1 2 3 Previous Next 88 Replies Latest reply on Jan 23, 2013 10:21 AM by ksulliv1 Go to original post Branched to a new discussion.
      • 40. Re: Acrobat 10.1.3 crash on quit
        ArchiPhone
        Some news from Enfocus?
        • 41. Re: Acrobat 10.1.3 crash on quit
          KCH LTD Level 1
          How about some news from Adobe?
          • 42. Re: Acrobat 10.1.3 crash on quit
            DAMiller468
            Haven't heard anything from Adobe or Enfocus here.
            • 43. Re: Acrobat 10.1.3 crash on quit
              SenorMano Level 1
              Experiencing the same issue here, and failing to comprehend why it seems that Adobe cannot release a stable build of Acrobat Pro X.
              After update to 10.1.3 in Windows 7 64-bit environment, Acrobat Pro X will intermittently crash when you close a document.
              Event Log error reported as:
              Faulting application name: Acrobat.exe, version: 10.1.3.23, time stamp: 0x4f7bc871
              Faulting module name: Acrobat.dll, version: 10.1.3.23, time stamp: 0x4f7bd9b8
              Exception code: 0xc0000005
              Fault offset: 0x000bdf75
              Faulting process id: 0xb38
              Faulting application start time: 0x01cd217dec47838a
              Faulting application path: C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe
              Faulting module path: C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.dll
              Report Id: 300c550a-8d71-11e1-afe4-5c260a306abe
              • 44. Re: Acrobat 10.1.3 crash on quit
                KCH LTD Level 1
                SenorMano -- (For me), Acrobat doesn't crash if I keep a PDF file open -- I can then open and close other PDFs without a hitch. It's a lame workaround, but it seems to work so it's my solution until Adobe addresses the problem.
                • 45. Re: Acrobat 10.1.3 crash on quit
                  SenorMano Level 1
                  Thanks KCH -- and Acrobat works if you relaunch it.
                  It just seems plain unacceptable that Adobe introduced this error in an update and refuses to acknowledge the issue. This is a least the second time they've made Acrobat X less stable with an update -- and this one was supposed to fix the "crash on preflight" issue in 10.1.2  (See https://blogs.adobe.com/dmcmahon/2012/01/25/acrobat-10-1-2-adobe-acrobat-has-stopped-worki ng-when-using-preflight/).
                  • 46. Re: Acrobat 10.1.3 crash on quit
                    KCH LTD Level 1
                    Yes ... maybe Adobe is saving it's best effort for CS6, shipping in May.
                    • 47. Re: Acrobat 10.1.3 crash on quit
                      KCH LTD Level 1
                      Er ... its best effort. You know what I mean.
                      • 48. Re: Acrobat 10.1.3 crash on quit
                        vamalik
                        Hi SenorMano,
                        I see that you are constantly facing this problem on your machine. Can you provide me the crash dump from of Acrobat to investigate the issue. The method to obtain crash dump is mentioned below:
                        On Windows 7 machine, when your Acrobat crashes, go to Task Manager->Processes and right click on Acrobat.exe process. There will be an option to create dump file. Select that option and share across this dump file via any file sharing server. You can paste the link to that file here.
                        • 49. Re: Acrobat 10.1.3 crash on quit
                          dennishenley
                          I am also experiencing the crash on quitting from Acrobat Pro X 10.1.3. It doesn't matter if I have opened a PDF for not. When I hold down the shift key to start Acrobat without plugins I get an instant crash.
                          This is happening on my work machine (Mac Pro Quad-Core Intel Xeon running 10.6.8) and my home machines (Macbook Pro and iMac, but with 10.7.3). This only happened after the update to 10.1.3.
                          I have also checked three other work machines at my company, all of which have been upgraded to 10.1.3 and they all experience the same issue, crashing on quitting.
                          Dennis
                          • 50. Re: Acrobat 10.1.3 crash on quit
                            SenorMano Level 1
                            Vamalik:
                            The dump file is over 200 MB. What all is included in there?
                            • 51. Re: Acrobat 10.1.3 crash on quit
                              vamalik Level 2
                              Hi SenarMano,
                              Crash dump contains the stack trace and other process related information at the time of crash.
                              You can compress this file via WinRar or any other similar utility so that its size gets reduced and then upload it on any file sharing server like DropBox, MegaUpload, etc. Then paste link to the same here.
                              Do you have any third party plugin installed in your Acrobat??? What happens if you remove it and open pdfs???
                              If it is possible for you to arrange a virtual meeting via Adobe Connect to let me investigate the issue on your machine, then kindly let me know the suitable date and time. I'll arrange for the same.
                              • 52. Re: Acrobat 10.1.3 crash on quit
                                Rutger2
                                Just in case Adobe have not yet realized; Acrobat 10.1.3 update causes Acrobat to crash on exit - for almost everyone (and certainly everyone who is using plugins such as Pitstop Pro)!
                                Asking for people to send 'crash dumps' just seems like time-wasting. It is an extremely simple matter to reproduce the fault on any machine (I know becuaes I've seen it on countless machines now).
                                Please fix it!
                                • 53. Re: Acrobat 10.1.3 crash on quit
                                  AbhigyanModi Adobe Employee
                                  Dear user "Rutger2"
                                  We (at Adobe) have been making extensive attempts to reproduce the crash that you are seeing but haven't been able to. The buid is deployed on thousands of machines internally at Adobe and millions outside. All that we have been able to see so far is a crash with PitStop. We are working with folks at Pitstop - while it is true that 10.1.3 caused the crash, the cause was a fix we made which we believe is correct. Pitstop engineering is woking on a fix.
