1. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Stephen_Spider May 2, 2012 5:38 AM (in response to Admiral Cook)Since CS6 isn't available yet, I'm guessing there could be all sorts of issues going on with whatever you are using. No telling how early of a beta might have been hacked for you.
What build is the software? Where did you find the software? (no specific links, thank you)
Until CS6 is officially released, you likely won't find help on the forums.
2. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Admiral Cook May 2, 2012 7:22 AM (in response to Stephen_Spider)No hacking, not beta, no suspicious files.
I've dowloaded it directly from Adobe and it's trial version.
There are links to it all over the internet.
It says version 6.0.0 (319).
3. Re: (CS6) Move clip by 1 or 5 frames - transition lost
John T Smith May 2, 2012 9:27 AM (in response to Admiral Cook)>There are links to it all over the internet
The official download page http://www.adobe.com/downloads/ still says 5.5
I would not trust any other link
4. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Ann Bens May 2, 2012 10:18 AM (in response to Admiral Cook)That is correct, Alt+left now means Nudge Clip Selection Left One Frame.
If you want to keep the transition you need to select both clips.
Might want to check the shortcuts there are a few changes
5. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Stephen_Spider May 2, 2012 11:06 AM (in response to Admiral Cook)"I've dowloaded it directly from Adobe"...
Cool.... where's that web page?
6. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Ann Bens May 2, 2012 11:56 AM (in response to Stephen_Spider)Some people were call it fortunate to download the trial, webpage is no longer available.
7. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Admiral Cook May 3, 2012 3:08 AM (in response to Ann Bens)I liked possibility to keep transition if we just want it to happen few frames earlier.
By new way it works we need to:
1. move clip
2. re-apply and re-customize transition
And what about my question about Audio Gain changes?
8. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Ann Bens May 3, 2012 3:55 AM (in response to Admiral Cook)I do not know why they changed the default settings.
9. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Admiral Cook May 3, 2012 5:48 AM (in response to Admiral Cook)OK, thanks for your replies.
10. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Stephen_Spider May 3, 2012 10:48 AM (in response to Admiral Cook)Does this happen when ripple trimming?
11. Re: (CS6) Move clip by 1 or 5 frames - transition lost
Admiral Cook May 4, 2012 4:10 PM (in response to Stephen_Spider)No, it doesn't.
I've found that Alt+comma will do what I used Alt+Left for in PP5.
Slide left 5 frames = Alt+Shift+comma
Slide right 1 frame = Alt+dot
Slide right 5 frames = Alt+Shift+dot
