceList
                propertyListBoxclearFormBehaviors
                propertyListBoxcontentTransparencySettings
                propertyListBoxdescription
                propertyListBoxendCap
                propertyListBoxendJoin
                propertyListBoxepss
                propertyListBoxepstexts
                propertyListBoxeventListeners
                propertyListBoxevents
                propertyListBoxfillColor
                propertyListBoxfillTint
                propertyListBoxfillTransparencySettings
                propertyListBoxflip
                propertyListBoxfontSize
                propertyListBoxgapColor
                propertyListBoxgapTint
                propertyListBoxgeometricBounds
                propertyListBoxgotoAnchorBehaviors
                propertyListBoxgotoFirstPageBehaviors
                propertyListBoxgotoLastPageBehaviors
                propertyListBoxgotoNextPageBehaviors
                propertyListBoxgotoNextViewBehaviors
                propertyListBoxgotoPreviousPageBehaviors
                propertyListBoxgotoPreviousViewBehaviors
                propertyListBoxgotoURLBehaviors
                propertyListBoxgradientFillAngle
                propertyListBoxgradientFillLength
                propertyListBoxgradientFillStart
                propertyListBoxgradientStrokeAngle
                propertyListBoxgradientStrokeLength
                propertyListBoxgradientStrokeStart
                propertyListBoxgraphicLines
                propertyListBoxgraphics
                propertyListBoxgroups
                propertyListBoxhiddenUntilTriggered
                propertyListBoxhorizontalLayoutConstraints
                propertyListBoxhorizontalScale
                propertyListBoxid
                propertyListBoximages
                propertyListBoxindex
                propertyListBoxisValid
                propertyListBoxitemLayer
                propertyListBoxlabel
                propertyListBoxleftLineEnd
                propertyListBoxlinkedPageItemOptions
                propertyListBoxlocalDisplaySetting
                propertyListBoxlocked
                propertyListBoxmiterLimit
                propertyListBoxmovieBehaviors
                propertyListBoxmultipleSelection
                propertyListBoxname
                propertyListBoxnonprinting
                propertyListBoxopenFileBehaviors
                propertyListBoxovals
                propertyListBoxoverprintFill
                propertyListBoxoverprintGap
                propertyListBoxoverprintStroke
                propertyListBoxoverridden
                propertyListBoxoverriddenMasterPageItem
                propertyListBoxpageItems
                propertyListBoxparent
                propertyListBoxparentPage
                propertyListBoxpdfs
                propertyListBoxpicts
                propertyListBoxpolygons
                propertyListBoxpreferences
                propertyListBoxprintFormBehaviors
                propertyListBoxprintableInPdf
                propertyListBoxproperties
                propertyListBoxreadOnly
                propertyListBoxrectangles
                propertyListBoxrequired
                propertyListBoxrightLineEnd
                propertyListBoxrightToLeftField
                propertyListBoxrotationAngle
                propertyListBoxshearAngle
                propertyListBoxshowHideFieldsBehaviors
                propertyListBoxsortChoices
                propertyListBoxsoundBehaviors
                propertyListBoxsplineItems
                propertyListBoxstrokeAlignment
                propertyListBoxstrokeColor
                propertyListBoxstrokeCornerAdjustment
                propertyListBoxstrokeDashAndGap
                propertyListBoxstrokeTint
                propertyListBoxstrokeTransparencySettings
                propertyListBoxstrokeType
                propertyListBoxstrokeWeight
                propertyListBoxsubmitFormBehaviors
                propertyListBoxtextFrames
                propertyListBoxtextWrapPreferences
                propertyListBoxtimingSettings
                propertyListBoxtopLeftCornerOption
                propertyListBoxtopLeftCornerRadius
                propertyListBoxtopRightCornerOption
                propertyListBoxtopRightCornerRadius
                propertyListBoxtransparencySettings
                propertyListBoxverticalLayoutConstraints
                propertyListBoxverticalScale
                propertyListBoxviewZoomBehaviors
                propertyListBoxvisible
                propertyListBoxvisibleBounds
                propertyListBoxwmfs
                propertyListBoxeslength
                propertyMasterSpreadcheckBoxes
                propertyMasterSpreadcomboBoxes
                propertyMasterSpreadlistBoxes
                propertyMasterSpreadprimaryTextFrame
                propertyMasterSpreadradioButtons
                propertyMasterSpreadsignatureFields
                propertyMasterSpreadtextBoxes
                propertyMediaItemhorizontalLayoutConstraints
                propertyMediaItemlinkedPageItemOptions
                propertyMediaItemverticalLayoutConstraints
                propertyMoviehorizontalLayoutConstraints
                propertyMovielinkedPageItemOptions
                propertyMovieverticalLayoutConstraints
                propertyMultiStateObjecthorizontalLayoutConstraints
                propertyMultiStateObjectlinkedPageItemOptions
                propertyMultiStateObjectverticalLayoutConstraints
                propertyObjectExportOptioncustomLayout
                propertyObjectExportOptioncustomLayoutType
                propertyObjectStyleenableTextFrameAutoSizingOptions
                propertyOvalcheckBoxes
                propertyOvalcomboBoxes
                propertyOvalhorizontalLayoutConstraints
                propertyOvalhtmlItems
                propertyOvallinkedPageItemOptions
                propertyOvallistBoxes
                propertyOvalradioButtons
                propertyOvalsignatureFields
                propertyOvaltextBoxes
                propertyOvalverticalLayoutConstraints
                propertyPDFhorizontalLayoutConstraints
                propertyPDFlinkedPageItemOptions
                propertyPDFverticalLayoutConstraints
