13 Replies Latest reply: May 21, 2012 4:11 AM by hans-g. RSS
    Date picker
    manojb05 Community Member
      Dear all,
      I am try to incorporate a datepicker from jquirey some thing like http://jqueryui.com/demos/datepicker/#date-range
      How can in corporate in website plz help me. I am download entire thing but lots of thing clubed.
      Regards
      Manoj
        • 1. Re: Date picker
          hans-g. ACP/MVP
          Hello Manoj,
          nice to see you! What concerns "datepicker": can you see "New window"?
          Clicking there you will get a website only with the datepicker. From there you could copy the necessary parts of the source code:
          Good luck!
          Hans-Günter
          • 2. Re: Date picker
            thanks hans for your prompt reply. In any chance how can copy that .js file because some time i am working offline (if we have a .js file its a safer for future other wise in future link is any updation sort ofthing)
            • 3. Re: Date picker
              hans-g. ACP/MVP
              Hello Manoj,
              click his download menu, clik download again in th new website and you will see this:
              Click "speichern" (you will see store I think) > done.
              Hans-Günter
              • 4. Re: Date picker
                ya i am try it, some problem with coding because nothing happend with calander field?
                <!DOCTYPE html>
                <html lang="en">
                <head>
                          <meta charset="utf-8">
                          <title>jQuery UI Datepicker - Select a Date Range</title>
                          <link type="text/css" href="css/ui-lightness/jquery-ui-1.7.3.custom.css" rel="stylesheet" />
                                    <script type="text/javascript" src="js/jquery-1.3.2.min.js"></script>
                                    <script type="text/javascript" src="js/jquery-ui-1.7.3.custom.min.js"></script>
                                    <script type="text/javascript">
                                              $(function(){
                                                        // Accordion
                                                        $("#accordion").accordion({ header: "h3" });
                                                        // Tabs
                                                        $('#tabs').tabs();
                                                        // Dialog
                                                        $('#dialog').dialog({
        autoOpen: false,
        width: 600,
        buttons: {
        "Ok": function() {
        $(this).dialog("close");
        "Cancel": function() {
                                                        // Dialog Link
                                                        $('#dialog_link').click(function(){
        $('#dialog').dialog('open');
        return false;
                                                        // Datepicker
                                                        $('#datepicker').datepicker({
        inline: true
                                                        // Slider
                                                        $('#slider').slider({
        range: true,
        values: [17, 67]
                                                        // Progressbar
                                                        $("#progressbar").progressbar({
        value: 20
                                                        //hover states on the static widgets
                                                        $('#dialog_link, ul#icons li').hover(
        function() { $(this).addClass('ui-state-hover'); },
        function() { $(this).removeClass('ui-state-hover'); }
                                    </script>
                </head>
                <body>
                <div class="demo">
                <label for="from">From</label>
                <input type="text" id="from" name="from"/>
                <label for="to">to</label>
                <input type="text" id="to" name="to"/>
                </div><!-- End demo -->
                <div class="demo-description">
                <p>Select the date range to search for.</p>
                </div><!-- End demo-description -->
                </body>
                </html>
                • 5. Re: Date picker
                  sudarshan.t Community Member
                  Post an active link to your page.
                  • 6. Re: Date picker
                    hans-g. ACP/MVP
                    when these files are stored in your according directory/ies it should work.
                    Use an offline browser or load it up to your server to control it.
                    Hans-Günter
                    • 7. Re: Date picker
                      • 8. Re: Date picker
                        I think it is because you're missing the CSS file that defines the date picker popup styles.
                        <link rel="stylesheet" href="../demos.css">
                        as found in http://jqueryui.com/demos/datepicker/date-range.html
                        • 9. Re: Date picker
                          hans-g. ACP/MVP
                          Hello Manoj,
                          in addition to Sudarshan's hint about the missing "<link rel="stylesheet" href="../demos.css">" you should have a look whether you could download all the necessary files, needed for the datepicker. Here ist the original source code, maybe you could work first/again with it:
                          <!DOCTYPE html>
                          <html lang="en">
                          <head>
                          <link rel="stylesheet" href="../../themes/base/jquery.ui.all.css">
                          <script src="../../jquery-1.7.2.js"></script>
                          <script src="../../ui/jquery.ui.core.js"></script>
                          <script src="../../ui/jquery.ui.widget.js"></script>
                          <script src="../../ui/jquery.ui.datepicker.js"></script>
                          <script>
                          $(function() {
                            var dates = $( "#from, #to" ).datepicker({
                             defaultDate: "+1w",
                             changeMonth: true,
                             numberOfMonths: 3,
                             onSelect: function( selectedDate ) {
                              var option = this.id == "from" ? "minDate" : "maxDate",
                               instance = $( this ).data( "datepicker" ),
                               date = $.datepicker.parseDate(
                                instance.settings.dateFormat ||
                                $.datepicker._defaults.dateFormat,
                                selectedDate, instance.settings );
                              dates.not( this ).datepicker( "option", option, date );
                          </script>
                          </head>
                          <body>
                          <div class="demo">
                          </body>
                          </html>
                          Here my DW with your source code:
                          and here with the original source code:
                          As you can see that in your code are only three advices, the original code "wants" six.
                          ... and don't forget to control the pathes!
                          Hans-Günter
                          • 10. Re: Date picker
                            thanks hans-g. i am really sorry to late reply.
                            Please chek my link some alignment problem or some code is missing http://www.newtonclients.com/date/date-range.html
                            Master link
                            how can i rectify
                            • 11. Re: Date picker
                              hans-g. ACP/MVP
                              Hello manoj,
                              you should control control your pathes  > ../ or ../../ eg.
                              Hans-Günter
                              P.S.
                              Cant see a succes of my former maeesage.
                              • 12. Re: Date picker
                                my link all are in same directory. i dont get it, what path you saying
                                • 13. Re: Date picker
                                  hans-g. ACP/MVP
                                  look a bit more attentively at my screenshots from above
