1. Re: Best I/O card for SDI or HDMI monitoring
shooternz Apr 30, 2012 11:33 PM (in response to Butch2oc)Wait and see what the monitoring solution in CS6 does for you. Its called 'Transmit'
2. Re: Best I/O card for SDI or HDMI monitoring
Butch2oc May 1, 2012 6:12 PM (in response to shooternz)Thanks shooternz... can you shed any light or does this mean I have got something to look forward to?
We participated in a rather long thread re proffesional monitoring sometime ago... looking forward to seeing CS6
Cheers
3. Re: Best I/O card for SDI or HDMI monitoring
lasvideo May 1, 2012 6:33 PM (in response to Butch2oc)Not Shooternz, but very familiar with Adobe Transmit. It means you can use just regular Adobe sequences (CUDA and all) and get HD SDI play out thru AJA, BM or Matrox hardware into an engineering monitor or tape machine. Adobe provided a hook for third party vendors to their video stream thus allowing a simpler and more stabile way to send video out to their hardware. It suffers from none of the issues users had with previous version of CS Premiere.
4. Re: Best I/O card for SDI or HDMI monitoring
Butch2oc May 1, 2012 7:05 PM (in response to lasvideo)So you are saying that a 3rd party card wont reduce performance with CS6 transmit?
5. Re: Best I/O card for SDI or HDMI monitoring
RDA972 May 1, 2012 8:06 PM (in response to Butch2oc)This video will tell you everything you need to know about Transmit:
6. Re: Best I/O card for SDI or HDMI monitoring
lasvideo May 1, 2012 9:05 PM (in response to Butch2oc)Final drivesr hasve not been released for most vendors, but since CS6 has not been officially released thats probably a moot point.
7. Re: Best I/O card for SDI or HDMI monitoring
Butch2oc May 1, 2012 11:52 PM (in response to RDA972)Thanks for that ... understand... seems great...
Just one thing... I noticed in the video that the cuts were 1 or 2 frames late going to the pro monitor.
Does this mean that an extra process is going on to enable the timeline to play as a CUDA timeline should and it has passed the delay to the output of the 3rd party card?
This would mean that the 3rd party will have to equal delay in their audio output to keep sync?
Cheers
8. Re: Best I/O card for SDI or HDMI monitoring
Richard M Knight May 2, 2012 1:02 AM (in response to Butch2oc)Does anybody know if Adobe Transmit adds any delay into the external monitor feed?
Richard Knight
9. Re: Best I/O card for SDI or HDMI monitoring
Butch2oc May 4, 2012 4:42 AM (in response to Richard M Knight)lasvideo, before we upgrade to CS6 it would be great to know if there is any delay to the pro monitor...
you said you are very familiar with Transmit.
would you know if "transmit" could be turned off to avoid it so we can still utilise
the improvements of CS6?
if you hear anything or if anyone has any knowledge
it would be much appreciated.
10. Re: Best I/O card for SDI or HDMI monitoring
lasvideo May 4, 2012 9:35 AM (in response to Butch2oc)Adobe Transmit is integrated into CS6 software. There is nothing to turn on or off. It just is
AJA hasn't released its final drivers so I am not at liberty to go into details.
I will speculate that based on AJAs fine track record with its hardware and software that they will release a final product that will satisfy most professionals.
