4 Replies Latest reply on Apr 30, 2012 3:14 PM by chris.campbell
    Flash Player doesn't play smoothly and out of sync in full screen
    deadeyz Level 1
      Hello! Everyone
      The flash player ( does not play smoothly and in full screen audio and vidoe is out of sync.  I didn't use to have any problem at all, it only started about two weeks ago and since then despite trying various things (i.e. disabling hardware excelration, uninstalling & reinstalling, trying various browsers etc.) has not resolved the issue.  I don't know why it has suddenly stopped playing smoothly as I have not installed any software recently which might have cuased this.
      I am using Windows XP (service pack3) and have dual partion with dual operating system (both XP).  There is the same problem on both operarting system and flash player won't run smoothly on either of them.  Although my computer and graphics card is quite old but the downloaded movies/DVD playback is fine even in full screen.  It runs smoothly and audio&video is in sync so I don't think it could my the graphics card.
      As I mentioned I have tried all the browsers but without any luck.  The BBC iplayer plays ok most of the time if not in full screen but as soon as you make it full screen the vidoe is more like a slide show and very jittery and audio&video gets out of sync.  Same with youtube vidoes, they play ok when not in full screen but the video in full screen does not play smoothly and audio&vidoes gets out of sync.  However the ITV player & Channel 4 content on 4OD does not even play smoothly when not in full screen and the video&audio is out of sync all the time.
      It would be really helpful if anyone can suggest anything to resolve this issue as I have not been able to find anything on the internet to solve the problem and its driving me up the wall.  Although I have tried to include as much details as I could think of so please let me know if I have missed any details that could be crucial in order to identify the problem.
      Thank you very much for reading this and taking the time to reply and your feedback.
      Below is the DxDiag report for my laptop:
      Time of this report: 4/22/2012, 00:15:58
      Machine name: TIMES-LAPTOP
      Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
      Language: English (Regional Setting: English)
      System Manufacturer: TimeComputers
      System Model: VT8372
      BIOS: Insyde Software MobilePRO BIOS Version 4.00.01
      Processor: mobile AMD Athlon(tm) XP 2000+,  MMX,  3DNow, ~1.7GHz
      Memory: 1248MB RAM
      Page File: 809MB used, 2790MB available
      Windows Dir: C:\WINDOWS
      DirectX Version: DirectX 9.0c (4.09.0000.0904) DX
      Setup Parameters: Not found
      DxDiag Version: 5.03.2600.5512 32bit Unicode
      ------------ DxDiag Notes ------------
      DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
      Sound Tab 1: No problems found.
      Music Tab: No problems found.
      Input Tab: No problems found.
      Network Tab: No problems found.
      -------------------- DirectX Debug Levels --------------------
      Direct3D:    0/4 (n/a)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (n/a)
      DirectMusic: 0/5 (n/a)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      --------------- Display Devices ---------------
      Card name: S3 Graphics ProSavageDDR
      Manufacturer: S3 Graphics Co., Ltd.
      Chip type: S3 ProSavage DDR
      DAC type: S3 SDAC
      Device Key: Enum\PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00
      Display Memory: 32.0 MB
      Current Mode: 1024 x 768 (32 bit) (60Hz)
      Monitor: Digital Flat Panel (1024x768)   Monitor Max Res:
      Driver Name: s3gnb.dll
      Driver Version: 6.14.0010.0025 (English)
      DDI Version: 9 (or higher)
      Driver Attributes: Final Retail
      Driver Date/Size: 3/2/2004 14:02:26, 402048 bytes
      WHQL Logo'd: Yes   WHQL Date Stamp: n/a
      VDD: n/a
      Mini VDD: s3gnbm.sys
      Mini VDD Date: 3/2/2004 14:02:30, 167040 bytes
      Device Identifier: {D7B75DD3-CE44-11CF-D873-7FA3A1C2CB35}
      Vendor ID: 0x5333
      Device ID: 0x8D04
      SubSys ID: 0x83751071
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel: ModeMPEG2_C ModeMPEG2_A ModeMPEG2_D
      Deinterlace Caps: n/a
      Registry: OK
      DDraw Status: Enabled
      D3D Status: Enabled
      AGP Status: Enabled DDraw
      Test Result: Not run
      D3D7 Test Result: Not run
      D3D8 Test Result: Not run
      D3D9 Test Result: Not run
      ------------- Sound Devices -------------
      Description: Vinyl AC'97 Audio (WAVE)
      Default Sound Playback: Yes
      Default Voice Playback: Yes
      Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_83751071&REV_50
      Manufacturer ID: 1
      Product ID: 100
      Type: WDM
      Driver Name: vinyl97.sys
      Driver Version: 6.14.0001.4170 (English)
      WHQL Logo'd: Yes
      Date and Size: 8/10/2006 07:32:14, 204672 bytes
      Other Files:
      Driver Provider: VIA Technologies, Inc.
      HW Accel Level: Full
      Cap Flags: 0xF5F
      Min/Max Sample Rate: 8000, 48000 Static/Strm
      HW Mix Bufs: 1, 0  Static/Strm
      HW 3D Bufs: 0, 0
      HW Memory: 0
      Voice Management: No  EAX(tm) 2.0
      Listen/Src: No, No    I3DL2(tm)
      Listen/Src: No, No Sensaura(tm)
      ZoomFX(tm): No
      Registry: OK
      Sound Test Result: Not run
      --------------------- Sound Capture Devices ---------------------
      Default Sound Capture: Yes
      Default Voice Capture: Yes
      Cap Flags: 0x41
      Format Flags: 0xFFF
      ----------- DirectMusic -----------
      DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
      DLS Version: 1.00.0016.0002
      Acceleration: n/a
      Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
      Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
      Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
      Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
      Registry: OK
      ------------------- DirectInput Devices -------------------
      Device Name: Mouse
      Attached: 1
      Controller ID: n/a
      Vendor/Product ID: n/a
      FF Driver: n/a
      Device Name: Keyboard
      Attached: 1
      Controller ID: n/a
      FF Driver: n/a
      Poll w/ Interrupt: No
      Registry: OK
      ----------- USB Devices -----------
      + USB Root Hub |
      Vendor/Product ID: 0x1106, 0x3038 |
      Matching Device ID: usb\root_hub |
      Service: usbhub |
      Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes |
      Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