                propertyPICThorizontalLayoutConstraints
                propertyPICTlinkedPageItemOptions
                propertyPICTverticalLayoutConstraints
                propertyPNGExportPreferenceantiAlias
                propertyPNGExportPreferenceeventListeners
                propertyPNGExportPreferenceevents
                propertyPNGExportPreferenceexportResolution
                propertyPNGExportPreferenceexportingSpread
                propertyPNGExportPreferenceisValid
                propertyPNGExportPreferencepageString
                propertyPNGExportPreferenceparent
                propertyPNGExportPreferencepngColorSpace
                propertyPNGExportPreferencepngExportRange
                propertyPNGExportPreferencepngQuality
                propertyPNGExportPreferenceproperties
                propertyPNGExportPreferencesimulateOverprint
                propertyPNGExportPreferencetransparentBackground
                propertyPNGExportPreferenceuseDocumentBleeds
                propertyPageappliedAlternateLayout
                propertyPagecheckBoxes
                propertyPagecomboBoxes
                propertyPagelayoutRule
                propertyPagelistBoxes
                propertyPageoptionalPage
                propertyPageradioButtons
                propertyPagesignatureFields
                propertyPagesnapshotBlendingMode
                propertyPagetextBoxes
                propertyPageItemhorizontalLayoutConstraints
                propertyPageItemlinkedPageItemOptions
                propertyPageItemverticalLayoutConstraints
                propertyParaStyleMappingdestinationStyleName
                propertyParaStyleMappingeventListeners
                propertyParaStyleMappingevents
                propertyParaStyleMappingindex
                propertyParaStyleMappingisValid
                propertyParaStyleMappingmappingRuleType
                propertyParaStyleMappingparent
                propertyParaStyleMappingproperties
                propertyParaStyleMappingsourceStyleName
                propertyParaStyleMappingslength
                propertyParagraphcheckBoxes
                propertyParagraphcomboBoxes
                propertyParagraphlistBoxes
                propertyParagraphparagraphKashidaWidth
                propertyParagraphradioButtons
                propertyParagraphsignatureFields
                propertyParagraphtextBoxes
                propertyParagraphStyleparagraphKashidaWidth
                propertyPlaceGuncheckBoxes
                propertyPlaceGuncomboBoxes
                propertyPlaceGunlistBoxes
                propertyPlaceGunradioButtons
                propertyPlaceGunsignatureFields
                propertyPlaceGuntextBoxes
                propertyPolygoncheckBoxes
                propertyPolygoncomboBoxes
                propertyPolygonhorizontalLayoutConstraints
                propertyPolygonhtmlItems
                propertyPolygonlinkedPageItemOptions
                propertyPolygonlistBoxes
                propertyPolygonradioButtons
                propertyPolygonsignatureFields
                propertyPolygontextBoxes
                propertyPolygonverticalLayoutConstraints
                propertyPrintFormBehaviorbehaviorEvent
                propertyPrintFormBehaviorenableBehavior
                propertyPrintFormBehavioreventListeners
                propertyPrintFormBehaviorevents
                propertyPrintFormBehaviorid
                propertyPrintFormBehaviorindex
                propertyPrintFormBehaviorisValid
                propertyPrintFormBehaviorlabel
                propertyPrintFormBehaviorname
                propertyPrintFormBehaviorparent
                propertyPrintFormBehaviorproperties
                propertyPrintFormBehaviorslength
                propertyRadioButtonAFTER_PLACE
                propertyRadioButtonBEFORE_PLACE
                propertyRadioButtonabsoluteFlip
                propertyRadioButtonabsoluteHorizontalScale
                propertyRadioButtonabsoluteRotationAngle
                propertyRadioButtonabsoluteShearAngle
                propertyRadioButtonabsoluteVerticalScale
                propertyRadioButtonactiveStateIndex
                propertyRadioButtonallArticles
                propertyRadioButtonallGraphics
                propertyRadioButtonallPageItems
                propertyRadioButtonallowOverrides
                propertyRadioButtonanchoredObjectSettings
                propertyRadioButtonanimationSettings
                propertyRadioButtonappliedObjectStyle
                propertyRadioButtonassociatedXMLElement
                propertyRadioButtonbehaviors
                propertyRadioButtonbottomLeftCornerOption
                propertyRadioButtonbottomLeftCornerRadius
                propertyRadioButtonbottomRightCornerOption
                propertyRadioButtonbottomRightCornerRadius
                propertyRadioButtoncheckedByDefault
                propertyRadioButtonclearFormBehaviors
                propertyRadioButtoncontentTransparencySettings
                propertyRadioButtondescription
                propertyRadioButtonendCap
                propertyRadioButtonendJoin
                propertyRadioButtonepss
                propertyRadioButtonepstexts
                propertyRadioButtoneventListeners
                propertyRadioButtonevents
                propertyRadioButtonexportValue
                propertyRadioButtonfillColor
                propertyRadioButtonfillTint
                propertyRadioButtonfillTransparencySettings
                propertyRadioButtonflip
                propertyRadioButtongapColor
                propertyRadioButtongapTint
                propertyRadioButtongeometricBounds
                propertyRadioButtongotoAnchorBehaviors
                propertyRadioButtongotoFirstPageBehaviors
                propertyRadioButtongotoLastPageBehaviors
                propertyRadioButtongotoNextPageBehaviors
                propertyRadioButtongotoNextViewBehaviors
                propertyRadioButtongotoPreviousPageBehaviors
                propertyRadioButtongotoPreviousViewBehaviors
                propertyRadioButtongotoURLBehaviors
                propertyRadioButtongradientFillAngle
                propertyRadioButtongradientFillLength
