23 Replies Latest reply on May 5, 2012 8:18 AM by RByds4te
    AVCHD and Premiere Pro...HELP
    RByds4te
      Hey guys,
      After some time I've managed to stabilize my computer (with some help ).
      I'm having some trouble though...
      I can't seem to get my AVCHD files to scrub smoothly in Pp5.5. I'm beginning to believe that the fault lies with Pp5.5 itself, not my hardware or settings.
      My software is up-to-date v5.5.2.
      I've gone through Harm's tune tips and have changed almost everything except creating a new page file.
      I've searched the forums, but have not found a fix for this problem.
      I've included some screen shots in order to help you guys help me......let me know if you need any more info.
      This is driving me bonkers.
      Computer specs:
      Adobe PP CS5.5
      OS: Windows 7 Pro
      CPU: Intel Core i7 3930K 3.2GHz
      CPU cooling: intel liquid cooling solution
      Motherboard: ASUS P9X79 Pro
      Memory: 32GB Samsung 1.35v
      GPU: ASUS GTX 570 1280mb
      Boot Drive: 180GB corasir Force GT SSD
      Storage: Seagate 7200rpm 1TB HDD x2 RAID 0
      PSU: Cooler Master 1000w Pro Gold
      Optical Drive: pioneer
      Case: Fractal Designs Full Tower (1) 180mm fan + (3) 140mm fans + (1) 120mm fan
        • 1. Re: AVCHD and Premiere Pro...HELP
          >AVCHD files
          Your project shows capture format HDV... I think that is wrong for AVCHD
          • 2. Re: AVCHD and Premiere Pro...HELP
            Stephen_Spider Level 3
            1) CS5.5 handles AVCHD really well.
            It seems that your system is plenty up to spec, so there is likely a software or driver glitch that is specific to your system. Don't dispair because that is likely fixable.
            I don't think the capture preset should matter when you are not employing a capture device.
            Make sure that you have the latest drivers from nvidia for you card.
            Also, describe what you see and what you expect during scrubbing. Does MPE RT playback work other than scrubbing?
            • 3. Re: AVCHD and Premiere Pro...HELP
              RByds4te Level 1
              Hey Stephen,
              When I scrub the footage, premiere jumps around the time line in large gaps. I might get 1-3 frames for every minute of video when moving the mouse/cursor at a reasonable rate. It makes previewing my footage almost impossible. I basically have to let the clip play in realtime to see what's on it.
              I expect the scrubbing to be smooth. Like I see in all the training material I have been watching.
              Not sure what MPE RT is? Mercury Playback Engine...Real Time?
              I'm also having issues with certain features when creating titles. Such as: slow feedback when changing the "degree" of the text (it takes sometime for the degree number to change onscreen...basically jumps around). When scrubbing the linear gradient option, I'm also seeing some lagging. I've circled the areas in RED on the image below:
              • 4. Re: AVCHD and Premiere Pro...HELP
                Yes MPE real time.
                Assuming your presets are correct and that you are utilizing the GTX570 for MPE hardware acceleration, your system should work better.
                Couple of things to try are agian, latest Nvidia driver, and perhaps disable Areo to see if there might a GPU related issue.
                The only other thing I can think of is less than it should be raid performance.
                Might try posting this in the hardware section to get the heavy hitters on the case.
                1 person found this helpful
                • 5. Re: AVCHD and Premiere Pro...HELP
                  RByds4te Level 1
                  Nvidia drivers are up-to-date.
                  I've tried Aero on and off...no dice.
                  I'll give the hardware forum a shot.
                  REPOSTED TO THE HARDWARE FORUM: http://forums.adobe.com/thread/995540
                  Thanks.
                  • 6. Re: AVCHD and Premiere Pro...HELP
                    SAFEHARBOR11 Most Valuable Participant
                    How do you bring the AVCHD files into Premiere? When transferring data from camera memory card to PC hard drive, copy the WHOLE FOLDER STRUCTURE to drive as is, then use Media Browser in Premiere to import clips. Next, silly question, but have you "zoomed in" to the timeline before scrubbing? Use the + and - keys. Get in closer for finer scrubbing response, viewing just a smaller part of the timeline rather than everything at once.
                    Jeff Pulera
                    Safe Harbor Computers
                    • 7. Re: AVCHD and Premiere Pro...HELP
                      RByds4te Level 1
                      Hey Jeff,
                      I open the folder from my camera (once its connected to my PC) and select the video clips from there. They are then copied to my RAID 0 drive.
                      Import from Media Browser is not an option?...
                      The zoom feature seemed to help a bit.
                      • 8. Re: AVCHD and Premiere Pro...HELP
                        Jim_Simon Level 9
                        It's best if you copy the entire PRIVATE folder, not just the video clips.
                        • 9. Re: AVCHD and Premiere Pro...HELP
                          As Jim and I have both said, it is important to copy over ALL the folders intact. If you try to dig down in the camera card and only copy the video files, that is where problems come up. Copy the whole works to your hard drive, and then at the lower left of Premiere interface, next to Effects Tab, look for the Media Browser tab there, and Import the clips that way.
                          AVHCD uses a lot of extra info in the various folders, sometimes having seperate audio even, and all the extra files have some meaning and importance. Media Browser understands all of that and once you point it to the parent directory it will sift through it all and properly import any relevant files and their connections to one another, behind the scenes. This is best practice for file-based media imports.
                          Jeff Pulera
                          • 10. Re: AVCHD and Premiere Pro...HELP
                            RByds4te Level 1
                            Hey Jeff,
                            Thanks for the info!
