I've installed Flex Builder 2, Data Services with Integrated
JRun, and gone through the sample applications which all work
beautifully (suggesting that everything installed correctly).
However, when I try to do the tutorials on creating FDS
applications such as
this
one, it doesn't work. I get an error on load, which I'll type
below. In the tutorial it has you create a destination in your
data-management-config.xml file which I've done and all looks fine
there. I've checked and rechecked and I can't figure out where I
could be going wrong. Does this error message mean anything to
anyone? Thanks.
[RPC Fault faultString = "Send failed"
faultCode="Client.ErrorMessageSend"
faultDetail="Channel.Connect.Failed error null"]
at.mx.data::ConcreteDataService/
http://www.adobe.com/2006/flex/mx/internal::dispatchFaultEvent()
at::DataListRequestResponder/fault()
at mx.rpc::AsyncRequest/fault()
at mx.messaging::ChannelSet/::faultPendingSends()
at mx.messaging::ChannelSet/channelFaultHandler()
at flash.events::EventDispatcher/dispatchEvent()
at
mx.messaging.channels::PollingChannel/mx.messaging.channels:PollingChannel::connectFailed()
at
mx.messaging.channels::RTMPChannel/mx.messaging.channels:RTMPChannel.statusHandler()