                                  That isn't to say that there isn't another problem, it's just that we haven't been able to see it despite all our attempts. If you or others could work with  Vaibhav (vamalik) in providing the crash dumps, it would help us in narrowing down the problem and fixing it.
                                  thanks
                                  abhigyan
                                  1 person found this helpful
                                  • 54. Re: Acrobat 10.1.3 crash on quit
                                    m0m0.1234567890
                                    dear AbhigyanModi
                                    i don't think it needs extensive attempts to recreate the error. my resources are quite limited and it took me no more than 5 minutes to achieve the crash on exit, on every machine I tried (mac only so far).
                                    the fixes we are supposed to get eventually always turn into payable upgrades leaving us no choice but to go the dictated path of throwing more money at it. i know how much development costs and appreciate all your efforts in making your apps as useful, feature rich and stable as possible but i still dream of the days when illustrator used to run no matter what (your last resort on an unstable system) and Photoshop all of a sudden came up with layers (a real improvement in comparison to content aware fills or deletes). now i might be mistaken but i bet on the pitstop fix being the payable upgrade to version 11. prove me wrong and I'll carry your flags to Rome.
                                    kind regards
                                    one happy adobe customer (no, really! check my order history)
                                    • 55. Re: Acrobat 10.1.3 crash on quit
                                      Rutger2 Level 1
                                      Pitstop 11 doesn't fix the problem - Acrobat 10.1.3 still 'crashes' on exit.
                                      As part of my job I visit print shops and design houses - most of them use Pitstop. Some of them have excitedly installed the trial of Pitstop 11 thinking it would cure various bugs. While people say Pitstop 11 itself is noticeably faster and better than v10, it does not fix Acrobat crashing. Expect you'll have to wait for 11.0.1 for that!
                                      • 56. Re: Acrobat 10.1.3 crash on quit
                                        vamalik Level 2
                                        Hi Rutger2,
                                        We make all possible attempts to reproduce the issues faced by our customers. However, there is a considerable difference between a typical user machine and a typical test machine. Therefore, we ask users for crash logs/dumps in case we are not able to reproduce the issue at our end.
                                        Using Pitstop 11, we haven't experienced any crash in Acrobat. So maybe there is some other problem on your machine. If you can provide us the crash log, we will investigate the issue and try to solve your and other users' problems.
                                        Steps to create Crash Dump, if you are working on Windows7 machine:
                                        1) As soon as Acrobat crashes, open Task Manager.
                                        2) Go to Processes tab and select Acrobat.exe process.
                                        3) Right Click on the Acrobat process and select Create Dump File.
                                        On Mac machines:
                                        1) When Crash dialog appears, select "Report"
                                        2) Copy the log text and paste it in a text file.
                                        Compress and share the log/dump file created via some file sharing server.
                                        • 57. Re: Acrobat 10.1.3 crash on quit
                                          klasinger Level 1
                                          As you wish, we send more crash reports:
                                          http://dl.dropbox.com/u/7143285/acro11crash/acro11dump.zip
                                          But does this help? For you information: anybody i know has the same problem with 10.1.3. So i cant understand what the problem to reproduce it? Is it possible to buy your testing mashines, seems to be real great stuff.
                                          In the meantime a patch should be appropriate? We talking about this since weeks.
                                          • 58. Re: Acrobat 10.1.3 crash on quit
                                            DAMiller468 Level 1
                                            We can reproduce this crash problem on all workstations, running Acrobat 10.1.3 and PitStop 10. We have not received a working solution from Adobe nor Enfocus.
                                            Unfortunately, we rely on the PitStop plug-in for our workflow. This problem is concerning and hinders productivity. Our confidence in Adobe’s and Enfocus’ ability to produce software that actually works together is low. Especially now that Adobe has switch to a one-year release cycle.
                                            We have decided to roll back to versions of the software that worked together.
                                            • 59. Re: Acrobat 10.1.3 crash on quit
                                              MightyMM
                                              Same problem here, my collegues also, OS10.6.8 Acrobat pro 10.1.3. But we work with Instant PDF. We can also reproduce the crash problem on all workstations.
                                              • 60. Re: Acrobat 10.1.3 crash on quit
                                                PrepKey
                                                I have the same problem. Acrobat version 10.1.3 crashes on exit.  I believe it is causing my copy of Quite Imposing Plus to lose its license information and revert to demo mode each time Acrobat restarts. I've been in touch with Quite Imposing but they have not been able to resolve the issue.
                                                I have Pitstop Pro 10, Update 3 and Quite Imposing Plus 3.0c installed. I'm on Mac OSX 10.7.4. The crash occurs any time acrobat closes, weither a PDF is open or not.
                                                Below is the crash report generated when Acrobat closes:
                                                http://dl.dropbox.com/u/23705003/CrashReport.txt
                                                • 61. Re: Acrobat 10.1.3 crash on quit
                                                  XOZ123abc
                                                  I also have this problem using acrobat 10.1.3 with pitstop pro version 10 update 1 on MAC OSX 10.6.8 every time you quit out of acrobat it crashes, sometimes when you close a document it crashes.  It doesn't seem to be saving my preferences upon closing Acrobat either.
