1. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
P Spier May 2, 2012 11:34 AM (in response to TwitchOSX)Shut everything down clean, then reboot and see what happens.
2. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
TwitchOSX May 2, 2012 11:36 AM (in response to P Spier)Yea.. I was thinking of doing that but I had to wait 20 minutes for the machine to even start reacting this morning and I finally got everything back up after the reboot. I guess I'll have to do that. Still don't know what's wrong with this computer that makes it unresponsive every morning after I wake it up from the screensaver. Ugh. Shouldnt be happening with a 3k computer.
3. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Manish-Sharma May 2, 2012 12:24 PM (in response to TwitchOSX)You might be not shutting down the machine in the nights , most probably leaving in the Sleep mode.....
Can you restart your machine and disbale suitcase fusion and then check out this link:- http://www.extensis.com/support/knowledge-base/illustrator-indesign-photoshop-and-quark-xp ress-hang-after-waking-my-mac-from-sleep-mode/
4. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
TwitchOSX May 2, 2012 12:28 PM (in response to Manish-Sharma)No, I don't shut the machine down at night. The screensaver comes on after a while and I don't know if it goes to sleep at some point or not.
However, Suitcase Fusion has nothing to do with that problem. It was happening since I got it pretty much.
5. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
TwitchOSX May 2, 2012 1:10 PM (in response to P Spier)Gotta be kidding me. Just shut everything down and restarted and ID still doesn't see Arial. This is not acceptable. I use Arial for most of my stuff.
6. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Daniel Flavin May 2, 2012 1:40 PM (in response to TwitchOSX)The Scourge of Arial
7. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
TwitchOSX May 2, 2012 1:44 PM (in response to Daniel Flavin)LOL. I think I've read that. The reason I started using Arial instead of Helvetica was that when I first started working here, they had like 15 different Helvetica fonts in the font menu. That became a pain in the a$$ to deal with so I just went with Arial. I have a few different versions of Arial but not 15 instances of different versions in my menus.
Still, InDesign only sees Arial Black, Arial Narrow and Arial Rounded. And all I NEED Is just plain old Arial and the Italic/Bold/Bold Italic versions. ARGH.
8. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
TwitchOSX May 2, 2012 1:46 PM (in response to TwitchOSX)Ahh crap. Now it works. I had Suitcase closed so I just opened it up and found Arial under System Fonts and activated it. Then I checked the Suitcase fonts and made sure Arial was turned on there. Then restarted InDesign and it's working fine. What a pain =)
9. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Manish-Sharma May 2, 2012 1:48 PM (in response to TwitchOSX)delete adobefnt*.lst files and then check,
If incase this doesn't work then copy the font to
Mac HD\Applications\Adobe InDesign CS5\Fonts and then check
10. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Manish-Sharma May 2, 2012 1:49 PM (in response to Manish-Sharma)Ahh, Didn't refreshed the page hence didn;t see the last post
11. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Daniel Flavin May 2, 2012 1:55 PM (in response to TwitchOSX)Glad you're back at it Twitch
12. Re: InDesign CS 5.5 suddenly doesn't know where Arial is.
Larry G. Schneider May 2, 2012 5:32 PM (in response to TwitchOSX)There's a checkbox somewhere which can be unchecked to stop the OS from trying to replicate the state of the machine at shutdown. I'm on my work machine with 10.6.8 right now but you should be able to google it.
