6 Replies Latest reply on Jul 29, 2014 11:09 PM by shoggoth000
    Export Release Build error - Exception in thread "main" java.lang.Error: Unable to find named traits
    Brian Vaughn Level 1
      I've been developing an AIR application for Android and iOS. During development, I've run the application (in debug mode) in the desktop simulator as well as on an iPhone 4 and a Nook Tablet.
      However, I recently tried to "Export Release Build" for iOS and hit the following error: (I've stripped out the package and class information in the error message below)
      !ENTRY com.adobe.flexbuilder.project 4 43 2012-04-06 13:09:15.516
      !MESSAGE Error occurred while packaging the application:
      Exception in thread "main" java.lang.Error: Unable to find named traits: valid.package.path.here::ValidClassName
                at adobe.abc.Domain.resolveTypeName(Domain.java:231)
                at adobe.abc.Domain.resolveTypeName(Domain.java:148)
                at adobe.abc.GlobalOptimizer.sccp_eval(GlobalOptimizer.java:6665)
                at adobe.abc.GlobalOptimizer.sccp_analyze(GlobalOptimizer.java:5909)
                at adobe.abc.GlobalOptimizer.sccp(GlobalOptimizer.java:4628)
                at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:3514)
                at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:2215)
                at adobe.abc.LLVMEmitter.optimizeABCs(LLVMEmitter.java:526)
                at adobe.abc.LLVMEmitter.generateBitcode(LLVMEmitter.java:336)
                at com.adobe.air.ipa.AOTCompiler.convertAbcToLlvmBitcodeImpl(AOTCompiler.java:472)
                at com.adobe.air.ipa.BitcodeGenerator.main(BitcodeGenerator.java:82)
      Compilation failed while executing : ADT
      !STACK 0
      java.lang.Exception
                at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore. java:1019)
                at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
                at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.doPackage (ExportReleaseVersionWizard.java:283)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.performFi nish(ExportReleaseVersionWizard.java:152)
                at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
                at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
                at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
                at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
                at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
                at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
                at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
                at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
                at org.eclipse.jface.window.Window.open(Window.java:801)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:97)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
                at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
                at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
                at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
                at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
                at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:597)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
      The class the error message is referring to is defined with a SWC that my project links to. However, I've even tried to define a class with that same name (and location) within my project and it still fails to find it.
      Why am I able to Project->Clean and run this project within the desktop AIR player (or on the device in debug mode) but unable to export it as a release build?
      I have found a couple of threads mentioning a similar error but none of them have been marked as resolved.