                                                  • 62. Re: Acrobat 10.1.3 crash on quit
                                                    vamalik Level 2
                                                    Hi rutger2, m0mo.1234567890 and klasinger,
                                                    We could reproduce one of the crash scenario - Acrobat 10.1.3 and Pitstop 10, in which the issue was there because of some mismatch between Acrobat and Pitstop plugin. For that Pitstop had provided a fix in their new version of plugin (Pitstop 11). We had verified this new plugin at our end and seeing no crash intimated to everyone on this forum to update their pitstop plugins.
                                                    However, as some of you have reported crash with Pitstop plugin 11 also, we have tried many different possible scenarios to get to the root of this new crash but without any success. And therefore I am asking different users to send their crash reports to us, because it is one way to investigate problems in real world environments.
                                                    All things apart, one more thing we can do is directly analyse the Acrobat installation on your machine. For this, if it is possible for you to arrange a virtual meeting via Adobe Connect to let me investigate the issue on your machine, then kindly let me know the suitable date and time. I'll arrange for the same.
                                                    • 63. Re: Acrobat 10.1.3 crash on quit
                                                      pr1ntd3s1gn3r
                                                      I knew from day 1 it was going to come down to buying Pitstop 11 to fix this.  Since I just upgraded to Pitstop 10 not too long ago, I'm just going to re-install Acrobat, stop updates at 10.1.2 and start looking at some of the newer Acrobat alternatives.  Getting pretty sick of the release cycle and quality of releases lately.
                                                      • 64. Re: Acrobat 10.1.3 crash on quit
                                                        XOZ123abc Level 1
                                                        I would like you to look at my machine, how long will it take?  The issue is that with a production machine there is no scheduling, if a customer walks in the door, you're busy.     -Thomas Cahill
                                                        Cannelli Printing Co., Inc.39 Wood StreetWest Haven, CT 06516Tel:  203-932-1719Fax: 203-932-2737www.cannelli.com
                                                        • 65. Re: Acrobat 10.1.3 crash on quit
                                                          XOZ123abc Level 1
                                                          Here is my crash report that occurs every time I close out of Acrobat:
                                                          Process:         AdobeAcrobat Path:            /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobatIdentifier:      com.adobe.Acrobat.ProVersion:         10.1.3 (10.1.3)Code Type:       X86 (Native)Parent Process:  launchd
                                                          Date/Time:       2012-05-16 10:30:17.274 -0400OS Version:      Mac OS X 10.6.8 (10K549)Report Version:  6
                                                          Interval Since Last Report:          20438323 secCrashes Since Last Report:           268Per-App Interval Since Last Report:  1041516 secPer-App Crashes Since Last Report:   35Anonymous UUID:                      32162B99-9519-4720-AD1A-22A9BEE34917
                                                          Exception Type:  EXC_BAD_ACCESS (SIGSEGV)Exception Codes: KERN_INVALID_ADDRESS at 0x000000002bfdba46Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                                          Thread 0 Crashed:  Dispatch queue: com.apple.main-thread0   ???                                0x2bfdba46 0 + 7380485821   com.adobe.Acrobat.framework        0x0001e8f6 RunAcrobat + 620412   com.adobe.Acrobat.framework        0x00057191 RunAcrobat + 2936203   com.adobe.Acrobat.framework        0x005370f2 AcroSecurityBailOutImpl + 13714744   com.adobe.Acrobat.framework        0x0077fcca AcroSecurityBailOutImpl + 37665705   com.adobe.Acrobat.framework        0x0060683a AcroSecurityBailOutImpl + 22212106   com.adobe.Acrobat.framework        0x0039bf56 AcroBundleThreadQuitProc + 32267   com.adobe.Acrobat.framework        0x0000f7e1 RunAcrobat + 3248   com.adobe.Acrobat.Pro              0x00001e92 main + 949   com.adobe.Acrobat.Pro              0x00001e16 start + 54
                                                          Thread 1:  Dispatch queue: com.apple.libdispatch-manager0   libSystem.B.dylib                  0x97a8d382 kevent + 101   libSystem.B.dylib                  0x97a8da9c dispatchmgr_invoke + 2152   libSystem.B.dylib                  0x97a8cf59 dispatchqueue_invoke + 1633   libSystem.B.dylib                  0x97a8ccfe dispatchworker_thread2 + 2404   libSystem.B.dylib                  0x97a8c781 pthreadwqthread + 3905   libSystem.B.dylib                  0x97a8c5c6 start_wqthread + 30
                                                          Thread 2:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 3:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 4:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 5:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 6:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 7:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 8:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 9:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 10:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 11:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 12:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 13:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 14:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 15:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 16:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   ...ple.CoreServices.CarbonCore     0x91e0821e TSWaitOnCondition + 1264   ...ple.CoreServices.CarbonCore     0x91df3b68 TSWaitOnConditionTimedRelative + 2025   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2506   AdobeACE                           0x01f5a737 ACEInitialize + 37417   AdobeACE                           0x01f5a6ad ACEInitialize + 36038   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 689   libSystem.B.dylib                  0x97a94259 pthreadstart + 34510  libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 17:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   