                            I'll shoot some new footage and import it the way you suggested.
                            I'll let you know how it goes.
                            • 11. Re: AVCHD and Premiere Pro...HELP
                              RByds4te Level 1
                              Well, I shot some new footage and copied the entire PRIVATE folder over. Then used Media Browers to import the files. Still having the scrubbing issues. Also have choppy video playback. The clips playback fine in WMP, but as soon as Premiere gets ahold of them, ick...
                              • 12. Re: AVCHD and Premiere Pro...HELP
                                Harm Millaard Level 7
                                Well, you effectively have only two disks/volumes, which is below practical minimum requirements. A player like WMP demands much less of a system than an editor and you are running into disk setup limitations. It is a pity, because your CPU is quite good, but your disk setup is not. Add a couple of disks...
                                • 13. Re: AVCHD and Premiere Pro...HELP
                                  RByds4te Level 1
                                  Hmmm, you really think the scrubbing issues and choppy video playback in premiere are related to disk issues?
                                  • 14. Re: AVCHD and Premiere Pro...HELP
                                    Jeff Bellune Level 5
                                    [Post with personal attack deleted]
                                    Jeff
                                    • 15. Re: AVCHD and Premiere Pro...HELP
                                      Jim_Simon Level 9
                                      Very unlikely.  AVCHD has the same data rate as DV, and even a single modern disk is plenty fast enough to feed multiple simultaneous streams.  Your RAID 0 should be far more than sufficient.
                                      No...AVCHD performance really hinges on the CPU more than anything.  Yours is plenty kick-***, so something else is causing the issue, but the hard drives aren't a likely candidate.
                                      • 16. Re: AVCHD and Premiere Pro...HELP
                                        You still don't get it Jim.
                                        Even with a single track with AVCHD material, it requires a sustained transfer rate of up to 50 MB/s and with 3 or 4 tracks that figure easily goes up to more than 95 MB/s sustained transfer rate, with 4K material it goes beyond 300 MB/s. Add the half duplex nature of SATA into the configuration on a system with only two disks, the Windows housekeeping, the memory requirements which are way more than 14 GB and the need for paging and you are lost.
                                        Sorry chap, you really have to get more acquainted with the intricacies of decoding AVCHD material before you make such blanket and incorrect statements.
                                        And this is only playing the timeline, not scrubbing it, which makes for much heavier disk requirements.
                                        • 17. Re: AVCHD and Premiere Pro...HELP
                                          RByds4te Level 1
                                          Hmmmmm, that make a bit more sense.
                                          Harm, the more in-depth you can go about the disk set-up (like you have above), the better. Just helps us non-computer guys out...thanks!
                                          Ok, so if I were to add another 2 1Tb drives and configure them into a RAID 1 (using the intel RAID device on my MB), would that do the trick?
                                          • 18. Re: AVCHD and Premiere Pro...HELP
                                            A mirrored raid is still seen as a single volume by Windows. There is nothing wrong with a raid1, it helps you keep your data safe, but it is costly and offers no performance gains over a single disk. If you have a look at the 'Featured Discussion' at the top of the hardware forum about Raid Performance and Rebuild issues, things may become a bit clearer.
                                            • 19. Re: AVCHD and Premiere Pro...HELP
                                              ramgate1979
                                              Kid, don't let Harm bambozle you.  Your computer is plenty fast to scrub AVCHD.  And you were correct in guessing that the problem was with CS5.5.  There are a number of threads here that talk about the problem.  Adobe has not addressed the problem (and, no, CS5.5.2 did not correct the problem).  If you can get a hold of a copy of Premiere CS5, give it a try.  Scrubbing will be as smooth as butter with AVCHD.  My guess is scrubbing the same material with some other editing software will be as equally smooth.  I've got a computer that has a fraction of the power of your computer.  DSLR footage and AVCHD is slow and choppy in CS5.5.  But in CS5, no problems at all.  Scrubbing is as smooth as glass in CS5.  What adobe did between CS5 and 5.5 I have no idea, but the problem hasn't been fixed.  And of course there is no guarantee it will be fixed in CS6.  Hell, they may move onto CS10 before they get around to fixing the issue (which is par for the course for adobe).
                                              Just trying to save you some grief, kid.  Nothing wrong with your computer, it is CS5.5.  Hope you read this before the moderator deletes my account.
                                              • 20. Re: AVCHD and Premiere Pro...HELP
                                                As long as your posts remain helpful (like the one to which I'm replying), reasonably polite and consist of things other than personal attacks and rants, nothing's going to happen to your account.
                                                Jeff
                                                • 21. Re: AVCHD and Premiere Pro...HELP
                                                  ramgate1979 Level 1
                                                  Then why did you delete my post to Harm?
                                                  • 22. Re: AVCHD and Premiere Pro...HELP
                                                    Because it was redundant.  Just like the two that I'm about to delete now.
                                                    You made your point in the post replying to RByds4te.  You don't need to repeat the same info in replies to other participants.  Stephen and Harm will see your reply to RByds4te when they check the thread, either here or by email.  They don't need their own personal copy.
                                                    Jeff
                                                    • 23. Re: AVCHD and Premiere Pro...HELP
                                                      RByds4te Level 1
                                                      ramgate1979,
                                                      Thanks for the straight forward response.
                                                      I am aware of the other posts and am a bit concerned that Adobe has not addressed this issue. I would very much like to get a copy of Pre Pro Cs5, but I cant (in my right mind) spend another $500 on premiere.
                                                      Perhaps Adobe would be willing send me a copy (or download) of Cs5, so that I can test this out?
                                                      Thanks.