                propertyRadioButtongradientFillStart
                propertyRadioButtongradientStrokeAngle
                propertyRadioButtongradientStrokeLength
                propertyRadioButtongradientStrokeStart
                propertyRadioButtongraphicLines
                propertyRadioButtongraphics
                propertyRadioButtongroups
                propertyRadioButtonhiddenUntilTriggered
                propertyRadioButtonhorizontalLayoutConstraints
                propertyRadioButtonhorizontalScale
                propertyRadioButtonid
                propertyRadioButtonimages
                propertyRadioButtonindex
                propertyRadioButtonisValid
                propertyRadioButtonitemLayer
                propertyRadioButtonlabel
                propertyRadioButtonleftLineEnd
                propertyRadioButtonlinkedPageItemOptions
                propertyRadioButtonlocalDisplaySetting
                propertyRadioButtonlocked
                propertyRadioButtonmiterLimit
                propertyRadioButtonmovieBehaviors
                propertyRadioButtonname
                propertyRadioButtonnonprinting
                propertyRadioButtonopenFileBehaviors
                propertyRadioButtonovals
                propertyRadioButtonoverprintFill
                propertyRadioButtonoverprintGap
                propertyRadioButtonoverprintStroke
                propertyRadioButtonoverridden
                propertyRadioButtonoverriddenMasterPageItem
                propertyRadioButtonpageItems
                propertyRadioButtonparent
                propertyRadioButtonparentPage
                propertyRadioButtonpdfs
                propertyRadioButtonpicts
                propertyRadioButtonpolygons
                propertyRadioButtonpreferences
                propertyRadioButtonprintFormBehaviors
                propertyRadioButtonprintableInPdf
                propertyRadioButtonproperties
                propertyRadioButtonreadOnly
                propertyRadioButtonrectangles
                propertyRadioButtonrequired
                propertyRadioButtonrightLineEnd
                propertyRadioButtonrotationAngle
                propertyRadioButtonshearAngle
                propertyRadioButtonshowHideFieldsBehaviors
                propertyRadioButtonsoundBehaviors
                propertyRadioButtonsplineItems
                propertyRadioButtonstates
                propertyRadioButtonstrokeAlignment
                propertyRadioButtonstrokeColor
                propertyRadioButtonstrokeCornerAdjustment
                propertyRadioButtonstrokeDashAndGap
                propertyRadioButtonstrokeTint
                propertyRadioButtonstrokeTransparencySettings
                propertyRadioButtonstrokeType
                propertyRadioButtonstrokeWeight
                propertyRadioButtonsubmitFormBehaviors
                propertyRadioButtontextFrames
                propertyRadioButtontextWrapPreferences
                propertyRadioButtontimingSettings
                propertyRadioButtontopLeftCornerOption
                propertyRadioButtontopLeftCornerRadius
                propertyRadioButtontopRightCornerOption
                propertyRadioButtontopRightCornerRadius
                propertyRadioButtontransparencySettings
                propertyRadioButtonverticalLayoutConstraints
                propertyRadioButtonverticalScale
                propertyRadioButtonviewZoomBehaviors
                propertyRadioButtonvisible
                propertyRadioButtonvisibleBounds
                propertyRadioButtonwmfs
                propertyRadioButtonslength
                propertyRectanglecheckBoxes
                propertyRectanglecomboBoxes
                propertyRectanglehorizontalLayoutConstraints
                propertyRectanglehtmlItems
                propertyRectanglelinkedPageItemOptions
                propertyRectanglelistBoxes
                propertyRectangleradioButtons
                propertyRectanglesignatureFields
                propertyRectangletextBoxes
                propertyRectangleverticalLayoutConstraints
                propertySectionalternateLayout
                propertySectionalternateLayoutLength
                propertySectionpagination
                propertySectionpaginationMaster
                propertySignatureFieldAFTER_PLACE
                propertySignatureFieldBEFORE_PLACE
                propertySignatureFieldabsoluteFlip
                propertySignatureFieldabsoluteHorizontalScale
                propertySignatureFieldabsoluteRotationAngle
                propertySignatureFieldabsoluteShearAngle
                propertySignatureFieldabsoluteVerticalScale
                propertySignatureFieldactiveStateIndex
                propertySignatureFieldallArticles
                propertySignatureFieldallGraphics
                propertySignatureFieldallPageItems
                propertySignatureFieldallowOverrides
                propertySignatureFieldanchoredObjectSettings
                propertySignatureFieldanimationSettings
                propertySignatureFieldappliedObjectStyle
                propertySignatureFieldassociatedXMLElement
                propertySignatureFieldbehaviors
                propertySignatureFieldbottomLeftCornerOption
                propertySignatureFieldbottomLeftCornerRadius
                propertySignatureFieldbottomRightCornerOption
                propertySignatureFieldbottomRightCornerRadius
                propertySignatureFieldclearFormBehaviors
                propertySignatureFieldcontentTransparencySettings
                propertySignatureFielddescription
                propertySignatureFieldendCap
                propertySignatureFieldendJoin
                propertySignatureFieldepss
                propertySignatureFieldepstexts
                propertySignatureFieldeventListeners
                propertySignatureFieldevents
                propertySignatureFieldfillColor
                propertySignatureFieldfillTint
                propertySignatureFieldfillTransparencySettings
                propertySignatureFieldflip
                propertySignatureFieldgapColor
                propertySignatureFieldgapTint
                propertySignatureFieldgeometricBounds