AdobeAGM                           0x020a779c AGMInitialize + 337704   AdobeAGM                           0x020a76d6 AGMInitialize + 335725   AdobeAGM                           0x020a7231 AGMInitialize + 323836   libSystem.B.dylib                  0x97a94259 pthreadstart + 3457   libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 18:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   AdobeAGM                           0x020a779c AGMInitialize + 337704   AdobeAGM                           0x020a76d6 AGMInitialize + 335725   AdobeAGM                           0x020a7231 AGMInitialize + 323836   libSystem.B.dylib                  0x97a94259 pthreadstart + 3457   libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 19:0   libSystem.B.dylib                  0x97a94aa2 __semwait_signal + 101   libSystem.B.dylib                  0x97a9475e pthreadcond_wait + 11912   libSystem.B.dylib                  0x97a963f8 pthread_cond_wait$UNIX2003 + 733   AdobeAGM                           0x020a779c AGMInitialize + 337704   AdobeAGM                           0x020a76d6 AGMInitialize + 335725   AdobeAGM                           0x020a7231 AGMInitialize + 323836   libSystem.B.dylib                  0x97a94259 pthreadstart + 3457   libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 20:0   libSystem.B.dylib                  0x97a66b5a semaphore_timedwait_signal_trap + 101   libSystem.B.dylib                  0x97a946e1 pthreadcond_wait + 10662   libSystem.B.dylib                  0x97ac35a8 pthread_cond_timedwait_relative_np + 473   ...ple.CoreServices.CarbonCore     0x91df3b90 TSWaitOnConditionTimedRelative + 2424   ...ple.CoreServices.CarbonCore     0x91def533 MPWaitOnQueue + 2505   com.adobe.Acrobat.framework        0x00069705 RunAcrobat + 3687446   com.adobe.Acrobat.framework        0x00069417 RunAcrobat + 3679947   ...ple.CoreServices.CarbonCore     0x91dd354a PrivateMPEntryPoint + 688   libSystem.B.dylib                  0x97a94259 pthreadstart + 3459   libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 21:0   libSystem.B.dylib                  0x97a66b42 semaphore_wait_signal_trap + 101   libSystem.B.dylib                  0x97a946f8 pthreadcond_wait + 10892   libSystem.B.dylib                  0x97add05f pthread_cond_wait + 483   com.adobe.amt.services             0x3631ff2c C_AMTUISwitchSuppressUpdates + 168644   com.adobe.amt.services             0x36318e78 C_EULA_SetState + 21665   com.adobe.amt.services             0x3631ff92 C_AMTUISwitchSuppressUpdates + 169666   libSystem.B.dylib                  0x97a94259 pthreadstart + 3457   libSystem.B.dylib                  0x97a940de thread_start + 34
                                                          Thread 22:0   libSystem.B.dylib                  0x97a8c412 __workq_kernreturn + 101   libSystem.B.dylib                  0x97a8c9a8 pthreadwqthread + 9412   libSystem.B.dylib                  0x97a8c5c6 start_wqthread + 30
                                                          Thread 23:0   libSystem.B.dylib                  0x97a8c412 __workq_kernreturn + 101   libSystem.B.dylib                  0x97a8c9a8 pthreadwqthread + 9412   libSystem.B.dylib                  0x97a8c5c6 start_wqthread + 30
                                                          Thread 0 crashed with X86 Thread State (32-bit):  eax: 0x31559cd0  ebx: 0x00057471  ecx: 0xa08454c0  edx: 0x00000000  edi: 0x315560d0  esi: 0x0000005d  ebp: 0xbffff7c8  esp: 0xbffff78c   ss: 0x00000023  efl: 0x00010246  eip: 0x2bfdba46   cs: 0x0000001b   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f  cr2: 0x2bfdba46
                                                          Binary Images:    0x1000 -     0x1fff +com.adobe.Acrobat.Pro 10.1.3 (10.1.3) <FCB16A78-77BB-D7C8-C51A-ABEA7442F48A> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat    0x6000 -  0x1ccdfef +com.adobe.Acrobat.framework 10.1.3 (10.1.3) <ED42701D-927F-4DF1-66FE-143BD16D2EBD> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat 0x1f58000 -  0x2079fff +AdobeACE ??? (???) <AED28AAB-6A04-E665-22B2-DBED624F1D0E> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE 0x209c000 -  0x2661feb +AdobeAGM ??? (???) <807014CE-E064-5B60-D459-389CE0B3CDB2> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM 0x2714000 -  0x2731ff7 +AdobeBIB ??? (???) <E6E0225B-3F17-013B-041D-69A0F42461F8> /Applications/Adobe Acrobat X Pro/Adobe Acrobat
                                                          Pro.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB 0x2738000 -  0x2a5cfe3 +com.adobe.CoolType AdobeCoolType 5.08.113.1 (5.08.113.1) <A2DE878B-3EDA-7E56-8F19-2E9901996483> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType0x28105000 - 0x28106ff7  ATSHI.dylib ??? (???) <F06AB560-C2AF-09F6-7328-773E43CA2713> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib0x28509000 - 0x2850dff7  com.apple.CommonCocoaPanels 4.0 (16) <30D57C5A-2C5E-3A3E-A9D8-F5E968322AD6> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels0x2 85da000 - 0x285deff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn0x28c2d000 - 0x28e25ff7
                                                          +com.adobe.Acrobat.adm 10.1.3 (10.1.3) <6C417E91-8B8F-743F-8539-B88A9C1524B1> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/SPPlugins/AdobeADM.bundle/Contents/MacOS/AdobeADM0x2e2ad000 - 0x2e482ff3 +libQtCoreEnfocus453.4.dylib 4.5.3 (compatibility 4.5.0) <EAD2C77F-2A60-E0B2-EE3E-9AFC53F30D8B> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/Enfocus/Resources/Qt/libQtCoreEnfocus453.4.dylib0x2e519000 - 0x2ed0ffe7 +libQtGuiEnfocus453.4.dylib 4.5.3 (compatibility 4.5.0) <424E5E5B-A8B7-3A73-1C5D-E4568A66F040> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/Enfocus/Resources/Qt/libQtGuiEnfocus453.4.dylib0x30dbc000 - 0x30e19fff +AdobeXMP ??? (???) <E3A59E8C-A514-8A4A-F965-E9C043C7AC96> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP0x30e22000 - 0x3100bffb +com.nsoftware.ipworks ??? (IPWorks 6.1)
                                                          <799A2785-B75A-780E-B497-698440D528C6> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/Enfocus/Resources/IPWorks.framework/IPWorks0x311d0000 - 0x311f6ffb +AdobeBIBUtils ??? (???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils0x31696000 - 0x316befff +AdobeAXE8SharedExpat ??? (???) <6DE8E2CA-91EC-77D7-E674-D336B7D09AF5> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t0x316c5000 - 0x316cbff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn0x316d2000 - 0x316daff3  com.apple.URLMount.AFPPlugin 3.2.2 (3.2.2) <46711A0E-D330-BD32-8B30-1FFE8B3346F0>
