1. Re: Cs 5.5 render problem, severe loss in quality.
JSS1138 Apr 30, 2012 10:31 AM (in response to DanielFilming)What is wrong?
Your testing methodology. You can't trust software players, computer monitors and especially Youtube uploads to judge the quality of media. For that, you need a properly calibrated external TV.
2. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 11:23 AM (in response to JSS1138)Ok.
Can someone look over my render settings and tell me if I should change anything?
3. Re: Cs 5.5 render problem, severe loss in quality.
Ann Bens Apr 30, 2012 11:50 AM (in response to DanielFilming)Does not the Canon shoot in 1920x1080?
Your sequence settings are 1440x1080 1,33 aspect.
Why the audio bitrate so high?
4. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 12:41 PM (in response to Ann Bens) -
5. Re: Cs 5.5 render problem, severe loss in quality.
Harm Millaard Apr 30, 2012 12:56 PM (in response to DanielFilming)Start with using the format your camera uses. XDCAM HD is wrong. If you don't know what codec your camera uses, forget about a sequence preset and just import a clip from the Media Browser and right click on the clip in the project panel and select New Sequence from Clip.
'Every autodidact had an idiot as a teacher'
6. Re: Cs 5.5 render problem, severe loss in quality.
Ann Bens Apr 30, 2012 1:08 PM (in response to DanielFilming)If you have no idea what you are doing stick to the default settings/presets, they are usually the best.
Make a new sequence and copy everything from the old into the new one.
This looks more appropriate for your camera.
For learning Premiere you can start here:
7. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 1:15 PM (in response to Ann Bens)A digital dslr preset? I should get my eyes checked!
Still, I would like to hear from someone who knows the optimal render settings I need. I want to learn as much as possible and you don't learn much using default settings.
Some to the point questions:
How are my Bitrate settings? is the bitrate encoding correct? target and maximum bitrate?
What does "Level" mean and should I chose a higher one?
AUDIO:
What should my codec be and why?
Should my frequency be 44 or 48? Why?
What bitrate should I use?
Thanks a lot for your help, Ann!
8. Re: Cs 5.5 render problem, severe loss in quality.
Ann Bens Apr 30, 2012 1:24 PM (in response to DanielFilming)What is final destination of your footage?
9. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 1:29 PM (in response to DanielFilming)As of right now it is youtube since I'm using youtube as a tool to get better at filmmaking and editing. The future however will hold larger platforms.
10. Re: Cs 5.5 render problem, severe loss in quality.
shooternz Apr 30, 2012 1:34 PM (in response to DanielFilming)Try using the H264 - Youtube preset after getting uyour sequence and camera settings matched..
BTW - Higher video bitrates are what provide better quality
11. Re: Cs 5.5 render problem, severe loss in quality.
Ann Bens Apr 30, 2012 1:40 PM (in response to DanielFilming)Use the HDTV 1080p 24 high quality preset.
You only need to change the framerate to 23.976 and check Render Use Maximum Render Quality; don't touch the rest.
Try again with the new sequence setting.
12. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 1:52 PM (in response to DanielFilming) -
13. Re: Cs 5.5 render problem, severe loss in quality.
Ann Bens Apr 30, 2012 2:10 PM (in response to DanielFilming)I said dont touch anything other then i told you to change.
You will always suffer a slight quality loss.
Did you upload to YT?
14. Re: Cs 5.5 render problem, severe loss in quality.
DanielFilming Apr 30, 2012 2:31 PM (in response to DanielFilming)Yeah I checked it, it's fine.
15. Re: Cs 5.5 render problem, severe loss in quality.
Todd_Kopriva May 2, 2012 9:25 PM (in response to DanielFilming)Ann gave you a good link, but here it is again...
Start here to learn Premiere Pro: http://adobe.ly/psbYc4