                propertySignatureFieldgotoAnchorBehaviors
                propertySignatureFieldgotoFirstPageBehaviors
                propertySignatureFieldgotoLastPageBehaviors
                propertySignatureFieldgotoNextPageBehaviors
                propertySignatureFieldgotoNextViewBehaviors
                propertySignatureFieldgotoPreviousPageBehaviors
                propertySignatureFieldgotoPreviousViewBehaviors
                propertySignatureFieldgotoURLBehaviors
                propertySignatureFieldgradientFillAngle
                propertySignatureFieldgradientFillLength
                propertySignatureFieldgradientFillStart
                propertySignatureFieldgradientStrokeAngle
                propertySignatureFieldgradientStrokeLength
                propertySignatureFieldgradientStrokeStart
                propertySignatureFieldgraphicLines
                propertySignatureFieldgraphics
                propertySignatureFieldgroups
                propertySignatureFieldhiddenUntilTriggered
                propertySignatureFieldhorizontalLayoutConstraints
                propertySignatureFieldhorizontalScale
                propertySignatureFieldid
                propertySignatureFieldimages
                propertySignatureFieldindex
                propertySignatureFieldisValid
                propertySignatureFielditemLayer
                propertySignatureFieldlabel
                propertySignatureFieldleftLineEnd
                propertySignatureFieldlinkedPageItemOptions
                propertySignatureFieldlocalDisplaySetting
                propertySignatureFieldlocked
                propertySignatureFieldmiterLimit
                propertySignatureFieldmovieBehaviors
                propertySignatureFieldname
                propertySignatureFieldnonprinting
                propertySignatureFieldopenFileBehaviors
                propertySignatureFieldovals
                propertySignatureFieldoverprintFill
                propertySignatureFieldoverprintGap
                propertySignatureFieldoverprintStroke
                propertySignatureFieldoverridden
                propertySignatureFieldoverriddenMasterPageItem
                propertySignatureFieldpageItems
                propertySignatureFieldparent
                propertySignatureFieldparentPage
                propertySignatureFieldpdfs
                propertySignatureFieldpicts
                propertySignatureFieldpolygons
                propertySignatureFieldpreferences
                propertySignatureFieldprintFormBehaviors
                propertySignatureFieldprintableInPdf
                propertySignatureFieldproperties
                propertySignatureFieldreadOnly
                propertySignatureFieldrectangles
                propertySignatureFieldrequired
                propertySignatureFieldrightLineEnd
                propertySignatureFieldrotationAngle
                propertySignatureFieldshearAngle
                propertySignatureFieldshowHideFieldsBehaviors
                propertySignatureFieldsoundBehaviors
                propertySignatureFieldsplineItems
                propertySignatureFieldstrokeAlignment
                propertySignatureFieldstrokeColor
                propertySignatureFieldstrokeCornerAdjustment
                propertySignatureFieldstrokeDashAndGap
                propertySignatureFieldstrokeTint
                propertySignatureFieldstrokeTransparencySettings
                propertySignatureFieldstrokeType
                propertySignatureFieldstrokeWeight
                propertySignatureFieldsubmitFormBehaviors
                propertySignatureFieldtextFrames
                propertySignatureFieldtextWrapPreferences
                propertySignatureFieldtimingSettings
                propertySignatureFieldtopLeftCornerOption
                propertySignatureFieldtopLeftCornerRadius
                propertySignatureFieldtopRightCornerOption
                propertySignatureFieldtopRightCornerRadius
                propertySignatureFieldtransparencySettings
                propertySignatureFieldverticalLayoutConstraints
                propertySignatureFieldverticalScale
                propertySignatureFieldviewZoomBehaviors
                propertySignatureFieldvisible
                propertySignatureFieldvisibleBounds
                propertySignatureFieldwmfs
                propertySignatureFieldslength
                propertySnippetcheckBoxes
                propertySnippetcomboBoxes
                propertySnippetlistBoxes
                propertySnippetradioButtons
                propertySnippetsignatureFields
                propertySnippettextBoxes
                propertySoundhorizontalLayoutConstraints
                propertySoundlinkedPageItemOptions
                propertySoundverticalLayoutConstraints
                propertySplineItemcheckBoxes
                propertySplineItemcomboBoxes
                propertySplineItemhorizontalLayoutConstraints
                propertySplineItemhtmlItems
                propertySplineItemlinkedPageItemOptions
                propertySplineItemlistBoxes
                propertySplineItemradioButtons
                propertySplineItemsignatureFields
                propertySplineItemtextBoxes
                propertySplineItemverticalLayoutConstraints
                propertySpreadcheckBoxes
                propertySpreadcomboBoxes
                propertySpreadlistBoxes
                propertySpreadradioButtons
                propertySpreadsignatureFields
                propertySpreadtextBoxes
                propertyStaticTextstaticAlignment
                propertyStorycellStyleMappings
                propertyStorycharStyleMappings
                propertyStorycheckBoxes
                propertyStorycomboBoxes
                propertyStorylistBoxes
                propertyStoryparaStyleMappings
                propertyStoryparagraphKashidaWidth
                propertyStoryradioButtons
                propertyStorysignatureFields
                propertyStorytableStyleMappings
                propertyStorytextBoxes
                propertyStoryWindowselectionKeyObject
                propertyStyleExportTagMapsplitDocument
                propertySubmitFormBehaviorbehaviorEvent
                propertySubmitFormBehaviorenableBehavior
