5 Replies Latest reply on Apr 30, 2012 11:47 AM by Dave LaRonde
    AE CS5.5 Trial not showing all export options
    Mynka Doll Level 1
      I recently downloaded the trial to give it a shot on a project for school I'm working on currently but I've run into an issue.  From what I've seen this version is supposed to have full export functions but the only types I'm given on my menus are Adobe project files. Is there an additional update to download that I could possibly be missing?  I've used the update menu item which downloaded a codec update and a couple of others but I'm still unable to export.  I plan on picking up the new version with student loans next semester but right now I'm working on a project I've edited in Final Cut and exported as a .mov and I need to burn this to a DVD after the effects are added but I cannot.  Any suggestions other then downloading Premier as well?  I'm in a bit of a time crunch so I was trying to avoid teaching myself 2 new programs but if that will fix my problem I might.  I just don't want to download and install the whole thing just to find that I'm still unable to add these effects and burn my project or save in a format I could pull in to FCP.  Thanks!
        • 1. Re: AE CS5.5 Trial not showing all export options
          Szalam Adobe Community Professional & MVP
          You don't want to "export" you want to "render". Read up on it here.
          As someone new to AE, I would highly recommend you start here. The links it provides will get you through learning the basics of the program like rendering your finished files. (This is one of the tutorials it links to - this one is specific to rendering.)
          1 person found this helpful
          • 2. Re: AE CS5.5 Trial not showing all export options
            Dave LaRonde Level 6
            It's also EXTREMELY helpful to run AE on the same machine as FCP.  You'll then have access to the necessary codecs.  In AE, render in a high-quality codec like ProRes 422 or ProRes HQ.  Then use Apple Compressor to create the files m2v & AC3 files for DVD authoring.
            • 3. Re: AE CS5.5 Trial not showing all export options
              Mynka Doll Level 1
              Ah render! *smacks forehead* I will try that as soon as I get home, thanks for the replies!  Yeah, I'm totally new to AE, I've used Adobe's graphics programs but I'm new to the video ones.  I hadn't noticed in the tutorial videos I watched that they were going under render, it was just a couple clicks and showing a bunch of save options... which I was not seeing. Thanks for the link too!
              • 4. Re: AE CS5.5 Trial not showing all export options
                Mynka Doll Level 1
                I wish I could run them on the same systems, but the school's labs have the Macs with the FCP and at home I only have PCs so far.  I had planned on saving in the best codec I could then taking the file back to the labs for burning.  When I edited I used the ProRes 422 and made a "before AE" disc which looked really nice so hopefully I won't experience too much degradation. *fingers crossed*
                • 5. Re: AE CS5.5 Trial not showing all export options
                  That's a pain, and one I know well:  I cut on FCP at work, and often do AE work at home on a Windows machine.  You'll need the latest version of Quicktime 7 for Windows: free download.
                  You'll be able to READ ProRes 422, but you can't WRITE ProRes 422.  Your options will be to render QT movies in the ProRes HQ or PNG codecs.
                  You can also render Image sequences, and if you want to do that I recommend PNG sequences.  There are two varieties of PNG: image sequence and QT movie codec.
