7 Replies Latest reply on May 3, 2012 2:16 PM by oddjewel
    Show/Hide Behavior onClick w/o onscreen gaps
    oddjewel Level 1
      I've set an onClick Behavior to show/hide elements within a div id. Everything is working but when the elements are hidden, it leaves blank spaces onscreen. I would like for the rest of the content to move up on the page and fill in the blank space.
      I understand this has something to do with setting display:none, but I can't just set the elements to display:none because then they don't show up at all.
      Is there a way to set it so that onClick, it applies a class like ".hide" which I could then set to display:none and thereby get all the content to move up?
      I have been struggling with this for so long - I KNOW it must be possible, please help!!
      Thank you!!
        • 1. Re: Show/Hide Behavior onClick w/o onscreen gaps
          osgood_ Most Valuable Participant
          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
          <html xmlns="http://www.w3.org/1999/xhtml">
          <head>
          <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
          <title>Untitled Document</title>
          <style type="text/css">
          #top {
              width: 300px;
              margin: 0 auto;
              background-color:#CCC;
              padding: 20px;
          #middle {
              width: 300px;
              margin: 0 auto;
              background-color:#9CC;
              padding: 20px;
          #bottom {
              width: 300px;
              margin: 0 auto;
              background-color:#FC3;
              padding: 20px;
          </style>
          <script language="JavaScript">
          function setVisibility(id, visibility) {
          document.getElementById(id).style.display = visibility;
          </script>
          </head>
          <body>
          <div id="top">Top</div>
          <div id="middle" onclick="setVisibility('middle', 'none');">Middle</div>
          <div id="bottom" onclick="setVisibility('middle', 'block');">Bottom</div>
          </body>
          </html>
          • 2. Re: Show/Hide Behavior onClick w/o onscreen gaps
            oddjewel Level 1
            Thanks for your fast response - but I want to be clickable is an image, not a div, that already has onClick swap image functions set to it:
            <div id="portnav"> <!-------------portnav begins------------>
              <img src="Images/Everything_03.png" name="everything" width="181" height="34" id="everything"
            onclick= "MM_swapImage('everything','','Images/EverythingRollover_03.png','printdesign','','Images /PrintDesign_03.png','illbutton','','Images/Illustration_03.png','webdev','','Images/WebDe v_03.png',1)" />
            </div><!----------------port nav ends.-------------->
            I want to set another onClick function that alters the content of another <div> entirely. I want it to be set so that onClick, div <all> is altered by div <illustration> disappearing, and div <printed> and div <webdev> moving up on the screen:
            <div id="all">
            <div id="illustration"><!--------------illustration begins.------->
            content content
            </div><!-----------------illustration ends.------------>
            <div id="printed"><!--------printed begins.--------->
            content content
            </div><!--------------------------printed ends.----------------->
            <div id="webnav"><!--------------webnav begins-------->
            content content
            </div><!---------------------webnav ends.----------------->
            </div><!------------all ends here.----------->
            Maybe I'm doing this the hard way or over-complicating it? I tried several Dreamweaver behaviors like show/hide and set text of container.... I've seen this done on several websites - what's the best way to do it?
            Thank you!
            • 3. Re: Show/Hide Behavior onClick w/o onscreen gaps
              <head>
              #all {
                  width: 330px;
                  margin: 0 auto;
              #illustration, #printed, #webnav {
                  width: 300px;
                  margin: 0 auto;
                  padding: 15px;
              #illustration {
                  background-color:#CC6;
              #printed {
                  background-color:#FF9;
              #webnav {
              </style>
              </script>
              </head>
              <body>
              <div id="all" onclick="setVisibility('illustration', 'none');">
              <div id="illustration"><!--- illustration begins --->
              Illustration
              </div><!--- illustration ends --->
              <div id="printed"><!--- printed begins --->
              Printed
              </div><!--- printed ends --->
              <div id="webnav"><!--- webnav begins --->
              Webnav
              </div><!--- webnav ends --->
              </div>
              </body>
              </html>
              1 person found this helpful
              • 4. Re: Show/Hide Behavior onClick w/o onscreen gaps
                oddjewel Level 1
                Well it's partially working - it's so close! What should my code look like to hide 2 divs instead of just one? I tried this:
                <div id="all" onclick="setVisibility('illustration', 'none');" "setVisibility('webnav', 'none');"> </div>
                I want to hide 2 divs (illustration & webnav) onClick instead of just the one. Is that possible?
                Thank you!!
                • 5. Re: Show/Hide Behavior onClick w/o onscreen gaps
                  oddjewel Level 1
                  Here's an example of what I'm trying to do (minus the fancy javascript slideshow effects) : http://www.castirondesign.com/work/
                  I have 4 links just like that (Everything, Illustration, Design, Web) and I'd like the contents of the div below to appear/reappear onClick as they do in the example.
                  I managed to get the contents of one div to hide (Illustration) onClick and the following content to move up onscreen... but I need the content from both div:Design and div:Web to disappear onClick:Illustration, and then reappear onClick:Everything.
                  • 6. Re: Show/Hide Behavior onClick w/o onscreen gaps
                    Try this:
                    <head>
                    body {
                        font-family: verdana, arial, helvetica, sans-serif;
                        font-size: 12px;
                        letter-spacing: 1px;
                    #nav {
                        text-align: center;
                        padding-top: 30px;
                    #nav a {
                        text-decoration: none;
                        background-color:#fff;
                        border: 1px solid #999;
                        color: black;
                        padding: 5px 10px;
                        margin: 0 0 0 10px;
                        display: inline-block;
                    #all {
                        width: 330px;
                        margin: 40px auto 0 auto;
                    #illustration, #design, #web {
                        width: 300px;
                        margin: 10px auto 0 auto;
                        padding: 15px;
                        border: 4px solid #fff;
                    #illustration {
                    #design {
                    #web {
                    </style>
                    </script>
                    </head>
                    <body>
                    <div id="nav"><a href="#" onclick="setVisibility('illustration', 'block'); setVisibility('design', 'block'); setVisibility('web', 'block');">Everything</a><a href="#" onclick="setVisibility('illustration', 'block'); setVisibility('design', 'none'); setVisibility('web', 'none');">Illustration</a> <a href="#" onclick="setVisibility('design', 'block'); setVisibility('illustration', 'none'); setVisibility('web', 'none');">Design</a> <a href="#" onclick="setVisibility('web', 'block'); setVisibility('illustration', 'none'); setVisibility('design', 'none');">Web</a></div>
                    <div id="all">
                    Illustration
                    <div id="design"><!--- design begins --->
                    Design
                    </div><!--- design ends --->
                    <div id="web"><!--- web begins --->
                    Web
                    </div><!--- web ends --->
                    </div>
                    </body>
                    </html>
                    • 7. Re: Show/Hide Behavior onClick w/o onscreen gaps
                      oddjewel Level 1
                      That worked PERFECTLY. Thanks so much!
