1 Reply Latest reply: May 2, 2012 7:52 PM by liangyongning RSS
    add attribute to a XML node at a specific position
    eprevot123 Community Member
      I have this XML :
      var myNode:XML = <node attribute="123"/>
      I know how to add an attribute to the node :
      myNode.@otherAttribute = "abc";
      But this adds the attribute to the end. What if I want to add it as the first attribute ? I would like to have :
      <node otherAttribute="abc" attribute="123"/>
      I know it is possible to add a child node to a specific position with insertChildAfter() or insertChildBefore() but I don't know if it's possible for an attribute.
        • 1. Re: add attribute to a XML node at a specific position
          liangyongning Community Member
          there's no native method for this, maybe you should create some functions for this. just like
          private function setAttribute(node:XML, name:String, value:String, index:int = -1):void
              var attrs:XMLList = node.attributes().copy(),
                  l:int = attrs.length();
              if(index == -1 || index > l - 1)
                  node.@[name] = value;
              else
                  delete node.@*;
                  var idx:int = 0;
                  for (var i:int = 0; i < l + 1; i++)
                      if(i == index)
                      else
                          var attr:XML = attrs[idx];
                          node.@[attr.name()] = attr.toString();
                          idx++;
          and use it like this:
          setAttribute(myNode, "otherAttribute", "abc", 0);