                propertySubmitFormBehavioreventListeners
                propertySubmitFormBehaviorevents
                propertySubmitFormBehaviorid
                propertySubmitFormBehaviorindex
                propertySubmitFormBehaviorisValid
                propertySubmitFormBehaviorlabel
                propertySubmitFormBehaviorname
                propertySubmitFormBehaviorparent
                propertySubmitFormBehaviorproperties
                propertySubmitFormBehaviorurl
                propertySubmitFormBehaviorslength
                propertyTablecheckBoxes
                propertyTablecomboBoxes
                propertyTablelistBoxes
                propertyTableradioButtons
                propertyTablesignatureFields
                propertyTabletextBoxes
                propertyTableStyleMappingdestinationStyleName
                propertyTableStyleMappingeventListeners
                propertyTableStyleMappingevents
                propertyTableStyleMappingindex
                propertyTableStyleMappingisValid
                propertyTableStyleMappingmappingRuleType
                propertyTableStyleMappingparent
                propertyTableStyleMappingproperties
                propertyTableStyleMappingsourceStyleName
                propertyTableStyleMappingslength
                propertyTextcheckBoxes
                propertyTextcomboBoxes
                propertyTextlistBoxes
                propertyTextparagraphKashidaWidth
                propertyTextradioButtons
                propertyTextsignatureFields
                propertyTexttextBoxes
                propertyTextBoxAFTER_PLACE
                propertyTextBoxBEFORE_PLACE
                propertyTextBoxabsoluteFlip
                propertyTextBoxabsoluteHorizontalScale
                propertyTextBoxabsoluteRotationAngle
                propertyTextBoxabsoluteShearAngle
                propertyTextBoxabsoluteVerticalScale
                propertyTextBoxactiveStateIndex
                propertyTextBoxallArticles
                propertyTextBoxallGraphics
                propertyTextBoxallPageItems
                propertyTextBoxallowOverrides
                propertyTextBoxanchoredObjectSettings
                propertyTextBoxanimationSettings
                propertyTextBoxappliedObjectStyle
                propertyTextBoxassociatedXMLElement
                propertyTextBoxbehaviors
                propertyTextBoxbottomLeftCornerOption
                propertyTextBoxbottomLeftCornerRadius
                propertyTextBoxbottomRightCornerOption
                propertyTextBoxbottomRightCornerRadius
                propertyTextBoxclearFormBehaviors
                propertyTextBoxcontentTransparencySettings
                propertyTextBoxdescription
                propertyTextBoxendCap
                propertyTextBoxendJoin
                propertyTextBoxepss
                propertyTextBoxepstexts
                propertyTextBoxeventListeners
                propertyTextBoxevents
                propertyTextBoxfillColor
                propertyTextBoxfillTint
                propertyTextBoxfillTransparencySettings
                propertyTextBoxflip
                propertyTextBoxfontSize
                propertyTextBoxgapColor
                propertyTextBoxgapTint
                propertyTextBoxgeometricBounds
                propertyTextBoxgotoAnchorBehaviors
                propertyTextBoxgotoFirstPageBehaviors
                propertyTextBoxgotoLastPageBehaviors
                propertyTextBoxgotoNextPageBehaviors
                propertyTextBoxgotoNextViewBehaviors
                propertyTextBoxgotoPreviousPageBehaviors
                propertyTextBoxgotoPreviousViewBehaviors
                propertyTextBoxgotoURLBehaviors
                propertyTextBoxgradientFillAngle
                propertyTextBoxgradientFillLength
                propertyTextBoxgradientFillStart
                propertyTextBoxgradientStrokeAngle
                propertyTextBoxgradientStrokeLength
                propertyTextBoxgradientStrokeStart
                propertyTextBoxgraphicLines
                propertyTextBoxgraphics
                propertyTextBoxgroups
                propertyTextBoxhiddenUntilTriggered
                propertyTextBoxhorizontalLayoutConstraints
                propertyTextBoxhorizontalScale
                propertyTextBoxid
                propertyTextBoximages
                propertyTextBoxindex
                propertyTextBoxisValid
                propertyTextBoxitemLayer
                propertyTextBoxlabel
                propertyTextBoxleftLineEnd
                propertyTextBoxlinkedPageItemOptions
                propertyTextBoxlocalDisplaySetting
                propertyTextBoxlocked
                propertyTextBoxmiterLimit
                propertyTextBoxmovieBehaviors
                propertyTextBoxmultiline
                propertyTextBoxname
                propertyTextBoxnonprinting
                propertyTextBoxopenFileBehaviors
                propertyTextBoxovals
                propertyTextBoxoverprintFill
                propertyTextBoxoverprintGap
                propertyTextBoxoverprintStroke
                propertyTextBoxoverridden
                propertyTextBoxoverriddenMasterPageItem
                propertyTextBoxpageItems
                propertyTextBoxparent
                propertyTextBoxparentPage
                propertyTextBoxpassword
                propertyTextBoxpdfs
                propertyTextBoxpicts
                propertyTextBoxpolygons
                propertyTextBoxpreferences
                propertyTextBoxprintFormBehaviors
                propertyTextBoxprintableInPdf
                propertyTextBoxproperties
                propertyTextBoxreadOnly
                propertyTextBoxrectangles
                propertyTextBoxrequired
                propertyTextBoxrightLineEnd
                propertyTextBoxrightToLeftField
                propertyTextBoxrotationAngle
                propertyTextBoxscrollable
                propertyTextBoxshearAngle
                propertyTextBoxshowHideFieldsBehaviors
                propertyTextBoxsoundBehaviors
                propertyTextBoxsplineItems
                propertyTextBoxstrokeAlignment
                propertyTextBoxstrokeColor
