I am currently working in Flashbuilder 4.6 creating a mobile application and I wish to push the users to a view by based on the menu item they select. My code below shows how I have tried to convert a string from a selected list item into a class object and then pass that into the parameter for the pushView:
<fx:Script>
<![CDATA[
import mx.collections.*;
import spark.components.SplitViewNavigator;
import spark.components.ViewNavigator;
import spark.events.IndexChangeEvent;
import spark.events.ViewNavigatorEvent;
import spark.managers.PersistenceManager;
import spark.skins.mobile.SplitViewNavigatorSkin;
public var menuAC:ArrayCollection;
public var j_array:Array = [{label:"Home", data:"NLView"},
{label:"All Jobs", data:"JList"},
{label:"Company Profiles", data:"SView"},
{label:"Search By Sector", data:"JView"}];
protected function list_changeHandler(event:IndexChangeEvent):void
var selectedItem:String = new String(list.selectedItem.data);
//trace("Selected Item = " + selectedItem);
var splitNavigator:SplitViewNavigator = navigator.parentNavigator as SplitViewNavigator;
var detailNavigator:ViewNavigator = splitNavigator.getViewNavigatorAt(0) as ViewNavigator;
splitNavigator.hideViewNavigatorPopUp();
if(list.selectedItem.data == "NewListView")
var myClass:Class = getDefinitionByName(selectedItem) as Class;
trace("View Class = " + myClass);
detailNavigator.pushView(myClass);
else if(list.selectedItem.data)
protected function view1_viewActivateHandler(event:ViewNavigatorEvent):void
if(data.view == "JSFilt")
menuAC = new ArrayCollection(j_array);
list.dataProvider = menuAC;
// TODO Auto-generated method stub
var detailNavigator:ViewNavigator = splitNavigator.getViewNavigatorAt(1) as ViewNavigator;
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<s:BitmapImage width="100%" height="100%" source="@Embed('assets/images/sidebg.png')" fillMode="repeat"/>
<s:BitmapImage horizontalCenter="0" top="5" width="175" height="130" source="@Embed('assets/images/G_S_Logo_170x130.png')"/>
<s:List id="list" left="0" right="0"
color="0xFFFFFF" contentBackgroundColor="0x101010"
fontSize="20" width="280"
alternatingItemColors="[0x202020,0x2a2a2a]"
top="140" horizontalCenter="0" bottom="200"
downColor="0x70B2EE"
selectionColor="0x70B2EE"
change="list_changeHandler(event)">
<s:itemRenderer>
<fx:Component>
<s:IconItemRenderer messageStyleName="myFontStyle" fontSize="22" height="70"
labelField="label"
messageField=""
</fx:Component>
</s:itemRenderer>
</s:List>
I have also tried using the following command which also did not work:
var viewClass:Class = Class(getDefinitionByName(getQualifiedClassName(selectedItem)));
Has anyone got anyidea how to look at a value selected on a list and then use that string name to push the App to the view as the pushView method wont accept a string??
Is there no one who can help on this forum, I post questions here and no one ever answers them?!?
I have tried to use the following code in replacement of what I had:
var myClass:Class = getDefinitionByName(selectedItem.data);
I should maybe just keep this simple and explain what I want to do. I want to pass a string into the "ViewNavigator.pushView()" that usually only accepts a View Class Object. So I would have the name of the view I want to navigate to stored as a String and then i want to execute the follwoing code, where "MyView" is a String:
var MyView:String = new String("RightView");
ViewNavigator.pushView(MyView);
This seems like a simple concept to me but the "viewNavigator.pushView()" only seems to accept a View Class being passed to it. Can someone please help me?
