1. Re: Colour curves
ronzie99 Apr 30, 2012 11:06 PM (in response to photodrawken)Your interpretation is correct as far as I can see.
2. Re: Colour curves
photodrawken Apr 30, 2012 11:43 PM (in response to ronzie99)Thanks for the feedback.
Now that I have a handle on the what of Curves, the important question becomes why use Curves.
From what I've read, it all seems to come down to contrast and luminance -- Curves allows modifying the contrast in an image according to the luminance values. IOW, one can apply more or less contrast to the shadows, midtones or highlights of an image. That contrast can either be the overall B&W type of contrast (if working on the combined RGB channel) or contrast for each of the colour channels. It's kind of a complex effect because the contrast is obtained by changing the output values (more or less Red, e.g.).
So, after some more experimenting, the before and after of Jen looks like this:
I tried to limit most of the adjustment of the Curves for the Red and the Blue to the brighter areas, since her face was more washed out by the flash than the rest of her; then I used a Green Curve to warm up the skin tones overall. I also used an RGB Curve to give some more contrast, again mostly in the lighter tones (in this case the Curves adjustment acted like an enhanced Levels adjustment).
It's a very interesting tool to use, for sure. I think my workflow will be to first use the gross tools (like Adjust Color for Skin Tones, Remove Color Cast, Levels, etc.) and then switch to the Curves to make any subtle overall corrections or corrections that need to be precisely targetted.
Ken
3. Re: Colour curves
ronzie99 May 1, 2012 12:32 AM (in response to photodrawken)Smart Curves is a powerful tool. You can define a curve as point to point, Beziette, independent added jagged point drag, whatever. You can therefore notch out a portion of a channel. The eye dropper tools to give you sampled curves as a guide are nice (if I have that correct). The curves do not have to have symmetrical continuous form as I've illustrated here:
(Don't pay attention to the image <G>)
The ability to save a curve for "batch recall" use to apply to a set of images in the same environment is a nice feature.
For those interested here is the link for a number of filter plug-ins at no charge. Titles are English mostly but descriptions are in English or multiple languages for most once you open the filter/function link:
http://free.pages.at/easyfilter/
and smart curve is here with instructions in multiple languages:
http://free.pages.at/easyfilter/curves.html
http://free.pages.at/easyfilter/colorconverter.html I've noticed has been a requested color coordinate/space converter such as RGB to CMYK. It might help with direct scans of color negatives for one when that function is not in the scanner software.
http://free.pages.at/easyfilter/filtermeister.html is a sheet for coders but also describes some of the filteers (in English).
BTW, this link is from one of Barbara B's appendixes from the Missing Manual series for PSE.
Thanks, Barbara.
4. Re: Colour curves
photodrawken May 1, 2012 10:27 AM (in response to ronzie99)Yes, the SmartCurves page you mentioned has a link to this page:
http://www.cambridgeincolour.com/tutorials/photoshop-curves.htm
which I found very helpful -- good explanations and well-illustrated.
Ken
