13 Replies Latest reply: Apr 29, 2012 5:31 AM by John Waller RSS
    Why i cant see text in explorer
    braico Community Member
      Hi if you look on explorer at my site on
      http://www.dorff.nl/index.html
      you will see that some part of text are missing. In firefox it all looks good.
      What can i do to avoid this problem?
      Regards Brian
        • 1. Re: Why i cant see text in explorer
          osgood_ MVP
          I don't know why it is but its the below jquery script that is causing the disappearance of your text in IE.
          <script type='text/javascript' src='js/jquery.js'></script>
          if you comment it out (as below) the text appears.
          <!-- <script type='text/javascript' src='js/jquery.js'></script> -->
          I don't know what this script is used for in your page...so you need to investigate if you need it or if there is an alternative. First I would get hold of a clean copy of that script and try again....sometimes when uploading things become corrupt.
          • 2. Re: Why i cant see text in explorer
            Where can i find this rule?
            Regards Brian
            Date: Sat, 28 Apr 2012 09:41:38 -0600
            To: braico@live.nl
            Subject: Why i cant see text in explorer
                created by osgood_ in Dreamweaver - View the full discussion
            I don't know why it is but its the below jquery script that is causing the disappearance of your text in IE.  if your comment it out (as below) the text appears.  I don't know what this script is used for in your page...so you need to investigate if you need it or if there is an alternative. First I would get hold of a clean copy of that script and try again....sometimes when uploading things become corrupt.
                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4367211#4367211
                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4367211#4367211. In the Actions box on the right, click the Stop Email Notifications link.
                 Start a new discussion in Dreamweaver by email or at Adobe Forums
              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
            • 3. Re: Why i cant see text in explorer
              sudarshan.t Community Member
              Line 16 in your HTML file
              • 4. Re: Why i cant see text in explorer
                Problem is if i change this rule my slide view doesnt work anymore and it messes all pages up..
                hope you got another idea?
                Cant find the clean copy anymore...
                Regards Brian
                To: braico@live.nl
                • 5. Re: Why i cant see text in explorer
                  Looking at your site, I just diagnosed that its not the jquery itself. It's the cufon that's creating the issue as I only see the text that you've used cufon on not displaying in IE.
                  Try using this script in your <head> tag to disable cufon rendering only for IE and see if it works:
                  <!--[if IE]><style type="text/css">cufontext {display: none!important}</style><![endif]-->
                  • 6. Re: Why i cant see text in explorer
                    John Waller ACP/MVP
                    Agreed.
                    There was a temporary issue with IE9 and the Cufon script pre-1.09. Cufon would not render at all in IE9 using earlier Cufon scripts.
                    Updating the Cufon script to the latest build usually fixes it
                    http://themeforest.net/forums/thread/fix-for-cufon-not-working-in-ie9beta/31932
                    • 7. Re: Why i cant see text in explorer
                      osgood_ MVP
                      Thought it might be something to do with the cufon...I just didn't have enough time to go through all the scripts and find the real cause of the problem.
                      At times like this you really need to go through each one isolating them and see where the real problem lies. Problem is a lot of people stuff their page with a ton of scripts and then check only after the construction is complete. If you use jquery scripts, which are unfamilar to you, you should check each time you add one to the page.
                      Some won't work in IE and other will conflict with other scripts already on the page and some elements on the page too. Once you have loaded the page with a significant number, without checking as you go, the process of tracking down the culprit becomes rather tedious and long-winded.
                      • 8. Re: Why i cant see text in explorer
                        Dear John,
                        How can i update the cufon?
                        Regards Brian
                        Date: Sat, 28 Apr 2012 13:41:23 -0600
                        To: braico@live.nl
                            created by John Waller in Dreamweaver - View the full discussion
                        Looking at your site, I just diagnosed that its not the jquery itself. It's the cufon that's creating the issueAgreed. Updating the Cufon script to the latest build usually fixes it http://themeforest.net/forums/thread/fix-for-cufon-not-working-in-ie9b eta/31932
                             Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4367519#4367519
                             To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4367519#4367519. In the Actions box on the right, click the Stop Email Notifications link.
                        • 9. Re: Why i cant see text in explorer
                          John Waller ACP/MVP
                          Download the current build to your computer (click the link below)
                          http://cufon.shoqolate.com/js/cufon-yui.js?v=1.09i
                          Upload it to your server replacing the existing cufon-yui.js file
                          http://www.dorff.nl/js/cufon-yui.js
                          • 10. Re: Why i cant see text in explorer
                            Ive replaced it but is still dont see me text in explorer?
                            Can you check this out what i am doing wrong?
                            Regard  Brian
                            Date: Sun, 29 Apr 2012 06:08:26 -0600
                            To: braico@live.nl
                            braico wrote: How can i update the cufon? Download the current buildhttps://raw.github.com/sorccu/cufon/master/js/cufon.js Upload it to your server and replace the existing cufon.js filehttp://www.dorff.nl/js/cufon-yui.js
                                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4368212#4368212
                                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4368212#4368212. In the Actions box on the right, click the Stop Email Notifications link.
                            • 11. Re: Why i cant see text in explorer
                              John Waller ACP/MVP
                              Where did you upload the file to? Should be inside the "js" folder.
                              I just downloaded http://www.dorff.nl/js/cufon-yui.js and it's still the old version 1.09.
                              Should be the current version 1.09i - which is IE9 compatible.
                              • 12. Re: Why i cant see text in explorer
                                When uploading the name was changed in cufon-yui.js.js
                                after removing the js it worked.
                                Thank You very much To all of you guys..
                                Date: Sun, 29 Apr 2012 06:26:32 -0600
                                To: braico@live.nl
                                Where did you upload the file to? Should be inside your folder named "js". I just downloaded http://www.dorff.nl/js/cufon-yui.js and it's still version 1.09 (not the current 1.09i)
                                     Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4368219#4368219
                                     To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4368219#4368219. In the Actions box on the right, click the Stop Email Notifications link.
                                • 13. Re: Why i cant see text in explorer
                                  John Waller ACP/MVP
                                  Yes, it's now working OK here in IE9.