                                                          /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp0x316fb000 - 0x31703fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/asneu.framework/Versions/A/asneu0x3174a000 - 0x3175cff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <08801444-00D2-E55B-AE80-B807B99BB0C6> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib0x3182c000 - 0x3189cfeb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps0x31c79000 - 0x31cb2ff3 +AdobeARE ??? (???) <E5933339-72CF-4821-A7D7-9629ACCF0872> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE0x31cd1000 - 0x31d30fe7
                                                          +AcroSQLite ??? (???) <08BCB05D-BB30-1E7F-E2FE-FA249DA67F66> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite0x31d68000 - 0x31d76fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <AFA4C3C8-D752-EC96-FF56-6E2F8ABB391B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib0x32fc9000 - 0x33036ffb +com.adobe.amtlib amtlib 3.5.0.34 (3.5.0.34) <8C1EBC9E-DDFF-660B-03FB-196CE8A4CED8> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/amtlib.framework/amtlib0x339b1000 - 0x339f8ff7  com.apple.AppleShareClientCore 2.1 (2.1) <351D93FA-D8AB-657F-2A67-9A6FF3875F82> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore 0x34045000 - 0x34047ff7  com.apple.printingprivate.framework.PrintingPrivate 6.1 (15.2) <1A6E0614-420C-1E2B-43DA-722639B1FBCB>
                                                          /System/Library/PrivateFrameworks/PrintingPrivate.framework/PrintingPrivate0x35700000 - 0x35c54fef +PitStop Pro_libFNP.dylib ??? (???) <2B3C8EC0-57F3-8E0E-9DB6-2C5E3C2755CD> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/Enfocus/PitStop Pro.acroplugin/Contents/MacOS/PitStop Pro_libFNP.dylib0x36200000 - 0x362b5fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib0x362fb000 - 0x36362fe7 +com.adobe.amt.services AMTServices 3.5.0.34 (BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00) (3.5.0.34) <F56D7855-B0F7-4E7E-1997-D4FC2F5ACB2D> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices0x36700000 - 0x367c9fe7 +AdobeJP2K ??? (???) <7A622F2A-B71F-20FD-CD4A-F7B298F6ECC5> /Applications/Adobe Acrobat X Pro/Adobe Acrobat
                                                          Pro.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K0x39c00000 - 0x3a62afe3 +com.macromedia.Flash Player.authplaylib 10.3.183.18 (10.3.183.18) <C9B0F37E-EAB8-9FD8-8ACE-4280081CEA9C> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <749D24EE-54BD-D74B-D305-C13F5E6C95D8> /usr/lib/dyld0x90003000 - 0x900f7ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib0x90206000 - 0x90263ff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit0x90264000 - 0x9029cff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP0x9029d000 - 0x9031dfeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9>
                                                          /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit0x9048e000 - 0x904cbff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration0x 904cc000 - 0x90597fef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices0x90598000 - 0x9059dff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory0x90701000 - 0x907b9feb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib0x907ba000 - 0x907f8ff7
                                                           com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook0x9080a000 - 0x90850ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib0x90851000 - 0x90858ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print0x90859000 - 0x9086dfe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib0x9086e000 - 0x908cffe7  com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText0x908d0000 - 0x909d2fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib0x909d3000 - 0x90a15ff7
                                                           libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib0x90a16000 - 0x90a1eff7  com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices0x9 0a1f000 - 0x90d19fef  com.apple.QuickTime 7.6.6 (1790) <A5B2CDA8-47C9-F1AE-ED54-625B0FAB426F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime0x90d33000 - 0x90de1ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink0x90de2000 - 0x90f64fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib0x90f85000 - 0x90f85ff7  com.apple.ApplicationServices 38 (38)
                                                          <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices0x 90f86000 - 0x90fa4fe7  libPng.dylib ??? (???) <45185287-25AD-C239-AA58-8FA53DF55B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib0x90fa5000 - 0x912c9fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox0x913c6000 - 0x913c9ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib0x913ca000 - 0x91467fe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E>
                                                          /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices0x91468000 - 0x914beff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime0x914c2000 - 0x914c9ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <61A74CE1-750D-9CAB-B780-306841739EE1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL0x914ca000 - 0x914d6ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib0x914fe000 - 0x9153fff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib0x91540000 - 0x91583ff7  com.apple.NavigationServices 3.5.4 (182)
                                                          <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices0x91584000 - 0x915c8fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata0x915c9000 - 0x916c9fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib0x916ca000 - 0x916f4ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut0x916f5000 - 0x917cffff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv0x917d0000 - 0x917d1ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7)
                                                          <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit0x917d2000 - 0x917e3ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis0x917e4000 - 0x9187ffe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS0x91a96000 - 0x91adaff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI0x91dad000 - 0x920cdff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore0x920ce000 - 0x92589ff7
                                                           com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox0x9258a00 0 - 0x92636fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork0x92637000 - 0x9275ffe7  com.apple.WebKit 6534.57 (6534.57.2) <4CB86278-4657-3503-8042-074628222DF3> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit0x92760000 - 0x927b8fe7  com.apple.datadetectorscore 2.0 (80.7) <58C659CA-72CC-31D2-9732-09BF1A0CAAF6> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e0x9290e000 - 0x92911ff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib0x9 2912000 - 0x9291dff7  libCSync.A.dylib