                propertyTextBoxstrokeCornerAdjustment
                propertyTextBoxstrokeDashAndGap
                propertyTextBoxstrokeTint
                propertyTextBoxstrokeTransparencySettings
                propertyTextBoxstrokeType
                propertyTextBoxstrokeWeight
                propertyTextBoxsubmitFormBehaviors
                propertyTextBoxtextFrames
                propertyTextBoxtextWrapPreferences
                propertyTextBoxtimingSettings
                propertyTextBoxtopLeftCornerOption
                propertyTextBoxtopLeftCornerRadius
                propertyTextBoxtopRightCornerOption
                propertyTextBoxtopRightCornerRadius
                propertyTextBoxtransparencySettings
                propertyTextBoxverticalLayoutConstraints
                propertyTextBoxverticalScale
                propertyTextBoxviewZoomBehaviors
                propertyTextBoxvisible
                propertyTextBoxvisibleBounds
                propertyTextBoxwmfs
                propertyTextBoxeslength
                propertyTextColumncheckBoxes
                propertyTextColumncomboBoxes
                propertyTextColumnlistBoxes
                propertyTextColumnparagraphKashidaWidth
                propertyTextColumnradioButtons
                propertyTextColumnsignatureFields
                propertyTextColumntextBoxes
                propertyTextDefaultparagraphKashidaWidth
                propertyTextFramecheckBoxes
                propertyTextFramecomboBoxes
                propertyTextFramehorizontalLayoutConstraints
                propertyTextFramelinkedPageItemOptions
                propertyTextFramelistBoxes
                propertyTextFrameobjectExportOptions
                propertyTextFrameradioButtons
                propertyTextFramesignatureFields
                propertyTextFrametextBoxes
                propertyTextFrameverticalLayoutConstraints
                propertyTextFramePreferenceautoSizingReferencePoint
                propertyTextFramePreferenceautoSizingType
                propertyTextFramePreferenceminimumHeightForAutoSizing
                propertyTextFramePreferenceminimumWidthForAutoSizing
                propertyTextFramePreferencetextColumnMaxWidth
                propertyTextFramePreferenceuseFlexibleColumnWidth
                propertyTextFramePreferenceuseMinimumHeightForAutoSizing
                propertyTextFramePreferenceuseMinimumWidthForAutoSizing
                propertyTextFramePreferenceuseNoLineBreaksForAutoSizing
                propertyTextPreferencequoteCharactersRotatedInVertical
                propertyTextStyleRangecheckBoxes
                propertyTextStyleRangecomboBoxes
                propertyTextStyleRangelistBoxes
                propertyTextStyleRangeparagraphKashidaWidth
                propertyTextStyleRangeradioButtons
                propertyTextStyleRangesignatureFields
                propertyTextStyleRangetextBoxes
                propertyWMFhorizontalLayoutConstraints
                propertyWMFlinkedPageItemOptions
                propertyWMFverticalLayoutConstraints
                propertyWindowselectionKeyObject
                propertyWordcheckBoxes
                propertyWordcomboBoxes
                propertyWordlistBoxes
                propertyWordparagraphKashidaWidth
                propertyWordradioButtons
                propertyWordsignatureFields
                propertyWordtextBoxes
                propertyXmlStorycellStyleMappings
                propertyXmlStorycharStyleMappings
                propertyXmlStorycheckBoxes
                propertyXmlStorycomboBoxes
                propertyXmlStorylistBoxes
                propertyXmlStoryparaStyleMappings
                propertyXmlStoryparagraphKashidaWidth
                propertyXmlStoryradioButtons
                propertyXmlStorysignatureFields
                propertyXmlStorytableStyleMappings
                propertyXmlStorytextBoxes
                property(enum)AlignDistributeBoundsKEY_OBJECT
                property(enum)AutoSizingReferenceEnumBOTTOM_CENTER_POINT
                property(enum)AutoSizingReferenceEnumBOTTOM_LEFT_POINT
                property(enum)AutoSizingReferenceEnumBOTTOM_RIGHT_POINT
                property(enum)AutoSizingReferenceEnumCENTER_POINT
                property(enum)AutoSizingReferenceEnumLEFT_CENTER_POINT
                property(enum)AutoSizingReferenceEnumRIGHT_CENTER_POINT
                property(enum)AutoSizingReferenceEnumTOP_CENTER_POINT
                property(enum)AutoSizingReferenceEnumTOP_LEFT_POINT
                property(enum)AutoSizingReferenceEnumTOP_RIGHT_POINT
                property(enum)AutoSizingTypeEnumHEIGHT_AND_WIDTH
                property(enum)AutoSizingTypeEnumHEIGHT_AND_WIDTH_PROPORTIONALLY
                property(enum)AutoSizingTypeEnumHEIGHT_ONLY
                property(enum)AutoSizingTypeEnumOFF
                property(enum)AutoSizingTypeEnumWIDTH_ONLY
                property(enum)CoordinateSpacesPAGE_COORDINATES
                property(enum)CustomLayoutTypeEnumALIGNMENT_AND_SPACING
                property(enum)CustomLayoutTypeEnumFLOAT_LEFT
                property(enum)CustomLayoutTypeEnumFLOAT_RIGHT
                property(enum)DiacriticPositionOptionsOPENTYPE_POSITION_FROM_BASELINE
                property(enum)DimensionsConstraintsFIXED_DIMENSION
                property(enum)DimensionsConstraintsFLEXIBLE_DIMENSION
                property(enum)DocumentIntentOptionsDPS_INTENT
                property(enum)EpubVersionEPUB2
                property(enum)EpubVersionEPUB3
                property(enum)EpubVersionEPUB3_WITH_LAYOUT
                property(enum)FindChangeTransliterateCharacterTypesARABIC_INDIC_DIGITS
                property(enum)FindChangeTransliterateCharacterTypesFARSI_DIGITS
                property(enum)FindChangeTransliterateCharacterTypesWESTERN_ARABIC_DIGITS
                property(enum)GuideTypeOptionsLIQUID
                property(enum)GuideTypeOptionsRULER
                property(enum)LanguageAndRegionINDIC
                property(enum)LayoutRuleOptionsGUIDE_BASED
                property(enum)LayoutRuleOptionsOBJECT_BASED
                property(enum)LayoutRuleOptionsOFF
                property(enum)LayoutRuleOptionsPRESERVE_EXISTING
                property(enum)LayoutRuleOptionsRECENTER
