I purchased RH 8. Currently, it crashed after I ran a visus scanner. When I clicked the SW icon, the warning message shows that "This application (RoboHelpHTML.exe) has failed to start because amtlib.dll was not found. Re-installing the application may fix this problem". I tried to find RH 8 but not successful since too many junk downloads that confused me. If you have an idea to fix this problem, please provide your advise. Thanks.
Check the Adobe Licensing Site - you should be able to download it from there.
Thanks for your response. The license site provides some PDFs.
Look under Licenses > Downloads
That will only work if you registered your copy. If not, try Customer Support. You will need to prove you purchased a legal copy. (I'm not suggesting you didn't, just advising what Adobe will ask for.)