                                                          545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib0x9291e000 - 0x9298dff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib0x9298e000 - 0x929fcff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI0x929fd000 - 0x92a2dff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit0x92a2e000 - 0x92a31fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E>
                                                          /usr/lib/system/libmathCommon.A.dylib0x92a5c000 - 0x92a62ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib0x92a63000 - 0x92b90ffb  com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox0x93ae500 0 - 0x93ae5ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib0x93aee000 - 0x93b28ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <038731B1-CC44-3943-E3DE-4BAAA203EB72> /usr/lib/libcups.2.dylib0x93b29000 - 0x93b48ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo0x93b49000 -
                                                          0x93b84ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib0x93b8e000 - 0x93b8eff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa0x9421a000 - 0x943ddfeb  com.apple.ImageIO.framework 3.0.5 (3.0.5) <87750C2B-193F-56A6-AB97-0842A2D02092> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO0x943de000 - 0x945c0fff  com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit0x945c1000 - 0x945c3ff7  com.apple.securityhi 4.0 (36638) <C7DA80C1-DCFD-C321-08DA-5E6946CA66E0>
                                                          /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI0x945c4000 - 0x9463dff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit0x94643000 - 0x949aeff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore0x949af000 - 0x95727fe7  com.apple.WebCore 6534.57 (6534.57.2) <6AF29D9A-F549-5BE7-3842-CFF75FC46360> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore0x95816000 - 0x958aefe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos0x958af000 - 0x95d94ffb  com.apple.RawCamera.bundle 3.12.0 (614) <A2B304C1-1E8D-AAB1-14F6-11462C666C82>
                                                          /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera0x95d95000 - 0x95dfffe7  libstdc+.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc+.6.dylib0x95e00000 - 0x95e10ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers0x95e 97000 - 0x95ecaff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE0x95ede000 - 0x95ee0ff7  libRadiance.dylib ??? (???) <98EC06D5-1A02-EDEF-BF9D-2C986761AD54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib0x95ee1000 - 0x95ee1ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF>
                                                          /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate0x95ee2000 - 0x95fb3fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib0x95fb4000 - 0x95fb4ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib0x95fb5000 - 0x95fbbfff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels0x95fbc000 - 0x963d2ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib0x963f1000 - 0x9644bfe7  com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0>
                                                          /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF0x9644c000 - 0x96c3b557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics0x96c3c000 - 0x96c8cff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls0x96c 8d000 - 0x96c91ff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib0x96c9 2000 - 0x96caaff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory0x96d33000 - 0x96d3eff7  libGL.dylib ??? (???)
                                                          <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib0x96d44000 - 0x96dd6fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore0x96e0a000 - 0x96f16fe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib0x96f17000 - 0x96f91fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio0x96f92000 - 0x9716bfff  libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib0x9716c000 - 0x9729afe7
                                                           com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData0x9729b000 - 0x972bfff7  libJPEG.dylib ??? (???) <5F2343E4-C268-B9AE-1BC3-466F5A614648> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib0x972c0000 - 0x97526ff7  com.apple.security 6.1.2 (55002) <E999CCEF-B769-4355-3E68-6003FCF6FE2B> /System/Library/Frameworks/Security.framework/Versions/A/Security0x97527000 - 0x9753cfff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture0x9753d000 - 0x9753dff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices0x9753e000 - 0x9753fff7  com.apple.MonitorPanelFramework 1.3.0
                                                          (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel0x9754000 0 - 0x97576fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib0x975f5000 - 0x975f9ff7  libGIF.dylib ??? (???) <5D29E5F4-30B9-5A24-55E7-BCBA30499093> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib0x975fa000 - 0x97603ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration0x97604000 - 0x97614ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib0x976cc000 - 0x976fffff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685>
                                                          /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib0x97722000 - 0x97730fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib0x97731000 - 0x97732ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent0x97733000 - 0x97776ff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib0x97777000 - 0x9777bff7  IOSurface ??? (???) <235E7E3D-B6E5-0AAA-C41A-7AC1F54A7EBF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface0x9781d000 - 0x97839fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9>
                                                          /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting0x9783a000 - 0x97977fe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox0x97978000 - 0x979dcffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering0x979ea000 - 0x97a65fff  com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA0x97a66000 - 0x97c0dff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib0x97c97000 - 0x97ce6fe7  libTIFF.dylib ??? (???) <D0EB31DC-40E6-9A97-64D3-9867605DC3DD>