                property(enum)LayoutRuleOptionsSCALE
                property(enum)LayoutRuleOptionsUSE_MASTER
                property(enum)MapTypeGROUP_MAPPING_RULE
                property(enum)MapTypeGROUP_TO_STYLE_MAPPING_RULE
                property(enum)MapTypeSTYLE_MAPPING_RULE
                property(enum)MapTypeSTYLE_TO_GROUP_MAPPING_RULE
                property(enum)PDFColorSpaceGRAY
                property(enum)PNGColorSpaceEnumGRAY
                property(enum)PNGColorSpaceEnumRGB
                property(enum)PNGExportRangeEnumEXPORT_ALL
                property(enum)PNGExportRangeEnumEXPORT_RANGE
                property(enum)PNGQualityEnumHIGH
                property(enum)PNGQualityEnumLOW
                property(enum)PNGQualityEnumMAXIMUM
                property(enum)PNGQualityEnumMEDIUM
                property(enum)PageViewOptionsBY_ALTERNATE_LAYOUT
                property(enum)PageViewOptionsHORIZONTALLY
                property(enum)PageViewOptionsVERTICALLY
                property(enum)PaginationOptionAUTO_PAGINATE
                property(enum)PaginationOptionFROM_LAST_PAGE
                property(enum)ParagraphJustificationOptionsNASKH_KASHIDA_JUSTIFICATION
                property(enum)ParagraphJustificationOptionsNASKH_KASHIDA_JUSTIFICATION_FRAC
                property(enum)ParagraphJustificationOptionsNASKH_TATWEEL_JUSTIFICATION
                property(enum)ParagraphJustificationOptionsNASKH_TATWEEL_JUSTIFICATION_FRAC
                property(enum)PreviewPagesOptionsALL_PAGES
                property(enum)PreviewPagesOptionsFIRST_10_PAGES
                property(enum)PreviewPagesOptionsFIRST_2_PAGES
                property(enum)PreviewPagesOptionsFIRST_5_PAGES
                property(enum)PreviewPagesOptionsFIRST_PAGE
                property(enum)SelectionOptionsSET_KEY
                property(enum)SnapshotBlendingModesFULL_SNAPSHOT_BLENDING
                property(enum)SnapshotBlendingModesIGNORE_LAYOUT_SNAPSHOTS
                property(enum)SnapshotBlendingModesLIMITED_SNAPSHOT_BLENDING
                property(enum)SnapshotBlendingModesUSE_NEAREST_SNAPSHOT
                property(enum)StateTypesDOWN_OFF
                property(enum)StateTypesDOWN_ON
                property(enum)StateTypesROLLOVER_OFF
                property(enum)StateTypesROLLOVER_ON
                property(enum)StateTypesUP_OFF
                property(enum)StateTypesUP_ON
                property(enum)StaticAlignmentOptionsCENTER_ALIGN
                property(enum)StaticAlignmentOptionsLEFT_ALIGN
                property(enum)StaticAlignmentOptionsRIGHT_ALIGN
                property(enum)TagTextExportCharacterSetCENTRALEUROPEAN_ISO
                property(enum)TagTextExportCharacterSetCYRILLIC_ISO
                property(enum)TagTextExportCharacterSetGREEK_ISO
                property(enum)TagTextExportCharacterSetWINDOWS_ARABIC
                property(enum)TagTextExportCharacterSetWINDOWS_HEBREW
                property(enum)TextFrameContentsPLACEHOLDER_TEXT_ARABIC
                property(enum)TextFrameContentsPLACEHOLDER_TEXT_CYRILLIC
                property(enum)TextFrameContentsPLACEHOLDER_TEXT_GREEK
                property(enum)TextFrameContentsPLACEHOLDER_TEXT_HEBREW
                property(enum)TextImportCharacterSetARABIC_ASMO
                property(enum)TextImportCharacterSetARABIC_ASMO_TRANSPARENT
                property(enum)TextImportCharacterSetMACINTOSH_ARABIC
                property(enum)TextImportCharacterSetMACINTOSH_GREEK_SHARED_CAPS
                property(enum)TextImportCharacterSetMACINTOSH_HEBREW
                property(enum)TextImportCharacterSetWINDOWS_ARABIC
                property(enum)TextImportCharacterSetWINDOWS_HEBREW
                Everybody happy?
                • 5. Re: [Ann] HTML/CHM for CS6 Javascript
                  Laubender CommunityMVP
                  @Jongware & John – Great ! Great ! Great !!
                  Thank you very much!
                  Uwe
                  • 6. Re: [Ann] HTML/CHM for CS6 Javascript
                    @Jongware – Could you also do a chm version for InDesign CS5.5?
                    I know there is the online documentation. I wonder how much trouble it is to transform that into a chm file.
                    Or are there tools to do it myself?
                    And another thing with the online documentation of CS5.5:
                    Did you by any chance have the Adobe Digitial Publishing Suite installed when you created the online version of InDesign CS5.5?
                    I noticed that there is the "getAllOverlays" method listed for "application":
                    http://jongware.mit.edu/idcsjs5.5/pc_Application.html#getAllOverlays
                    That method is missing in the above lists by John. That is no omission since there seems no DPS involved on his side. And in your case, no wonder, it is missing in the CS6 documentation too, since DPS v20 for InDesign CS6 is not available yet and the current v19 does not work with InDesign CS6.
                    On the other hand the "app.getDigpubVersion()" method is missing in your online documentation of InDesign CS5.5 which, so I believe, belongs totally to DPS and is only available if you have a installed DPS (like me). But maybe this method came with v19 of DPS and you had v17 or v18 installed the day you did the online documentation.
                    Thank you again for your efforts!
                    Uwe
                    • 7. Re: [Ann] HTML/CHM for CS6 Javascript
                      pkahrel Community Member
                      Thanks very much!
                      Peter
                      • 8. Re: [Ann] HTML/CHM for CS6 Javascript
                        [Jongware] CommunityMVP
                        Updated:
                        When you see a property such as "Document.articles", sometimes you want to get to the reference to the "Articles" -- plural --, for example when you want to add or list them. But more often, you want to see the properties of an individual article; and to get to those, you have to click "Articles", then browse down the list to a reference to the singular and then click that. So now, when I see a plural reference and there also is a singular class, this is shown besides the plural.
