Hi
I am using RH8 and when creating a See Also, realise the font colour cannot be changed.
I found this post http://forums.adobe.com/message/471145#471145 with instuctions to add an image and hyperlink it to a javascript.
I am not at all computer savvy and am not very familiar with javascript. Although I thought I had followed the instruction, when I compile the CHM guide and test it, the Internet Explorer Script Error window displays with the error the following error:
Line: 1
Char: 1
Error: 'object1' is undefined
Code: 0
Is there something I am missing from the instructions?
Ah, you triggered a memory.
I tracked down the thread and there are a couple of scripts posted - although I haven't tried to download them, so can't guarantee that they are still available as listed. Or possibly they are available on Peter Grainge's site - www.grainge.org - he has the most amazing repository of RH knowledge on the planet.
Related Topics control via "JavaScript:RelatedTopics.Click" broken in RH8
Amber
You need to have a look at the HTML code for your see also button and see what ID it has. It'll look something like this:
<object CLASSID="clsid:A2F1FA63-C1E6-11d2-9140-006DC83B9955"
ID=SeeAlso
BORDER=0
style="margin-top: 0px;
margin-bottom: 0px;
margin-left: 0px;
margin-right: 0px;
vertical-align: baseline;"
align=bottom>
The bit after ID is what you need in the javascript so something like the below, depending what text occurs:
javascript:SeeAlso.Click()
or
javascript:object1.Click()
or
javascript.Object1.Click()
Hi
I had checked that I had the right ID (object1) in this case, as I noticed Rick's post, but thanks for the help.
If you can think of anything else, please let me know.
Adele
Can you post the code? Perhaps there's a typo somewhere causing it that fresh eyes might spot?
Hi
Here goes:
</table>
<p>
<!--Metadata type="DesignerControl" startspan
<object classid="clsid:A2F1FA63-C1E6-11d2-9140-006DC83B9955" border="0"
id="object1" style="margin-top: 0px; margin-bottom: 0px; margin-left: 0px;
margin-right: 0px;" align="bottom">
<param name="_Version" value="65536" />
<param name="_ExtentX" value="1323" />
<param name="_ExtentY" value="556" />
<param name="_StockProps" value="13" />
<param name="ForeColor" value="0" />
<param name="BackColor" value="15790320" />
<param name="UseButton" value="0" />
<param name="UseText" value="0" />
<param name="ControlLabel" value="See Also" />
<param name="UseIcon" value="0" />
<param name="Items" value="Guide$$**$$" />
<param name="Image" value="" />
<param name="FontInfo" value="Verdana,10,0,," />
<param name="_CURRENTFILEPATH" value="C:\LOCAL GUIDES\Sample_Guide\Guide_conventions.htm"
<param name="_ID" value="object1" />
<param name="DialogDisplay" value="1" />
<param name="Frame" value="" />
<param name="Window" value="" />
<param name="ChmFile" value="" />
<param name="DisableJump" value="0" />
</object>-->
<object
classid="clsid:ADB880A6-D8FF-11CF-9377-00AA003B7A11"
type="application/x-oleobject">
<param name="Command" value="ALink,MENU" />
<param name="Font" value="Verdana,10,0,," />
<param name="Item1" value="" />
<param name="Item2" value="Guide" />
</object>
<!--Metadata type="DesignerControl" endspan-->
<a href="javascript:object1.Click();"><img src="2012_related_topics.gif"
alt="" style="border: none;"
width="95" height="25" border="0" /></a></p>
</body>
Thanks for your help.
Adele
The second OBJECT tag is missing the ID. So if you just add it in it should work. I think double-clicking on the hidden control and clicking OK would probably add it in automatically.
Hi
Thanks for all your help.
Double-clicking the hidden control doesn't work.
By second object tag, do you mean?:
<object
</object>
I tried to add it in there, but it is removed each time. By the way, as background, from <!--Metadat...a to the first </object>-- appears green. The second <object... to </object> appears in the usual multi-colored HTML and then the <!--Metadata endspan is green again.
Could you show me the corrected entry?
Hi all
If memory serves, that's a bug that version 8 introduced. I believe that It strips out the tag. Unfortunately, you will probably struggle with this a bit.
Cheers... Rick
Hi Rick
Thanks. That gives me more weight for upgrading to RH9.
Looks like I will have to give up with this one for now.
Cheers
Adele
Amber
Thanks for the thread. I downloaded the scripts and they will do as a work around. We use both CHM and WebHelp and the scripts worked for each one.
Thanks again for all your help. I was sure I had added everything ok and was going crazy!