                                                          /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib0x97ce7000 - 0x97cf5ff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL0x97d2c000 - 0x97dd4ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD0x97dd5000 - 0x9820aff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib0x9820b000 - 0x98215fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound0x98216000 - 0x982d2fff
                                                           com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync0x982f2000 - 0x985a0fe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore0x985a1000 - 0x9865afe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib0x9865b000 - 0x98665ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition0x98666000 - 0x98666ff7  com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz0x98667000 - 0x986a1fe7  libssl.0.9.8.dylib
                                                          0.9.8 (compatibility 0.9.8) <C62A7753-99A2-6782-92E7-6628A6190A90> /usr/lib/libssl.0.9.8.dylib0x986a8000 - 0x98823fe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation0x98824000 - 0x98967fef  com.apple.QTKit 7.7 (1790) <95F7C69A-1D24-A96A-E95D-1DF8CCD03FB3> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit0x98968000 - 0x98999ff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib0x9899a0 00 - 0x9899aff7  com.apple.Carbon 150 (152) <734BDB59-8B13-54FA-0653-AA8623DF9846> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon0x98a7a000 - 0x98a9bfe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL0x98ad8000 - 0x98affff7  com.apple.quartzfilters 1.6.0
                                                          (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters0x98b00000 - 0x98badfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib0x98bae000 - 0x98bc0ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t0x98bc1000 - 0x98c14ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices0x98c15000 - 0x98c15ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib0x98c16000 - 0x98c36fe7
                                                           libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib0x98c37000 - 0x98c44ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS0x98fb8000 - 0x990bafef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO0x990c7000 - 0x990d1ff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData0x9914a000 - 0x993bbfef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation0x993bc000 - 0x993defef  com.apple.DirectoryService.Framework 3.6 (621.14) <A24C9308-4EB3-456D-1691-43DDB6F9A79F>
                                                          /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService0x993df0 00 - 0x99cc2ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit0x99cc3000 - 0x99eeeff3  com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer0x99eef000 - 0x99ef2ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help0x99ef3000 - 0x99f38ff7  com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore0x99f390 00 - 0x9a019fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C>
                                                          /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage0x9a080000 - 0x9a0a6ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices0x9a0a7000 - 0x9a0eeffb  com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices0x9a0ef000 - 0x9a103ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis0x9a96c000 - 0x9a994ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib0x9a995000 - 0x9a9e2feb
                                                           com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer0x9a9 e3000 - 0x9a9e9fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore0x9a9ea000 - 0x9aa27ff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia0x9aa28000 - 0x9aaaaffb  SecurityFoundation ??? (???) <2E1F1AF0-A258-D215-2600-5DF03896D1F1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation0xba 300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <80E8C2F7-3210-7A58-F083-F24AF7075E79> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib0xba500000 -
                                                          0xba501ff7  libGreekConverter.dylib 49.0.0 (compatibility 1.0.0) <02C6817E-B73A-6C2E-7575-9B73AFDA19FE> /System/Library/CoreServices/Encodings/libGreekConverter.dylib0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <02CCC192-2AC9-73DF-4A40-0B3AF87B6372> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <8697CB9C-AC3B-301B-F1BD-382E30FA5642> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib0xbb500000 - 0xbb500ff7  libThaiConverter.dylib 49.0.0 (compatibility 1.0.0) <0B67094E-3A8B-5E3E-E529-A3574EE78DC8> /System/Library/CoreServices/Encodings/libThaiConverter.dylib0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
                                                          Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 6 GB, SMC 1.39f11Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MBMemory Module: global_nameAirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.42.4)Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial portsNetwork Service: Ethernet 1, Ethernet, en0Network Service: AirPort, AirPort, en2PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1Serial ATA Device: HL-DT-ST DVD-RW GH61NSerial ATA Device: WDC WD1001FALS-41Y6A0, 931.51 GBUSB Device: My Passport 0740, 0x1058  (Western Digital Technologies, Inc.), 0x0740, 0xfa200000 / 2USB Device: EPSON Scanner, 0x04b8  (Seiko Epson Corp.), 0x0129, 0xfd300000 / 3USB Device: Hub, 0x05ac  (Apple Inc.), 0x9126, 0xfd100000 / 2USB Device: i-Key, 0x04b9  (Rainbow Technologies, Inc.), 0x1000, 0xfd120000 / 8USB Device: Keyboard Hub, 0x05ac  (Apple
                                                          Inc.), 0x1006, 0xfd130000 / 7USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0xfd132000 / 9USB Device: Display iSight, 0x05ac  (Apple Inc.), 0x8508, 0xfd150000 / 6USB Device: Apple LED Cinema Display, 0x05ac  (Apple Inc.), 0x9226, 0xfd160000 / 5USB Device: Display Audio, 0x05ac  (Apple Inc.), 0x1105, 0xfd140000 / 4USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x5a110000 / 4FireWire Device: built-in_hub, Up to 800 Mb/sec
                                                          • 66. Re: Acrobat 10.1.3 crash on quit
                                                            Thomas - thanks for the information and the logs. You seem to be using PitStop Pro and there is a known problem with version 10 of Pitstop. The Pitstop team has fixed the issue in their latest version (Pitstop 11). Can you try again after either uninstalling PitStop or installing the latest version from their website.