                        Some numbers for the CS6 version, by the way, to illustrate the depth & width of this help
                        8,105Topics
                        117,298Local links
                        1Internet link
                        0Graphics
                        • 9. Re: [Ann] HTML/CHM for CS6 Javascript
                          .. added CS6 InCopy and CS6 Server as well.
                          Uwe, I don't do anything 'special' to get or not get special DPS commands included -- I only use what I get to see in the most recent OMV file.
                          Since DPS is constantly updated (well, probably a good thing) you'll have to check Adobe's OMV for changes in the JS interface, each time you update it. Besides, I'm not a fan user of DPS so I'm not going to jump through hoops everytime ithis happens.
                          • 10. Re: [Ann] HTML/CHM for CS6 Javascript
                            Some odd choices here ...
                            For example, who could ever have a grudge against PagesPanel.verticalView!? Surely that's not no longer an option in CS6?
                            • 11. Re: [Ann] HTML/CHM for CS6 Javascript
                              CS5.5 was a strange omission -- perhaps because it came out at such a strange time! Corrected; I also threw in InCopy and ID Server for completeness' sake.
                              If you have a set of HTML files you can convert them to a single CHM file with Microsoft's HTML Help Workshop. The version I am using is from 1999, which is ancient in terms of software, but it does a very good job, as an input size of 19MB gets compressed into a mere 3.5MB in minutes.
                              These help files are 'old format'; there is also a 'new format', but (a) I don't have the tools or any experience with creating it, (b) I'm not too sure if my preferred Mac viewer (Robin Lu's iCHM) can display them, and (c) I'm not too wild about how files are displayed .
                              • 12. Re: [Ann] HTML/CHM for CS6 Javascript
                                John Hawkinson CommunityMVP
                                Whoops. The position of the UI control for this changed, and I figured it just moved around in the scripting DOM, but that doesn't appear to be the case. Sounds like an oversight. Bug #3177903: PagesPanel.verticalView property disappeared (CS6 regression). If you find any others, it would be good to find them prior to Monday.
                                On the bright side, you can just set app.scriptPreferences.version=7.5 and it still works.
                                Any others?
                                *Kicks self* for not running this report earlier and not really paying attention...
                                • 13. Re: [Ann] HTML/CHM for CS6 Javascript
                                  @Jongware – and you did an update for this in the  CS4 files as well. Cool.
                                  Uwe
                                  • 14. Re: [Ann] HTML/CHM for CS6 Javascript
                                    See here: http://jongware.mit.edu/idcs6js/pe_PageViewOptions.html <g>
                                    The odd choice was to move it in the Panel Options dialog.
                                    Peter
                                    • 15. Re: [Ann] HTML/CHM for CS6 Javascript
                                      Yes, but what variable uses this enumerator?
                                      • 16. Re: [Ann] HTML/CHM for CS6 Javascript
                                        Dunno. I've been looking under all kinds of preferences and settings, but haven't found it. To make finding what parent(s) a property or a method belongs to, I was going to ask if it's possible to change the xslt in such a way that the output list includes full path names, so to speak.
                                        Peter
                                        • 17. Re: [Ann] HTML/CHM for CS6 Javascript
                                          I had found the PageViewOptions enumerator before I concluded that there was no way to do this, but it didn't get me anywhere...but I'd be happy to be shown to be wrong!
                                          Unfortunately that's not how the XML is structured. Take a look at the OMV cache file, it looks like this:
                                          <dictionary engine="">
                                            <map name="8.0" ...>
                                              <topicref navtitle="Assignment Suite">
                                                <topicref navtitle="Assignment" href="#/Assignment"/>
                                              </topicref>
                                            </map>
                                            <package>
                                              <classdef name="Assignment" dynamic="true">
                                                <shortdesc>An assignment.</shortdesc>
                                                <elements type="instance">
                                                  <property name="documentPath" rwaccess="readonly">
                                                    <shortdesc>The path to the document that the hyperlink ...</shortdesc>
                                                    <datatype>
                                                      <type>File</type>
                                                    </datatype>
                                                  </property>
                                                  <method name="update">
                                                    <shortdesc>Updates the assignment file.</shortdesc>
                                                    <parameters>
                                                      <parameter name="versionComments">
                                                        <shortdesc>The comment for this version. (Optional)</shortdesc>
                                                        <datatype>
                                                          <type>string</type>
                                                        </datatype>
                                                      </parameter>
                                                    </parameters>
                                                  </method>
                                                </elements>
                                              </classdef>
                                            </package>
                                          </dictionary>
                                          That is, for each proprerty (including eums), we only know the associated Class. And the Class belongs to a Suite.
                                          Sometimes the descriptions include (unstructured) references to an enumerator, but there are no decriptions that reference this enumerator.
                                          And nothing has a <datatype/> tag that lists this enumerator.
                                          So, it's certainly possible to change the XSLT to look up the Suite of a class in the <map/> section, but I didn't bother because it's a little more code and doesn't get us anything real. The PageViewOptions class belongs to the Enumeration suite, and that's all we can say.
                                          Or did I misunderstand?
                                          • 18. Re: [Ann] HTML/CHM for CS6 Javascript
                                            Ok, thanks, I see now that the xml won't let you get the full path. Thanks.
                                            • 19. Re: [Ann] HTML/CHM for CS6 Javascript
                                              It sounds to me like Adobe intended this enumeration to be used in the PagesPanel ... but they removed the property that it was supposed to be associated with it ...
                                              • 20. Re: [Ann] HTML/CHM for CS6 Javascript
                                                Well, that was exciting.
                                                Bug was marked Withdrawn/Closed/As Designed on Monday, I guess because QE thought that there was some way to use PageViewOptions.
                                                I lodged an inquiry then and today it was confirmed that it is indeed a bug (after "lengthy investigation") and it's been reopened and moved to CSnext.
                                                Gotta fight for your bugs!