                                                            • 67. Re: Acrobat 10.1.3 crash on quit
                                                              XOZ123abc Level 1
                                                              AbhigyanModi,    Thank you for the information, I also sent the same information to Enfocus and have not received any reply.
                                                              • 68. Re: Acrobat 10.1.3 crash on quit
        KCH LTD Level 1
        This is all well and good, but it does not help those of us experiencing problems who do not use PitStop. Based on this thread, I'm not the only one ...
        • 69. Re: Acrobat 10.1.3 crash on quit
        Dear user "KCH LTD" - would you be willing to work with us on the crash that happens without Pitstop. We haven't been able to reproduce the problem without Pitstop. If you are, please send me your email  information  in a private message and me and I'll have someone get in touch with you. thanks.
        • 70. Re: Acrobat 10.1.3 crash on quit
        XOZ123abc Level 1
        You may have sent me this in error, I am using Pitstop and I am not the user "KCH LTD"
        -Thomas Cahill "xoz123"
        • 71. Re: Acrobat 10.1.3 crash on quit
        leen_v
        The introduced changes in the Acrobat 10.1.3 update give indeed problems for PitStop Pro 10 customers. The problems were reported end of april and in PitStop Pro 11 (released may 3rd) we already made the needed adjustments to fix this problem.
        Customers who want to use the Acrobat 10.1.3 update are hence advised to upgrade to PitStop Pro 11 in case they want to work with the latest Acrobat 10.1.3 update as PitStop Pro 11 solves these reported issues. Otherwise customers can downgrade to Acrobat 10.1.2.
        As a general recommendation, please send any issue you would still face with PitStop Pro 11 to support@enfocus.com in order to let us investigate any remaining problem.
        Leen – Enfocus Product Manager
        • 72. Re: Acrobat 10.1.3 crash on quit
        pr1ntd3s1gn3r Level 1
        Thanks for confirming, leen.  It's too bad for us that instead of patching Pitstop 10, you're forcing us to upgrade to Pitstop 11 (to keep our Acrobat installations patched and secure) when we otherwise wouldn't have.  Since upgrading isn't an option for me at this time, I suppose I'll need to start looking for ways to get the work done without Pitstop.
        • 73. Re: Acrobat 10.1.3 crash on quit
        nieves53
        I am another person experiencing the Adobe Acrobat 10.1.3 crash syndrome. I am on a MacPro running OSX 10.6.8. I see that there has been no addional posts from Adobe for over a month and there are no new updates on the Adobe site that I can find. Has anyone out there found the culprit to this annoying problem? Is there any fix other than leaving a PDF open to avoid the crashes?
        • 74. Re: Acrobat 10.1.3 crash on quit
        BoostedG
        I am having the crash issue installing the latest update. And another user has the exact same issue as I do after he installed the latest update as well. I am running on Windows 7 64-bit. Here is a link to download the crash dump.
        https://www.dropbox.com/s/ovhrpgs4ct6dhmq/Acrobat.zip
        I hope that someone form Adobe will be able to analyze the dump and provide a solution in the near future.
        • 75. Re: Acrobat 10.1.3 crash on quit
        mmtrab
        (Acrobat Pro 10.1.3 | Win 7 Pro 64-bit)
        Hi vamalik,
        the issue definitively in my case is caused by the active "weblink.api" in the Acrobat plug_ins folder. This Feature makes part of the Acrobat standard installation. Before updating to Acrobat 10.1.3 this issue was never apearanced. After eleminating this "Plug-in" the issue is'nt longer observable. I allocated a core dump file as above proposed.
        mmtrab
        • 76. Re: Acrobat 10.1.3 crash on quit
        SRihan Level 1
        Hi mmtrab,
        Thanks for the information and the dump file.
        What is the current version of "weblink.api" on your machine (where this issue is seen) ? Have you tried doing a Repair of Acrobat installation from Control Panel --> Add-Remove programs ?
        Thanks.
        • 77. Re: Acrobat 10.1.3 crash on quit
        mmtrab Level 1
        Hi S.Rihan,
        thanks for picking up the Acrobat bug behavior!
        The version number ot the "weblink.api is 10.1.3.23 (time stamp 04.04.2012 - 7.54.04). We observed the same behavior on other machines after upgrading to Acrobat 10.1.3. After running the Acrobat Repair Feature (integrated in the Acrobat UI) the described issue was still the same.
        • 78. Re: Acrobat 10.1.3 crash on quit
        JFerr34
        I have been reading this for a while and I heard some great troubleshooting. However, I am running windows 64 bit with Adobe Pro with 3d PDF conversion Plugins.  I figured out it was a plugin just couldnt figure out which one. I may be right may be wrong but mine is working. I made the dump file and will try and get it up here for you guys. but here is what i did. I took the last two comments dealing with the weblink.api and changed it to weblink.api.old. Before i changed the name it crashed constantly after i changed the name it has not crashed once. Ill keep you up to date as to what happens.
        • 79. Re: Acrobat 10.1.3 crash on quit
        JFerr34 Level 1
        I am running the same config almost as you are with Windows 64bit and acrobat if you are willing to try something it might work like it did fot me.
        All i ask is you let me know if it worked for you too
        C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\plug_ins  there is a plugin called Weblink.api just change it to weblink.api.old and see if you still crash if you dont then it has worked on more then 10 computers if it doesnt then yours is the first.
